  3. Voxl 2 is Bricked
Voxl 2 is Bricked
7 Posts 2 Posters 1.3k Views 1 Watching
  • wintaW Offline
    wintaW Offline
    winta
    Voxl 2 is bricked and not responding to adb shell or wifi.
    We tried forcing it into fastboot but we couldn't see change.
    Tried the qdl method for unbricking by following the guide and got the following response on terminal
    <response value="ACK" rawmode="false" /></data>
    partition 1 is now bootable
    FIREHOSE WRITE: <?xml version="1.0"?>
    <data><power value="reset"/></data>
    FIREHOSE READ: <?xml version="1.0" encoding="UTF-8" ?>
    <data>
    <log value="INFO: Calling handler for power" /></data>
    LOG: INFO: Calling handler for power
    <data>
    This was the expected output shown on the page as well.
    When we switch sw2 switch off though, adb shell still isnt loading
    When the sw2 switch is on voxl 2 is recognised over usb in lsusb command but when it is off it isnt being recognised over lsusb either
    wintaW 1 Reply Last reply
    • wintaW winta
      <data>
      <data>
      wintaW Offline
      wintaW Offline
      winta
      wrote on last edited by winta
      @tom @Eric-Katzfey @modaltb Could you look into?
      • wintaW winta
        @Prawin-Sankar-T-A What OS is your host machine running? Sometimes QDL won't start up the first time and requires power cycling the board and retrying a couple times
          wintaW Offline
          wintaW Offline
          winta
          @tom My host machine is using Ubuntu 20.04. Based on documentation provided here, I have tried this method a couple of times.
          • wintaW winta
            @Prawin-Sankar It may be worth submitting an RMA at this point: https://www.modalai.com/pages/rma
              wintaW Offline
              wintaW Offline
              winta
              @tom Are'nt there any other debugging methods we could try out?
              • wintaW winta
                @Prawin-Sankar QDL is the lowest level flashing method we can share publicly so if that's not working there's not much we can do.
