How do I issue an AT command (to modem) and get response?
For sure /dev/ttyUSB2 comes up... All three (/dev/ttyUSB[012]) come up as soon as the modem is powered up. Also, the init scripts in voxl assume its ttyUSB2, and the LTE connection does come up just fine.
Regarding dmesg, honestly, I haven't looked at that simply because fundamentally the link is up and running (I've been streaming video over LTE with it). I just can't probe things with AT commands.
Just ran dmesg with USB as filter, below is some of that dump...[ 5.626078] qcserial 1-1.2:1.0: Qualcomm USB modem converter detected [ 5.626577] usb 1-1.2: Qualcomm USB modem converter now attached to ttyUSB0 [ 5.655658] qcserial 1-1.2:1.2: Qualcomm USB modem converter detected [ 5.656186] usb 1-1.2: Qualcomm USB modem converter now attached to ttyUSB1 [ 5.815383] qcserial 1-1.2:1.3: Qualcomm USB modem converter detected [ 5.815979] usb 1-1.2: Qualcomm USB modem converter now attached to ttyUSB2 -
@Ed-Sutter Does
/dev/ttyUSB2come up at all? It could be there's another drive we're missing in order to enable coms over that port. Does it enumerate as something else on VOXL2 e.g./dev/ttyUSB3?Does
dmesggive you any clues that may point you in the right direction. -
@Ed-Sutter Does
dmesggive you any clues that may point you in the right direction.@tom There is definitely different dmesg output when using the two different modems.
For the RC7611...[ 19.303681] usb 1-1.1: New USB device found, idVendor=1199, idProduct=68c0 [ 19.303716] usb 1-1.1: New USB device strings: Mfr=3, Product=2, SerialNumber=4 [ 19.303743] usb 1-1.1: Product: Qualcomm CDMA Technologies MSM [ 19.303766] usb 1-1.1: Manufacturer: Qualcomm, Incorporated [ 19.303788] usb 1-1.1: SerialNumber: 7e7dbded [ 19.343459] option 1-1.1:1.0: GSM modem (1-port) converter detected [ 19.345574] usb 1-1.1: GSM modem (1-port) converter now attached to ttyUSB0 [ 19.347060] option 1-1.1:1.2: GSM modem (1-port) converter detected [ 19.349603] usb 1-1.1: GSM modem (1-port) converter now attached to ttyUSB1 [ 19.351815] option 1-1.1:1.3: GSM modem (1-port) converter detected [ 19.353829] usb 1-1.1: GSM modem (1-port) converter now attached to ttyUSB2 [ 19.362619] mdss_register_panel: mdss mdp resource not initialized yet [ 19.362665] mdss_wb soc:qcom,mdss_wb_panel: unable to register writeback panel [ 19.373309] qmi_wwan 1-1.1:1.8: cdc-wdm0: USB WDM device [ 19.377024] qmi_wwan 1-1.1:1.8 wwan0: register 'qmi_wwan' at usb-xhci-hcd.0.auto-1.1, WWAN/QMI device, ffffffc06c1ebd10 [ 19.383161] mdss_register_panel: mdss mdp resource not initialized yet [ 19.383184] mdss_wb soc:qcom,mdss_wb_panel: unable to register writeback panel [ 22.285452] usb 1-1.1: USB disconnect, device number 3 [ 22.287788] option1 ttyUSB0: GSM modem (1-port) converter now disconnected from ttyUSB0 [ 22.287966] option 1-1.1:1.0: device disconnected [ 22.289656] option1 ttyUSB1: GSM modem (1-port) converter now disconnected from ttyUSB1 [ 22.289854] option 1-1.1:1.2: device disconnected [ 22.294800] option1 ttyUSB2: GSM modem (1-port) converter now disconnected from ttyUSB2 [ 22.295177] option 1-1.1:1.3: device disconnected [ 22.296485] qmi_wwan 1-1.1:1.8 wwan0: unregister 'qmi_wwan' usb-xhci-hcd.0.auto-1.1, WWAN/QMI device [ 22.297369] [RMNET:HI] rmnet_config_notify_cb(): Kernel is trying to unregister wwan0 [ 22.350081] [RMNET:HI] rmnet_config_notify_cb(): Kernel is trying to unregister wwan0 [ 24.045813] msm-dwc3 7600000.hsusb: DWC3 in low power mode [ 30.455740] msm-dwc3 7600000.hsusb: DWC3 exited from low power mode [ 30.711346] usb 1-1.1: new high-speed USB device number 4 using xhci-hcd [ 30.812657] usb 1-1.1: config 1 has an invalid interface number: 8 but max is 3 [ 30.812706] usb 1-1.1: config 1 has no interface number 1then for the EM7565...
[ 3.882936] usb 1-1.2: New USB device found, idVendor=1199, idProduct=9091 [ 3.882948] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 3.882955] usb 1-1.2: Product: Sierra Wireless EM7565 Qualcomm\xffffffc2\xffffffae Snapdragon\xffffffe2\xffffff84\xffffffa2 X16 LTE-A [ 3.882961] usb 1-1.2: Manufacturer: Sierra Wireless, Incorporated [ 3.882969] usb 1-1.2: SerialNumber: UF92358533041506 [ 3.893106] ufshcd 624000.ufshc: ufshcd_ioctl: User buffer is NULL! [ 3.908035] qcserial 1-1.2:1.0: Qualcomm USB modem converter detected [ 3.908701] usb 1-1.2: Qualcomm USB modem converter now attached to ttyUSB0 [ 3.911484] mdss_register_panel: mdss mdp resource not initialized yet [ 3.911493] mdss_wb soc:qcom,mdss_wb_panel: unable to register writeback panel [ 3.933495] ufshcd 624000.ufshc: ufshcd_ioctl: User buffer is NULL! [ 3.938487] qcserial 1-1.2:1.2: Qualcomm USB modem converter detected [ 3.938850] usb 1-1.2: Qualcomm USB modem converter now attached to ttyUSB1 [ 3.941502] mdss_register_panel: mdss mdp resource not initialized yet [ 3.941513] mdss_wb soc:qcom,mdss_wb_panel: unable to register writeback panel [ 3.961700] ufshcd 624000.ufshc: ufshcd_ioctl: User buffer is NULL! [ 3.962458] ufshcd 624000.ufshc: ufshcd_ioctl: User buffer is NULL! [ 3.964776] ufshcd 624000.ufshc: ufshcd_ioctl: User buffer is NULL! [ 3.970480] qcserial 1-1.2:1.3: Qualcomm USB modem converter detected [ 3.970849] usb 1-1.2: Qualcomm USB modem converter now attached to ttyUSB2 [ 3.973775] mdss_register_panel: mdss mdp resource not initialized yet [ 3.973786] mdss_wb soc:qcom,mdss_wb_panel: unable to register writeback panel [ 4.003719] qmi_wwan 1-1.2:1.8: cdc-wdm0: USB WDM device [ 4.004200] qmi_wwan 1-1.2:1.8 wwan0: register 'qmi_wwan' at usb-xhci-hcd.0.auto-1.2, WWAN/QMI device, ffffffc0f080c390 [ 4.006956] mdss_register_panel: mdss mdp resource not initialized yet [ 4.006966] mdss_wb soc:qcom,mdss_wb_panel: unable to register writeback panel [ 4.017858] ufshcd 624000.ufshc: ufshcd_ioctl: User buffer is NULL! [ 4.019045] ufshcd 624000.ufshc: ufshcd_ioctl: User buffer is NULL!Do those errors on the EM7565 make any sense to you?
@Ed-Sutter I'm not sure whether those errors are related to the Sierra modem or not. It might be worth reaching out to Sierra themselves about the issue? They may be able to provide any missing kernel patches if there are any.
usually you just need to tell the kernel to associate the USB id with a driver. Has that been done where you have built your own kernel with the new USB device ID?
ah, shoot. that's an easy one
Yikes! I hope I took good notes.
