VOXL2 not arming
hello , I have bought VOXL2 , I have setup voxl-vission-px4 and connected the modal ai 's esc to the board.
The Qgroundcontrol is able to connect to the voxl2 but i am not able to run motor tests (they are not running). The compass is not calibrating when a UBlox m8n gps. All the mpa services are running but I am not able to arm the board.If i disable the compass in qgc, then arm it . i get a message that mav_cmd has rejected arming request.
Pls respond asap , I am not sure where i have gone wrong.
@yashas-katte I would suggest looking at our technical docs
@yashas-katte Please also look at PX4 documentation and QGroundControl documentation. You should be able to figure out the reason for arm failure using QGroundControl. Which GPS unit did you plug in? UBlox m8n is a GNSS part and doesn't have a compass (magnetometer) on it's own. But those are usually packaged up into a GPS unit that does include a compass. For example we usually use the Holybro Pixhawk 4 unit that has GPS, compass, and LED integrated together. And how did you try to run the motor test? Is it via the motor tab in QGC? Yes, that doesn't work. But you should be able to spin the motors using px4 commands directly on target. Please make sure you remove the propellers from the motors before doing any such test!
Hello, Thanks for such fast response.
I re flashed voxl2 , connected the motors , and crsf rc.
The rc is able to bind (as it showing green light) but in qgc , it tells RC RSSI is unavailable.
The connection has been refred to by https://docs.modalai.com/voxl2-rc-configs/
I will move on to gps/mag once this gets fixed.Thanks in advance
@yashas-katte Can you tell us more about what you are trying to do? Are you building a custom drone with VOXL2? What RC receiver are you using and what port are you connecting it to?
Yes , I trying to build a custom with VOXl2. I am trying to using a TBS crossfire in mavlink mode.
The ports i am using is the same as proivided in the documentation for crossfire recvierThe RC is able to bind to the transmitter TBS Tango , but Qgc shows RC RSSI in unavailble.
Even px4-listener input_rc , shows output never published.
I want to know where I have gone wrong , Pls help
@yashas-katte You can bind to the receiver if it has power, even if there is no connection over the UART. Let's start with the TBS Crossfire receiver in Mavlink mode. What driver are you using on VOXL2 to interact with the receiver? The recveiver will not send any Mavlink packets on the UART unless it sees Mavlink heartbeat packets coming from the VOXL2. Can you put an oscilloscope on the VOXL2 Tx line and verify that it is transmitting packets?
I don't understand how to use the drivers , the link provided in the docs is depreciated.
I checked with oscilloscope on Voxl2 TX : we got heartbeat packets. but input_rc is never published.
This oscliscope's output:
Pls help , Thanks in advance
@yashas-katte Okay, that's a good start. Are you autostarting px4 using the /etc/systemd/system/voxl-px4.service? There are certain options you can provide to the voxl-px4 start script to specify which drivers are started. Can you tell me what options are provided to voxl-px4 in your case?
@yashas-katte Also, can you now look at the RX line on VOXL2 to see if the receiver is trying to send anything back?
There is nothing coming through the RX pin. I launched VOXL-PX4 manually after disabling mavlink server and voxl-px4.
When I set csrf to mavlink mode , there is no error in px4 terminal. But there is no rc_input(never published).
Same result with ppm also. when set at sbus , ibus , dsmx modes.
Also , I get an error saying PX4-IO failed to detect.
I am assuming that only works with we have IO expander board which we are not using currently.
Is that the problem? -
Is that the problem?@yashas-katte To use a TBS Crossfire receiver in Mavlink mode you start px4 with the command
voxl-px4 -rwhere the-roption specifies the mavlink option. Take a look at the file/usr/bin/voxl-px4to see how it operates. It is just a bash script. Also, it uses the file/etc/modalai/voxl-px4.configto do the actual startup. Can you manually start withvoxl-px4 -rfrom the command line and then post all of the output you get from px4? Also, there are a number of configuration options with the TBS Crossfire receiver. You have to make sure that the pins are configured correctly for it to work with PX4. If PX4 is sending out the mavlink heartbeat message to the receiver and it is not responding then I would suspect that the receiver hasn't been configured correctly. -
This -r flag worked I am able to rc data! , I edited the service file to add -r.
But I am facing another issue.
The connection between Qgrouncontrol keeps getting dropped and connected again.
I have set voxl-configure-mpa --factory-reset.
As I had to disable those when I run voxl-px4 manually.
Is there something wrong there?voxl2:/$ voxl-px4 -r Found DSP signature file INFO [px4] mlockall() enabled. PX4's virtual address space is locked into RAM. INFO [px4] assuming working directory is rootfs, no symlinks needed. ______ __ __ ___ | ___ \ \ \ / / / | | |_/ / \ V / / /| | | __/ / \ / /_| | | | / /^\ \ \___ | \_| \/ \/ |_/ px4 starting. INFO [px4] Calling startup script: /bin/sh /etc/modalai/voxl-px4.config 0 Running on M0054 INFO [muorb] SLPI: Creating qurt thread hpwork INFO [muorb] SLPI: Successfully created px4 task PX4_hpwork with tid 83 INFO [muorb] SLPI: Creating qurt thread lpwork INFO [muorb] SLPI: Successfully created px4 task PX4_lpwork with tid 82 INFO [muorb] SLPI: Creating qurt thread wkr_hrt INFO [muorb] SLPI: Successfully created px4 task PX4_wkr_hrt with tid 81 INFO [muorb] SLPI: Creating qurt thread client_sync_thread INFO [muorb] SLPI: Successfully created px4 task PX4_client_sync_thread with tid 80 INFO [muorb] SLPI: Creating qurt thread wq_manager INFO [muorb] SLPI: Successfully created px4 task PX4_wq_manager with tid 79 INFO [muorb] SLPI: Creating qurt thread qshell INFO [muorb] SLPI: Successfully created px4 task PX4_qshell with tid 78 INFO [qshell] Send cmd: 'icm42688p start -s' INFO [muorb] SLPI: Marking DeviceNode(qshell_req) as advertised in process_remote_topic INFO [muorb] SLPI: qshell gotten: icm42688p start -s INFO [muorb] SLPI: Creating qurt thread wq_SPI1 INFO [muorb] SLPI: Successfully created px4 task PX4_wq_SPI1 with tid 77 INFO [muorb] SLPI: *** SPI Device ID 0x26000a 2490378 INFO [uorb] Advertising remote topic sensor_accel INFO [uorb] Marking DeviceNode(parameter_server_set_used_request) as advertised in process_remote_topic INFO [muorb] SLPI: Marking DeviceNode(parameter_server_set_used_response) as advertised in process_remote_to INFO [uorb] Advertising remote topic sensor_gyro INFO [uorb] Advertising remote topic imu_server INFO [muorb] SLPI: on SPI bus 1 INFO [muorb] SLPI: icm42688p #0 on SPI bus 1 (devid=0x0) INFO [muorb] SLPI: INFO [muorb] SLPI: Ok executing command: icm42688p start -s INFO [muorb] SLPI: Sending qshell retval with timestamp 49225949, current timestamp 49225949 INFO [uorb] Advertising remote topic qshell_retval INFO [qshell] qshell return value timestamp: 49225949, local time: 49231289 INFO [muorb] SLPI: Marking DeviceNode(parameter_client_reset_request) as advertised in process_remote_topic ERROR [muorb] SLPI: Cannot reset all parameters on client side INFO [uorb] Marking DeviceNode(parameter_client_reset_response) as advertised in process_remote_topic INFO [muorb] SLPI: Advertising remote topic parameter_update INFO [muorb] SLPI: Marking DeviceNode(parameter_client_set_value_request) as advertised in process_remote_to INFO [uorb] Marking DeviceNode(parameter_client_set_value_response) as advertised in process_remote_topic INFO [logger] logger started (mode=all) Starting Holybro magnetometer INFO [qshell] Send cmd: 'ist8310 start -R 10 -X -b 1' INFO [muorb] SLPI: Marking DeviceNode(qshell_req) as advertised in process_remote_topic INFO [muorb] SLPI: qshell gotten: ist8310 start -R 10 -X -b 1 INFO [muorb] SLPI: Creating qurt thread wq_I2C1 INFO [muorb] SLPI: Successfully created px4 task PX4_wq_I2C1 with tid 76 INFO [muorb] SLPI: *** I2C Device ID 0x60e09 396809 ERROR [muorb] SLPI: i2c probe failed ERROR [muorb] SLPI: Failed to execute command: ist8310 start -R 10 -X -b 1 INFO [muorb] SLPI: Sending qshell retval with timestamp 51937708, current timestamp 51937709 INFO [qshell] cmd returned with: -1 INFO [qshell] qshell return value timestamp: 51937708, local time: 51939344 ERROR [qshell] Command failed Starting Holybro LED driver INFO [qshell] Send cmd: 'rgbled_ncp5623c start -X -b 1 -f 400 -a 56' INFO [muorb] SLPI: Marking DeviceNode(qshell_req) as advertised in process_remote_topic INFO [muorb] SLPI: qshell gotten: rgbled_ncp5623c start -X -b 1 -f 400 -a 56 INFO [muorb] SLPI: Creating qurt thread wq_I2C1 INFO [muorb] SLPI: Successfully created px4 task PX4_wq_I2C1 with tid 4172 INFO [muorb] SLPI: *** I2C Device ID 0x7b3809 8075273 ERROR [muorb] SLPI: i2c probe failed ERROR [muorb] SLPI: Failed to execute command: rgbled_ncp5623c start -X -b 1 -f 400 -a 56 INFO [muorb] SLPI: Sending qshell retval with timestamp 51984318, current timestamp 51984320 INFO [qshell] cmd returned with: -1 INFO [qshell] qshell return value timestamp: 51984318, local time: 51986095 ERROR [qshell] Command failed INFO [qshell] Send cmd: 'icp10100 start -I -b 5' INFO [muorb] SLPI: Marking DeviceNode(qshell_req) as advertised in process_remote_topic INFO [muorb] SLPI: qshell gotten: icp10100 start -I -b 5 INFO [muorb] SLPI: Creating qurt thread wq_I2C5 INFO [muorb] SLPI: Successfully created px4 task PX4_wq_I2C5 with tid 8268 INFO [muorb] SLPI: *** I2C Device ID 0x9c6329 10249001 INFO [muorb] SLPI: probe probe succeeded. data = 0x1 0x48 INFO [muorb] SLPI: icp10100 #0 on I2C bus 5 INFO [muorb] SLPI: Ok executing command: icp10100 start -I -b 5 INFO [muorb] SLPI: Sending qshell retval with timestamp 52031607, current timestamp 52031609 INFO [qshell] qshell return value timestamp: 52031607, local time: 52033362 INFO [qshell] Send cmd: 'modalai_esc start' INFO [muorb] SLPI: Marking DeviceNode(qshell_req) as advertised in process_remote_topic INFO [uorb] Advertising remote topic sensor_baro INFO [muorb] SLPI: qshell gotten: modalai_esc start INFO [muorb] SLPI: Creating qurt thread wq_hp_default INFO [muorb] SLPI: Successfully created px4 task PX4_wq_hp_default with tid 75 INFO [uorb] Advertising remote topic test_motor INFO [muorb] SLPI: Ok executing command: modalai_esc start INFO [muorb] SLPI: Sending qshell retval with timestamp 52107976, current timestamp 52107978 INFO [muorb] SLPI: Opened UART ESC device INFO [qshell] qshell return value timestamp: 52107976, local time: 52109827 INFO [qshell] Send cmd: 'mixer load /dev/uart_esc quad_x.main.mix' INFO [muorb] SLPI: Marking DeviceNode(qshell_req) as advertised in process_remote_topic INFO [muorb] SLPI: qshell gotten: mixer load /dev/uart_esc quad_x.main.mix INFO [muorb] SLPI: Creating qurt thread wq_rate_ctrl INFO [muorb] SLPI: Successfully created px4 task PX4_wq_rate_ctrl with tid 73 INFO [muorb] SLPI: Ok executing command: mixer load /dev/uart_esc quad_x.main.mix INFO [muorb] SLPI: Sending qshell retval with timestamp 52178454, current timestamp 52178456 INFO [qshell] qshell return value timestamp: 52178454, local time: 52181721 INFO [uorb] Advertising remote topic actuator_outputs INFO [uorb] Advertising remote topic multirotor_motor_limits INFO [qshell] Send cmd: 'voxlpm start -X -b 2' INFO [muorb] SLPI: Marking DeviceNode(qshell_req) as advertised in process_remote_topic INFO [muorb] SLPI: qshell gotten: voxlpm start -X -b 2 INFO [muorb] SLPI: Creating qurt thread wq_I2C2 INFO [muorb] SLPI: Successfully created px4 task PX4_wq_I2C2 with tid 4171 INFO [muorb] SLPI: *** I2C Device ID 0x784411 7881745 INFO [uorb] Advertising remote topic battery_status INFO [muorb] SLPI: voxlpm #0 on I2C bus 2 (external) INFO [muorb] SLPI: Ok executing command: voxlpm start -X -b 2 INFO [muorb] SLPI: Sending qshell retval with timestamp 52248695, current timestamp 52248698 INFO [qshell] qshell return value timestamp: 52248695, local time: 52250854 INFO [uorb] Advertising remote topic power_monitor Starting Holybro GPS INFO [qshell] Send cmd: 'gps start -d 7 -b 115200' INFO [muorb] SLPI: Marking DeviceNode(qshell_req) as advertised in process_remote_topic INFO [muorb] SLPI: qshell gotten: gps start -d 7 -b 115200 INFO [muorb] SLPI: Creating qurt thread gps INFO [muorb] SLPI: Successfully created px4 task PX4_gps with tid 72 INFO [muorb] SLPI: Ok executing command: gps start -d 7 -b 115200 INFO [muorb] SLPI: Sending qshell retval with timestamp 52317126, current timestamp 52317128 INFO [qshell] qshell return value timestamp: 52317126, local time: 52318912 Starting TBS crossfire RC - MAV Mode INFO [qshell] Send cmd: 'tbs_crossfire start -m -p 7 -b 115200' INFO [muorb] SLPI: Marking DeviceNode(qshell_req) as advertised in process_remote_topic INFO [muorb] SLPI: qshell gotten: tbs_crossfire start -m -p 7 -b 115200 INFO [muorb] SLPI: Creating qurt thread tbs_crossfire_main INFO [muorb] SLPI: Successfully created px4 task PX4_tbs_crossfire_main with tid 70 INFO [muorb] SLPI: Ok executing command: tbs_crossfire start -m -p 7 -b 115200 INFO [muorb] SLPI: Sending qshell retval with timestamp 52348137, current timestamp 52348139 INFO [muorb] SLPI: Creating qurt thread tbs_crossfire_mav INFO [muorb] SLPI: Successfully created px4 task PX4_tbs_crossfire_mav with tid 69 INFO [qshell] qshell return value timestamp: 52348137, local time: 52351007 INFO [qshell] Send cmd: 'sensors start' INFO [muorb] SLPI: Marking DeviceNode(qshell_req) as advertised in process_remote_topic INFO [muorb] SLPI: qshell gotten: sensors start INFO [muorb] SLPI: Creating qurt thread wq_nav_and_controllers INFO [muorb] SLPI: Successfully created px4 task PX4_wq_nav_and_controllers with tid 67 INFO [uorb] Advertising remote topic vehicle_acceleration INFO [muorb] SLPI: Ok executing command: sensors start INFO [muorb] SLPI: Sending qshell retval with timestamp 53436075, current timestamp 53436077 INFO [uorb] Advertising remote topic vehicle_angular_acceleration INFO [uorb] Advertising remote topic vehicle_angular_velocity INFO [qshell] qshell return value timestamp: 53436075, local time: 53443048 INFO [muorb] SLPI: Creating qurt thread wq_INS0 INFO [muorb] SLPI: Successfully created px4 task PX4_wq_INS0 with tid 66 INFO [uorb] Advertising remote topic vehicle_imu INFO [uorb] Advertising remote topic vehicle_imu_status INFO [uorb] Advertising remote topic sensors_status_imu INFO [uorb] Advertising remote topic vehicle_air_data INFO [uorb] Advertising remote topic sensor_selection INFO [uorb] Advertising remote topic sensor_combined INFO [qshell] Send cmd: 'ekf2 start' INFO [muorb] SLPI: Marking DeviceNode(qshell_req) as advertised in process_remote_topic INFO [muorb] SLPI: qshell gotten: ekf2 start INFO [muorb] SLPI: Ok executing command: ekf2 start INFO [muorb] SLPI: Sending qshell retval with timestamp 53738412, current timestamp 53738414 INFO [qshell] qshell return value timestamp: 53738412, local time: 53741299 INFO [uorb] Advertising remote topic ekf2_timestamps INFO [qshell] Send cmd: 'mc_pos_control start' INFO [muorb] SLPI: Marking DeviceNode(qshell_req) as advertised in process_remote_topic INFO [muorb] SLPI: qshell gotten: mc_pos_control start INFO [muorb] SLPI: Ok executing command: mc_pos_control start INFO [muorb] SLPI: Sending qshell retval with timestamp 53806315, current timestamp 53806317 INFO [qshell] qshell return value timestamp: 53806315, local time: 53809617 INFO [qshell] Send cmd: 'mc_att_control start' INFO [muorb] SLPI: Marking DeviceNode(qshell_req) as advertised in process_remote_topic INFO [muorb] SLPI: qshell gotten: mc_att_control start INFO [muorb] SLPI: Ok executing command: mc_att_control start INFO [muorb] SLPI: Sending qshell retval with timestamp 53883470, current timestamp 53883473 INFO [qshell] qshell return value timestamp: 53883470, local time: 53887354 INFO [qshell] Send cmd: 'mc_rate_control start' INFO [muorb] SLPI: Marking DeviceNode(qshell_req) as advertised in process_remote_topic INFO [muorb] SLPI: qshell gotten: mc_rate_control start INFO [muorb] SLPI: Ok executing command: mc_rate_control start INFO [muorb] SLPI: Sending qshell retval with timestamp 53979850, current timestamp 53979852 INFO [qshell] qshell return value timestamp: 53979850, local time: 53981827 INFO [qshell] Send cmd: 'mc_hover_thrust_estimator start' INFO [muorb] SLPI: Marking DeviceNode(qshell_req) as advertised in process_remote_topic INFO [muorb] SLPI: qshell gotten: mc_hover_thrust_estimator start INFO [muorb] SLPI: Ok executing command: mc_hover_thrust_estimator start INFO [muorb] SLPI: Sending qshell retval with timestamp 54052733, current timestamp 54052736 INFO [qshell] qshell return value timestamp: 54052733, local time: 54054615 INFO [qshell] Send cmd: 'land_detector start multicopter' INFO [muorb] SLPI: Marking DeviceNode(qshell_req) as advertised in process_remote_topic INFO [muorb] SLPI: qshell gotten: land_detector start multicopter INFO [muorb] SLPI: Ok executing command: land_detector start multicopter INFO [muorb] SLPI: Sending qshell retval with timestamp 54117935, current timestamp 54117938 INFO [qshell] qshell return value timestamp: 54117935, local time: 54120972 INFO [uorb] Advertising remote topic vehicle_land_detected INFO [commander] LED: open /dev/led0 failed (22) INFO [muorb] SLPI: Advertising remote topic led_control INFO [muorb] SLPI: Advertising remote topic tune_control INFO [PreFlightCheck] Failed EKF health preflight check while waiting for filter to settle INFO [muorb] SLPI: Advertising remote topic vehicle_control_mode INFO [muorb] SLPI: Advertising remote topic vehicle_status INFO [muorb] SLPI: Advertising remote topic actuator_armed INFO [muorb] SLPI: Advertising remote topic position_setpoint_triplet INFO [muorb] SLPI: Advertising remote topic commander_state INFO [muorb] SLPI: Advertising remote topic vehicle_status_flags INFO [uorb] Advertising remote topic rate_ctrl_status INFO [uorb] Advertising remote topic actuator_controls_0 INFO [muorb] SLPI: Advertising remote topic vehicle_command INFO [commander] Handling Commander command 176 INFO [muorb] SLPI: Advertising remote topic vehicle_command_ack INFO [mavlink] Enabling TBS Crossfire mode in mavlink INFO [mavlink] mode: Minimal, data rate: 10000 B/s on udp port 14556 remote port 14557 INFO [muorb] SLPI: Marking DeviceNode(vehicle_command) as advertised in process_remote_topic INFO [mavlink] MAVLink only on localhost (set param MAV_BROADCAST = 1 to enable network) INFO [muorb] SLPI: Advertising remote topic telemetry_status INFO [px4] Startup script returned successfully pxh> INFO [uorb] Marking DeviceNode(mavlink_rx_msg) as advertised in process_remote_topicThanks for helping
@yashas-katte Are you trying to use the TBS Crossfire receiver as your connection to QGC or do you also have a separate wireless network connection for that?
I did not understand by what do you mean by connecting TBS crossfire receiver to QGC.
I know that communication between PX4 and QGC happens through UDP then through mavlink.
I just have a expander board , with a usb wifi adapter connected to it. -
I just have a expander board , with a usb wifi adapter connected to it.@yashas-katte Okay, great. There is actually a way to tunnel the UDP packets using the TBS Crossfire (transceiver). We have support for it but it doesn't really work very well yet. The startup file
/etc/modalai/voxl-px4.config, however, assumes that when you specify the-roption that you want to use this feature in addition to using the TBS Crossfire as an RC receiver. So it will do a couple of things that may be interfering with your normal WiFi based QGC connection. Edit that file and look for the lines that haveif [ "$RC" == "CRSF_MAV" ]; then. The first couple are fine and what you want for RC control. The last two can be causing problems with your setup and should be commented out. You don't want to slow everything in mavlink down and you don't want to start themavlink_bridge. -
VOXL2 is arming now. Thanks for the response!
We are facing new issues with esc calibration.
Out motor setup is EMAX 1407 3300KV.
On no load it is pulling 10Amps but the motors are heating till extent of it burning during calibration.
I ran voxl-esc-tools provided in the website.
Also , When we tested VOXL2 drone. After particular throttle input value the motor directions are reversed.
While doing the spin test we are able to get correct rpm as specified in the command.
Only during the calibration we are facing motor heating issue. -
Only during the calibration we are facing motor heating issue.@yashas-katte Could you please start a new forum question for these new ESC issues? Thanks!
