  3. VOXL FLIGHT DECK WIFI CARD NOT BEING READ
flight-deck
5 Posts 3 Posters 991 Views 1 Watching
  • M Offline
    M Offline
    mirasul
    The Wi-Fi was working fine out of the box and then when I attached it to my drone the Wi-Fi card is not being shown in ip a or ifconfig... I don't know what could have happened. Is there a command to enable the Wi-Fi adapter? My setup contains 4 motors 4 ESCs attached to a Power distribution board. The VOXL is powered via LiPo 3s 11.1v battery connected to the Power Module v3. I can ADB in but there is no WLAN0 in ifconfig. Please advise what I should do. I don't have a Debug Add-On board so I can't flash it to factory defaults.
    Print out of ifconfig:Screenshot from 2022-10-20 23-06-04.png
    • Adrian HidalgoA Offline
      Adrian Hidalgo
      @mirasul, that is weird.
      Let's start with your software version. What version are you running?
      What if you try
      voxl-wifi -f
      This'll reset wifi back to factory.
      • M Offline
        M Offline
        mirasul
        I have tried setting it back to factory, to my understanding it should broadcast as VOXL-<MAC ADDRESS of VOXL> however, it doesn't broadcast anything. Here is the output:
        My software version:
        • M Offline
          M Offline
          mirasul
          I just replaced the wifi antennas but no luck still WLAN0 still not shown in ifconfig… please help me out. Do I need to RMA device?
            @mirasul This is most likely a hardware issue in which the WiFi chip on the VOXL has either failed or the solder connection between it and the board has failed.
            I would recommend sending it in for an RMA: https://www.modalai.com/pages/rma
