  2. VOXL Dev Drones
  3. VOXL m500 Reference Drone
  4. stereo calibration problem & ask for calibration results
10 Posts 5 Posters 1.4k Views 3 Watching
  • M Offline
    M Offline
    malvin
    Hi ,
    I have some issue when i run voxl-calibrate-camera stereo.
    I cant do stereo calibration.
    Because the VOXL web portal shows nothing on camera calibration overlay page.
    So, may i ask for all the camera calibration results?
    m500 seria number : M2100000FU4
      What do you mean by nothing on the portal camera calibration page? Can you see the stereo image frames? If not, the calibration file won't help. Can you share a screen capture of what you mean?
      • M Offline
        M Offline
        malvin
        Dear Chad,
        Thanks for the reply.
        I can't see the stereo image.
        By the way, voxl- calibration-camera tracking works fine on the portal.
          Can you see the raw stereo camera stream in portal?
          • M Offline
            M Offline
            malvin
            Ya, it works well.
            • M Offline
              M Offline
              malvin
              Hi all,
              We followed the following tutorial to upgrade the flight system image to version 1.3.1.
              https://docs.modalai.com/Qualcomm-Flight-RB5-system-image/
              But We didn't save the calibration files in /data/modalai and lost them.
              The voxl-version now :
              voxl-inspect-services :
              So I tried to calibrate the stereo camera by voxl-calibrate-camera stereo by following this guide.
              https://docs.modalai.com/calibrate-cameras/
              The problem is that the portal didn't display the stereo calibration images (Camera Calibration Overlay),
              but I can see the raw stereo camera stream in portal.
              @Chad-Sweet @Alex-Gardner Could you give me some advices?
              Thanks.
                Are you trying to calibrate "stereo" or one of the specific ones, when we have multiple sets of stereo cams they're named "stereo_front" or "stereo_rear" and you'll need to specify when running the calibration tool
                • M Offline
                  M Offline
                  malvin
                  I can calibrate stereo by using "stereo_front" and "stereo_rear" now.
                  But I cant detect the chess board in a frame which rectangle is small.
                  I will make a new chess board for calibration.
                  D 1 Reply Last reply
                  • M malvin
                    D Offline
                    D Offline
                    dtsbourg
                    @malvin said in stereo calibration problem & ask for calibration results:
                    Hi! I am having a similar issue. Which checkboard did you make in order to successfully run calibration when the rectangle is small?
                    • D dtsbourg
                      @dtsbourg There is some good info here: https://docs.modalai.com/calibrate-cameras/
