    Datasheet for VOXL2 Ethernet expansion and USB Hub addon
    • Jetson NanoJ
      Jetson Nano
      We are in need of VOXL2 Ethernet expansion and USB Hub add-on to integrate with Flir Boson camera. We need data sheet of the product. In the technical docs page, it's not available.
      • VinnyV
        Vinny ModalAI Team @Jetson Nano
        Hi @Jetson-Nano
        That is considered a beta product in its current form and not broadly available, hence documentation is sparse/not available.
        We have considered making an improved and current version of this design for public use, so if you have any feedback or suggestions/requirements, we'll gladly consider it for our future design efforts.
        • Jetson NanoJ
          Jetson Nano @Vinny
          @Vinny Hey Vinny,
          At the very least if you could tell us what connectors are on-board and which pheripherial are exposed [such as USB, UART, Ethernet port is seen] and where it is connected on the voxl 2 [like /dev/tthy4 ] it would be very helpful. Without these even making suggestions for improvements would be difficult.
          • VinnyV
            HI @Jetson-Nano
            The board is similar to the M0090 5G Modem board in the following ways:
            • Plugs into VOXL 2 via J3&J5
            • Exposes a UART+I2C JST and an SPI JST
            • Uses the same USB hub, and exposes 3 USB Downstream ports, with one being a direct Type-A host port, the other 2 being our JST formats.
            Where it is different from the 5G modem is we add a USB to ETH bridge, and expose a full RJ45 jack with Gb speeds (but limited to a USB2 backhaul)
            We also have an SD/UFS card slot for memory expansion.
            And we do not support the PCIe interface for modems... the RJ45 takes up that space.
            I do not know how they enumerate with the OS, I am not on the SW team. Sorry I cannot help there.
            • ModeratorM
              Moderator ModalAI Team @Vinny
              Any of our USB expansion boards should work with VOXL 2 and Boson, you don't need this specific board
