  3. LTE strength
LTE strength
11 Posts 2 Posters 1.7k Views 2 Watching
    You can use a variety of AT commands in order to read / write to the modem. One command that we often use to query signal strength is AT+QENG="servingcell". You can send this command and read the output to the terminal all in a single command using echo -ne "AT+QENG=\"servingcell\"\r" | busybox microcom -t 1000 /dev/ttyUSB2.
    • Aldo Castro FreireA Offline
      Aldo Castro Freire
      thank you I will try that
        Aldo Castro Freire
        @tom said in LTE strength:
        Hi just one question what does this mean ? : busybox microcom -t 1000 /dev/ttyUSB2
          @Aldo-Castro-Freire microcom is a program that can be used to talk to devices over a serial port (/dev/ttyUSB2). It handles sending AT commands to the modem cleanly.
            Aldo Castro Freire
            I also have another modem that is 5g that I would like to connect to the microusb? what device would that be ? it would be ttyUSB1 ?
              What 5g modem are you attempting to use? The drivers would need to be integrated into the kernel in order for it to be recognized.
                Aldo Castro Freire
                I am getting "ERROR" when running this command
                  Check here for Sierra's AT command documentation: https://source.sierrawireless.com/resources/airprime/software/airprime_wpx5xx_wp76xx_wp77xx_at_command_reference/
                    Aldo Castro Freire
                    I am not sure but none of the commands are running.
                    Also, it does not have the command AT+QENG for me to check out
                      Can you show an example output of what you are seeing? Also, which modem are you using?
