    Voxl 2 is Bricked
    • wintaW
      winta
      Voxl 2 is bricked and not responding to adb shell or wifi.
      We tried forcing it into fastboot but we couldn't see change.
      Tried the qdl method for unbricking by following the guide and got the following response on terminal
      partition 1 is now bootable
      <data>
      <data>
      This was the expected output shown on the page as well.
      When we switch sw2 switch off though, adb shell still isnt loading
      When the sw2 switch is on voxl 2 is recognised over usb in lsusb command but when it is off it isnt being recognised over lsusb either
      wintaW 1 Reply Last reply Reply Quote 0
      • wintaW
        winta @winta
        @tom @Eric-Katzfey @modaltb Could you look into?
          tom admin @winta
          @Prawin-Sankar-T-A What OS is your host machine running? Sometimes QDL won't start up the first time and requires power cycling the board and retrying a couple times
          • wintaW
            winta @tom
            @tom My host machine is using Ubuntu 20.04. Based on documentation provided here, I have tried this method a couple of times.
              tom admin @winta
              @Prawin-Sankar It may be worth submitting an RMA at this point: https://www.modalai.com/pages/rma
              • wintaW
                winta @tom
                @tom Are'nt there any other debugging methods we could try out?
                  tom admin @winta
                  @Prawin-Sankar QDL is the lowest level flashing method we can share publicly so if that's not working there's not much we can do.
