  3. Using GPIO/I2C as pwm from voxl for payload
17 Posts 5 Posters 2.9k Views 5 Watching
    This isn't something we have tried. Python3 isn't on VOXL by default but you can follow the instructions here to get it going
    • Aldo Castro FreireA Offline
      Aldo Castro Freire
      How do I build the ipk image mentioned in the first step ?
      • Aldo Castro FreireA Aldo Castro Freire
        wrote on last edited by tom
        @Aldo-Castro-Freire If you haven't yet, you will want to follow the steps here to get voxl-docker installed on your desktop in order to use voxl-emulator which allows you to build IPKs for VOXL on your desktop machine.
        • First you will run voxl-docker -i voxl-emulator
        • Then in the docker container you will run ./build.sh
        • Next, also in the container you will run ./make_package.sh
        • Create a directory to store ipks if you haven't adb shell mkdir -p /home/root/ipk
        • After, this you can exit the docker container and push the ipk to your VOXL with adb push Python_3.6.9_8x96.ipk /home/root/ipk/.
        • Lastly, you can install the ipk with opkg install /home/root/ipk/Python_3.6.9_8x96.ipk
        M 1 Reply Last reply
          To be clear though, @Aldo-Castro-Freire you will still need to use voxl-io to communicate with the peripheral
          Aldo Castro FreireA 1 Reply Last reply
          • Chad SweetC Chad Sweet
            Aldo Castro Freire
            @Chad-Sweet I am confused now, I thought the point of the library is that so I will not have to deal with the low-level logic. vox-i2c Basically I still wanna be using the pca9865 to convert to PWM that I can use to control
            using this:
            https://learn.adafruit.com/16-channel-pwm-servo-driver/python-circuitpython
            right now I am not sure. how to connect those two together.
              Yes, sorry for the confusion, voxl-i2c is a part of voxl-io. You will want to use voxl-i2c to communicate with an i2c peripheral
                Aldo Castro Freire
                My question is there a driver for pca9865 that I can use? Cause right now it seems I have not way of accessing the i2c port even if I use the libraries from adafruit.
                So my question is can I run a python program that uses the i2c port to control the pca9865 that will allow me to control servos or payload actuation as an IoT device basically.
                  No, that is not currently available. What you described would require coding in python to make the appropriate voxl-i2c calls per the pca9865 specification
                    Aldo Castro Freire
                    Is there any other module that I can use to control something using the voxl. As I see I am not sure if voxl support any other devices.
                    Do you have any recommendations?
                    Looking for a way to trigger servos without having to install another computer.
                      M Offline
                      M Offline
                      MattO
                      @tom said in Using GPIO/I2C as pwm from voxl for payload:
                      Hi Tom - I just wanted to let you know, after following these directions, I think there may be an error in the step for pushing the IPK to VOXL. Basically, what happened to me using the push command above, is that the contents of the Python_3.6.9_8x96.ipk file got put into a file named "ipk", and the reason is I'm pretty sure I did not have an "ipk" directory yet in /home/root (never pushed an ipk up prior to this). Basically, I had to delete the ipk file that was created, and mkdir an ipk directory in /home/root/. Then, I ran the command below to push the package, and the last step to install worked perfect.
                      adb push Python_3.6.9_8x96.ipk /home/root/ipk/Python_3.6.9_8x96.ipk
                      Might want to fix the instructions/README in the "voxl-python-3.6.9" in github too. Hope this helps!
                        @MattO Thanks for the heads up! I will take a look at this.
                          @tom It's not required to push the ipk to a specific directory, that was just an example of a location that I like to use.
                            @MattO The instructions should be more clear now: https://gitlab.com/voxl-public/other/voxl-python-3.6.9#installing-the-ipk
