    QGC Not Connecting to the Sentinel
    1343
    • Raza RizviR
      Raza Rizvi
      Hello, I am following this QuickStart Guide, but my QGC is unable to connect to the Sentinel drone.
      1. The drone is successfully connected to the WiFi
      ifconfig # On the Drone
      ifconfig # On the Host Laptop
      1. I can Ping from the drone to my Host laptop, and vice-versa
      1. I mentioned the Host IP Address inside the voxl-vision-px4.conf
      Still, when running the QGC on Host, it shows disconnected
      • Adrian HidalgoA
        Adrian Hidalgo ModalAI Team
        @Raza-Rizvi can you make sure that there's no firewall setup blocking the connection.
        Could you also provide the output of
        systemctl status -l voxl-vision-px4
        Raza RizviR 1 Reply Last reply Reply Quote 0
        • Raza RizviR
          Raza Rizvi @Adrian Hidalgo
          @Adrian-Hidalgo
          Yes, the firewall is disabled.
          Here's the output to the mentioned command:
          The mavlink server is also running
          • Adrian HidalgoA
            @Raza-Rizvi are you connected over softap or station?
            Can you ssh into the drone?
            • Raza RizviR
              @Adrian-Hidalgo
              I am connected over station. And Yes, I can SSH to the drone.
              • tomT
                tom admin
                @Raza-Rizvi Please post the output of “voxl-inspect-services” and “voxl-version”
                • Raza RizviR
                  Raza Rizvi @tom
                  @tom
                  • tomT
                    tom admin
                    @Raza-Rizvi That error message "voxl-mavlink-server does not appear to be running" isn't normal. You may want to run through voxl-configure-mpa again, set your host IP in voxl-vision-px4.conf, then reboot your drone.
