  3. How to add 2nd USB port to VOXL-1?
7 Posts 3 Posters 670 Views 3 Watching
  • Ed SutterE Offline
    Ed SutterE Offline
    Ed Sutter
    Our configuration of the Voxl-Flight-Deck will (in some configurations) need to support two plug-in USB devices. As best I can tell, the only adapter board that supports this is the modem-addon. The case that forces us down the path of 2 plug-in devices is when we need to use a USB LTE modem; hence, we won't be using the modem-addon.
    Any thoughts on how to do that (without custom hardware)?
    • Ed SutterE Ed Sutter
      @Ed-Sutter I'm not sure I follow your comment. If you need to use 2 USB plug in devices and an LTE modem at the same time then why doesn't the LTE modem add-on board work for you?
      Ed SutterE 1 Reply Last reply
        Ed SutterE Offline
        Ed SutterE Offline
        Ed Sutter
        @Eric-Katzfey We need to support an LTE band that (as luck would have it) is not supported by any of the modems that are compatible with your add-on card.
          @Ed-Sutter Oh, got it. Okay so one USB for external LTE modem and another for external camera. You can still use our LTE modem board but just don't put an LTE modem in the socket.
            Ed SutterE Offline
            Ed SutterE Offline
            Ed Sutter
            @Eric-Katzfey Right.. I was just wondering if there was a more efficient option. Tx
              You can purchase without a modem, it's a little cheaper and then just serves as a hub https://www.modalai.com/products/voxl-lte?variant=39300535681075
              • Chad SweetC Chad Sweet
                Ed SutterE Offline
                Ed SutterE Offline
                Ed Sutter
                @Chad-Sweet Yep, that's likely what we'll have to do...
                Tx
