  3. save critical data
save critical data
6 Posts 4 Posters 1.1k Views 2 Watching
  • P Offline
    P Offline
    Pooyan
    Hello all,
    I want to have the critical data (voxl-inspect-cpu, voxl-inspect-battery) of a flight saved during the flight time to use them later offline. I would appreciate it if you could tell me how I can do that by providing some details for help.
    Best,
    ModeratorM 1 Reply Last reply
    • P Pooyan
      Hello all,
      Best,
      @Pooyan You could use voxl-logger with the -w option to save raw data. You would then need to post process though.
      It might make things easier to ```
      https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-logger/-/blob/master/tools/voxl-logger.cpp?ref_type=heads
      We're happy to incorporate merge requests if you go that route!
      • ModeratorM Moderator
        The source code for voxl-inspect-cpu is here (the data is coming from voxl-cpu-monitor and displayed by voxl-inspect-cpu.
        and for voxl-inspect-battery is here here . The battery data is coming as a mavlink message via MPA and displayed using voxl-inspect-battery.
        So you can use voxl-logger, as suggested above to log the needed data and parse it offline -- you can use the source code of the inspect tools for guidance.
        P 1 Reply Last reply
          P Offline
          P Offline
          Pooyan
          @Alex-Kushleyev @Moderator Great thank you. now I want to have an application to analyze data online and based on that turn on or off another application. I already have tried the voxl-cross-template but now I want to write my own application for that. Can you please provide me with some tips for that?
          And to check the syntax errors in the application while writing and implementing it, may you please give me some hints?
          I appreciate that so much.
          • P Pooyan
            @Pooyan Our applications share data using Modal Pipe Architecture (MPA). The foundation for that is the libmodal-pipe library. All of our code is open so you can look at examples of applications that publish data via MPA and others that consume data. This can be the basis for your custom application.
              P Offline
              P Offline
              Pooyan
              @Eric-Katzfey Thank you so much for the information.
