  3. VOXL2 not arming
VOXL2 not arming
18 Posts 3 Posters 2.4k Views 1 Watching
  • yashas katteY Offline
    yashas katte
    wrote on last edited by yashas katte
    hello , I have bought VOXL2 , I have setup voxl-vission-px4 and connected the modal ai 's esc to the board.
    The Qgroundcontrol is able to connect to the voxl2 but i am not able to run motor tests (they are not running). The compass is not calibrating when a UBlox m8n gps. All the mpa services are running but I am not able to arm the board.
    If i disable the compass in qgc, then arm it . i get a message that mav_cmd has rejected arming request.
    Pls respond asap , I am not sure where i have gone wrong.
    • Adrian HidalgoA Offline
      Adrian Hidalgo
      @yashas-katte I would suggest looking at our technical docs
      • yashas katteY yashas katte
        @yashas-katte Please also look at PX4 documentation and QGroundControl documentation. You should be able to figure out the reason for arm failure using QGroundControl. Which GPS unit did you plug in? UBlox m8n is a GNSS part and doesn't have a compass (magnetometer) on it's own. But those are usually packaged up into a GPS unit that does include a compass. For example we usually use the Holybro Pixhawk 4 unit that has GPS, compass, and LED integrated together. And how did you try to run the motor test? Is it via the motor tab in QGC? Yes, that doesn't work. But you should be able to spin the motors using px4 commands directly on target. Please make sure you remove the propellers from the motors before doing any such test!
          yashas katte
          Hello, Thanks for such fast response.
          I re flashed voxl2 , connected the motors , and crsf rc.
          The rc is able to bind (as it showing green light) but in qgc , it tells RC RSSI is unavailable.
          The connection has been refred to by https://docs.modalai.com/voxl2-rc-configs/
          I will move on to gps/mag once this gets fixed.
          Thanks in advance
            Thanks in advance
            @yashas-katte Can you tell us more about what you are trying to do? Are you building a custom drone with VOXL2? What RC receiver are you using and what port are you connecting it to?
              yashas katte
              Yes , I trying to build a custom with VOXl2. I am trying to using a TBS crossfire in mavlink mode.
              The ports i am using is the same as proivided in the documentation for crossfire recvier
              The RC is able to bind to the transmitter TBS Tango , but Qgc shows RC RSSI in unavailble.
              Even px4-listener input_rc , shows output never published.
              I want to know where I have gone wrong , Pls help
                @yashas-katte You can bind to the receiver if it has power, even if there is no connection over the UART. Let's start with the TBS Crossfire receiver in Mavlink mode. What driver are you using on VOXL2 to interact with the receiver? The recveiver will not send any Mavlink packets on the UART unless it sees Mavlink heartbeat packets coming from the VOXL2. Can you put an oscilloscope on the VOXL2 Tx line and verify that it is transmitting packets?
                  yashas katte
                  I don't understand how to use the drivers , the link provided in the docs is depreciated.
                  I checked with oscilloscope on Voxl2 TX : we got heartbeat packets. but input_rc is never published.
                  This oscliscope's output:
                  Pls help , Thanks in advance
                    @yashas-katte Okay, that's a good start. Are you autostarting px4 using the /etc/systemd/system/voxl-px4.service? There are certain options you can provide to the voxl-px4 start script to specify which drivers are started. Can you tell me what options are provided to voxl-px4 in your case?
                      @yashas-katte Also, can you now look at the RX line on VOXL2 to see if the receiver is trying to send anything back?
                        yashas katte
                        There is nothing coming through the RX pin. I launched VOXL-PX4 manually after disabling mavlink server and voxl-px4.
                        When I set csrf to mavlink mode , there is no error in px4 terminal. But there is no rc_input(never published).
                        Same result with ppm also. when set at sbus , ibus , dsmx modes.
                        Also , I get an error saying PX4-IO failed to detect.
                        I am assuming that only works with we have IO expander board which we are not using currently.
                        Is that the problem?
                          @yashas-katte To use a TBS Crossfire receiver in Mavlink mode you start px4 with the command voxl-px4 -r where the -r option specifies the mavlink option. Take a look at the file /usr/bin/voxl-px4 to see how it operates. It is just a bash script. Also, it uses the file /etc/modalai/voxl-px4.config to do the actual startup. Can you manually start with voxl-px4 -r from the command line and then post all of the output you get from px4? Also, there are a number of configuration options with the TBS Crossfire receiver. You have to make sure that the pins are configured correctly for it to work with PX4. If PX4 is sending out the mavlink heartbeat message to the receiver and it is not responding then I would suspect that the receiver hasn't been configured correctly.
                            yashas katte
                            This -r flag worked I am able to rc data! , I edited the service file to add -r.
                            But I am facing another issue.
                            The connection between Qgrouncontrol keeps getting dropped and connected again.
                            I have set voxl-configure-mpa --factory-reset.
                            As I had to disable those when I run voxl-px4 manually.
                            Is there something wrong there?
                            voxl2:/$ voxl-px4 -r
                            Found DSP signature file
                            ______  __   __    ___
                            | ___ \ \ \ / /   /   |
                            | |_/ /  \ V /   / /| |
                            |  __/   /   \  / /_| |
                            | |     / /^\ \ \___  |
                            \_|     \/   \/     |_/
                            px4 starting.
                            INFO  [px4] Calling startup script: /bin/sh /etc/modalai/voxl-px4.config 0
                            Running on M0054
                            INFO  [muorb] SLPI: Creating qurt thread hpwork
                            INFO  [muorb] SLPI: Successfully created px4 task PX4_hpwork with tid 83
                            INFO  [muorb] SLPI: Creating qurt thread lpwork
                            INFO  [muorb] SLPI: Successfully created px4 task PX4_lpwork with tid 82
                            INFO  [muorb] SLPI: Creating qurt thread wkr_hrt
                            INFO  [muorb] SLPI: Successfully created px4 task PX4_wkr_hrt with tid 81
                            INFO  [muorb] SLPI: Creating qurt thread client_sync_thread
                            INFO  [muorb] SLPI: Successfully created px4 task PX4_client_sync_thread with tid 80
                            INFO  [muorb] SLPI: Creating qurt thread wq_manager
                            INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_manager with tid 79
                            INFO  [muorb] SLPI: Creating qurt thread qshell
                            INFO  [muorb] SLPI: Successfully created px4 task PX4_qshell with tid 78
                            INFO  [qshell] Send cmd: 'icm42688p start -s'
                            INFO  [muorb] SLPI: qshell gotten: icm42688p start -s
                            INFO  [muorb] SLPI: Creating qurt thread wq_SPI1
                            INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_SPI1 with tid 77
                            INFO  [muorb] SLPI: *** SPI Device ID 0x26000a 2490378
                            INFO  [uorb] Advertising remote topic sensor_accel
                            INFO  [uorb] Marking DeviceNode(parameter_server_set_used_request) as advertised in process_remote_topic
                            INFO  [muorb] SLPI: Marking DeviceNode(parameter_server_set_used_response) as advertised in process_remote_to
                            INFO  [uorb] Advertising remote topic sensor_gyro
                            INFO  [uorb] Advertising remote topic imu_server
                            INFO  [muorb] SLPI: on SPI bus 1
                            INFO  [muorb] SLPI: icm42688p #0 on SPI bus 1 (devid=0x0)
                            INFO  [muorb] SLPI:
                            INFO  [muorb] SLPI: Ok executing command: icm42688p start -s
                            INFO  [muorb] SLPI: Sending qshell retval with timestamp 49225949, current timestamp 49225949
                            INFO  [uorb] Advertising remote topic qshell_retval
                            INFO  [qshell] qshell return value timestamp: 49225949, local time: 49231289
                            INFO  [muorb] SLPI: Marking DeviceNode(parameter_client_reset_request) as advertised in process_remote_topic
                            ERROR [muorb] SLPI: Cannot reset all parameters on client side
                            INFO  [uorb] Marking DeviceNode(parameter_client_reset_response) as advertised in process_remote_topic
                            INFO  [muorb] SLPI: Advertising remote topic parameter_update
                            INFO  [muorb] SLPI: Marking DeviceNode(parameter_client_set_value_request) as advertised in process_remote_to
                            INFO  [uorb] Marking DeviceNode(parameter_client_set_value_response) as advertised in process_remote_topic
                            INFO  [logger] logger started (mode=all)
                            Starting Holybro magnetometer
                            INFO  [qshell] Send cmd: 'ist8310 start -R 10 -X -b 1'
                            INFO  [muorb] SLPI: qshell gotten: ist8310 start -R 10 -X -b 1
                            INFO  [muorb] SLPI: Creating qurt thread wq_I2C1
                            INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_I2C1 with tid 76
                            INFO  [muorb] SLPI: *** I2C Device ID 0x60e09 396809
                            ERROR [muorb] SLPI: i2c probe failed
                            ERROR [muorb] SLPI: Failed to execute command: ist8310 start -R 10 -X -b 1
                            INFO  [muorb] SLPI: Sending qshell retval with timestamp 51937708, current timestamp 51937709
                            INFO  [qshell] cmd returned with: -1
                            INFO  [qshell] qshell return value timestamp: 51937708, local time: 51939344
                            ERROR [qshell] Command failed
                            Starting Holybro LED driver
                            INFO  [qshell] Send cmd: 'rgbled_ncp5623c start -X -b 1 -f 400 -a 56'
                            INFO  [muorb] SLPI: qshell gotten: rgbled_ncp5623c start -X -b 1 -f 400 -a 56
                            INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_I2C1 with tid 4172
                            INFO  [muorb] SLPI: *** I2C Device ID 0x7b3809 8075273
                            ERROR [muorb] SLPI: Failed to execute command: rgbled_ncp5623c start -X -b 1 -f 400 -a 56
                            INFO  [muorb] SLPI: Sending qshell retval with timestamp 51984318, current timestamp 51984320
                            INFO  [qshell] qshell return value timestamp: 51984318, local time: 51986095
                            INFO  [qshell] Send cmd: 'icp10100 start -I -b 5'
                            INFO  [muorb] SLPI: qshell gotten: icp10100 start -I -b 5
                            INFO  [muorb] SLPI: Creating qurt thread wq_I2C5
                            INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_I2C5 with tid 8268
                            INFO  [muorb] SLPI: *** I2C Device ID 0x9c6329 10249001
                            INFO  [muorb] SLPI: probe probe succeeded. data = 0x1 0x48
                            INFO  [muorb] SLPI: icp10100 #0 on I2C bus 5
                            INFO  [muorb] SLPI: Ok executing command: icp10100 start -I -b 5
                            INFO  [muorb] SLPI: Sending qshell retval with timestamp 52031607, current timestamp 52031609
                            INFO  [qshell] qshell return value timestamp: 52031607, local time: 52033362
                            INFO  [qshell] Send cmd: 'modalai_esc start'
                            INFO  [uorb] Advertising remote topic sensor_baro
                            INFO  [muorb] SLPI: qshell gotten: modalai_esc start
                            INFO  [muorb] SLPI: Creating qurt thread wq_hp_default
                            INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_hp_default with tid 75
                            INFO  [uorb] Advertising remote topic test_motor
                            INFO  [muorb] SLPI: Ok executing command: modalai_esc start
                            INFO  [muorb] SLPI: Sending qshell retval with timestamp 52107976, current timestamp 52107978
                            INFO  [muorb] SLPI: Opened UART ESC device
                            INFO  [qshell] qshell return value timestamp: 52107976, local time: 52109827
                            INFO  [qshell] Send cmd: 'mixer load /dev/uart_esc quad_x.main.mix'
                            INFO  [muorb] SLPI: qshell gotten: mixer load /dev/uart_esc quad_x.main.mix
                            INFO  [muorb] SLPI: Creating qurt thread wq_rate_ctrl
                            INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_rate_ctrl with tid 73
                            INFO  [muorb] SLPI: Ok executing command: mixer load /dev/uart_esc quad_x.main.mix
                            INFO  [muorb] SLPI: Sending qshell retval with timestamp 52178454, current timestamp 52178456
                            INFO  [qshell] qshell return value timestamp: 52178454, local time: 52181721
                            INFO  [uorb] Advertising remote topic actuator_outputs
                            INFO  [uorb] Advertising remote topic multirotor_motor_limits
                            INFO  [qshell] Send cmd: 'voxlpm start -X -b 2'
                            INFO  [muorb] SLPI: qshell gotten: voxlpm start -X -b 2
                            INFO  [muorb] SLPI: Creating qurt thread wq_I2C2
                            INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_I2C2 with tid 4171
                            INFO  [muorb] SLPI: *** I2C Device ID 0x784411 7881745
                            INFO  [uorb] Advertising remote topic battery_status
                            INFO  [muorb] SLPI: voxlpm #0 on I2C bus 2 (external)
                            INFO  [muorb] SLPI: Ok executing command: voxlpm start -X -b 2
                            INFO  [muorb] SLPI: Sending qshell retval with timestamp 52248695, current timestamp 52248698
                            INFO  [qshell] qshell return value timestamp: 52248695, local time: 52250854
                            INFO  [uorb] Advertising remote topic power_monitor
                            Starting Holybro GPS
                            INFO  [qshell] Send cmd: 'gps start -d 7 -b 115200'
                            INFO  [muorb] SLPI: qshell gotten: gps start -d 7 -b 115200
                            INFO  [muorb] SLPI: Creating qurt thread gps
                            INFO  [muorb] SLPI: Successfully created px4 task PX4_gps with tid 72
                            INFO  [muorb] SLPI: Ok executing command: gps start -d 7 -b 115200
                            INFO  [muorb] SLPI: Sending qshell retval with timestamp 52317126, current timestamp 52317128
                            INFO  [qshell] qshell return value timestamp: 52317126, local time: 52318912
                            Starting TBS crossfire RC - MAV Mode
                            INFO  [qshell] Send cmd: 'tbs_crossfire start -m -p 7 -b 115200'
                            INFO  [muorb] SLPI: qshell gotten: tbs_crossfire start -m -p 7 -b 115200
                            INFO  [muorb] SLPI: Creating qurt thread tbs_crossfire_main
                            INFO  [muorb] SLPI: Successfully created px4 task PX4_tbs_crossfire_main with tid 70
                            INFO  [muorb] SLPI: Ok executing command: tbs_crossfire start -m -p 7 -b 115200
                            INFO  [muorb] SLPI: Sending qshell retval with timestamp 52348137, current timestamp 52348139
                            INFO  [muorb] SLPI: Creating qurt thread tbs_crossfire_mav
                            INFO  [muorb] SLPI: Successfully created px4 task PX4_tbs_crossfire_mav with tid 69
                            INFO  [qshell] qshell return value timestamp: 52348137, local time: 52351007
                            INFO  [qshell] Send cmd: 'sensors start'
                            INFO  [muorb] SLPI: qshell gotten: sensors start
                            INFO  [muorb] SLPI: Creating qurt thread wq_nav_and_controllers
                            INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_nav_and_controllers with tid 67
                            INFO  [uorb] Advertising remote topic vehicle_acceleration
                            INFO  [muorb] SLPI: Ok executing command: sensors start
                            INFO  [muorb] SLPI: Sending qshell retval with timestamp 53436075, current timestamp 53436077
                            INFO  [uorb] Advertising remote topic vehicle_angular_acceleration
                            INFO  [uorb] Advertising remote topic vehicle_angular_velocity
                            INFO  [qshell] qshell return value timestamp: 53436075, local time: 53443048
                            INFO  [muorb] SLPI: Creating qurt thread wq_INS0
                            INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_INS0 with tid 66
                            INFO  [uorb] Advertising remote topic vehicle_imu
                            INFO  [uorb] Advertising remote topic vehicle_imu_status
                            INFO  [uorb] Advertising remote topic sensors_status_imu
                            INFO  [uorb] Advertising remote topic vehicle_air_data
                            INFO  [uorb] Advertising remote topic sensor_selection
                            INFO  [uorb] Advertising remote topic sensor_combined
                            INFO  [qshell] Send cmd: 'ekf2 start'
                            INFO  [muorb] SLPI: qshell gotten: ekf2 start
                            INFO  [muorb] SLPI: Ok executing command: ekf2 start
                            INFO  [muorb] SLPI: Sending qshell retval with timestamp 53738412, current timestamp 53738414
                            INFO  [qshell] qshell return value timestamp: 53738412, local time: 53741299
                            INFO  [uorb] Advertising remote topic ekf2_timestamps
                            INFO  [qshell] Send cmd: 'mc_pos_control start'
                            INFO  [muorb] SLPI: qshell gotten: mc_pos_control start
                            INFO  [muorb] SLPI: Ok executing command: mc_pos_control start
                            INFO  [muorb] SLPI: Sending qshell retval with timestamp 53806315, current timestamp 53806317
                            INFO  [qshell] qshell return value timestamp: 53806315, local time: 53809617
                            INFO  [qshell] Send cmd: 'mc_att_control start'
                            INFO  [muorb] SLPI: qshell gotten: mc_att_control start
                            INFO  [muorb] SLPI: Ok executing command: mc_att_control start
                            INFO  [muorb] SLPI: Sending qshell retval with timestamp 53883470, current timestamp 53883473
                            INFO  [qshell] qshell return value timestamp: 53883470, local time: 53887354
                            INFO  [qshell] Send cmd: 'mc_rate_control start'
                            INFO  [muorb] SLPI: qshell gotten: mc_rate_control start
                            INFO  [muorb] SLPI: Ok executing command: mc_rate_control start
                            INFO  [muorb] SLPI: Sending qshell retval with timestamp 53979850, current timestamp 53979852
                            INFO  [qshell] qshell return value timestamp: 53979850, local time: 53981827
                            INFO  [qshell] Send cmd: 'mc_hover_thrust_estimator start'
                            INFO  [muorb] SLPI: qshell gotten: mc_hover_thrust_estimator start
                            INFO  [muorb] SLPI: Ok executing command: mc_hover_thrust_estimator start
                            INFO  [muorb] SLPI: Sending qshell retval with timestamp 54052733, current timestamp 54052736
                            INFO  [qshell] qshell return value timestamp: 54052733, local time: 54054615
                            INFO  [qshell] Send cmd: 'land_detector start multicopter'
                            INFO  [muorb] SLPI: qshell gotten: land_detector start multicopter
                            INFO  [muorb] SLPI: Ok executing command: land_detector start multicopter
                            INFO  [muorb] SLPI: Sending qshell retval with timestamp 54117935, current timestamp 54117938
                            INFO  [qshell] qshell return value timestamp: 54117935, local time: 54120972
                            INFO  [uorb] Advertising remote topic vehicle_land_detected
                            INFO  [commander] LED: open /dev/led0 failed (22)
                            INFO  [muorb] SLPI: Advertising remote topic led_control
                            INFO  [muorb] SLPI: Advertising remote topic tune_control
                            INFO  [PreFlightCheck] Failed EKF health preflight check while waiting for filter to settle
                            INFO  [muorb] SLPI: Advertising remote topic vehicle_control_mode
                            INFO  [muorb] SLPI: Advertising remote topic vehicle_status
                            INFO  [muorb] SLPI: Advertising remote topic actuator_armed
                            INFO  [muorb] SLPI: Advertising remote topic position_setpoint_triplet
                            INFO  [muorb] SLPI: Advertising remote topic commander_state
                            INFO  [muorb] SLPI: Advertising remote topic vehicle_status_flags
                            INFO  [uorb] Advertising remote topic rate_ctrl_status
                            INFO  [uorb] Advertising remote topic actuator_controls_0
                            INFO  [muorb] SLPI: Advertising remote topic vehicle_command
                            INFO  [commander] Handling Commander command 176
                            INFO  [muorb] SLPI: Advertising remote topic vehicle_command_ack
                            INFO  [mavlink] Enabling TBS Crossfire mode in mavlink
                            INFO  [mavlink] mode: Minimal, data rate: 10000 B/s on udp port 14556 remote port 14557
                            INFO  [muorb] SLPI: Marking DeviceNode(vehicle_command) as advertised in process_remote_topic
                            INFO  [mavlink] MAVLink only on localhost (set param MAV_BROADCAST = 1 to enable network)
                            INFO  [muorb] SLPI: Advertising remote topic telemetry_status
                            pxh> INFO  [uorb] Marking DeviceNode(mavlink_rx_msg) as advertised in process_remote_topic
                            Thanks for helping
                              ______  __   __    ___
                              | ___ \ \ \ / /   /   |
                              | |_/ /  \ V /   / /| |
                              |  __/   /   \  / /_| |
                              | |     / /^\ \ \___  |
                              \_|     \/   \/     |_/
                              px4 starting.
                              Running on M0054
                              INFO  [muorb] SLPI:
                              Thanks for helping
                              @yashas-katte Are you trying to use the TBS Crossfire receiver as your connection to QGC or do you also have a separate wireless network connection for that?
                                yashas katte
                                I did not understand by what do you mean by connecting TBS crossfire receiver to QGC.
                                I know that communication between PX4 and QGC happens through UDP then through mavlink.
                                I just have a expander board , with a usb wifi adapter connected to it.
                                  @yashas-katte Okay, great. There is actually a way to tunnel the UDP packets using the TBS Crossfire (transceiver). We have support for it but it doesn't really work very well yet. The startup file /etc/modalai/voxl-px4.config, however, assumes that when you specify the -r option that you want to use this feature in addition to using the TBS Crossfire as an RC receiver. So it will do a couple of things that may be interfering with your normal WiFi based QGC connection. Edit that file and look for the lines that have if [ "$RC" == "CRSF_MAV" ]; then. The first couple are fine and what you want for RC control. The last two can be causing problems with your setup and should be commented out. You don't want to slow everything in mavlink down and you don't want to start the mavlink_bridge.
                                    yashas katte
                                    VOXL2 is arming now. Thanks for the response!
                                    We are facing new issues with esc calibration.
                                    Out motor setup is EMAX 1407 3300KV.
                                    On no load it is pulling 10Amps but the motors are heating till extent of it burning during calibration.
                                    I ran voxl-esc-tools provided in the website.
                                    Also , When we tested VOXL2 drone. After particular throttle input value the motor directions are reversed.
                                    While doing the spin test we are able to get correct rpm as specified in the command.
                                    Only during the calibration we are facing motor heating issue.
                                      @yashas-katte Could you please start a new forum question for these new ESC issues? Thanks!
