    LTE strength
    1425
    • Aldo Castro FreireA
      Aldo Castro Freire
      Is there any advice or method to measure the lte strength that my module is able to receive?
        tom admin
        You can use a variety of AT commands in order to read / write to the modem. One command that we often use to query signal strength is AT+QENG="servingcell". You can send this command and read the output to the terminal all in a single command using echo -ne "AT+QENG=\"servingcell\"\r" | busybox microcom -t 1000 /dev/ttyUSB2.
          Aldo Castro Freire
          thank you I will try that
            Aldo Castro Freire
            @tom said in LTE strength:
            Hi just one question what does this mean ? : busybox microcom -t 1000 /dev/ttyUSB2
              tom admin
              @Aldo-Castro-Freire microcom is a program that can be used to talk to devices over a serial port (/dev/ttyUSB2). It handles sending AT commands to the modem cleanly.
                Aldo Castro Freire
                I also have another modem that is 5g that I would like to connect to the microusb? what device would that be ? it would be ttyUSB1 ?
                  tom admin
                  What 5g modem are you attempting to use? The drivers would need to be integrated into the kernel in order for it to be recognized.
                    Aldo Castro Freire
                    I am getting "ERROR" when running this command
                      tom admin
                      Check here for Sierra's AT command documentation: https://source.sierrawireless.com/resources/airprime/software/airprime_wpx5xx_wp76xx_wp77xx_at_command_reference/
                        Aldo Castro Freire
                        I am not sure but none of the commands are running.
                        Also, it does not have the command AT+QENG for me to check out
                          tom admin
                          Can you show an example output of what you are seeing? Also, which modem are you using?
