  3. Voxl 2 Mini Static IP
11 Posts 3 Posters 2.9k Views
  • B Offline
    B Offline
    bendraper
    https://docs.modalai.com/voxl2-mini-shell-access/
    The bottom of this doc says "If using wired ethernet, set up a static IP address." but I've tried doing ifconfig eth0 ~ip address~ netmask ~subnet~ to no avail. I've also tried ip addr add xxx.xxx.xxx.xxx/yy dev eth0 to no avail (always sets ip to 169.254.4.1). I know the Voxl 2 wasn't able to have a static ip set so if it is the same for the mini then so be it, the doc just made it seem like it may be possible so I was just curious
    wilkinsafW 1 Reply Last reply
    • B bendraper
      wilkinsafW Offline
      wilkinsafW Offline
      wilkinsaf
      @bendraper It is possible to set a static ip on both the voxl2 and voxl2 mini.
      It is just ubuntu OS. What modem/router are you connecting to?
      B 1 Reply Last reply
      • wilkinsafW wilkinsaf
        B Offline
        B Offline
        bendraper
        @wilkinsaf I was just connecting to my laptop for now. Laptop set with a static IP
        • B bendraper
          wilkinsafW Offline
          wilkinsafW Offline
          wilkinsaf
          @bendraper
          Here is what one of my guys uses
          ip addr flush dev eth0
          ip link set dev eth0 up
          ip addr add 192.168.1.100/255.255.255.0 dev eth0
            @bendraper
            wilkinsafW Offline
            wilkinsafW Offline
            wilkinsaf
            i would make sure that the ethernet is the only thing connected that is supplying network connectivity. (no modem, 4g/5g hat, etc...)
            otherwise you willl need to do some extra configuration with voxl-modem
            B 3 Replies Last reply
              B Offline
              B Offline
              bendraper
              @wilkinsaf This worked! Thank you
                B Offline
                B Offline
                bendraper
                @wilkinsaf Actually it seems these settings don't stick after rebooting the voxl... Any ideas?
                  B Offline
                  B Offline
                  bendraper
                  @wilkinsaf google seems to suggest changing a /etc/network/interfaces file may do the trick but this file does not exist in the voxl filesystem
                  wilkinsafW blueB 2 Replies Last reply
                  • B bendraper
                    wilkinsafW Offline
                    wilkinsafW Offline
                    wilkinsaf
                    @bendraper
                    If you make a script to do this, you might want to make it monitor eth0 state so if eth0 goes down and back up, the IP doesn't get removed.
                    Here's a bash example of what I do to check the IP address of ethernet and put it back if it goes down and back up
                    while true
                    do
                       if [[ -e "/sys/class/net/$eth_dongle_interface" ]]; then
                             eth_dongle_ip=$(ip -4 addr show $eth_dongle_interface | grep -oP '(?<=inet\s)\d+(\.\d+){3}' | head -1)
                       else
                             eth_dongle_ip=""
                       fi
                       if [[ "$eth_dongle_ip" != *"$ETHERNET_IP"* &&  -e "/sys/class/net/$eth_dongle_interface" ]]; then
                                    echo "setting IP address to: $ETHERNET_IP"
                                    ip addr flush dev $eth_dongle_interface
                                    sleep 1
                                    ip link set dev $eth_dongle_interface up
                                    sleep 1
                                    ip addr add $ETHERNET_IP/255.255.255.0 dev $eth_dongle_interface
                        fi
                        sleep 1
                    done
                    Of course, this is in my modified voxl-modem with custom variables for the interface (eth0 or eth1) and variables for the IP address. You might just want to hard code those when testing.
                    • B bendraper
                      blueB Offline
                      blueB Offline
                      blue
                      @tom @wilkinsaf @Moderator I am hoping you can help shed some light on an issue with setting up the VOXL2 Mini with a static IP. I have seen mention of utilizing a customized version of voxl-modem for a static IP so perhaps I am missing something but I have tried every approach to setting a static IP and more than I have ever used with no avail. It seems there is a service that is enabled by default to clear the IP address of the VOXL2 Mini and messes with the routing of the eth0 interface because anything I implement does not function properly. I must be missing something here if you would please enlighten me 🙂
                      Goal:
                      Set a persistent static IP on VOXL2 Mini that is maintained after reboots and during operation, then access the VOXL2 Mini with an ssh connection via a Ethernet to USB adapter.
                      Overview of Approaches:
                      -Approach #1: Does NOT Work- Use commands to flush and wipe the eth0 interface and set a new IP as shown below. This works temporarily but is overwritten typically within 30 seconds while running. After a reboot, the IP address defaults back to 169.254.4.1 and VOXL2 Mini cannot be accessed via ssh on eth0.
                      -Approach #2: Does NOT Work- Use system.d file to set eth0 interface with a new IP as shown below. This works temporarily but is overwritten typically within 30 seconds while running. After a reboot, the IP address defaults back to 169.254.4.1 and VOXL2 Mini cannot be accessed via ssh on eth0.
                      -Approach #3: Does NOT Work- Use bash script to constantly check and set the IP. This works to set the IP but the VOXL2 Mini cannot be accessed via ssh on eth0.
                      Approach #1
                      Steps to Reproduce:
                      1. adb into VOXL2 Mini
                      2. Run:
                      ifconfig
                      1. Wait 2 minutes and run:
                      ifconfig
                      Actual Result:
                      -IP address changes back to 169.254.4.1.
                      -Device no longer available via ssh on eth0 at 169.254.4.1.
                      Expected Result:
                      -IP should not change after being set.
                      Approach #2
                      Steps to Reproduce:
                      2. Run: sudo mkdir -p /etc/systemd/network
                      3. Run: sudo vi /etc/systemd/network/10-eth0-static.network
                      4. Add the following to the file created above:
                      [Match]
                      Name=eth0
                      [Network]
                      Address=192.169.144.15/24
                      Gateway=192.169.144.1
                      DNS=8.8.8.8
                      1. Run:
                      sudo systemctl restart systemd-networkd
                      sudo systemctl enable systemd-networkd
                      ip addr show eth0
                      sudo systemctl status systemd-networkd
                      ifconfig
                      Actual Result:
                      Expected Result:
                      -IP should not change from 192.169.144.15 after being set.
                      Approach #3
                      Steps to Reproduce:
                      2. Run:
                        vi /usr/local/bin/set-eth-dongle-ip.sh
                      3. Add the following to the file created above:
                      #!/bin/bash
                      eth_dongle_interface="eth0" # Replace with your dongle interface name
                      ETHERNET_IP="192.168.144.15" # Replace with your desired IP address
                      BROADCAST_IP="192.168.144.255" # Replace with the correct broadcast address
                      while true; do
                          else
                              eth_dongle_ip=""
                          fi
                          if [[ "$eth_dongle_ip" != "$ETHERNET_IP" && -e "/sys/class/net/$eth_dongle_interface" ]]; then
                              echo "Setting IP address to: $ETHERNET_IP"
                              sleep 1
                              sleep 1
                              ip addr add $ETHERNET_IP/24 broadcast $BROADCAST_IP dev $eth_dongle_interface
                          fi
                          sleep 1
                      done
                      1. make service file executeable, run:
                        sudo chmod +x /usr/local/bin/set-eth-dongle-ip.sh
                      2. create systemd service file, run:
                        vi etc/systemd/system/set-eth-dongle-ip.service
                      [Unit]
                      Description=Set Ethernet Dongle IP Address
                      After=network.target
                      [Service]
                      ExecStart=/usr/local/bin/set-eth-dongle-ip.sh
                      Restart=always
                      User=root
                      [Install]
                      WantedBy=multi-user.target
                      1. Run:
                      #reload the systemd daemon to recognize the new service
                      sudo systemctl daemon-reload
                      # enable the service so that it runs on boot
                      sudo systemctl enable set-eth-dongle-ip.service
                      # start service immediately
                      sudo systemctl start set-eth-dongle-ip.service
                      # verify service has started properly
                      sudo systemctl status set-eth-dongle-ip.service
                      ifconfig
                      Actual Result:
                      Expected Result:
                      Thank you,
                      Aaron
                      blueB 1 Reply Last reply
                      • blueB blue
                        Goal:
                        Approach #1
                        Steps to Reproduce:
                        2. Run:
                        ifconfig
                        ifconfig
                        Actual Result:
                        Expected Result:
                        Approach #2
                        Steps to Reproduce:
                        [Match]
                        Name=eth0
                        [Network]
                        DNS=8.8.8.8
                        1. Run:
                        ip addr show eth0
                        ifconfig
                        Actual Result:
                        Expected Result:
                        Approach #3
                        Steps to Reproduce:
                        2. Run:
                        #!/bin/bash
                        while true; do
                            else
                                eth_dongle_ip=""
                            fi
                                sleep 1
                                sleep 1
                            fi
                            sleep 1
                        done
                        [Unit]
                        [Service]
                        Restart=always
                        User=root
                        [Install]
                        1. Run:
                        ifconfig
                        Actual Result:
                        Expected Result:
                        blueB Offline
                        blueB Offline
                        blue
                        After having some issues with a static IP on the VOXL2 Mini above it ended up being an issue with being on the wrong subnet for the host computer to communicate.
                        We ended up fixing the issue by changing the subnet for the host computer once we changed the IP on the VOXL2 Mini.
                        e.g VOXL2 Mini IP of 192.168.144.15 will require a host computer on the same subnet e.g. 192.168.144.98.
                        Thank you,
                        Aaron
