  3. LTE strength
LTE strength
11 Posts 2 Posters 1.7k Views 2 Watching
  • Aldo Castro FreireA Offline
    Aldo Castro Freire
    Is there any advice or method to measure the lte strength that my module is able to receive?
    • tomT Offline
      You can use a variety of AT commands in order to read / write to the modem. One command that we often use to query signal strength is AT+QENG="servingcell". You can send this command and read the output to the terminal all in a single command using echo -ne "AT+QENG=\"servingcell\"\r" | busybox microcom -t 1000 /dev/ttyUSB2.
        Aldo Castro Freire
        thank you I will try that
          Aldo Castro Freire
          @tom said in LTE strength:
          Hi just one question what does this mean ? : busybox microcom -t 1000 /dev/ttyUSB2
          • tomT Offline
            @Aldo-Castro-Freire microcom is a program that can be used to talk to devices over a serial port (/dev/ttyUSB2). It handles sending AT commands to the modem cleanly.
              Aldo Castro Freire
              I also have another modem that is 5g that I would like to connect to the microusb? what device would that be ? it would be ttyUSB1 ?
              • tomT Offline
                What 5g modem are you attempting to use? The drivers would need to be integrated into the kernel in order for it to be recognized.
                  Aldo Castro Freire
                  I am getting "ERROR" when running this command
                  • tomT Offline
                    Check here for Sierra's AT command documentation: https://source.sierrawireless.com/resources/airprime/software/airprime_wpx5xx_wp76xx_wp77xx_at_command_reference/
                      Aldo Castro Freire
                      I am not sure but none of the commands are running.
                      Also, it does not have the command AT+QENG for me to check out
                      • tomT Offline
                        Can you show an example output of what you are seeing? Also, which modem are you using?
