Quectel 5G Hat errors on voxl-modem, possibly not being detected
Hello. Today I've been trying to integrate the 5G hat on the VOXL2, and I don't believe it's getting detected. After doing
voxl-configure-modemand selecting quectel and the APN of my SIM card, I reboot the VOXL 2 and get this output from the voxl-modem service:voxl2:/$ systemctl status voxl-modem ● voxl-modem.service - Modem Initialization Loaded: loaded (/etc/systemd/system/voxl-modem.service; enabled; vendor preset: enabled) Active: active (running) since Thu 2023-03-02 12:58:06 UTC; 10s ago Process: 1267 ExecStartPre=/bin/sleep 2 (code=exited, status=0/SUCCESS) Main PID: 1693 (voxl-modem-star) Tasks: 2 (limit: 4915) CGroup: /system.slice/voxl-modem.service └─1693 /bin/bash /usr/bin/voxl-modem-start Mar 02 12:58:07 m0054 voxl-modem-start[1693]: [03-02_12:58:07:867] network interface '' or qmidev '' is not exist Mar 02 12:58:07 m0054 voxl-modem-start[1693]: [03-02_12:58:07:867] qmidevice_detect failed Mar 02 12:58:07 m0054 voxl-modem-start[1693]: [03-02_12:58:07:868] Quectel_QConnectManager_Linux_V1.6.0.24 Mar 02 12:58:07 m0054 voxl-modem-start[1693]: [03-02_12:58:07:868] network interface '' or qmidev '' is not exist Mar 02 12:58:07 m0054 voxl-modem-start[1693]: [03-02_12:58:07:868] qmidevice_detect failed Mar 02 12:58:07 m0054 voxl-modem-start[1693]: [03-02_12:58:07:870] Quectel_QConnectManager_Linux_V1.6.0.24 Mar 02 12:58:07 m0054 voxl-modem-start[1693]: [03-02_12:58:07:870] network interface '' or qmidev '' is not exist Mar 02 12:58:07 m0054 voxl-modem-start[1693]: [03-02_12:58:07:870] qmidevice_detect failed Mar 02 12:58:07 m0054 voxl-modem-start[1693]: [03-02_12:58:07:871] Quectel_QConnectManager_Linux_V1.6.0.24 Mar 02 12:58:07 m0054 voxl-modem-start[1693]: [03-02_12:58:07:871] network interface '' or qmidev '' is not existHowever, when I start the VOXL2 without the 5G hat on and do the same, I get the same output. I am thinking that it is not detecting the 5G hat.
I tried using the most recent nightly build, but that did not help. Any ideas?
@John-Nomikos-0 If you stop the voxl-modem service:
systemctl stop voxl-modemand run the quectel program on it's own with:quectel-CM -s $APNwhere $APN is the apn of your sim card, do you get the same output?I do not get the same output. Instead, I get this:
voxl2:/$ quectel-CM -s soracom.io [03-02_12:58:37:688] Quectel_QConnectManager_Linux_V1.6.0.24 [03-02_12:58:37:690] Find /sys/bus/usb/devices/1-1.1 idVendor=0x2c7c idProduct=0x800, bus=0x001, dev=0x004 [03-02_12:58:37:692] Auto find qmichannel = /dev/cdc-wdm0 [03-02_12:58:37:692] Auto find usbnet_adapter = wwan0 [03-02_12:58:37:692] netcard driver = qmi_wwan, driver version = 22-Aug-2005 [03-02_12:58:37:693] Modem works in QMI mode [03-02_12:58:37:718] /proc/2264/fd/7 -> /dev/cdc-wdm0 [03-02_12:58:37:718] /proc/2264/exe -> /usr/bin/quectel-CM [03-02_12:58:39:720] cdc_wdm_fd = 7 [03-02_12:59:09:740] QmiWwanInit message timeout [03-02_12:59:39:742] QmiWwanGetClientID message timeout -
systemctl stop voxl-modemand run the quectel program on it's own with:quectel-CM -s $APNwhere $APN is the apn of your sim card, do you get the same output? -
@tom I would also double check that the quectel modem is fully seated in the PCI slot, and screwed down
voxl2:/$ quectel-CM -s soracom.io [03-02_12:58:37:688] Quectel_QConnectManager_Linux_V1.6.0.24 [03-02_12:58:37:690] Find /sys/bus/usb/devices/1-1.1 idVendor=0x2c7c idProduct=0x800, bus=0x001, dev=0x004 [03-02_12:58:37:692] Auto find qmichannel = /dev/cdc-wdm0 [03-02_12:58:37:692] Auto find usbnet_adapter = wwan0 [03-02_12:58:37:692] netcard driver = qmi_wwan, driver version = 22-Aug-2005 [03-02_12:58:37:693] Modem works in QMI mode [03-02_12:58:37:718] /proc/2264/fd/7 -> /dev/cdc-wdm0 [03-02_12:58:37:718] /proc/2264/exe -> /usr/bin/quectel-CM [03-02_12:58:39:720] cdc_wdm_fd = 7 [03-02_12:59:09:740] QmiWwanInit message timeout [03-02_12:59:39:742] QmiWwanGetClientID message timeoutOh I did not stop voxl-modem. Here is the actual output:
voxl2:/$ quectel-CM -s soracom.io [03-02_13:02:47:038] Quectel_QConnectManager_Linux_V1.6.0.24 [03-02_13:02:47:040] Find /sys/bus/usb/devices/1-1.1 idVendor=0x2c7c idProduct=0x800, bus=0x001, dev=0x004 [03-02_13:02:47:042] Auto find qmichannel = /dev/cdc-wdm0 [03-02_13:02:47:042] Auto find usbnet_adapter = wwan0 [03-02_13:02:47:042] netcard driver = qmi_wwan, driver version = 22-Aug-2005 [03-02_13:02:47:043] Modem works in QMI mode [03-02_13:02:47:062] cdc_wdm_fd = 7 [03-02_13:02:47:147] Get clientWDS = 2 [03-02_13:02:47:179] Get clientDMS = 1 [03-02_13:02:47:211] Get clientNAS = 4 [03-02_13:02:47:243] Get clientUIM = 1 [03-02_13:02:47:275] Get clientWDA = 1 [03-02_13:02:47:307] requestBaseBandVersion RM502QAEAAR11A04M4G [03-02_13:02:47:435] requestGetSIMStatus SIMStatus: SIM_READY [03-02_13:02:47:435] requestSetProfile[1] soracom.io///0 [03-02_13:02:47:499] requestGetProfile[1] soracom.io///0 [03-02_13:02:47:530] requestRegistrationState2 MCC: 310, MNC: 410, PS: Detached, DataCap: UNKNOW [03-02_13:02:47:563] requestQueryDataCall IPv4ConnectionStatus: DISCONNECTED [03-02_13:02:47:563] ifconfig wwan0 0.0.0.0 [03-02_13:02:47:580] ifconfig wwan0 downAlso the hat is not screwed down, that is something I could try.
Here's what I see with ifconfig:
voxl2:/$ ifconfig bond0: flags=5123<UP,BROADCAST,MASTER,MULTICAST> mtu 1500 ether 22:f7:00:43:64:34 txqueuelen 1000 (Ethernet) RX packets 0 bytes 0 (0.0 B) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 0 bytes 0 (0.0 B) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 dummy0: flags=195<UP,BROADCAST,RUNNING,NOARP> mtu 1500 inet6 fe80::b6fc:7109:8dd5:7c6c prefixlen 64 scopeid 0x20<link> ether 16:30:4b:20:ed:31 txqueuelen 1000 (Ethernet) RX packets 0 bytes 0 (0.0 B) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 15 bytes 4042 (4.0 KB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536 inet 127.0.0.1 netmask 255.0.0.0 inet6 ::1 prefixlen 128 scopeid 0x10<host> loop txqueuelen 1000 (Local Loopback) RX packets 307856 bytes 32852320 (32.8 MB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 307856 bytes 32852320 (32.8 MB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0Here is what ls /dev shows:
voxl2:/$ ls /dev 6002000.stm cvp i2c-4 loop3 msm_amrwbplus network_latency ram5 ramdump_microdump_modem sda8 sde16 sde35 sde54 sensors spidev3.0 tty12 tty31 tty50 ttyHS3 v4l-subdev4 vcsu1 adsprpc-smd dcc_sram iio:device0 loop4 msm_ape network_throughput ram6 ramdump_npu sda9 sde17 sde36 sde55 serial spss_utils tty13 tty32 tty51 ttyUSB0 v4l-subdev5 vcsu2 adsprpc-smd-secure diag iio:device1 loop5 msm_audio_cal null ram7 ramdump_slpi sdb sde18 sde37 sde56 sg0 stderr tty14 tty33 tty52 ttyUSB1 v4l-subdev6 vcsu3 android_mbim disk iio:device2 loop6 msm_evrc ppp ram8 ramdump_spss sdb1 sde19 sde38 sde57 sg1 stdin tty15 tty34 tty53 ttyUSB2 v4l-subdev7 vcsu4 ashmem dpl_ctrl initctl loop7 msm_evrc_in ptmx ram9 ramdump_venus sdb2 sde2 sde39 sde58 sg2 stdout tty16 tty35 tty54 ttyUSB3 v4l-subdev8 vcsu5 at_usb0 dri input loop8 msm_g711alaw pts ramdump_a650_zap random sdc sde20 sde4 sde59 sg3 subsys_a650_zap tty17 tty36 tty55 uhid v4l-subdev9 vcsu6 at_usb1 ecryptfs ion loop9 msm_g711alaw_in qce ramdump_adsp rebooterdev sdc1 sde21 sde40 sde6 sg4 subsys_adsp tty18 tty37 tty56 uinput vcs vga_arbiter avtimer fd kgsl-3d0 mapper msm_g711mlaw qsee_ipc_irq_spss ramdump_cdsp rfkill sdc2 sde22 sde41 sde60 sg5 subsys_cdsp tty19 tty38 tty57 urandom vcs1 video0 binder full kmsg media0 msm_g711mlaw_in qseecom ramdump_cvpss rmnet_ctrl sdd sde23 sde42 sde7 sg6 subsys_cvpss tty2 tty39 tty58 usb-ffs vcs2 video1 block fuse lightnvm media1 msm_hdcp qvr_external_sensor_ioctl ramdump_ipa_fws rpmsg_ctrl0 sdd1 sde24 sde43 sde8 sg7 subsys_ipa_fws tty20 tty4 tty59 usf1 vcs3 video32 bsg gpiochip0 log mem msm_hweffects ram0 ramdump_ipa_uc rpmsg_ctrl1 sdd2 sde25 sde44 sde9 sg8 subsys_ipa_uc tty21 tty40 tty6 v4l-subdev0 vcs4 video33 btpower gpiochip1 loop-control memory_bandwidth msm_mp3 ram1 ramdump_md_a650_zap rtc sdd3 sde26 sde45 sdf shm subsys_npu tty22 tty41 tty60 v4l-subdev1 vcs5 vndbinder btrfs-control gpiochip2 loop0 mqueue msm_multi_aac ram10 ramdump_md_adsp rtc0 sdd4 sde27 sde46 sdf1 smcinvoke subsys_slpi tty23 tty42 tty61 v4l-subdev10 vcs6 voxl_b2b bus gpiochip3 loop1 msm-rng msm_npu ram11 ramdump_md_cdsp sda sde sde28 sde47 sdf2 snd subsys_spss tty24 tty43 tty62 v4l-subdev11 vcsa voxl_rc_in byte-cntr gpiochip4 loop10 msm_aac msm_qcelp ram12 ramdump_md_cvpss sda1 sde1 sde29 sde48 sdf3 socket subsys_venus tty25 tty44 tty63 v4l-subdev12 vcsa1 zero cdc-wdm0 hwbinder loop11 msm_aac_in msm_qcelp_in ram13 ramdump_md_ipa_fws sda2 sde10 sde3 sde49 sdf4 sp_kernel synx_device tty26 tty45 tty7 v4l-subdev13 vcsa2 zram0 char hwrng loop12 msm_alac msm_rtac ram14 ramdump_md_ipa_uc sda3 sde11 sde30 sde5 sdf5 sp_ssr tty tty27 tty46 tty8 v4l-subdev14 vcsa3 console i2c-0 loop13 msm_amrnb msm_sps ram15 ramdump_md_npu sda4 sde12 sde31 sde50 sdf6 spcom tty0 tty28 tty47 tty9 v4l-subdev15 vcsa4 coresight-tmc-etf i2c-1 loop14 msm_amrnb_in msm_wma ram2 ramdump_md_slpi sda5 sde13 sde32 sde51 sdf7 spidev0.0 tty1 tty29 tty48 ttyHS0 v4l-subdev16 vcsa5 coresight-tmc-etr i2c-2 loop15 msm_amrwb msm_wmapro ram3 ramdump_md_spss sda6 sde14 sde33 sde52 sdf8 spidev11.0 tty10 tty3 tty49 ttyHS1 v4l-subdev2 vcsa6 cpu_dma_latency i2c-3 loop2 msm_amrwb_in net ram4 ramdump_md_venus sda7 sde15 sde34 sde53 sdf9 spidev14.0 tty11 tty30 tty5 ttyHS2 v4l-subdev3 vcsu -
voxl2:/$ ls /dev 6002000.stm cvp i2c-4 loop3 msm_amrwbplus network_latency ram5 ramdump_microdump_modem sda8 sde16 sde35 sde54 sensors spidev3.0 tty12 tty31 tty50 ttyHS3 v4l-subdev4 vcsu1 adsprpc-smd dcc_sram iio:device0 loop4 msm_ape network_throughput ram6 ramdump_npu sda9 sde17 sde36 sde55 serial spss_utils tty13 tty32 tty51 ttyUSB0 v4l-subdev5 vcsu2 adsprpc-smd-secure diag iio:device1 loop5 msm_audio_cal null ram7 ramdump_slpi sdb sde18 sde37 sde56 sg0 stderr tty14 tty33 tty52 ttyUSB1 v4l-subdev6 vcsu3 android_mbim disk iio:device2 loop6 msm_evrc ppp ram8 ramdump_spss sdb1 sde19 sde38 sde57 sg1 stdin tty15 tty34 tty53 ttyUSB2 v4l-subdev7 vcsu4 ashmem dpl_ctrl initctl loop7 msm_evrc_in ptmx ram9 ramdump_venus sdb2 sde2 sde39 sde58 sg2 stdout tty16 tty35 tty54 ttyUSB3 v4l-subdev8 vcsu5 at_usb0 dri input loop8 msm_g711alaw pts ramdump_a650_zap random sdc sde20 sde4 sde59 sg3 subsys_a650_zap tty17 tty36 tty55 uhid v4l-subdev9 vcsu6 at_usb1 ecryptfs ion loop9 msm_g711alaw_in qce ramdump_adsp rebooterdev sdc1 sde21 sde40 sde6 sg4 subsys_adsp tty18 tty37 tty56 uinput vcs vga_arbiter avtimer fd kgsl-3d0 mapper msm_g711mlaw qsee_ipc_irq_spss ramdump_cdsp rfkill sdc2 sde22 sde41 sde60 sg5 subsys_cdsp tty19 tty38 tty57 urandom vcs1 video0 binder full kmsg media0 msm_g711mlaw_in qseecom ramdump_cvpss rmnet_ctrl sdd sde23 sde42 sde7 sg6 subsys_cvpss tty2 tty39 tty58 usb-ffs vcs2 video1 block fuse lightnvm media1 msm_hdcp qvr_external_sensor_ioctl ramdump_ipa_fws rpmsg_ctrl0 sdd1 sde24 sde43 sde8 sg7 subsys_ipa_fws tty20 tty4 tty59 usf1 vcs3 video32 bsg gpiochip0 log mem msm_hweffects ram0 ramdump_ipa_uc rpmsg_ctrl1 sdd2 sde25 sde44 sde9 sg8 subsys_ipa_uc tty21 tty40 tty6 v4l-subdev0 vcs4 video33 btpower gpiochip1 loop-control memory_bandwidth msm_mp3 ram1 ramdump_md_a650_zap rtc sdd3 sde26 sde45 sdf shm subsys_npu tty22 tty41 tty60 v4l-subdev1 vcs5 vndbinder btrfs-control gpiochip2 loop0 mqueue msm_multi_aac ram10 ramdump_md_adsp rtc0 sdd4 sde27 sde46 sdf1 smcinvoke subsys_slpi tty23 tty42 tty61 v4l-subdev10 vcs6 voxl_b2b bus gpiochip3 loop1 msm-rng msm_npu ram11 ramdump_md_cdsp sda sde sde28 sde47 sdf2 snd subsys_spss tty24 tty43 tty62 v4l-subdev11 vcsa voxl_rc_in byte-cntr gpiochip4 loop10 msm_aac msm_qcelp ram12 ramdump_md_cvpss sda1 sde1 sde29 sde48 sdf3 socket subsys_venus tty25 tty44 tty63 v4l-subdev12 vcsa1 zero cdc-wdm0 hwbinder loop11 msm_aac_in msm_qcelp_in ram13 ramdump_md_ipa_fws sda2 sde10 sde3 sde49 sdf4 sp_kernel synx_device tty26 tty45 tty7 v4l-subdev13 vcsa2 zram0 char hwrng loop12 msm_alac msm_rtac ram14 ramdump_md_ipa_uc sda3 sde11 sde30 sde5 sdf5 sp_ssr tty tty27 tty46 tty8 v4l-subdev14 vcsa3 console i2c-0 loop13 msm_amrnb msm_sps ram15 ramdump_md_npu sda4 sde12 sde31 sde50 sdf6 spcom tty0 tty28 tty47 tty9 v4l-subdev15 vcsa4 coresight-tmc-etf i2c-1 loop14 msm_amrnb_in msm_wma ram2 ramdump_md_slpi sda5 sde13 sde32 sde51 sdf7 spidev0.0 tty1 tty29 tty48 ttyHS0 v4l-subdev16 vcsa5 coresight-tmc-etr i2c-2 loop15 msm_amrwb msm_wmapro ram3 ramdump_md_spss sda6 sde14 sde33 sde52 sdf8 spidev11.0 tty10 tty3 tty49 ttyHS1 v4l-subdev2 vcsa6 cpu_dma_latency i2c-3 loop2 msm_amrwb_in net ram4 ramdump_md_venus sda7 sde15 sde34 sde53 sdf9 spidev14.0 tty11 tty30 tty5 ttyHS2 v4l-subdev3 vcsu@John-Nomikos-0 I do see the
/dev/ttyUSB*and/dev/cdc-wdm0interfaces I expect, which is good, but not thewwan0interface inifconfigThat output from quectel-CM is making me think that cellular network isn't happy, have you had success with this SIM card and a quectel modem before?
Do you have a different SIM card on a different network you could test with?
Also, do you have all 4 antennas connected to the quectel modem?
You were correct. It turns out that we did not have a plan with the SIM card I was using. So I switched to a working SIM card that we were using on a ZTE stick before.
Now when I run
quectel-CM -s $APN, I get this output:voxl2:/$ quectel-CM -s iot.tmowholesale.static [03-02_13:01:39:023] Quectel_QConnectManager_Linux_V1.6.0.24 [03-02_13:01:39:025] Find /sys/bus/usb/devices/1-1.1 idVendor=0x2c7c idProduct=0x800, bus=0x001, dev=0x004 [03-02_13:01:39:027] Auto find qmichannel = /dev/cdc-wdm0 [03-02_13:01:39:027] Auto find usbnet_adapter = wwan0 [03-02_13:01:39:027] netcard driver = qmi_wwan, driver version = 22-Aug-2005 [03-02_13:01:39:028] Modem works in QMI mode [03-02_13:01:39:052] cdc_wdm_fd = 7 [03-02_13:01:39:141] Get clientWDS = 5 [03-02_13:01:39:173] Get clientDMS = 1 [03-02_13:01:39:205] Get clientNAS = 4 [03-02_13:01:39:237] Get clientUIM = 1 [03-02_13:01:39:269] Get clientWDA = 1 [03-02_13:01:39:301] requestBaseBandVersion RM502QAEAAR11A04M4G [03-02_13:01:39:429] requestGetSIMStatus SIMStatus: SIM_READY [03-02_13:01:39:429] requestSetProfile[1] iot.tmowholesale.static///0 [03-02_13:01:39:493] requestGetProfile[1] iot.tmowholesale.static///0 [03-02_13:01:39:525] requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW [03-02_13:01:39:557] requestQueryDataCall IPv4ConnectionStatus: DISCONNECTED [03-02_13:01:39:557] ifconfig wwan0 0.0.0.0 [03-02_13:01:39:573] ifconfig wwan0 down [03-02_13:02:06:437] requestRegistrationState2 MCC: 310, MNC: 260, PS: Detached, DataCap: UNKNOW [03-02_13:02:06:469] requestRegistrationState2 MCC: 310, MNC: 260, PS: Detached, DataCap: UNKNOW [03-02_13:02:09:765] requestRegistrationState2 MCC: 310, MNC: 260, PS: Detached, DataCap: UNKNOW [03-02_13:02:32:133] requestRegistrationState2 MCC: 310, MNC: 260, PS: Detached, DataCap: UNKNOW [03-02_13:02:35:365] requestRegistrationState2 MCC: 310, MNC: 260, PS: Detached, DataCap: UNKNOWAnd ifconfig shows this: (before I run the command above, after I run it wwan0 goes away)
voxl2:/$ ifconfig bond0: flags=5123<UP,BROADCAST,MASTER,MULTICAST> mtu 1500 ether 8e:62:c9:ae:cb:5e txqueuelen 1000 (Ethernet) RX packets 0 bytes 0 (0.0 B) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 0 bytes 0 (0.0 B) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 dummy0: flags=195<UP,BROADCAST,RUNNING,NOARP> mtu 1500 inet6 fe80::f942:3eee:119e:32f0 prefixlen 64 scopeid 0x20<link> ether 4a:91:5e:0b:29:d0 txqueuelen 1000 (Ethernet) RX packets 0 bytes 0 (0.0 B) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 4 bytes 824 (824.0 B) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536 inet 127.0.0.1 netmask 255.0.0.0 inet6 ::1 prefixlen 128 scopeid 0x10<host> loop txqueuelen 1000 (Local Loopback) RX packets 80 bytes 5920 (5.9 KB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 80 bytes 5920 (5.9 KB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 wwan0: flags=4291<UP,BROADCAST,RUNNING,NOARP,MULTICAST> mtu 1500 inet6 fe80::f1eb:2024:d885:26f4 prefixlen 64 scopeid 0x20<link> ether 7a:2d:dc:62:b9:84 txqueuelen 1000 (Ethernet) RX packets 0 bytes 0 (0.0 B) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 0 bytes 0 (0.0 B) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0Pinging 8.8.8.8 shows 100% packet loss.
Also, doing systemctl status on voxl-modem shows the same output as before.
I do have all 4 antennas connected.
Now when I run
I tried with a different SIM card, since I believe the issue had to do with that specific SIM.
This one actually goes through the dialing process which seems good. However, no connection is being established.
Output:
voxl2:/$ quectel-CM -s vzwinternet [03-02_13:00:11:484] Quectel_QConnectManager_Linux_V1.6.0.24 [03-02_13:00:11:486] Find /sys/bus/usb/devices/1-1.1 idVendor=0x2c7c idProduct=0x800, bus=0x001, dev=0x004 [03-02_13:00:11:488] Auto find qmichannel = /dev/cdc-wdm0 [03-02_13:00:11:488] Auto find usbnet_adapter = wwan0 [03-02_13:00:11:488] netcard driver = qmi_wwan, driver version = 22-Aug-2005 [03-02_13:00:11:489] Modem works in QMI mode [03-02_13:00:11:515] cdc_wdm_fd = 7 [03-02_13:00:11:593] Get clientWDS = 2 [03-02_13:00:11:625] Get clientDMS = 1 [03-02_13:00:11:657] Get clientNAS = 4 [03-02_13:00:11:689] Get clientUIM = 1 [03-02_13:00:11:721] Get clientWDA = 1 [03-02_13:00:11:753] requestBaseBandVersion RM502QAEAAR11A04M4G [03-02_13:00:11:881] requestGetSIMStatus SIMStatus: SIM_READY [03-02_13:00:11:881] requestSetProfile[1] vzwinternet///0 [03-02_13:00:11:945] requestGetProfile[1] vzwinternet///0 [03-02_13:00:11:977] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:00:12:009] requestQueryDataCall IPv4ConnectionStatus: DISCONNECTED [03-02_13:00:12:009] ifconfig wwan0 0.0.0.0 [03-02_13:00:12:027] ifconfig wwan0 down [03-02_13:00:12:265] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe [03-02_13:00:12:265] call_end_reason is 1 [03-02_13:00:12:265] call_end_reason_type is 6 [03-02_13:00:12:265] call_end_reason_verbose is 113 [03-02_13:00:12:266] try to requestSetupDataCall 5 second later [03-02_13:00:17:289] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe [03-02_13:00:17:289] call_end_reason is 3 [03-02_13:00:17:289] call_end_reason_type is 3 [03-02_13:00:17:289] call_end_reason_verbose is 2001 [03-02_13:00:17:289] try to requestSetupDataCall 10 second later [03-02_13:00:27:337] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe [03-02_13:00:27:337] call_end_reason is 3 [03-02_13:00:27:337] call_end_reason_type is 3 [03-02_13:00:27:338] call_end_reason_verbose is 2001 [03-02_13:00:27:338] try to requestSetupDataCall 20 second later [03-02_13:00:27:497] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:00:28:873] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:00:33:161] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:00:34:633] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:00:36:201] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:00:37:609] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:00:47:657] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe [03-02_13:00:47:657] call_end_reason is 3 [03-02_13:00:47:658] call_end_reason_type is 3 [03-02_13:00:47:658] call_end_reason_verbose is 2001 [03-02_13:00:47:658] try to requestSetupDataCall 40 second later [03-02_13:00:49:257] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:00:50:697] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:00:53:673] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:00:55:209] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:00:56:425] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:00:57:641] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:01:00:393] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:01:01:769] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:01:08:521] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:01:09:673] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:01:23:593] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:01:25:097] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:01:28:329] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe [03-02_13:01:28:329] call_end_reason is 1 [03-02_13:01:28:330] call_end_reason_type is 6 [03-02_13:01:28:330] call_end_reason_verbose is 113 [03-02_13:01:28:330] try to requestSetupDataCall 60 second later [03-02_13:01:30:313] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:01:31:561] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:01:34:345] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:01:35:593] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:01:39:977] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:01:41:577] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:01:43:241] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: LTE [03-02_13:01:44:745] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: LTE [03-02_13:01:46:090] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:01:47:753] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:01:49:257] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: LTE [03-02_13:01:51:817] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:01:57:417] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:02:11:497] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:02:13:961] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:02:15:177] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:02:17:641] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:02:19:017] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:02:20:233] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:02:27:401] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:02:28:425] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe [03-02_13:02:28:425] call_end_reason is 3 [03-02_13:02:28:426] call_end_reason_type is 3 [03-02_13:02:28:426] call_end_reason_verbose is 2001 [03-02_13:02:28:427] try to requestSetupDataCall 60 second later [03-02_13:02:28:809] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:02:30:249] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: LTE [03-02_13:02:37:545] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:02:38:761] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:02:45:993] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:02:47:561] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:02:55:817] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:02:57:065] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:03:01:513] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:03:03:081] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:03:04:329] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:03:06:985] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:03:18:281] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:03:19:657] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: LTE [03-02_13:03:21:161] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:03:22:281] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:03:26:345] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:03:27:529] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:03:28:553] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe [03-02_13:03:28:554] call_end_reason is 3 [03-02_13:03:28:554] call_end_reason_type is 3 [03-02_13:03:28:554] call_end_reason_verbose is 2001 [03-02_13:03:28:554] try to requestSetupDataCall 60 second later [03-02_13:03:31:721] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:03:33:321] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:03:34:729] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:03:36:361] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:03:42:345] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:03:45:545] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:03:48:554] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:03:49:802] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:04:00:841] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:04:02:281] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:04:29:481] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe [03-02_13:04:29:482] call_end_reason is 1 [03-02_13:04:29:482] call_end_reason_type is 6 [03-02_13:04:29:482] call_end_reason_verbose is 113 [03-02_13:04:29:482] try to requestSetupDataCall 60 second later [03-02_13:05:08:745] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:05:10:153] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:05:11:497] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:05:12:681] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:05:14:313] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:05:16:841] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:05:30:505] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe [03-02_13:05:30:505] call_end_reason is 1 [03-02_13:05:30:505] call_end_reason_type is 6 [03-02_13:05:30:505] call_end_reason_verbose is 113 [03-02_13:05:30:505] try to requestSetupDataCall 60 second later [03-02_13:05:33:897] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:05:35:529] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: LTE [03-02_13:05:38:473] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:05:40:106] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:06:31:689] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe [03-02_13:06:31:689] call_end_reason is 1 [03-02_13:06:31:690] call_end_reason_type is 6 [03-02_13:06:31:690] call_end_reason_verbose is 113 [03-02_13:06:31:690] try to requestSetupDataCall 60 second later [03-02_13:07:27:209] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:07:28:713] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:07:32:425] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe [03-02_13:07:32:426] call_end_reason is 1 [03-02_13:07:32:426] call_end_reason_type is 6 [03-02_13:07:32:426] call_end_reason_verbose is 113 [03-02_13:07:32:426] try to requestSetupDataCall 60 second later [03-02_13:08:21:801] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:08:23:145] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:08:33:193] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe [03-02_13:08:33:193] call_end_reason is 3 [03-02_13:08:33:194] call_end_reason_type is 3 [03-02_13:08:33:194] call_end_reason_verbose is 2001 [03-02_13:08:33:194] try to requestSetupDataCall 60 second later [03-02_13:08:40:201] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:08:41:673] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: LTE [03-02_13:09:33:737] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe [03-02_13:09:33:737] call_end_reason is 3 [03-02_13:09:33:737] call_end_reason_type is 3 [03-02_13:09:33:737] call_end_reason_verbose is 2001 [03-02_13:09:33:737] try to requestSetupDataCall 60 second later [03-02_13:09:59:721] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:10:00:937] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:10:07:785] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:10:09:129] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:10:10:377] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:10:11:721] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:10:34:857] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe [03-02_13:10:34:857] call_end_reason is 1 [03-02_13:10:34:857] call_end_reason_type is 6 [03-02_13:10:34:857] call_end_reason_verbose is 113 [03-02_13:10:34:857] try to requestSetupDataCall 60 second later [03-02_13:11:34:921] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe [03-02_13:11:34:921] call_end_reason is 3 [03-02_13:11:34:921] call_end_reason_type is 3 [03-02_13:11:34:921] call_end_reason_verbose is 2001 [03-02_13:11:34:922] try to requestSetupDataCall 60 second later -
Output:
voxl2:/$ quectel-CM -s vzwinternet [03-02_13:00:11:484] Quectel_QConnectManager_Linux_V1.6.0.24 [03-02_13:00:11:486] Find /sys/bus/usb/devices/1-1.1 idVendor=0x2c7c idProduct=0x800, bus=0x001, dev=0x004 [03-02_13:00:11:488] Auto find qmichannel = /dev/cdc-wdm0 [03-02_13:00:11:488] Auto find usbnet_adapter = wwan0 [03-02_13:00:11:488] netcard driver = qmi_wwan, driver version = 22-Aug-2005 [03-02_13:00:11:489] Modem works in QMI mode [03-02_13:00:11:515] cdc_wdm_fd = 7 [03-02_13:00:11:593] Get clientWDS = 2 [03-02_13:00:11:625] Get clientDMS = 1 [03-02_13:00:11:657] Get clientNAS = 4 [03-02_13:00:11:689] Get clientUIM = 1 [03-02_13:00:11:721] Get clientWDA = 1 [03-02_13:00:11:753] requestBaseBandVersion RM502QAEAAR11A04M4G [03-02_13:00:11:881] requestGetSIMStatus SIMStatus: SIM_READY [03-02_13:00:11:881] requestSetProfile[1] vzwinternet///0 [03-02_13:00:11:945] requestGetProfile[1] vzwinternet///0 [03-02_13:00:11:977] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:00:12:009] requestQueryDataCall IPv4ConnectionStatus: DISCONNECTED [03-02_13:00:12:009] ifconfig wwan0 0.0.0.0 [03-02_13:00:12:027] ifconfig wwan0 down [03-02_13:00:12:265] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe [03-02_13:00:12:265] call_end_reason is 1 [03-02_13:00:12:265] call_end_reason_type is 6 [03-02_13:00:12:265] call_end_reason_verbose is 113 [03-02_13:00:12:266] try to requestSetupDataCall 5 second later [03-02_13:00:17:289] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe [03-02_13:00:17:289] call_end_reason is 3 [03-02_13:00:17:289] call_end_reason_type is 3 [03-02_13:00:17:289] call_end_reason_verbose is 2001 [03-02_13:00:17:289] try to requestSetupDataCall 10 second later [03-02_13:00:27:337] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe [03-02_13:00:27:337] call_end_reason is 3 [03-02_13:00:27:337] call_end_reason_type is 3 [03-02_13:00:27:338] call_end_reason_verbose is 2001 [03-02_13:00:27:338] try to requestSetupDataCall 20 second later [03-02_13:00:27:497] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:00:28:873] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:00:33:161] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:00:34:633] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:00:36:201] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:00:37:609] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:00:47:657] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe [03-02_13:00:47:657] call_end_reason is 3 [03-02_13:00:47:658] call_end_reason_type is 3 [03-02_13:00:47:658] call_end_reason_verbose is 2001 [03-02_13:00:47:658] try to requestSetupDataCall 40 second later [03-02_13:00:49:257] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:00:50:697] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:00:53:673] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:00:55:209] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:00:56:425] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:00:57:641] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:01:00:393] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:01:01:769] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:01:08:521] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:01:09:673] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:01:23:593] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:01:25:097] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:01:28:329] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe [03-02_13:01:28:329] call_end_reason is 1 [03-02_13:01:28:330] call_end_reason_type is 6 [03-02_13:01:28:330] call_end_reason_verbose is 113 [03-02_13:01:28:330] try to requestSetupDataCall 60 second later [03-02_13:01:30:313] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:01:31:561] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:01:34:345] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:01:35:593] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:01:39:977] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:01:41:577] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:01:43:241] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: LTE [03-02_13:01:44:745] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: LTE [03-02_13:01:46:090] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:01:47:753] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:01:49:257] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: LTE [03-02_13:01:51:817] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:01:57:417] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:02:11:497] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:02:13:961] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:02:15:177] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:02:17:641] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:02:19:017] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:02:20:233] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:02:27:401] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:02:28:425] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe [03-02_13:02:28:425] call_end_reason is 3 [03-02_13:02:28:426] call_end_reason_type is 3 [03-02_13:02:28:426] call_end_reason_verbose is 2001 [03-02_13:02:28:427] try to requestSetupDataCall 60 second later [03-02_13:02:28:809] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:02:30:249] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: LTE [03-02_13:02:37:545] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:02:38:761] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:02:45:993] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:02:47:561] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:02:55:817] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:02:57:065] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:03:01:513] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:03:03:081] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:03:04:329] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:03:06:985] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:03:18:281] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:03:19:657] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: LTE [03-02_13:03:21:161] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:03:22:281] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:03:26:345] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:03:27:529] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:03:28:553] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe [03-02_13:03:28:554] call_end_reason is 3 [03-02_13:03:28:554] call_end_reason_type is 3 [03-02_13:03:28:554] call_end_reason_verbose is 2001 [03-02_13:03:28:554] try to requestSetupDataCall 60 second later [03-02_13:03:31:721] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:03:33:321] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:03:34:729] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:03:36:361] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:03:42:345] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:03:45:545] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:03:48:554] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:03:49:802] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:04:00:841] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:04:02:281] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:04:29:481] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe [03-02_13:04:29:482] call_end_reason is 1 [03-02_13:04:29:482] call_end_reason_type is 6 [03-02_13:04:29:482] call_end_reason_verbose is 113 [03-02_13:04:29:482] try to requestSetupDataCall 60 second later [03-02_13:05:08:745] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:05:10:153] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:05:11:497] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:05:12:681] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:05:14:313] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:05:16:841] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:05:30:505] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe [03-02_13:05:30:505] call_end_reason is 1 [03-02_13:05:30:505] call_end_reason_type is 6 [03-02_13:05:30:505] call_end_reason_verbose is 113 [03-02_13:05:30:505] try to requestSetupDataCall 60 second later [03-02_13:05:33:897] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:05:35:529] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: LTE [03-02_13:05:38:473] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:05:40:106] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:06:31:689] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe [03-02_13:06:31:689] call_end_reason is 1 [03-02_13:06:31:690] call_end_reason_type is 6 [03-02_13:06:31:690] call_end_reason_verbose is 113 [03-02_13:06:31:690] try to requestSetupDataCall 60 second later [03-02_13:07:27:209] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:07:28:713] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:07:32:425] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe [03-02_13:07:32:426] call_end_reason is 1 [03-02_13:07:32:426] call_end_reason_type is 6 [03-02_13:07:32:426] call_end_reason_verbose is 113 [03-02_13:07:32:426] try to requestSetupDataCall 60 second later [03-02_13:08:21:801] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:08:23:145] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:08:33:193] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe [03-02_13:08:33:193] call_end_reason is 3 [03-02_13:08:33:194] call_end_reason_type is 3 [03-02_13:08:33:194] call_end_reason_verbose is 2001 [03-02_13:08:33:194] try to requestSetupDataCall 60 second later [03-02_13:08:40:201] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:08:41:673] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: LTE [03-02_13:09:33:737] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe [03-02_13:09:33:737] call_end_reason is 3 [03-02_13:09:33:737] call_end_reason_type is 3 [03-02_13:09:33:737] call_end_reason_verbose is 2001 [03-02_13:09:33:737] try to requestSetupDataCall 60 second later [03-02_13:09:59:721] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:10:00:937] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:10:07:785] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:10:09:129] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:10:10:377] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:10:11:721] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA [03-02_13:10:34:857] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe [03-02_13:10:34:857] call_end_reason is 1 [03-02_13:10:34:857] call_end_reason_type is 6 [03-02_13:10:34:857] call_end_reason_verbose is 113 [03-02_13:10:34:857] try to requestSetupDataCall 60 second later [03-02_13:11:34:921] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe [03-02_13:11:34:921] call_end_reason is 3 [03-02_13:11:34:921] call_end_reason_type is 3 [03-02_13:11:34:921] call_end_reason_verbose is 2001 [03-02_13:11:34:922] try to requestSetupDataCall 60 second later@John-Nomikos-0 I wonder if this is because we are trying with a sim card that is assigned a static ip address
working with a verison sim:
I wonder if this is just a sim card thing....then again I have no idea what is different with these sim cards
hmmm now i appear to be having the same issues. can not even get wwan0 up anymore.
I did install zerotier so that I could talk to the VOXL2 from QGC. However, I am unsure if that would cause this. I stopped the zerotier software in the meantime -
@wilkinsaf Unfortunately I don't have too much more to recommend in terms of debugging. We haven't tried zerotier before but have had good success with tailscale
@tom I walked into tmobile, got a sim card for $21... works.
I did some reading on quectel modem and think that you have to register the modem mac address through verizon. They do annoying things like that.
At the moment everything is working well. Going to powercycle, but shout out to TMobile. -
I also remembered you referencing some commands for sending AT commands using busybox microcom I believe.
I can not find the forum post, but if you have any documentation (or know where that forum post is) it we be helpful for us. -
I can not find the forum post, but if you have any documentation (or know where that forum post is) it we be helpful for us.JK found it
https://forum.modalai.com/post/4746 (with a link to the quectel AT commands)
https://forum.modalai.com/topic/401/lte-modem-works-but-cannot-ping/23Had to change my search topic to title AND posts
