  3. How do I verify that I'm running latest-n-greatest?
20 Posts 3 Posters 3.1k Views 2 Watching
    @Ed-Sutter I would recommend just updating to the latest platform release: https://docs.modalai.com/platform-releases/
    Ed SutterE 1 Reply Last reply
      Ed SutterE Offline
      Ed SutterE Offline
      Ed Sutter
      @tom Ok, I did that; but is there any way to know what source code is in that build? For example, I need to verify that qmi_wwan.c has my modem's VID/PID.
        @Ed-Sutter I don't have a direct answer for you, @Eric-Katzfey would know more than me but he is out of office for a bit. Are you seeing any performance difference using the new platform release. That release is only a few months old so should contain any Sierra related changes we've made.
        If you do an lsusb -t are the correct drivers picking up the modem? If so it sounds like the VID/PID are being recognized.
          @Ed-Sutter You said in another thread that you saw the patch that adds the PID/VID, can you point me toward that patch?
            Ed SutterE Offline
            Ed SutterE Offline
            Ed Sutter
            @tom I don't see any difference with the latest build. My problem is the same thing I've been posting about in other threads here and here. The power and dns problems are resolved, but still when I run the modem for a while it just stops communicating, and the only way I've been able to restore the interface is with a reboot.
            At one point Eric had mentioned the VID/PID thing, and looking at the file that he pointed me to in git, it did not have the VID/PID info for my modem (EM7565). So, I tried rebuilding voxl-build, but I replaced the qmi_wwan.c file with the one I used on Ubuntu from Sierra Wireless. Anyway, the build failed because somewhere in the bowls of bitbake a patch is made on the qmi_wwan.c file, but since I replaced it, the patch got confused and the build failed. That's the only reason I know that some patch is installed on that file.
            Make sense?
              @Ed-Sutter I see what you're saying. In order to add the VID/PID then we would have to patch qmi_wwan which we've done for other modems and integrate it into https://gitlab.com/voxl-public/system-image-build/meta-voxl.
              If you look through meta-voxl you'll see some other modem related patches we've done in the past, e.g.: https://gitlab.com/voxl-public/system-image-build/meta-voxl/-/blob/master/recipes-kernel/linux-quic/files/qmi_wwan2.patch
              What I would do is run through voxl-build without making any changes. Once it gets past the patching step you should now be able to see the post-patched qmi_wwan.c file and can create another patch based off of that file to then add to meta-voxl.
                Ed SutterE Offline
                Ed SutterE Offline
                Ed Sutter
                @tom I was able to look at the post-patched qmi_wwan.c file and it does have the VID/PID in there. I just don't know for sure if that patch is in the platform build that I just installed (actually, I'm hoping its not because the latest build doesn't fix my problem).
                This is what is running on my machine now...
                / # voxl-version
                system-image: 3.8.0
                kernel:       #1 SMP PREEMPT Tue Apr 26 18:08:39 UTC 2022 3.18.71-perf
                hw version:   VOXL
                voxl-suite:   0.7.0
                If that patch is not part of this package (which appears to be 6 months old), then I'd like to know how I can pull that patch in.
                If on the other hand, its already in this package, then I don't have a clue what to do about my modem issue.
                  @Ed-Sutter Okay cool, well in that case I would recommend building the kernel using voxl-build, flashing the kernel, and seeing if there is a difference in performance.
                    Ed SutterE Offline
                    Ed SutterE Offline
                    Ed Sutter
                    @tom Ok I did that but now I'm scared...
                    I had built the kernel yesterday, so I ran through the steps in "Testing the Kernel Before Flashing" and everything checked out (the timestamp changed).
                    I then followed the steps in "Flashing the Kernel", got this output:
                    $: fastboot flash boot /opt/data/workspace/poky/build/tmp-glibc/deploy/images/apq8096-drone/apq8096-boot.
                    target reported max download size of 536870912 bytes
                    sending 'boot' (56096 KB)...
                    OKAY [  1.551s]
                    writing 'boot'...
                    OKAY [  0.429s]
                    finished. total time: 1.980s
                    but then typed adb devices and got this output:
                    $: adb devices
                    List of devices attached
                    I have not reset or power-cycled anything yet. Should I do that?
                      @Ed-Sutter Yeah you have to reboot or run fastboot reboot, it's still in fastboot mode. For example it'll probably show up with fastboot devices
                        Ed SutterE Offline
                        Ed SutterE Offline
                        Ed Sutter
                        @tom PHEW! Ok, good... It did reboot with the recent kernel image. Now I have to run my tests to see if that helped my modem issue.
                        Thanks much for the help, I'll post back here to let you know if it fixed my problem.
                          @Ed-Sutter Great! I updated the README to make that step more clear.
                            Ed SutterE Offline
                            Ed SutterE Offline
                            Ed Sutter
                            @tom Well, bummer... It didn't help. My test already locked up.
                              @Ed-Sutter Hmm not too sure where to go from here other than contact Sierra for ideas.
                              In the past we've used scripts that run in the background that monitor a network connection and re-enables the connection if it drops off, that might be the route to go.
                              It would be a modified version of something like this: https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-modem/-/blob/master/scripts/modallink_relink.py
                                Ed SutterE Offline
                                Ed SutterE Offline
                                Ed Sutter
                                @tom Thanks!
                                  Ed SutterE Offline
                                  Ed SutterE Offline
                                  Ed Sutter
                                  @tom I just noticed something... When sierra.py runs, the very last thing it does is write 'Y' into /sys/class/net/wwan0/qmi/raw_ip. That write is successful, but then a few seconds later, I can cat that file and see 'N'.
                                  What is running after sierra.py that would do that?
                                    @Ed-Sutter I'm not sure, I think you'd have to dig through the qmi_wwan driver
                                    • Steve TurnerS Offline
                                      Steve Turner
                                      Apologies for highjacking the thread and being a noob, but @Ed-Sutter are you able to build a system image from https://gitlab.com/voxl-public/system-image-build/meta-voxl ?
                                      Or is this the kernel only that you then install ontop of an existing system image?
                                        @Steve-Turner voxl-build allows you to build the kernel only which you can then flash on top of an existing system. Qualcomm licenses are required in order to build a full system image.
