    VOXL 2 No ESC(s) detected
    3902
    • Taylor PresleyT
      Taylor Presley
      I am following the installation instructions for VOXL 2 found here. I've reflashed the system image with release 0.9.5 from 3/30, installed the slpi uart bridge package to VOXL2, disabled px4, and created the symlink for libpx4. I've also doublechecked that the MCBL_00029-1 cable is correct per this wiring diagram.
      I've run out of options, can someone help me troubleshoot connecting/configuring the VOXL 2 ESC board? Any help is greatly appreciated!
      Outputs are below, thanks in advance,
      Taylor
      mdr@mdr-System-Product-Name:~/Downloads$ adb shell
      system-image: 1.5.5-M0054-14.1a-perf
      kernel:       #1 SMP PREEMPT Fri Mar 24 00:48:55 UTC 2023 4.19.125
      hw version:   M0054
      voxl-suite:   0.9.5
      voxl2:/$ cd /home/root/voxl-esc/voxl-esc-tools/
      voxl2:~/voxl-esc/voxl-esc-tools(dev)$ ./voxl-esc-scan.py
      [GCC 8.4.0]
      Found voxl-esc tools bin version: 1.1
      VOXL Platform: M0054
      Detected VOXL2 M0054 or M0104!
      INFO: Scanning for ESC firmware: /dev/slpi-uart-2, baud: 230400
      INFO: Scanning for ESC firmware: /dev/slpi-uart-2, baud: 115200
      INFO: Scanning for ESC bootloader: /dev/slpi-uart-2, baud: 38400
      Updated baud rate to 38400
      INFO: Scanning for ESC bootloader: /dev/slpi-uart-2, baud: 230400
      Updated baud rate to 230400
      ERROR: No ESC(s) detected, exiting.
      voxl2:~/voxl-esc/voxl-esc-tools(dev)$ voxl-inspect-services
       modallink-relink     | Disabled  | Not Running |
       voxl-camera-server   | Disabled  | Not Running |
       voxl-cpu-monitor     | Disabled  | Not Running |
       voxl-dfs-server      | Disabled  | Not Running |
       voxl-imu-server      | Disabled  | Not Running |
       voxl-mavlink-server  | Disabled  | Not Running |
       voxl-portal          | Disabled  | Not Running |
       voxl-px4-imu-server  | Disabled  | Not Running |
       voxl-px4             | Disabled  | Not Running |
       voxl-qvio-server     | Disabled  | Not Running |
       voxl-remote-id       | Disabled  | Not Running |
       voxl-softap          | Disabled  | Not Running |
       voxl-static-ip       | Disabled  | Not Running |
       voxl-streamer        | Disabled  | Not Running |
       voxl-tag-detector    | Disabled  | Not Running |
       voxl-tflite-server   | Disabled  | Not Running |
       voxl-vision-px4      | Disabled  | Not Running |
      • modaltbM
        modaltb ModalAI Team
        Hi @Taylor-Presley ,
        Confirming you are using J18 as the UART port to the ESC, and that the ESC has VBatt power (e.g. when you apply power you get an LED blink at least).
        Do you have access to an oscilloscope to probe? That's my next step with comms issues, I'll try to just probe the UART and make sure there's traffic.
        • Taylor PresleyT
          Taylor Presley
          @modaltb confirmed I'm using J18 and the ESC has power (I get an LED blink and quick chirp on connection). I've got a borrowed oscilloscope and confirmed there is traffic on the ESC. I also tried switching TX/RX on the cabling and this didn't help. I've also now installed voxl-esc per this discussion now and still get the following:
          voxl2:/$ voxl-esc scan
          enabling bridge
          bridge enabled
          [GCC 8.4.0]
          FAILED to ping ESCs
          disabling bridge
          bridge disabled
          What would you recommend for next step?
          • modaltbM
            What if we remove VOXL2 from the equation real quick, and try to go host PC to the ESC? This would be my next step, and we use little USB to Serial adapters for this, e.g. this dongle.
            We have a guide here and this would reduce a variable for us.... I'm semi scratching my head at this point.
            • VinnyV
              Vinny ModalAI Team @Taylor Presley
              Hi @Taylor-Presley
              Make sure if you get that dongle modaltb suggested, you set the interface voltage to 3.3V.
              • Taylor PresleyT
                Taylor Presley
                @modaltb @Vinny I'm using an Adafruit USB to TTL cable that I had around. Only gnd, tx, and rx are connected, and the ESC is powered by the power supply. It had the same issue.
                mdr@mdr-System-Product-Name:~/voxl-esc-dev-python27/tools$ python voxl-esc-scan.py
                INFO: Device and baud rate are not provided, attempting to autodetect..
                Scanning for ESC firmware: /dev/ttyUSB0, baud: 250000
                Scanning for ESC firmware: /dev/ttyUSB0, baud: 2000000
                Scanning for ESC firmware: /dev/ttyUSB0, baud: 921600
                Scanning for ESC firmware: /dev/ttyUSB0, baud: 57600
                Scanning for ESC firmware: /dev/ttyUSB0, baud: 115200
                Scanning for ESC firmware: /dev/ttyUSB0, baud: 230400
                Scanning for ESC bootloader: /dev/ttyUSB0, baud: 38400
                Scanning for ESC bootloader: /dev/ttyUSB0, baud: 230400
                Scanning for ESC bootloader: /dev/ttyUSB0, baud: 921600
                I can order the other dongle, but I'm measuring traffic on Tx and Rx. Thoughts?
                  Alex Kushleyev ModalAI Team
                  Can you check using two scope probes that there is a tx packet into ESC and a reply from ESC immediately after? Also check the signal levels - both should be at 3.3V. Tx and Rx could be shorted, appearing that there is rx and tx traffic. Can also measure resistance between tx and rx lines.
                  • Taylor PresleyT
                    Taylor Presley
                    @Alex-Kushleyev @Vinny @modaltb It has taken a while for me to run this to ground, but I have an update. It does look like there is a tx packet into ESC and a reply when I run the script, and from what I can tell they are simultaneous. Both are at 3.3V and measuring resistance between the lines is ~40-50 kilohms.
                    I've ordered another ESC and will perform the same tests to see if I can get a successful scan on it. Thanks for the help so far!
                    Taylor
                    • modaltbM
                      Hi @Taylor-Presley give me a holler if after you get the new setup you still have problems and I can get on the phone with you and try to troubleshoot!
                        @Taylor-Presley , just to clarify, when you checked TX and RX on the scope, you should have seen first TX data coming from VOXL2 to ESC and then almost immediately ESC responding, right? (not RX and TX showing data at the same time)
                        If that is true, then the ESC seems to be working fine (at least in terms of UART communication) and there may be an issue that is outside of the ESC. Considering that you tried running voxl-esc tools on VOXL2 and on a PC, I am a bit puzzled.
                        Just to be absolutely sure, can you please run the voxl-esc tools from master branch, not the python27 branch. The python27 branch should still work but we are no longer testing it. the latest and greatest is in the master branch.
                        Thank you!
                          Hello @Taylor-Presley , were you able to resolve your issue? I am curious what it was or you still need some help. Thanks!
                          Taylor PresleyT Cai BillC 2 Replies Last reply Reply Quote 0
                          • Taylor PresleyT
                            Taylor Presley @Alex Kushleyev
                            @Alex-Kushleyev we were able to run voxl-esc tools but could only spin up 3 motors. The new ESC that you sent us works now and I'm able to spin all the motors. I wasn't able really to trace a root cause, but I'm just happy that it's working now. Thanks for all the help so far!
                            • Cai BillC
                              Cai Bill @Alex Kushleyev
                              I have the same issue, should I order a new esc? When I run the voxl-esc scan on the voxl2, it is trying to find esc under /dev/slpi-uart-2, which I went and checked under /dev/, and there is such port shown up.
                              The ESC does boot up with the sound, but I think the serial port maybe damaged.
                              Scan Report:
                              voxl-esc
                              Starting Wizard
                              What do you want to do?
                              1) scan              3) spin              5) upload_params
                              2) detect            4) upgrade_firmware
                              #? 1
                              enabling bridge
                              bridge enabled
                              [GCC 8.4.0]
                              Found previous connection information in .voxl_esc_cache ..
                              Prioritizing /dev/slpi-uart-2 @ 57600
                              Sending library name request: libslpi_uart_bridge_slpi.so
                              Couldn't configure flight_controller sensor
                              Error calling voxl_uart_init
                              /usr/bin/voxl-esc: line 131:  8107 Segmentation fault      python3 voxl-esc-scan.py
                              FAILED to ping ESCs
                              disabling bridge
                              bridge disabled
                              DONE
                              ls /dev/slpi-uart-*
                              ls: cannot access '/dev/slpi-uart-*': No such file or directory
                                Alex Kushleyev ModalAI Team @Cai Bill
                                @Cai-Bill, you are using very old voxl-esc tools. Please upgrade your SDK to at least 1.1.3 or 1.2, preferably latest 1.3.
                                Then perform a scan and you should be able to detect the esc. Alternatively, you could connect your esc to a PC if you have the right uart to usb adapter and run the voxl-esc tools on the linux pc.
                                The device for uart is not a typical linux device, it wont show up under /dev.
                                Cai BillC 1 Reply Last reply Reply Quote 0
                                • Cai BillC
                                  I have upgrade the SDK1.3 and got the following error for esc:
                                  voxl2:/$ voxl-esc setup_sentinel_v1
                                  enabling bridge
                                  bridge enabled
                                  [INFO] Setting CPU to performance mode
                                  [INFO] Scanning for ESC...
                                  terminate called after throwing an instance of 'qmi_error'
                                    what():  qmi_client_send_msg_sync() failed, (client_id=)0, result=0: qmi service error (-2)
                                  [ERROR] Unknown board detected:
                                  disabling bridge
                                  bridge disabled
                                  EXITING VOXL-ESC WITH ERROR
                                  Any clue on what may be the case?
                                  • Cai BillC
                                    Cai Bill @Cai Bill
                                    After reboot
                                    I got the following error:
                                    Received standard error event SNS_STD_ERROR_NOT_SUPPORTED
                                    Connection error: connection reset
                                    ERROR:   fc_sensor_initialize failed
                                    ERROR:   Failed to initialize slpi
                                    ERROR:   Encountered error while initializing bus 12
                                    ERROR:   voxl_uart_flush: Bus '12' is not initialized
                                    ERROR:   voxl_uart_write: Bus '12' is not initialized
                                    ERROR:   voxl_uart_read_bytes: Bus '12' is not initialized
                                    ERROR:   voxl_uart_close: Bus '12' is not initialized
                                    • Cai BillC
                                      Cai Bill @Cai Bill
                                      After a third Reboot and and run the tool again I have the esc working:
                                      enabling bridge
                                      bridge enabled
                                      [INFO] M0117-1 detected
                                      [INFO] has for most recent firmware: eb6fb500
                                      [INFO] Expected ESC firmware info:
                                      	Firmware: modalai_esc_firmware_m0117_1_v0_39_RC10_eb6fb500.bin
                                      	Firmware hash: eb6fb500
                                      [INFO] Number of ESCs with correct FW: 0
                                      [INFO] 0 of the ESCs do not have the current firmware
                                      [INFO] Uploading current ESC firmware...
                                      [GCC 8.4.0]
                                      Found voxl-esc tools bin version: 1.6
                                      INFO: Firmware file name : firmware/modalai_esc_firmware_m0117_1_v0_39_RC10_eb6fb500.bin
                                      INFO: Firmware file size : 23088 bytes
                                      INFO: ESC(s) detected: [0, 1, 2, 3]
                                      INFO: Sending reset command to ESC ID 0
                                      INFO: Installing firmware to ESC ID 0 : firmware/modalai_esc_firmware_m0117_1_v0_39_RC10_eb6fb500.bin
                                      	Progress: 100% [##################################################]
                                      INFO: Firmware successfully updated for ESC id 0
                                      [GCC 8.4.0]
                                      INFO: ESC(s) detected: [1, 2, 3]
                                      INFO: Sending reset command to ESC ID 1
                                      INFO: Installing firmware to ESC ID 1 : firmware/modalai_esc_firmware_m0117_1_v0_39_RC10_eb6fb500.bin
                                      INFO: Firmware successfully updated for ESC id 1
                                      [GCC 8.4.0]
                                      INFO: ESC(s) detected: [0, 2, 3]
                                      INFO: Sending reset command to ESC ID 2
                                      INFO: Installing firmware to ESC ID 2 : firmware/modalai_esc_firmware_m0117_1_v0_39_RC10_eb6fb500.bin
                                      INFO: Firmware successfully updated for ESC id 2
                                      [GCC 8.4.0]
                                      INFO: ESC(s) detected: [0, 1, 3]
                                      INFO: Sending reset command to ESC ID 3
                                      INFO: Installing firmware to ESC ID 3 : firmware/modalai_esc_firmware_m0117_1_v0_39_RC10_eb6fb500.bin
                                      INFO: Firmware successfully updated for ESC id 3
                                      [INFO] Verifying firmware upload was succecssful...
                                      successfully flashed firmware to all 4 escs
                                      uploading params file ../voxl-esc-params/Sentinel_V1/Sentinel_V1.xml
                                      [GCC 8.4.0]
                                      INFO: ESC Information:
                                      INFO: ---------------------
                                      	Board      : version 34: ModalAi 4-in-1 ESC (M0117-1)
                                      	UID        : 0x203034305743570C00290031
                                      	Firmware   : version   39, hash eb6fb500
                                      	Bootloader : version  183, hash 25317f42
                                      	UID        : 0x203034305743570C00290041
                                      	UID        : 0x203034305743570C0029003E
                                      	UID        : 0x203034305743570C0029002E
                                      successfully pinged ESCs
                                      [GCC 8.4.0]
                                      INFO: Params file name : ../voxl-esc-params/Sentinel_V1/Sentinel_V1.xml
                                      INFO: Params file size : 7561 bytes
                                      INFO: ESCs detected:
                                      ID: 0, SW: 39, HW: 34: ModalAi 4-in-1 ESC (M0117-1)
                                      ID: 1, SW: 39, HW: 34: ModalAi 4-in-1 ESC (M0117-1)
                                      ID: 2, SW: 39, HW: 34: ModalAi 4-in-1 ESC (M0117-1)
                                      ID: 3, SW: 39, HW: 34: ModalAi 4-in-1 ESC (M0117-1)
                                      INFO: Loading XML config file...
                                      INFO: Uploading params for ESC ID 255...
                                      -- board config
                                      -- id config
                                      -- uart config
                                      -- tune config
                                          DONE
                                      INFO: Resetting ESCs...
                                          DONE
                                      WARNING: Received 12 bytes of data from SLPI while SLPI uart not in use (topic uart_data)
                                      disabling bridge
                                      bridge disabled
                                      Still have no idea why the first two time failed, I did apt update and upgrade between every reboot and I also give chmod 755 to /data/, maybe that helped?
                                        tom admin @Cai Bill
                                        @Cai-Bill When you upgraded to SDK 1.3 did you download the full SDK and use ./install.sh or did you just run apt update && apt upgrade?
                                        • Cai BillC
                                          Cai Bill @tom
                                          @tom I used ./install.sh
                                            @Cai-Bill , I am not exactly sure why there was the issue during the firmware upgrade, but looks like you made it through, and is the ESC working properly now with PX4?
