  3. ADB Connecting Issue with VOXL2 Board
voxl-2
35 Posts 6 Posters 9.8k Views 3 Watching
    @dlee Are you able to force it into fastboot with the button?
    dleeD 1 Reply Last reply
      dleeD Offline
      dleeD Offline
      dlee
      @tom I can use fastboot mode above the board.
      And I got a different problem another voxl2 board (I have 3 of voxl2 boards) video link. When I connected board to my companion pc using adb cable, the connection is maintained for a very short time and disconnected. Do you know about this problem?
        @dlee I haven't seen that behavior before. Try adb kill-server then adb shell again
          dleeD Offline
          dleeD Offline
          dlee
          @tom Same. Anyway, can I do something using fastboot?
            @dlee Yes, that is how the system image is flashed, which is required after a QDL flash. See here: https://docs.modalai.com/platform-releases/#4-run-install-script
            The install script can be run while the board is in fastboot mode. Look for it with fastboot devices
              dleeD Offline
              dleeD Offline
              dlee
              wrote on last edited by dlee
              #22
              @tom I already did QDL flash.
              This is what I did.
              1. QDL flash
              2. Voxl2 flash using fastboot mode
              3. Connect to the voxl-suite
              4. After I reboot, adb shell didn't work.
                error: no devices/emulators found.
              I tried many times of this from 1 to 4.
                @dlee In that case I would RMA it as that is not normal behavior: https://www.modalai.com/pages/rma
                • dleeD Offline
                  dleeD Offline
                  dlee
                  @tom One more question. Since we have three VOXL2 boards behaving the same way can we buy one RMA (PCB) diagnostic for all three boards or do we have to purchase a RMA (PCB) diagnostic for each board that is faulty?
                  Thanks.
                    @dlee I didn't realize all 3 were exhibiting this behavior, if that's the case something else is going on.
                    What system image and voxl-suite are you flashing on top of the QDL image? Are you loading or running anything else on top of that??
                      @dlee Do you have anything plugged in to your VOXL2s? cameras? modems? add-on boards, usb devices etc.?
                        dleeD Offline
                        dleeD Offline
                        dlee
                        #27
                        @tom I plugged microhard module to use station wifi on voxl (not in microhard). But when I detach the microhard modem, it still didn't work.
                          @dlee Remove the microhard modem and anything else you have plugged in. Does it then allow you to stay in ADB?
                            dleeD Offline
                            dleeD Offline
                            dlee
                            @tom Removed it. ADB wasn't detected. Do you have some advices my setup?
                              @dlee I would plug in USB-C and see what dmesg -wH shows
                                dleeD Offline
                                dleeD Offline
                                dlee
                                @tom This is the result of dmesg -wH
                                [Feb13 02:49] audit: type=1326 audit(1676326229.184:214): auid=1000 uid=1000 gid=1000 ses=3 subj=snap.slack.slack pid=1571188 comm="slack" exe="/snap/slack/68/usr/lib/slack/slack" sig=0 arch=c000003e syscall=92 compat=0 ip=0x7f40dea483b7 code=0x50000
                                [Feb13 03:02] audit: type=1326 audit(1676326970.794:215): auid=1000 uid=1000 gid=1000 ses=3 subj=snap.slack.slack pid=1571188 comm="slack" exe="/snap/slack/68/usr/lib/slack/slack" sig=0 arch=c000003e syscall=92 compat=0 ip=0x7f40dea483b7 code=0x50000
                                [Feb13 03:05] audit: type=1326 audit(1676327178.011:216): auid=1000 uid=1000 gid=1000 ses=3 subj=snap.slack.slack pid=1571188 comm="slack" exe="/snap/slack/68/usr/lib/slack/slack" sig=0 arch=c000003e syscall=92 compat=0 ip=0x7f40dea483b7 code=0x50000
                                [Feb13 03:06] audit: type=1326 audit(1676327247.035:217): auid=1000 uid=1000 gid=1000 ses=3 subj=snap.slack.slack pid=1571188 comm="slack" exe="/snap/slack/68/usr/lib/slack/slack" sig=0 arch=c000003e syscall=92 compat=0 ip=0x7f40dea483b7 code=0x50000
                                [Feb13 03:07] audit: type=1326 audit(1676327271.040:218): auid=1000 uid=1000 gid=1000 ses=3 subj=snap.slack.slack pid=1571188 comm="slack" exe="/snap/slack/68/usr/lib/slack/slack" sig=0 arch=c000003e syscall=92 compat=0 ip=0x7f40dea483b7 code=0x50000
                                [Feb13 03:09] xhci_hcd 0000:00:14.0: Timeout while waiting for setup device command
                                [  +5.375697] xhci_hcd 0000:00:14.0: Timeout while waiting for setup device command
                                [  +0.207848] usb 2-2.1: device not accepting address 26, error -62
                                [Feb13 03:10] usb 2-2.1: new SuperSpeed USB device number 28 using xhci_hcd
                                [  +0.027777] usb 2-2.1: New USB device found, idVendor=05c6, idProduct=901d, bcdDevice= 0.00
                                [  +0.000016] usb 2-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
                                [  +0.000007] usb 2-2.1: Product: QUSB_BULK_SN:73AD68FF
                                [  +0.000006] usb 2-2.1: Manufacturer: Qualcomm CDMA Technologies MSM
                                [  +0.000005] usb 2-2.1: SerialNumber: 8cc63c2c
                                • modaltbM Offline
                                  modaltbM Offline
                                  modaltb
                                  @dlee said in ADB Connecting Issue with VOXL2 Board:
                                  When VOXL2 is showing up as QUSB_BULK_* in USB devices it means it's in emergency download (EDL) mode.
                                  It goes into EDL mode:
                                  • if the EDL switch (SW2) is "ON"
                                  • VOXL2 fails to boot normally do to an error
                                  If the error is recoverable, using QDL resolves SW/flash related issues. If after using QDL to reflash, and turning SW2 back off, the VOXL2 continues to boot into EDL mode, in my experience there's possible HW damage that is causing bootup to fail....
                                  • modaltbM modaltb
                                    dleeD Offline
                                    dleeD Offline
                                    dlee
                                    @modaltb If HW was damaged, Can I get RMA service?
                                    VinnyV 1 Reply Last reply
                                    • modaltbM Offline
                                      modaltbM Offline
                                      modaltb
                                      Hi @dlee information on the RMA process is here : https://www.modalai.com/pages/rma
                                      • dleeD dlee
                                        Hi @dlee
                                        Can you please double check SW2. From that photo you posted, it seems as if it may stay be in the "ON" position, which would keep it in "EDL" mode and show up as "QUSB_BULK..." instead of an ADB debug device.
                                        Please be sure to follow this step carefully when performing QDL updates:
                                        https://docs.modalai.com/voxl2-qdl/
                                        We do not have many HW failures on Voxl2 in the field from routine use, so to have one so soon is surprising. However, if you are confident you are following all instructions and still wish to RMA it, we'll test it again to check for all basic functionality and debug the root cause of the failure, if any, and prompt you for further actions.
