  3. Why does my stereo calibration fails for extrinsics?
7 Posts 4 Posters 1.2k Views 1 Watching
  • Darshit DesaiD Offline
    Darshit Desai
    I am using the modal ai portal for calibration of onboard stereo cameras but it has failed to calibrate the extrinsics multiple times.
    The board size is 6x9 with each square of 25 mm
    Please open voxl-portal in a web browser to view the camera calibrator overlay stream
    Calibrating Left Camera
    Matrix
    [508.80440670594, 0, 308.5135447003642;
     0, 505.8572996337453, 244.1641938401985;
     0, 0, 1]
    Distortion
    [-0.1811268882769062;
     0.07256140246308232;
     0.001569367963422894;
     -0.001895561795494848;
     0]
    distortion_model: plumb_bob
    Re-projection error reported by calibrateCamera: 0.228868
    Calibration Succeded!
    Calibrating Right Camera
    Matrix
    [499.3757621172282, 0, 325.48861203442;
     0, 497.8217173811094, 235.3877218749848;
     0, 0, 1]
    Distortion
    [-0.1815603484893367;
     0.06567294535447908;
     -0.001628603839397166;
     0.001644475509575583;
     0]
    Re-projection error reported by calibrateCamera: 0.219737
    Calibrating Extrinsics
    4 frames will be processed
    R
    [0.9998749556474266, -0.01520329924164708, 0.004351179291381281;
     0.01514403461767066, 0.9997962803983895, 0.01334375947938024;
     -0.004553162039243111, -0.01327619650779887, 0.9999015008098201]
    T
    [-0.08098804070286524;
     -0.000892545176548338;
     -0.003303076144588922]
    Re-projection error reported by stereoCalibrate: 0.832656
    Detected horizontal stereo pair
    Distance between cameras: 0.0810
    Extrinsics Calibration Failed
    exceeded allowable max reprojection error:  0.5
    Saved intrinsics to: /data/modalai/opencv_stereo_intrinsics.yml
    Exiting Cleanly
      Can you take a picture of your setup?
      Are the image sensors mounted rigidly on the same plane?
        Darshit Desai
        • Chad SweetC Chad Sweet
          Darshit Desai
          @Chad-Sweet I am not sure about the plane of the camera. I am attaching some photos for your reference
          https://drive.google.com/drive/folders/1nJOy9G0-hZSNSN0kZyrtJ9HcxRaZa50X?usp=share_link
          A 1 Reply Last reply
            afdrus
            @Chad-Sweet I am also facing the same issue, it is unclear from the documentation what is the procedure that should be followed to calibrate the extrinsics. Should the board be tilted? Should it be vertical or horizontal?
            ModeratorM 1 Reply Last reply
            • A afdrus
              @afdrus have you watched the video here found at this link? https://docs.modalai.com/calibrate-cameras/#stereo-calibration-process
              The angle of the PCB is not related to stereo calibration. For stereo configuration, the sensors must be rigidly mounted and coplanar. Any movement or tilt between the sensors will not work
              • ModeratorM Moderator
                afdrus
                @Moderator thank you for the reply, by board I meant the checkboard used for the calibration not the PCB.
                However, I watched the video, but it looks old because the current extrinsics procedure is asking me to move the checkboard in 4 poses whereas the video is showing only 2 poses. How much tilt should the checkboard have during the extrinsics calibration process in order to have a low calibration error?
