  3. Datasheet for VOXL2 Ethernet expansion and USB Hub addon
5 Posts 3 Posters 1.0k Views
  • Jetson NanoJ Offline
    Jetson Nano
    Veteran
    We are in need of VOXL2 Ethernet expansion and USB Hub add-on to integrate with Flir Boson camera. We need data sheet of the product. In the technical docs page, it's not available.
    VinnyV 1 Reply Last reply
    • Jetson NanoJ Jetson Nano
      VinnyV Offline
      VinnyV Offline
      Vinny
      Hi @Jetson-Nano
      That is considered a beta product in its current form and not broadly available, hence documentation is sparse/not available.
      We have considered making an improved and current version of this design for public use, so if you have any feedback or suggestions/requirements, we'll gladly consider it for our future design efforts.
      • VinnyV Vinny
        Hi @Jetson-Nano
        Jetson Nano
        Veteran
        @Vinny Hey Vinny,
        At the very least if you could tell us what connectors are on-board and which pheripherial are exposed [such as USB, UART, Ethernet port is seen] and where it is connected on the voxl 2 [like /dev/tthy4 ] it would be very helpful. Without these even making suggestions for improvements would be difficult.
          @Vinny Hey Vinny,
          VinnyV Offline
          VinnyV Offline
          Vinny
          HI @Jetson-Nano
          The board is similar to the M0090 5G Modem board in the following ways:
          • Plugs into VOXL 2 via J3&J5
          • Exposes a UART+I2C JST and an SPI JST
          • Uses the same USB hub, and exposes 3 USB Downstream ports, with one being a direct Type-A host port, the other 2 being our JST formats.
          Where it is different from the 5G modem is we add a USB to ETH bridge, and expose a full RJ45 jack with Gb speeds (but limited to a USB2 backhaul)
          We also have an SD/UFS card slot for memory expansion.
          And we do not support the PCIe interface for modems... the RJ45 takes up that space.
          I do not know how they enumerate with the OS, I am not on the SW team. Sorry I cannot help there.
          ModeratorM 1 Reply Last reply
          • VinnyV Vinny
            HI @Jetson-Nano
            Any of our USB expansion boards should work with VOXL 2 and Boson, you don't need this specific board
