  3. ADB devices not found on after following "boot camp" on wsl windows 10
voxl-flight
12 Posts 3 Posters 3.4k Views 1 Watching
  • rdjarvisR Offline
    rdjarvisR Offline
    rdjarvis
    I followed all instructions in the "boot camp" section and after all updates/installs, kill-server, start-server...etc.
    No ADB devices are visible in wsl.
    VOXL is visible when running ADB Driver 2.0 on the PC, but cannot see devices in wsl.
    Suggestions?
    RDJ
    • rdjarvisR rdjarvis
      Suggestions?
      RDJ
      @rdjarvis Our resident WSL expert says to do the following:
      In normal windows command prompt (outside of WSDL)
      adb kill-server
      adb start-server
      then check in WSL
      rdjarvisR 2 Replies Last reply
        adb kill-server
        adb start-server
        then check in WSL
        rdjarvisR Offline
        rdjarvisR Offline
        rdjarvis
        @tom Ill try that right now!
          adb kill-server
          adb start-server
          then check in WSL
          rdjarvisR Offline
          rdjarvisR Offline
          rdjarvis
          @tom this is what windows command prompt tells me when running "adb kill-server"
          'adb' is not recognized as an internal or external command,
          operable program or batch file.
            @rdjarvis I was under the impression that "VOXL is visible when running ADB Driver 2.0 on the PC" meant you were able to access adb on your normal command prompt
            rdjarvisR 1 Reply Last reply
              rdjarvisR Offline
              rdjarvisR Offline
              rdjarvis
                @rdjarvis I'm not familiar with that tool unfortunately, I would follow the instructions here starting with the section titled "How to set up ADB on Microsoft Windows" with the Android SDK installed from https://dl.google.com/android/repository/platform-tools-latest-windows.zip
                  rdjarvisR Offline
                  rdjarvisR Offline
                  rdjarvis
                  @tom thank you, I will get started
                  VinnyV 1 Reply Last reply
                    VinnyV Offline
                    VinnyV Offline
                    Vinny
                    Hi @rdjarvis ,
                    Once you have adb tools installed on your PC, I've successfully used WSL as Tom mentioned only after trying the kill and restart commands in command window/prompt. Sometimes it may take a few tries in the command prompt, but once I get Windows command prompt to see the adb device, WSL always sees it.
                    I cannot speak to other utilities, but command prompt always works for me.
                    I tried the reverse and it doesn't work, so I think some configurations require Windows to see the adb device first before it let's WSL see it.
                    Hope that helps.
                    • VinnyV Vinny
                      Hi @rdjarvis ,
                      Hope that helps.
                      rdjarvisR Offline
                      rdjarvisR Offline
                      rdjarvis
                      @Vinny thanks, just got into the office and will start over. I wasnt successful with the ADB platform tools.....yet
                      • rdjarvisR Offline
                        rdjarvisR Offline
                        rdjarvis
                        UPDATE
                        ADB Devices are now visible in Windows CMD after I updated the system path in environment variables.
                        Now the fun begins
                          UPDATE
                          Now the fun begins
                          @rdjarvis Woot! Enjoy!
