    VOXL2 not arming
    1453
    • yashas katteY
      yashas katte
      hello , I have bought VOXL2 , I have setup voxl-vission-px4 and connected the modal ai 's esc to the board.
      The Qgroundcontrol is able to connect to the voxl2 but i am not able to run motor tests (they are not running). The compass is not calibrating when a UBlox m8n gps. All the mpa services are running but I am not able to arm the board.
      If i disable the compass in qgc, then arm it . i get a message that mav_cmd has rejected arming request.
      Pls respond asap , I am not sure where i have gone wrong.
      • Adrian HidalgoA
        Adrian Hidalgo ModalAI Team
        @yashas-katte I would suggest looking at our technical docs
          Eric Katzfey ModalAI Team @yashas katte
          @yashas-katte Please also look at PX4 documentation and QGroundControl documentation. You should be able to figure out the reason for arm failure using QGroundControl. Which GPS unit did you plug in? UBlox m8n is a GNSS part and doesn't have a compass (magnetometer) on it's own. But those are usually packaged up into a GPS unit that does include a compass. For example we usually use the Holybro Pixhawk 4 unit that has GPS, compass, and LED integrated together. And how did you try to run the motor test? Is it via the motor tab in QGC? Yes, that doesn't work. But you should be able to spin the motors using px4 commands directly on target. Please make sure you remove the propellers from the motors before doing any such test!
          • yashas katteY
            yashas katte
            Hello, Thanks for such fast response.
            I re flashed voxl2 , connected the motors , and crsf rc.
            The rc is able to bind (as it showing green light) but in qgc , it tells RC RSSI is unavailable.
            The connection has been refred to by https://docs.modalai.com/voxl2-rc-configs/
            I will move on to gps/mag once this gets fixed.
            Thanks in advance
              @yashas-katte Can you tell us more about what you are trying to do? Are you building a custom drone with VOXL2? What RC receiver are you using and what port are you connecting it to?
              • yashas katteY
                yashas katte
                Yes , I trying to build a custom with VOXl2. I am trying to using a TBS crossfire in mavlink mode.
                The ports i am using is the same as proivided in the documentation for crossfire recvier
                The RC is able to bind to the transmitter TBS Tango , but Qgc shows RC RSSI in unavailble.
                Even px4-listener input_rc , shows output never published.
                I want to know where I have gone wrong , Pls help
                  @yashas-katte You can bind to the receiver if it has power, even if there is no connection over the UART. Let's start with the TBS Crossfire receiver in Mavlink mode. What driver are you using on VOXL2 to interact with the receiver? The recveiver will not send any Mavlink packets on the UART unless it sees Mavlink heartbeat packets coming from the VOXL2. Can you put an oscilloscope on the VOXL2 Tx line and verify that it is transmitting packets?
                  • yashas katteY
                    yashas katte
                    I don't understand how to use the drivers , the link provided in the docs is depreciated.
                    I checked with oscilloscope on Voxl2 TX : we got heartbeat packets. but input_rc is never published.
                    This oscliscope's output:
                    Pls help , Thanks in advance
                      @yashas-katte Okay, that's a good start. Are you autostarting px4 using the /etc/systemd/system/voxl-px4.service? There are certain options you can provide to the voxl-px4 start script to specify which drivers are started. Can you tell me what options are provided to voxl-px4 in your case?
                        @yashas-katte Also, can you now look at the RX line on VOXL2 to see if the receiver is trying to send anything back?
                        • yashas katteY
                          yashas katte
                          There is nothing coming through the RX pin. I launched VOXL-PX4 manually after disabling mavlink server and voxl-px4.
                          When I set csrf to mavlink mode , there is no error in px4 terminal. But there is no rc_input(never published).
                          Same result with ppm also. when set at sbus , ibus , dsmx modes.
                          Also , I get an error saying PX4-IO failed to detect.
                          I am assuming that only works with we have IO expander board which we are not using currently.
                          Is that the problem?
                            @yashas-katte To use a TBS Crossfire receiver in Mavlink mode you start px4 with the command voxl-px4 -r where the -r option specifies the mavlink option. Take a look at the file /usr/bin/voxl-px4 to see how it operates. It is just a bash script. Also, it uses the file /etc/modalai/voxl-px4.config to do the actual startup. Can you manually start with voxl-px4 -r from the command line and then post all of the output you get from px4? Also, there are a number of configuration options with the TBS Crossfire receiver. You have to make sure that the pins are configured correctly for it to work with PX4. If PX4 is sending out the mavlink heartbeat message to the receiver and it is not responding then I would suspect that the receiver hasn't been configured correctly.
                            • yashas katteY
                              yashas katte
                              This -r flag worked I am able to rc data! , I edited the service file to add -r.
                              But I am facing another issue.
                              The connection between Qgrouncontrol keeps getting dropped and connected again.
                              I have set voxl-configure-mpa --factory-reset.
                              As I had to disable those when I run voxl-px4 manually.
                              Is there something wrong there?
                              voxl2:/$ voxl-px4 -r
                              Found DSP signature file
                              ______  __   __    ___
                              | ___ \ \ \ / /   /   |
                              | |_/ /  \ V /   / /| |
                              |  __/   /   \  / /_| |
                              | |     / /^\ \ \___  |
                              \_|     \/   \/     |_/
                              px4 starting.
                              INFO  [px4] Calling startup script: /bin/sh /etc/modalai/voxl-px4.config 0
                              Running on M0054
                              INFO  [muorb] SLPI: Creating qurt thread hpwork
                              INFO  [muorb] SLPI: Successfully created px4 task PX4_hpwork with tid 83
                              INFO  [muorb] SLPI: Creating qurt thread lpwork
                              INFO  [muorb] SLPI: Successfully created px4 task PX4_lpwork with tid 82
                              INFO  [muorb] SLPI: Creating qurt thread wkr_hrt
                              INFO  [muorb] SLPI: Successfully created px4 task PX4_wkr_hrt with tid 81
                              INFO  [muorb] SLPI: Creating qurt thread client_sync_thread
                              INFO  [muorb] SLPI: Successfully created px4 task PX4_client_sync_thread with tid 80
                              INFO  [muorb] SLPI: Creating qurt thread wq_manager
                              INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_manager with tid 79
                              INFO  [muorb] SLPI: Creating qurt thread qshell
                              INFO  [muorb] SLPI: Successfully created px4 task PX4_qshell with tid 78
                              INFO  [muorb] SLPI: Creating qurt thread wq_SPI1
                              INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_SPI1 with tid 77
                              INFO  [uorb] Advertising remote topic sensor_accel
                              INFO  [uorb] Marking DeviceNode(parameter_server_set_used_request) as advertised in process_remote_topic
                              INFO  [uorb] Advertising remote topic sensor_gyro
                              INFO  [uorb] Advertising remote topic imu_server
                              INFO  [muorb] SLPI: icm42688p #0 on SPI bus 1 (devid=0x0)
                              INFO  [muorb] SLPI:
                              INFO  [muorb] SLPI: Sending qshell retval with timestamp 49225949, current timestamp 49225949
                              INFO  [uorb] Advertising remote topic qshell_retval
                              INFO  [qshell] qshell return value timestamp: 49225949, local time: 49231289
                              ERROR [muorb] SLPI: Cannot reset all parameters on client side
                              INFO  [uorb] Marking DeviceNode(parameter_client_reset_response) as advertised in process_remote_topic
                              INFO  [uorb] Marking DeviceNode(parameter_client_set_value_response) as advertised in process_remote_topic
                              Starting Holybro magnetometer
                              INFO  [muorb] SLPI: Creating qurt thread wq_I2C1
                              INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_I2C1 with tid 76
                              ERROR [muorb] SLPI: Failed to execute command: ist8310 start -R 10 -X -b 1
                              INFO  [muorb] SLPI: Sending qshell retval with timestamp 51937708, current timestamp 51937709
                              INFO  [qshell] qshell return value timestamp: 51937708, local time: 51939344
                              ERROR [qshell] Command failed
                              Starting Holybro LED driver
                              INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_I2C1 with tid 4172
                              ERROR [muorb] SLPI: Failed to execute command: rgbled_ncp5623c start -X -b 1 -f 400 -a 56
                              INFO  [muorb] SLPI: Sending qshell retval with timestamp 51984318, current timestamp 51984320
                              INFO  [qshell] qshell return value timestamp: 51984318, local time: 51986095
                              INFO  [qshell] Send cmd: 'icp10100 start -I -b 5'
                              INFO  [muorb] SLPI: qshell gotten: icp10100 start -I -b 5
                              INFO  [muorb] SLPI: Creating qurt thread wq_I2C5
                              INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_I2C5 with tid 8268
                              INFO  [muorb] SLPI: *** I2C Device ID 0x9c6329 10249001
                              INFO  [muorb] SLPI: probe probe succeeded. data = 0x1 0x48
                              INFO  [muorb] SLPI: icp10100 #0 on I2C bus 5
                              INFO  [muorb] SLPI: Ok executing command: icp10100 start -I -b 5
                              INFO  [muorb] SLPI: Sending qshell retval with timestamp 52031607, current timestamp 52031609
                              INFO  [qshell] qshell return value timestamp: 52031607, local time: 52033362
                              INFO  [qshell] Send cmd: 'modalai_esc start'
                              INFO  [uorb] Advertising remote topic sensor_baro
                              INFO  [muorb] SLPI: qshell gotten: modalai_esc start
                              INFO  [muorb] SLPI: Creating qurt thread wq_hp_default
                              INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_hp_default with tid 75
                              INFO  [uorb] Advertising remote topic test_motor
                              INFO  [muorb] SLPI: Ok executing command: modalai_esc start
                              INFO  [muorb] SLPI: Sending qshell retval with timestamp 52107976, current timestamp 52107978
                              INFO  [muorb] SLPI: Opened UART ESC device
                              INFO  [qshell] qshell return value timestamp: 52107976, local time: 52109827
                              INFO  [qshell] Send cmd: 'mixer load /dev/uart_esc quad_x.main.mix'
                              INFO  [muorb] SLPI: qshell gotten: mixer load /dev/uart_esc quad_x.main.mix
                              INFO  [muorb] SLPI: Creating qurt thread wq_rate_ctrl
                              INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_rate_ctrl with tid 73
                              INFO  [muorb] SLPI: Ok executing command: mixer load /dev/uart_esc quad_x.main.mix
                              INFO  [muorb] SLPI: Sending qshell retval with timestamp 52178454, current timestamp 52178456
                              INFO  [qshell] qshell return value timestamp: 52178454, local time: 52181721
                              INFO  [uorb] Advertising remote topic actuator_outputs
                              INFO  [uorb] Advertising remote topic multirotor_motor_limits
                              INFO  [qshell] Send cmd: 'voxlpm start -X -b 2'
                              INFO  [muorb] SLPI: qshell gotten: voxlpm start -X -b 2
                              INFO  [muorb] SLPI: Creating qurt thread wq_I2C2
                              INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_I2C2 with tid 4171
                              INFO  [muorb] SLPI: *** I2C Device ID 0x784411 7881745
                              INFO  [uorb] Advertising remote topic battery_status
                              INFO  [muorb] SLPI: voxlpm #0 on I2C bus 2 (external)
                              INFO  [muorb] SLPI: Ok executing command: voxlpm start -X -b 2
                              INFO  [muorb] SLPI: Sending qshell retval with timestamp 52248695, current timestamp 52248698
                              INFO  [qshell] qshell return value timestamp: 52248695, local time: 52250854
                              INFO  [uorb] Advertising remote topic power_monitor
                              Starting Holybro GPS
                              INFO  [qshell] Send cmd: 'gps start -d 7 -b 115200'
                              INFO  [muorb] SLPI: qshell gotten: gps start -d 7 -b 115200
                              INFO  [muorb] SLPI: Creating qurt thread gps
                              INFO  [muorb] SLPI: Successfully created px4 task PX4_gps with tid 72
                              INFO  [muorb] SLPI: Ok executing command: gps start -d 7 -b 115200
                              INFO  [muorb] SLPI: Sending qshell retval with timestamp 52317126, current timestamp 52317128
                              INFO  [qshell] qshell return value timestamp: 52317126, local time: 52318912
                              Starting TBS crossfire RC - MAV Mode
                              INFO  [qshell] Send cmd: 'tbs_crossfire start -m -p 7 -b 115200'
                              INFO  [muorb] SLPI: qshell gotten: tbs_crossfire start -m -p 7 -b 115200
                              INFO  [muorb] SLPI: Creating qurt thread tbs_crossfire_main
                              INFO  [muorb] SLPI: Successfully created px4 task PX4_tbs_crossfire_main with tid 70
                              INFO  [muorb] SLPI: Ok executing command: tbs_crossfire start -m -p 7 -b 115200
                              INFO  [muorb] SLPI: Sending qshell retval with timestamp 52348137, current timestamp 52348139
                              INFO  [muorb] SLPI: Creating qurt thread tbs_crossfire_mav
                              INFO  [muorb] SLPI: Successfully created px4 task PX4_tbs_crossfire_mav with tid 69
                              INFO  [qshell] qshell return value timestamp: 52348137, local time: 52351007
                              INFO  [muorb] SLPI: Creating qurt thread wq_nav_and_controllers
                              INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_nav_and_controllers with tid 67
                              INFO  [uorb] Advertising remote topic vehicle_acceleration
                              INFO  [muorb] SLPI: Sending qshell retval with timestamp 53436075, current timestamp 53436077
                              INFO  [uorb] Advertising remote topic vehicle_angular_acceleration
                              INFO  [uorb] Advertising remote topic vehicle_angular_velocity
                              INFO  [qshell] qshell return value timestamp: 53436075, local time: 53443048
                              INFO  [muorb] SLPI: Creating qurt thread wq_INS0
                              INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_INS0 with tid 66
                              INFO  [uorb] Advertising remote topic vehicle_imu
                              INFO  [uorb] Advertising remote topic vehicle_imu_status
                              INFO  [uorb] Advertising remote topic sensors_status_imu
                              INFO  [uorb] Advertising remote topic vehicle_air_data
                              INFO  [uorb] Advertising remote topic sensor_selection
                              INFO  [uorb] Advertising remote topic sensor_combined
                              INFO  [muorb] SLPI: Sending qshell retval with timestamp 53738412, current timestamp 53738414
                              INFO  [qshell] qshell return value timestamp: 53738412, local time: 53741299
                              INFO  [uorb] Advertising remote topic ekf2_timestamps
                              INFO  [muorb] SLPI: Sending qshell retval with timestamp 53806315, current timestamp 53806317
                              INFO  [qshell] qshell return value timestamp: 53806315, local time: 53809617
                              INFO  [muorb] SLPI: Sending qshell retval with timestamp 53883470, current timestamp 53883473
                              INFO  [qshell] qshell return value timestamp: 53883470, local time: 53887354
                              INFO  [muorb] SLPI: Sending qshell retval with timestamp 53979850, current timestamp 53979852
                              INFO  [qshell] qshell return value timestamp: 53979850, local time: 53981827
                              INFO  [muorb] SLPI: Sending qshell retval with timestamp 54052733, current timestamp 54052736
                              INFO  [qshell] qshell return value timestamp: 54052733, local time: 54054615
                              INFO  [muorb] SLPI: Sending qshell retval with timestamp 54117935, current timestamp 54117938
                              INFO  [qshell] qshell return value timestamp: 54117935, local time: 54120972
                              INFO  [uorb] Advertising remote topic vehicle_land_detected
                              INFO  [commander] LED: open /dev/led0 failed (22)
                              INFO  [muorb] SLPI: Advertising remote topic led_control
                              INFO  [muorb] SLPI: Advertising remote topic tune_control
                              INFO  [PreFlightCheck] Failed EKF health preflight check while waiting for filter to settle
                              INFO  [muorb] SLPI: Advertising remote topic vehicle_control_mode
                              INFO  [muorb] SLPI: Advertising remote topic vehicle_status
                              INFO  [muorb] SLPI: Advertising remote topic actuator_armed
                              INFO  [muorb] SLPI: Advertising remote topic commander_state
                              INFO  [muorb] SLPI: Advertising remote topic vehicle_status_flags
                              INFO  [uorb] Advertising remote topic rate_ctrl_status
                              INFO  [uorb] Advertising remote topic actuator_controls_0
                              INFO  [muorb] SLPI: Advertising remote topic vehicle_command
                              INFO  [commander] Handling Commander command 176
                              INFO  [muorb] SLPI: Advertising remote topic vehicle_command_ack
                              INFO  [mavlink] Enabling TBS Crossfire mode in mavlink
                              INFO  [mavlink] mode: Minimal, data rate: 10000 B/s on udp port 14556 remote port 14557
                              INFO  [muorb] SLPI: Marking DeviceNode(vehicle_command) as advertised in process_remote_topic
                              INFO  [mavlink] MAVLink only on localhost (set param MAV_BROADCAST = 1 to enable network)
                              INFO  [muorb] SLPI: Advertising remote topic telemetry_status
                              pxh> INFO  [uorb] Marking DeviceNode(mavlink_rx_msg) as advertised in process_remote_topic
                              Thanks for helping
                                @yashas-katte Are you trying to use the TBS Crossfire receiver as your connection to QGC or do you also have a separate wireless network connection for that?
                                • yashas katteY
                                  yashas katte
                                  I did not understand by what do you mean by connecting TBS crossfire receiver to QGC.
                                  I know that communication between PX4 and QGC happens through UDP then through mavlink.
                                  I just have a expander board , with a usb wifi adapter connected to it.
                                    @yashas-katte Okay, great. There is actually a way to tunnel the UDP packets using the TBS Crossfire (transceiver). We have support for it but it doesn't really work very well yet. The startup file /etc/modalai/voxl-px4.config, however, assumes that when you specify the -r option that you want to use this feature in addition to using the TBS Crossfire as an RC receiver. So it will do a couple of things that may be interfering with your normal WiFi based QGC connection. Edit that file and look for the lines that have if [ "$RC" == "CRSF_MAV" ]; then. The first couple are fine and what you want for RC control. The last two can be causing problems with your setup and should be commented out. You don't want to slow everything in mavlink down and you don't want to start the mavlink_bridge.
                                    • yashas katteY
                                      yashas katte
                                      VOXL2 is arming now. Thanks for the response!
                                      We are facing new issues with esc calibration.
                                      Out motor setup is EMAX 1407 3300KV.
                                      On no load it is pulling 10Amps but the motors are heating till extent of it burning during calibration.
                                      I ran voxl-esc-tools provided in the website.
                                      Also , When we tested VOXL2 drone. After particular throttle input value the motor directions are reversed.
                                      While doing the spin test we are able to get correct rpm as specified in the command.
                                      Only during the calibration we are facing motor heating issue.
                                        @yashas-katte Could you please start a new forum question for these new ESC issues? Thanks!
