    Voxl 2 is Bricked
    • W
      winta
      Voxl 2 is bricked and not responding to adb shell or wifi.
      We tried forcing it into fastboot but we couldn't see change.
      Tried the qdl method for unbricking by following the guide and got the following response on terminal
      partition 1 is now bootable
      <data>
      <data>
      This was the expected output shown on the page as well.
      When we switch sw2 switch off though, adb shell still isnt loading
      When the sw2 switch is on voxl 2 is recognised over usb in lsusb command but when it is off it isnt being recognised over lsusb either
      W 1 Reply Last reply 13 Dec 2023, 05:52 Reply Quote 0
      • W
        winta @winta
        @tom @Eric-Katzfey @modaltb Could you look into?
        T 1 Reply Last reply 13 Dec 2023, 18:02 Reply Quote 0
        • T
          tom admin @winta
          @Prawin-Sankar-T-A What OS is your host machine running? Sometimes QDL won't start up the first time and requires power cycling the board and retrying a couple times
          W 1 Reply Last reply 14 Dec 2023, 07:01 Reply Quote 0
          • W
            winta @tom
            @tom My host machine is using Ubuntu 20.04. Based on documentation provided here, I have tried this method a couple of times.
            T 1 Reply Last reply 14 Dec 2023, 18:03 Reply Quote 0
            • T
              tom admin @winta
              @Prawin-Sankar It may be worth submitting an RMA at this point: https://www.modalai.com/pages/rma
              W 1 Reply Last reply 15 Dec 2023, 09:39 Reply Quote 0
              • W
                winta @tom
                @tom Are'nt there any other debugging methods we could try out?
                T 1 Reply Last reply 15 Dec 2023, 17:45 Reply Quote 0
                • T
                  tom admin @winta
                  @Prawin-Sankar QDL is the lowest level flashing method we can share publicly so if that's not working there's not much we can do.
                  1 out of 7
