  3. Quectel 5G Hat errors on voxl-modem, possibly not being detected
voxl-2
17 Posts 3 Posters 3.6k Views 1 Watching
    @tom I would also double check that the quectel modem is fully seated in the PCI slot, and screwed down
    @tom and what do you see with ifconfig, and ls /dev
    • John Nomikos 0J John Nomikos 0
      I do not get the same output. Instead, I get this:
      voxl2:/$ quectel-CM -s soracom.io
      [03-02_12:58:37:688] Quectel_QConnectManager_Linux_V1.6.0.24
      [03-02_12:58:37:690] Find /sys/bus/usb/devices/1-1.1 idVendor=0x2c7c idProduct=0x800, bus=0x001, dev=0x004
      [03-02_12:58:37:692] Auto find qmichannel = /dev/cdc-wdm0
      [03-02_12:58:37:692] Auto find usbnet_adapter = wwan0
      [03-02_12:58:37:692] netcard driver = qmi_wwan, driver version = 22-Aug-2005
      [03-02_12:58:37:693] Modem works in QMI mode
      [03-02_12:58:37:718] /proc/2264/fd/7 -> /dev/cdc-wdm0
      [03-02_12:58:37:718] /proc/2264/exe -> /usr/bin/quectel-CM
      [03-02_12:58:39:720] cdc_wdm_fd = 7
      [03-02_12:59:09:740] QmiWwanInit message timeout
      [03-02_12:59:39:742] QmiWwanGetClientID message timeout
      John Nomikos 0J Offline
      John Nomikos 0
      Oh I did not stop voxl-modem. Here is the actual output:
      [03-02_13:02:47:038] Quectel_QConnectManager_Linux_V1.6.0.24
      [03-02_13:02:47:040] Find /sys/bus/usb/devices/1-1.1 idVendor=0x2c7c idProduct=0x800, bus=0x001, dev=0x004
      [03-02_13:02:47:042] Auto find qmichannel = /dev/cdc-wdm0
      [03-02_13:02:47:042] Auto find usbnet_adapter = wwan0
      [03-02_13:02:47:042] netcard driver = qmi_wwan, driver version = 22-Aug-2005
      [03-02_13:02:47:043] Modem works in QMI mode
      [03-02_13:02:47:062] cdc_wdm_fd = 7
      [03-02_13:02:47:147] Get clientWDS = 2
      [03-02_13:02:47:179] Get clientDMS = 1
      [03-02_13:02:47:211] Get clientNAS = 4
      [03-02_13:02:47:243] Get clientUIM = 1
      [03-02_13:02:47:275] Get clientWDA = 1
      [03-02_13:02:47:307] requestBaseBandVersion RM502QAEAAR11A04M4G
      [03-02_13:02:47:435] requestGetSIMStatus SIMStatus: SIM_READY
      [03-02_13:02:47:435] requestSetProfile[1] soracom.io///0
      [03-02_13:02:47:499] requestGetProfile[1] soracom.io///0
      [03-02_13:02:47:530] requestRegistrationState2 MCC: 310, MNC: 410, PS: Detached, DataCap: UNKNOW
      [03-02_13:02:47:563] requestQueryDataCall IPv4ConnectionStatus: DISCONNECTED
      [03-02_13:02:47:563] ifconfig wwan0 0.0.0.0
      [03-02_13:02:47:580] ifconfig wwan0 down
      Also the hat is not screwed down, that is something I could try.
      Here's what I see with ifconfig:
      voxl2:/$ ifconfig
      bond0: flags=5123<UP,BROADCAST,MASTER,MULTICAST>  mtu 1500
              ether 22:f7:00:43:64:34  txqueuelen 1000  (Ethernet)
              RX packets 0  bytes 0 (0.0 B)
              TX packets 0  bytes 0 (0.0 B)
      dummy0: flags=195<UP,BROADCAST,RUNNING,NOARP>  mtu 1500
              inet6 fe80::b6fc:7109:8dd5:7c6c  prefixlen 64  scopeid 0x20<link>
              ether 16:30:4b:20:ed:31  txqueuelen 1000  (Ethernet)
              TX packets 15  bytes 4042 (4.0 KB)
              RX packets 307856  bytes 32852320 (32.8 MB)
              TX packets 307856  bytes 32852320 (32.8 MB)
      Here is what ls /dev shows:
      voxl2:/$ ls /dev
      6002000.stm         cvp        i2c-4         loop3             msm_amrwbplus    network_latency            ram5                 ramdump_microdump_modem  sda8   sde16  sde35  sde54  sensors     spidev3.0        tty12  tty31  tty50   ttyHS3        v4l-subdev4  vcsu1
      adsprpc-smd         dcc_sram   iio:device0   loop4             msm_ape          network_throughput         ram6                 ramdump_npu              sda9   sde17  sde36  sde55  serial      spss_utils       tty13  tty32  tty51   ttyUSB0       v4l-subdev5  vcsu2
      adsprpc-smd-secure  diag       iio:device1   loop5             msm_audio_cal    null                       ram7                 ramdump_slpi             sdb    sde18  sde37  sde56  sg0         stderr           tty14  tty33  tty52   ttyUSB1       v4l-subdev6  vcsu3
      android_mbim        disk       iio:device2   loop6             msm_evrc         ppp                        ram8                 ramdump_spss             sdb1   sde19  sde38  sde57  sg1         stdin            tty15  tty34  tty53   ttyUSB2       v4l-subdev7  vcsu4
      ashmem              dpl_ctrl   initctl       loop7             msm_evrc_in      ptmx                       ram9                 ramdump_venus            sdb2   sde2   sde39  sde58  sg2         stdout           tty16  tty35  tty54   ttyUSB3       v4l-subdev8  vcsu5
      at_usb0             dri        input         loop8             msm_g711alaw     pts                        ramdump_a650_zap     random                   sdc    sde20  sde4   sde59  sg3         subsys_a650_zap  tty17  tty36  tty55   uhid          v4l-subdev9  vcsu6
      at_usb1             ecryptfs   ion           loop9             msm_g711alaw_in  qce                        ramdump_adsp         rebooterdev              sdc1   sde21  sde40  sde6   sg4         subsys_adsp      tty18  tty37  tty56   uinput        vcs          vga_arbiter
      avtimer             fd         kgsl-3d0      mapper            msm_g711mlaw     qsee_ipc_irq_spss          ramdump_cdsp         rfkill                   sdc2   sde22  sde41  sde60  sg5         subsys_cdsp      tty19  tty38  tty57   urandom       vcs1         video0
      binder              full       kmsg          media0            msm_g711mlaw_in  qseecom                    ramdump_cvpss        rmnet_ctrl               sdd    sde23  sde42  sde7   sg6         subsys_cvpss     tty2   tty39  tty58   usb-ffs       vcs2         video1
      block               fuse       lightnvm      media1            msm_hdcp         qvr_external_sensor_ioctl  ramdump_ipa_fws      rpmsg_ctrl0              sdd1   sde24  sde43  sde8   sg7         subsys_ipa_fws   tty20  tty4   tty59   usf1          vcs3         video32
      bsg                 gpiochip0  log           mem               msm_hweffects    ram0                       ramdump_ipa_uc       rpmsg_ctrl1              sdd2   sde25  sde44  sde9   sg8         subsys_ipa_uc    tty21  tty40  tty6    v4l-subdev0   vcs4         video33
      btpower             gpiochip1  loop-control  memory_bandwidth  msm_mp3          ram1                       ramdump_md_a650_zap  rtc                      sdd3   sde26  sde45  sdf    shm         subsys_npu       tty22  tty41  tty60   v4l-subdev1   vcs5         vndbinder
      btrfs-control       gpiochip2  loop0         mqueue            msm_multi_aac    ram10                      ramdump_md_adsp      rtc0                     sdd4   sde27  sde46  sdf1   smcinvoke   subsys_slpi      tty23  tty42  tty61   v4l-subdev10  vcs6         voxl_b2b
      bus                 gpiochip3  loop1         msm-rng           msm_npu          ram11                      ramdump_md_cdsp      sda                      sde    sde28  sde47  sdf2   snd         subsys_spss      tty24  tty43  tty62   v4l-subdev11  vcsa         voxl_rc_in
      byte-cntr           gpiochip4  loop10        msm_aac           msm_qcelp        ram12                      ramdump_md_cvpss     sda1                     sde1   sde29  sde48  sdf3   socket      subsys_venus     tty25  tty44  tty63   v4l-subdev12  vcsa1        zero
      cdc-wdm0            hwbinder   loop11        msm_aac_in        msm_qcelp_in     ram13                      ramdump_md_ipa_fws   sda2                     sde10  sde3   sde49  sdf4   sp_kernel   synx_device      tty26  tty45  tty7    v4l-subdev13  vcsa2        zram0
      char                hwrng      loop12        msm_alac          msm_rtac         ram14                      ramdump_md_ipa_uc    sda3                     sde11  sde30  sde5   sdf5   sp_ssr      tty              tty27  tty46  tty8    v4l-subdev14  vcsa3
      console             i2c-0      loop13        msm_amrnb         msm_sps          ram15                      ramdump_md_npu       sda4                     sde12  sde31  sde50  sdf6   spcom       tty0             tty28  tty47  tty9    v4l-subdev15  vcsa4
      coresight-tmc-etf   i2c-1      loop14        msm_amrnb_in      msm_wma          ram2                       ramdump_md_slpi      sda5                     sde13  sde32  sde51  sdf7   spidev0.0   tty1             tty29  tty48  ttyHS0  v4l-subdev16  vcsa5
      coresight-tmc-etr   i2c-2      loop15        msm_amrwb         msm_wmapro       ram3                       ramdump_md_spss      sda6                     sde14  sde33  sde52  sdf8   spidev11.0  tty10            tty3   tty49  ttyHS1  v4l-subdev2   vcsa6
      cpu_dma_latency     i2c-3      loop2         msm_amrwb_in      net              ram4                       ramdump_md_venus     sda7                     sde15  sde34  sde53  sdf9   spidev14.0  tty11            tty30  tty5   ttyHS2  v4l-subdev3   vcsu
        voxl2:/$ ifconfig
        voxl2:/$ ls /dev
        @John-Nomikos-0 I do see the /dev/ttyUSB* and /dev/cdc-wdm0 interfaces I expect, which is good, but not the wwan0 interface in ifconfig
        That output from quectel-CM is making me think that cellular network isn't happy, have you had success with this SIM card and a quectel modem before?
        Do you have a different SIM card on a different network you could test with?
        Also, do you have all 4 antennas connected to the quectel modem?
        John Nomikos 0J 1 Reply Last reply
          John Nomikos 0
          wrote on last edited by John Nomikos 0
          You were correct. It turns out that we did not have a plan with the SIM card I was using. So I switched to a working SIM card that we were using on a ZTE stick before.
          Now when I run quectel-CM -s $APN, I get this output:
          voxl2:/$ quectel-CM -s iot.tmowholesale.static
          [03-02_13:01:39:023] Quectel_QConnectManager_Linux_V1.6.0.24
          [03-02_13:01:39:025] Find /sys/bus/usb/devices/1-1.1 idVendor=0x2c7c idProduct=0x800, bus=0x001, dev=0x004
          [03-02_13:01:39:027] Auto find qmichannel = /dev/cdc-wdm0
          [03-02_13:01:39:027] Auto find usbnet_adapter = wwan0
          [03-02_13:01:39:027] netcard driver = qmi_wwan, driver version = 22-Aug-2005
          [03-02_13:01:39:028] Modem works in QMI mode
          [03-02_13:01:39:052] cdc_wdm_fd = 7
          [03-02_13:01:39:141] Get clientWDS = 5
          [03-02_13:01:39:173] Get clientDMS = 1
          [03-02_13:01:39:205] Get clientNAS = 4
          [03-02_13:01:39:237] Get clientUIM = 1
          [03-02_13:01:39:269] Get clientWDA = 1
          [03-02_13:01:39:301] requestBaseBandVersion RM502QAEAAR11A04M4G
          [03-02_13:01:39:429] requestGetSIMStatus SIMStatus: SIM_READY
          [03-02_13:01:39:429] requestSetProfile[1] iot.tmowholesale.static///0
          [03-02_13:01:39:493] requestGetProfile[1] iot.tmowholesale.static///0
          [03-02_13:01:39:525] requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
          [03-02_13:01:39:557] requestQueryDataCall IPv4ConnectionStatus: DISCONNECTED
          [03-02_13:01:39:557] ifconfig wwan0 0.0.0.0
          [03-02_13:01:39:573] ifconfig wwan0 down
          [03-02_13:02:06:437] requestRegistrationState2 MCC: 310, MNC: 260, PS: Detached, DataCap: UNKNOW
          [03-02_13:02:06:469] requestRegistrationState2 MCC: 310, MNC: 260, PS: Detached, DataCap: UNKNOW
          [03-02_13:02:09:765] requestRegistrationState2 MCC: 310, MNC: 260, PS: Detached, DataCap: UNKNOW
          [03-02_13:02:32:133] requestRegistrationState2 MCC: 310, MNC: 260, PS: Detached, DataCap: UNKNOW
          [03-02_13:02:35:365] requestRegistrationState2 MCC: 310, MNC: 260, PS: Detached, DataCap: UNKNOW
          And ifconfig shows this: (before I run the command above, after I run it wwan0 goes away)
          voxl2:/$ ifconfig
                  ether 8e:62:c9:ae:cb:5e  txqueuelen 1000  (Ethernet)
                  inet6 fe80::f942:3eee:119e:32f0  prefixlen 64  scopeid 0x20<link>
                  ether 4a:91:5e:0b:29:d0  txqueuelen 1000  (Ethernet)
                  TX packets 4  bytes 824 (824.0 B)
                  RX packets 80  bytes 5920 (5.9 KB)
                  TX packets 80  bytes 5920 (5.9 KB)
          wwan0: flags=4291<UP,BROADCAST,RUNNING,NOARP,MULTICAST>  mtu 1500
                  inet6 fe80::f1eb:2024:d885:26f4  prefixlen 64  scopeid 0x20<link>
                  ether 7a:2d:dc:62:b9:84  txqueuelen 1000  (Ethernet)
          Pinging 8.8.8.8 shows 100% packet loss.
          Also, doing systemctl status on voxl-modem shows the same output as before.
          I do have all 4 antennas connected.
            voxl2:/$ ifconfig
            John Nomikos 0
            I tried with a different SIM card, since I believe the issue had to do with that specific SIM.
            This one actually goes through the dialing process which seems good. However, no connection is being established.
            Output:
            voxl2:/$ quectel-CM -s vzwinternet
            [03-02_13:00:11:484] Quectel_QConnectManager_Linux_V1.6.0.24
            [03-02_13:00:11:486] Find /sys/bus/usb/devices/1-1.1 idVendor=0x2c7c idProduct=0x800, bus=0x001, dev=0x004
            [03-02_13:00:11:488] Auto find qmichannel = /dev/cdc-wdm0
            [03-02_13:00:11:488] Auto find usbnet_adapter = wwan0
            [03-02_13:00:11:488] netcard driver = qmi_wwan, driver version = 22-Aug-2005
            [03-02_13:00:11:489] Modem works in QMI mode
            [03-02_13:00:11:515] cdc_wdm_fd = 7
            [03-02_13:00:11:593] Get clientWDS = 2
            [03-02_13:00:11:625] Get clientDMS = 1
            [03-02_13:00:11:657] Get clientNAS = 4
            [03-02_13:00:11:689] Get clientUIM = 1
            [03-02_13:00:11:721] Get clientWDA = 1
            [03-02_13:00:11:753] requestBaseBandVersion RM502QAEAAR11A04M4G
            [03-02_13:00:11:881] requestGetSIMStatus SIMStatus: SIM_READY
            [03-02_13:00:11:881] requestSetProfile[1] vzwinternet///0
            [03-02_13:00:11:945] requestGetProfile[1] vzwinternet///0
            [03-02_13:00:11:977] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:00:12:009] requestQueryDataCall IPv4ConnectionStatus: DISCONNECTED
            [03-02_13:00:12:009] ifconfig wwan0 0.0.0.0
            [03-02_13:00:12:027] ifconfig wwan0 down
            [03-02_13:00:12:265] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
            [03-02_13:00:12:265] call_end_reason is 1
            [03-02_13:00:12:265] call_end_reason_type is 6
            [03-02_13:00:12:265] call_end_reason_verbose is 113
            [03-02_13:00:12:266] try to requestSetupDataCall 5 second later
            [03-02_13:00:17:289] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
            [03-02_13:00:17:289] call_end_reason is 3
            [03-02_13:00:17:289] call_end_reason_type is 3
            [03-02_13:00:17:289] call_end_reason_verbose is 2001
            [03-02_13:00:17:289] try to requestSetupDataCall 10 second later
            [03-02_13:00:27:337] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
            [03-02_13:00:27:337] call_end_reason is 3
            [03-02_13:00:27:337] call_end_reason_type is 3
            [03-02_13:00:27:338] call_end_reason_verbose is 2001
            [03-02_13:00:27:338] try to requestSetupDataCall 20 second later
            [03-02_13:00:27:497] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:00:28:873] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:00:33:161] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:00:34:633] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:00:36:201] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:00:37:609] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:00:47:657] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
            [03-02_13:00:47:657] call_end_reason is 3
            [03-02_13:00:47:658] call_end_reason_type is 3
            [03-02_13:00:47:658] call_end_reason_verbose is 2001
            [03-02_13:00:47:658] try to requestSetupDataCall 40 second later
            [03-02_13:00:49:257] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:00:50:697] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:00:53:673] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:00:55:209] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:00:56:425] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:00:57:641] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:01:00:393] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:01:01:769] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:01:08:521] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:01:09:673] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:01:23:593] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:01:25:097] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:01:28:329] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
            [03-02_13:01:28:329] call_end_reason is 1
            [03-02_13:01:28:330] call_end_reason_type is 6
            [03-02_13:01:28:330] call_end_reason_verbose is 113
            [03-02_13:01:28:330] try to requestSetupDataCall 60 second later
            [03-02_13:01:30:313] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:01:31:561] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:01:34:345] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:01:35:593] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:01:39:977] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:01:41:577] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:01:43:241] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: LTE
            [03-02_13:01:44:745] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: LTE
            [03-02_13:01:46:090] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:01:47:753] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:01:49:257] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: LTE
            [03-02_13:01:51:817] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:01:57:417] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:02:11:497] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:02:13:961] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:02:15:177] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:02:17:641] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:02:19:017] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:02:20:233] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:02:27:401] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:02:28:425] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
            [03-02_13:02:28:425] call_end_reason is 3
            [03-02_13:02:28:426] call_end_reason_type is 3
            [03-02_13:02:28:426] call_end_reason_verbose is 2001
            [03-02_13:02:28:427] try to requestSetupDataCall 60 second later
            [03-02_13:02:28:809] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:02:30:249] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: LTE
            [03-02_13:02:37:545] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:02:38:761] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:02:45:993] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:02:47:561] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:02:55:817] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:02:57:065] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:03:01:513] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:03:03:081] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:03:04:329] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:03:06:985] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:03:18:281] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:03:19:657] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: LTE
            [03-02_13:03:21:161] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:03:22:281] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:03:26:345] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:03:27:529] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:03:28:553] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
            [03-02_13:03:28:554] call_end_reason is 3
            [03-02_13:03:28:554] call_end_reason_type is 3
            [03-02_13:03:28:554] call_end_reason_verbose is 2001
            [03-02_13:03:28:554] try to requestSetupDataCall 60 second later
            [03-02_13:03:31:721] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:03:33:321] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:03:34:729] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:03:36:361] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:03:42:345] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:03:45:545] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:03:48:554] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:03:49:802] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:04:00:841] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:04:02:281] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:04:29:481] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
            [03-02_13:04:29:482] call_end_reason is 1
            [03-02_13:04:29:482] call_end_reason_type is 6
            [03-02_13:04:29:482] call_end_reason_verbose is 113
            [03-02_13:04:29:482] try to requestSetupDataCall 60 second later
            [03-02_13:05:08:745] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:05:10:153] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:05:11:497] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:05:12:681] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:05:14:313] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:05:16:841] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:05:30:505] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
            [03-02_13:05:30:505] call_end_reason is 1
            [03-02_13:05:30:505] call_end_reason_type is 6
            [03-02_13:05:30:505] call_end_reason_verbose is 113
            [03-02_13:05:30:505] try to requestSetupDataCall 60 second later
            [03-02_13:05:33:897] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:05:35:529] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: LTE
            [03-02_13:05:38:473] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:05:40:106] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:06:31:689] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
            [03-02_13:06:31:689] call_end_reason is 1
            [03-02_13:06:31:690] call_end_reason_type is 6
            [03-02_13:06:31:690] call_end_reason_verbose is 113
            [03-02_13:06:31:690] try to requestSetupDataCall 60 second later
            [03-02_13:07:27:209] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:07:28:713] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:07:32:425] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
            [03-02_13:07:32:426] call_end_reason is 1
            [03-02_13:07:32:426] call_end_reason_type is 6
            [03-02_13:07:32:426] call_end_reason_verbose is 113
            [03-02_13:07:32:426] try to requestSetupDataCall 60 second later
            [03-02_13:08:21:801] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:08:23:145] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:08:33:193] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
            [03-02_13:08:33:193] call_end_reason is 3
            [03-02_13:08:33:194] call_end_reason_type is 3
            [03-02_13:08:33:194] call_end_reason_verbose is 2001
            [03-02_13:08:33:194] try to requestSetupDataCall 60 second later
            [03-02_13:08:40:201] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:08:41:673] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: LTE
            [03-02_13:09:33:737] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
            [03-02_13:09:33:737] call_end_reason is 3
            [03-02_13:09:33:737] call_end_reason_type is 3
            [03-02_13:09:33:737] call_end_reason_verbose is 2001
            [03-02_13:09:33:737] try to requestSetupDataCall 60 second later
            [03-02_13:09:59:721] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:10:00:937] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:10:07:785] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:10:09:129] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:10:10:377] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:10:11:721] requestRegistrationState2 MCC: 311, MNC: 480, PS: Attached, DataCap: 5G_NSA
            [03-02_13:10:34:857] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
            [03-02_13:10:34:857] call_end_reason is 1
            [03-02_13:10:34:857] call_end_reason_type is 6
            [03-02_13:10:34:857] call_end_reason_verbose is 113
            [03-02_13:10:34:857] try to requestSetupDataCall 60 second later
            [03-02_13:11:34:921] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
            [03-02_13:11:34:921] call_end_reason is 3
            [03-02_13:11:34:921] call_end_reason_type is 3
            [03-02_13:11:34:921] call_end_reason_verbose is 2001
            [03-02_13:11:34:922] try to requestSetupDataCall 60 second later
            wilkinsafW 1 Reply Last reply
              Output:
              wilkinsafW Offline
              wilkinsafW Offline
              wilkinsaf
              @John-Nomikos-0 I wonder if this is because we are trying with a sim card that is assigned a static ip address
              • wilkinsafW wilkinsaf
                wilkinsafW Offline
                wilkinsafW Offline
                wilkinsaf
                working with a verison sim:
                  wilkinsafW Offline
                  wilkinsafW Offline
                  wilkinsaf
                  I wonder if this is just a sim card thing....then again I have no idea what is different with these sim cards
                    wilkinsafW Offline
                    wilkinsafW Offline
                    wilkinsaf
                    hmmm now i appear to be having the same issues. can not even get wwan0 up anymore.
                    I did install zerotier so that I could talk to the VOXL2 from QGC. However, I am unsure if that would cause this. I stopped the zerotier software in the meantime
                      @wilkinsaf Unfortunately I don't have too much more to recommend in terms of debugging. We haven't tried zerotier before but have had good success with tailscale
                      wilkinsafW 2 Replies Last reply
                        wilkinsafW Offline
                        wilkinsafW Offline
                        wilkinsaf
                        @tom I walked into tmobile, got a sim card for $21... works.
                        I did some reading on quectel modem and think that you have to register the modem mac address through verizon. They do annoying things like that.
                        At the moment everything is working well. Going to powercycle, but shout out to TMobile.
                          wilkinsafW Offline
                          wilkinsafW Offline
                          wilkinsaf
                          I also remembered you referencing some commands for sending AT commands using busybox microcom I believe.
                          I can not find the forum post, but if you have any documentation (or know where that forum post is) it we be helpful for us.
                            wilkinsafW Offline
                            wilkinsafW Offline
                            wilkinsaf
                            JK found it
                            https://forum.modalai.com/post/4746 (with a link to the quectel AT commands)
                            https://forum.modalai.com/topic/401/lte-modem-works-but-cannot-ping/23
                            Had to change my search topic to title AND posts
