  3. VOXL UVC Server not connecting
19 Posts 3 Posters 3.0k Views 1 Watching
    @Kris What do you get if you try voxl-uvc-server -s?
    KrisK Offline
    KrisK Offline
    Kris
    wrote on last edited by Kris
    Hi, @Eric-Katzfey.
    This is what I get.
    voxl:~$ voxl-uvc-server -s
    *** START DEVICE LIST ***
    Found device 1
    Got device descriptor for 0bda:3035 200901010001
    Found device 0bda:3035
    DEVICE CONFIGURATION (0bda:3035/200901010001) ---
    Status: idle
    VideoControl:
    	bcdUVC: 0x0100
    VideoStreaming(1):
    	bEndpointAddress: 129
    	Formats:
    	MJPEGFormat(1)
    		  bits per pixel: 0
    		  GUID: 4d4a5047000000000000000000000000 (MJPG)
    		  default frame: 1
    		  aspect ratio: 0x0
    		  interlace flags: 00
    		  copy protect: 00
    			FrameDescriptor(1)
    			  capabilities: 00
    			  bit rate: 995328000-995328000
    			  max frame size: 4147200
    			  default interval: 1/30
    			  interval[0]: 1/30
    			FrameDescriptor(2)
    			  capabilities: 00
    			  bit rate: 147456000-147456000
    			  max frame size: 614400
    			  interval[0]: 1/30
    			FrameDescriptor(3)
    			  capabilities: 00
    			  bit rate: 230400000-230400000
    			  max frame size: 960000
    			  interval[0]: 1/30
    			FrameDescriptor(4)
    			  capabilities: 00
    			  bit rate: 377487360-377487360
    			  max frame size: 1572864
    			  interval[0]: 1/30
    			FrameDescriptor(5)
    			  capabilities: 00
    			  bit rate: 442368000-442368000
    			  max frame size: 1843200
    			  interval[0]: 1/30
    			FrameDescriptor(6)
    			  capabilities: 00
    			  bit rate: 589824000-589824000
    			  max frame size: 2457600
    			  interval[0]: 1/30
    			FrameDescriptor(7)
    			  capabilities: 00
    			  bit rate: 986112000-986112000
    			  max frame size: 4108800
    			  interval[0]: 1/30
    			FrameDescriptor(8)
    			  capabilities: 00
    			  bit rate: 1509949440-1509949440
    			  max frame size: 6291456
    			  interval[0]: 1/30
    			FrameDescriptor(9)
    			  capabilities: 00
    			  bit rate: -1876320256--1876320256
    			  max frame size: 10077696
    			  interval[0]: 1/30
    			FrameDescriptor(10)
    			  capabilities: 00
    			  interval[0]: 1/30
    			StillFrameDescriptor
    			  bEndPointAddress: 00
    			  wWidth(1) = 1920
    			  wHeight(1) = 1080
    			  wWidth(2) = 640
    			  wHeight(2) = 480
    			  wWidth(3) = 640
    			  wHeight(3) = 480
    			  wWidth(4) = 640
    			  wHeight(4) = 480
    			  wWidth(5) = 640
    			  wHeight(5) = 480
    			  wWidth(6) = 640
    			  wHeight(6) = 480
    			  wWidth(7) = 640
    			  wHeight(7) = 480
    			  wWidth(8) = 640
    			  wHeight(8) = 480
    			  wWidth(9) = 640
    			  wHeight(9) = 480
    	UncompressedFormat(2)
    		  bits per pixel: 16
    		  GUID: 5955593200001000800000aa00389b71 (YUY2)
    		  default frame: 1
    		  aspect ratio: 0x0
    		  interlace flags: 00
    		  copy protect: 00
    			FrameDescriptor(1)
    			  capabilities: 00
    			  bit rate: 99532800-99532800
    			  interval[0]: 1/3
    			FrameDescriptor(2)
    			  capabilities: 00
    			  interval[0]: 1/30
    			FrameDescriptor(3)
    			  capabilities: 00
    			  bit rate: 117964800-117964800
    			  default interval: 1/8
    			  interval[0]: 1/8
    			FrameDescriptor(4)
    			  capabilities: 00
    			  bit rate: 153600000-153600000
    			  default interval: 1/20
    			  interval[0]: 1/20
    			FrameDescriptor(5)
    			  capabilities: 00
    			  bit rate: 157286400-157286400
    			  interval[0]: 1/8
    			FrameDescriptor(6)
    			  capabilities: 00
    			  bit rate: 150994944-150994944
    			  interval[0]: 1/3
    			FrameDescriptor(7)
    			  capabilities: 00
    			  bit rate: 161243136-161243136
    voxl:~$ lsusb
    Bus 001 Device 003: ID 0bda:3035 Realtek Semiconductor Corp.
    Bus 001 Device 002: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
    Found device 1
    Status: idle
    VideoControl:
    	bcdUVC: 0x0100
    VideoStreaming(1):
    	Formats:
    	MJPEGFormat(1)
    		  bits per pixel: 0
    		  default frame: 1
    		  aspect ratio: 0x0
    		  interlace flags: 00
    		  copy protect: 00
    			FrameDescriptor(1)
    			  capabilities: 00
    			  interval[0]: 1/30
    			FrameDescriptor(2)
    			  capabilities: 00
    			  interval[0]: 1/30
    			FrameDescriptor(3)
    			  capabilities: 00
    			  interval[0]: 1/30
    			FrameDescriptor(4)
    			  capabilities: 00
    			  interval[0]: 1/30
    			FrameDescriptor(5)
    			  capabilities: 00
    			  interval[0]: 1/30
    			FrameDescriptor(6)
    			  capabilities: 00
    			  interval[0]: 1/30
    			FrameDescriptor(7)
    			  capabilities: 00
    			  interval[0]: 1/30
    			FrameDescriptor(8)
    			  capabilities: 00
    			  interval[0]: 1/30
    			FrameDescriptor(9)
    			  capabilities: 00
    			  interval[0]: 1/30
    			FrameDescriptor(10)
    			  capabilities: 00
    			  interval[0]: 1/30
    			  wWidth(1) = 1920
    			  wHeight(1) = 1080
    			  wWidth(2) = 640
    			  wHeight(2) = 480
    			  wWidth(3) = 640
    			  wHeight(3) = 480
    			  wWidth(4) = 640
    			  wHeight(4) = 480
    			  wWidth(5) = 640
    			  wHeight(5) = 480
    			  wWidth(6) = 640
    			  wHeight(6) = 480
    			  wWidth(7) = 640
    			  wHeight(7) = 480
    			  wWidth(8) = 640
    			  wHeight(8) = 480
    			  wWidth(9) = 640
    			  wHeight(9) = 480
    		  bits per pixel: 16
    		  default frame: 1
    		  aspect ratio: 0x0
    		  interlace flags: 00
    		  copy protect: 00
    			FrameDescriptor(1)
    			  capabilities: 00
    			  interval[0]: 1/3
    			FrameDescriptor(2)
    			  capabilities: 00
    			  interval[0]: 1/30
    			FrameDescriptor(3)
    			  capabilities: 00
    			  interval[0]: 1/8
    			FrameDescriptor(4)
    			  capabilities: 00
    			  interval[0]: 1/20
    			FrameDescriptor(5)
    			  capabilities: 00
    			  interval[0]: 1/8
    			FrameDescriptor(6)
    			  capabilities: 00
    			  interval[0]: 1/3
    			FrameDescriptor(7)
    			  capabilities: 00
    			  interval[0]: 1/2
    			FrameDescriptor(8)
    			  capabilities: 00
    			  interval[0]: 1/3
    			  wWidth(1) = 640
    			  wHeight(1) = 480
    			  wWidth(2) = 1920
    			  wHeight(2) = 1080
    			  wWidth(3) = 1280
    			  wHeight(3) = 720
    			  wWidth(4) = 2592
    			  wHeight(4) = 1944
    END DEVICE CONFIGURATION
    *** END DEVICE LIST ***
    voxl:~$
    voxl:~$ lsusb
    • KrisK Kris
      Hi, @Eric-Katzfey.
      This is what I get.
      Found device 1
      Status: idle
      VideoControl:
      	bcdUVC: 0x0100
      VideoStreaming(1):
      	Formats:
      	MJPEGFormat(1)
      		  bits per pixel: 0
      		  default frame: 1
      		  aspect ratio: 0x0
      		  interlace flags: 00
      		  copy protect: 00
      			FrameDescriptor(1)
      			  capabilities: 00
      			  interval[0]: 1/30
      			FrameDescriptor(2)
      			  capabilities: 00
      			  interval[0]: 1/30
      			FrameDescriptor(3)
      			  capabilities: 00
      			  interval[0]: 1/30
      			FrameDescriptor(4)
      			  capabilities: 00
      			  interval[0]: 1/30
      			FrameDescriptor(5)
      			  capabilities: 00
      			  interval[0]: 1/30
      			FrameDescriptor(6)
      			  capabilities: 00
      			  interval[0]: 1/30
      			FrameDescriptor(7)
      			  capabilities: 00
      			  interval[0]: 1/30
      			FrameDescriptor(8)
      			  capabilities: 00
      			  interval[0]: 1/30
      			FrameDescriptor(9)
      			  capabilities: 00
      			  interval[0]: 1/30
      			FrameDescriptor(10)
      			  capabilities: 00
      			  interval[0]: 1/30
      			  wWidth(1) = 1920
      			  wHeight(1) = 1080
      			  wWidth(2) = 640
      			  wHeight(2) = 480
      			  wWidth(3) = 640
      			  wHeight(3) = 480
      			  wWidth(4) = 640
      			  wHeight(4) = 480
      			  wWidth(5) = 640
      			  wHeight(5) = 480
      			  wWidth(6) = 640
      			  wHeight(6) = 480
      			  wWidth(7) = 640
      			  wHeight(7) = 480
      			  wWidth(8) = 640
      			  wHeight(8) = 480
      			  wWidth(9) = 640
      			  wHeight(9) = 480
      		  bits per pixel: 16
      		  default frame: 1
      		  aspect ratio: 0x0
      		  interlace flags: 00
      		  copy protect: 00
      			FrameDescriptor(1)
      			  capabilities: 00
      			  interval[0]: 1/3
      			FrameDescriptor(2)
      			  capabilities: 00
      			  interval[0]: 1/30
      			FrameDescriptor(3)
      			  capabilities: 00
      			  interval[0]: 1/8
      			FrameDescriptor(4)
      			  capabilities: 00
      			  interval[0]: 1/20
      			FrameDescriptor(5)
      			  capabilities: 00
      			  interval[0]: 1/8
      			FrameDescriptor(6)
      			  capabilities: 00
      			  interval[0]: 1/3
      			FrameDescriptor(7)
      			  capabilities: 00
      voxl:~$ lsusb
      Found device 1
      Status: idle
      VideoControl:
      	bcdUVC: 0x0100
      VideoStreaming(1):
      	Formats:
      	MJPEGFormat(1)
      		  bits per pixel: 0
      		  default frame: 1
      		  aspect ratio: 0x0
      		  interlace flags: 00
      		  copy protect: 00
      			FrameDescriptor(1)
      			  capabilities: 00
      			  interval[0]: 1/30
      			FrameDescriptor(2)
      			  capabilities: 00
      			  interval[0]: 1/30
      			FrameDescriptor(3)
      			  capabilities: 00
      			  interval[0]: 1/30
      			FrameDescriptor(4)
      			  capabilities: 00
      			  interval[0]: 1/30
      			FrameDescriptor(5)
      			  capabilities: 00
      			  interval[0]: 1/30
      			FrameDescriptor(6)
      			  capabilities: 00
      			  interval[0]: 1/30
      			FrameDescriptor(7)
      			  capabilities: 00
      			  interval[0]: 1/30
      			FrameDescriptor(8)
      			  capabilities: 00
      			  interval[0]: 1/30
      			FrameDescriptor(9)
      			  capabilities: 00
      			  interval[0]: 1/30
      			FrameDescriptor(10)
      			  capabilities: 00
      			  interval[0]: 1/30
      			  wWidth(1) = 1920
      			  wHeight(1) = 1080
      			  wWidth(2) = 640
      			  wHeight(2) = 480
      			  wWidth(3) = 640
      			  wHeight(3) = 480
      			  wWidth(4) = 640
      			  wHeight(4) = 480
      			  wWidth(5) = 640
      			  wHeight(5) = 480
      			  wWidth(6) = 640
      			  wHeight(6) = 480
      			  wWidth(7) = 640
      			  wHeight(7) = 480
      			  wWidth(8) = 640
      			  wHeight(8) = 480
      			  wWidth(9) = 640
      			  wHeight(9) = 480
      		  bits per pixel: 16
      		  default frame: 1
      		  aspect ratio: 0x0
      		  interlace flags: 00
      		  copy protect: 00
      			FrameDescriptor(1)
      			  capabilities: 00
      			  interval[0]: 1/3
      			FrameDescriptor(2)
      			  capabilities: 00
      			  interval[0]: 1/30
      			FrameDescriptor(3)
      			  capabilities: 00
      			  interval[0]: 1/8
      			FrameDescriptor(4)
      			  capabilities: 00
      			  interval[0]: 1/20
      			FrameDescriptor(5)
      			  capabilities: 00
      			  interval[0]: 1/8
      			FrameDescriptor(6)
      			  capabilities: 00
      			  interval[0]: 1/3
      			FrameDescriptor(7)
      			  capabilities: 00
      			  interval[0]: 1/2
      			FrameDescriptor(8)
      			  capabilities: 00
      			  interval[0]: 1/3
      			  wWidth(1) = 640
      			  wHeight(1) = 480
      			  wWidth(2) = 1920
      			  wHeight(2) = 1080
      			  wWidth(3) = 1280
      			  wHeight(3) = 720
      			  wWidth(4) = 2592
      			  wHeight(4) = 1944
      voxl:~$
      voxl:~$ lsusb
      @Kris Okay, that all looks good. What about voxl-uvc-server -d -m?
      KrisK 1 Reply Last reply
        KrisK Offline
        KrisK Offline
        Kris
        voxl:~$ voxl-uvc-server -d -m
        Enabling debug messages
        Enabling MPA debug messages
        voxl-uvc-server starting
        Image resolution 640x480, 30 fps chosen
        UVC initialized
        Device found
        Device opened
        uvc_get_stream_ctrl_format_size succeeded for format 0
        Streaming starting
        Got frame callback! frame_format = 3, width = 640, height = 480, length = 614400, ptr = (nil)
         * got image 30
         * got image 60
         * got image 90
         * got image 120
         * got image 150
         * got image 180
         * got image 210
         * got image 240
         * got image 270
         * got image 300
         * got image 330
         * got image 360
         * got image 390
         * got image 420
         * got image 450
         * got image 480
         * got image 510
         * got image 540
         * got image 570
         * got image 600
         * got image 630
         * got image 660
         * got image 690
         * got image 720
         * got image 750
         * got image 780
         * got image 810
         * got image 840
         * got image 870
         * got image 900
         * got image 930
         * got image 960
         * got image 990
        ^CGot SIGINT, exiting
        helper thread received sigusr 10
        channel 0 request thread closing
        Done streaming
        UVC exited
        voxl-uvc-server ending
        voxl:~$
        • KrisK Kris
          UVC initialized
          Device found
          Device opened
          Streaming starting
           * got image 30
           * got image 60
           * got image 90
           * got image 120
           * got image 150
           * got image 180
           * got image 210
           * got image 240
           * got image 270
           * got image 300
           * got image 330
           * got image 360
           * got image 390
           * got image 420
           * got image 450
           * got image 480
           * got image 510
           * got image 540
           * got image 570
           * got image 600
           * got image 630
           * got image 660
           * got image 690
           * got image 720
           * got image 750
           * got image 780
           * got image 810
           * got image 840
           * got image 870
           * got image 900
           * got image 930
           * got image 960
           * got image 990
          Done streaming
          UVC exited
          voxl:~$
          @Kris Okay, so that shows that voxl-uvc-server is running.
            KrisK Offline
            KrisK Offline
            Kris
            What do I need to do to view the images/video from my UVC camera?
            voxl:~$ show-video-device-info.sh
            /dev/video2: USB Camera 0bda:3035
            • KrisK Kris
              @Kris You run voxl-uvc-server to get the frames from the camera. See docs.modalai.com/voxl-uvc-server for more information. Then you run voxl-streamer -c uvc-generic to create an RTSP stream that can be viewed remotely using VLC or QGC. Se docs.modalai.com/voxl-streamer for more information.
              KrisK 2 Replies Last reply
                KrisK Offline
                KrisK Offline
                Kris
                #9
                This is where I am a little confused. Do I need to SSH into VOXL and run the
                in one terminal. Then open a new terminal, SSH into VOXL again and run
                voxl:~$ voxl-streamer -c uvc-generic
                  KrisK Offline
                  KrisK Offline
                  Kris
                  @Eric-Katzfey Ok, Thank you!!! I finally got it working 👍
                  • KrisK Kris
                    @Kris I usually use adb shell to setup two separate sessions. I run voxl-uvc-server in one and voxl-streamer in the other.
                      KrisK Offline
                      KrisK Offline
                      Kris
                      @Eric-Katzfey How can I change the frame rates, etc.
                      Or edit the config files?
                        KrisK Offline
                        KrisK Offline
                        Kris
                        @Eric-Katzfey I am trying to get better quality because I need to record via some type of Screen Recorder. I would prefer to save the recorded videos to an SD card, but I don't think that is possible.
                        • KrisK Kris
                          @Kris Yes, you can edit the config files to change resolution, frame rate, etc.
                          • KrisK Kris
                            @Kris We don't currently have a way to save to SD card from the UVC camera. However, you can create your own code to do this. This is a feature that we will be adding in the future.
                              KrisK Offline
                              KrisK Offline
                              Kris
                              @Eric-Katzfey Would I edit the config files from the "uvc-geneirc" at the top or the "uvc-video" at the bottom of the config files?
                              • KrisK Kris
                                @Kris If you are using the uvc-generic configuration then that is the one that you would edit.
                                  KrisK Offline
                                  KrisK Offline
                                  Kris
                                  @Eric-Katzfey Got it 👍
                                  Thank you for your help and quick responses 😊
                                  • local adL Offline
                                    local adL Offline
                                    local ad
                                    WOW what a great thread, so on time for me Thanks Kris
