  3. USB tethering with VOXL
voxl-flight
9 Posts 3 Posters 3.1k Views 2 Watching
  • S Offline
    S Offline
    skl1g14
    I have been following this thread https://forum.modalai.com/topic/851/rndis-connection?_=1704780402514.
    I have a Jetson nano and a Voxl flight deck with the base Linux Yocto Jethro with 3.18 kernel System Image but my jetson nano does not have any Ethernet port and wireless adapter.
    I was planning to reverse USB tether so that the network from voxl can extend to the jetson nano.
    By default, the jetson nano have a usb0 virtual Ethernet interface and I verify it by connecting my PC (host) and jetson nano (device).
    https://jetbot.org/master/software_setup/wifi_setup.html.
    However, there is no interface when i try to connect my voxl (host) to jetson nano (device).
    From the guide, https://docs.modalai.com/voxl-as-usb-host , i suspect it is my OTG cable being incompatible.
    With that, i am considering setting up rndis for the voxl flight such that i can do jetson nano (host) and voxl (device) instead.
    Is there a guide on how to do so? Or will it be less pain to just get different cables and retry.
    ModeratorM 1 Reply Last reply
    • S skl1g14
      @skl1g14 it might be easier to just use a UART between the two?
      S 1 Reply Last reply
      • ModeratorM Moderator
        S Offline
        S Offline
        skl1g14
        Dear @Moderator,
        That is true but we are expecting a data rate much higher than what UART is able to provide.
        • S skl1g14
          Dear @Moderator,
          @skl1g14 , can you please confirm that you are using VOXL1 or VOXL2?
            S Offline
            S Offline
            skl1g14
            @Alex-Kushleyev
            voxl1
            • S skl1g14
              @Alex-Kushleyev
              voxl1
              @skl1g14 , thank you for confirming
              Yes if you would like to use VOXL1 as host via OTG connector, you need to have a special cable.
              A few other options:
              • since VOXL1 has on-board wifi, can you just plug in a wifi dongle into your Jetson Nano (VOXL1 can be a wifi AP or station)
                • this seems like the option requiring least amount of adapters!
              • using USB expander board (https://docs.modalai.com/usb-to-ethernet-with-voxl/) you could add USB-to-ethernet adapter to VOXL and plug in another USB-ethernet adapter into Jetson Nano .. and connect it all together using an ethernet cable.. too many adapters though!
              I don't think we ever tried to do USB tethering with VOXL. That would also require enabling a usb gadget kernel module : https://linuxlink.timesys.com/docs/wiki/engineering/HOWTO_Use_USB_Gadget_Ethernet
                S Offline
                S Offline
                skl1g14
                @Alex-Kushleyev
                Hi Alex, thanks for the quick response.
                For now we are going option A with a wifi adapter. That works well.
                In the meantime I am moving on to other stuff.
                I tried recompiling the kernel with https://gitlab.com/voxl-public/system-image-build/meta-voxl/-/tree/master?ref_type=heads enabling the usb_gadget flag but no luck so far.
                Apparently yocto does not have a simple way to just "make menuconfig"
                Will keep this post updated if i manage to get it.
                • S skl1g14
                  @Alex-Kushleyev
                  S Offline
                  S Offline
                  skl1g14
                  Here is the hack if anyone needs it.
                  The latest platform image have the RNDIS host flag set. https://gitlab.com/voxl-public/system-image-build/meta-voxl/-/blob/master/recipes-kernel/linux-quic/files/enable_RNDIS_HOST.cfg?ref_type=heads
                  1. First step is to get a compatible OTG cable. I got an off-brand one that works. Run dmesg -wH on your jetson carrier board. If there are the usb0/rndis0/l4tbr0 means the connection is solid.
                  2. In voxl, save the following script somewhere. /home/root/usb_tethering.sh is a good choice.
                  #!/bin/bash
                  # Enable IP forwarding
                  echo 1 > /proc/sys/net/ipv4/ip_forward
                  # Bring up usb0 interface
                  ifconfig usb0 up
                  # Assign IP address to usb0
                  ifconfig usb0 192.168.55.2 netmask 255.255.255.0
                  # Add route for USB network
                  route add -net 192.168.55.0 netmask 255.255.255.0 dev usb0
                  # Set up iptables rules for NAT
                  iptables -A FORWARD -o wlan0 -i usb0 -s 192.168.55.0/24 -m conntrack --ctstate NEW -j ACCEPT
                  iptables -A FORWARD -m conntrack --ctstate ESTABLISHED,RELATED -j ACCEPT
                  iptables -t nat -A POSTROUTING -o wlan0 -j MASQUERADE
                  1. Make it persistent by creating a systemd service. Save it at /etc/systemd/system/tethering.service
                  [Unit]
                  Description=USB Tethering Service
                  After=network.target
                  [Service]
                  Type=simple
                  ExecStart=/home/root/usb_tethering.sh
                  [Install]
                  WantedBy=default.target
                  1. Run the following
                  sudo systemctl daemon-reload
                  sudo systemctl enable tethering.service
                  1. Check with ifconfig on voxl (should have a static addr 192.168.55.2 for usb0 interface)
                  2. Check with ifconfig on jetson carrier board (the l4tbr0 default addr should be 192.168.55.1)
                  3. Try pinging each other (optional)
                  4. In voxl, set to station mode and connect to a access point. For jetson carrier board, check if it is possible to connect to a public web.
                  ping google.com
                  • In jetson, the dns nameserver for the l4tbr0 interface may need to change to 8.8.8.8.
                    Check with
                  systemd-resolve --status
                  • Alternatively, change globally by modifying the nameserver address to 8.8.8.8 at /etc/resolv.conf
                  Bandwidth ~ 265 Mbps which should be expected from a usb2.0 controller (max 480 Mbps) and the overhead from the interfaces.
                  • S skl1g14
                    #!/bin/bash
                    ifconfig usb0 up
                    [Unit]
                    [Service]
                    Type=simple
                    [Install]
                    ping google.com
                      Check with
                    @skl1g14 , very nice!! Thank you for documenting your configuration and results!!
