  3. VOXL UVC Server not connecting
19 Posts 3 Posters 2.8k Views 1 Watching
  • KrisK Offline
    KrisK Offline
    Kris
    I have been trying to connect my UVC camera to view either in VLC or in QGC.
    I thought if I followed the guide for the VOXL UVC Server, that it would work or at least get me in the right direction.
    When I enter;
    voxl:~$ voxl-uvc-server
    nothing happens.
    voxl:~$ voxl-version
    system-image: 3.8.0
    kernel:       #1 SMP PREEMPT Tue Apr 26 18:08:39 UTC 2022 3.18.71-perf
    hw version:   VOXL
    voxl-suite:   0.8.1
    0.7.0
    voxl:~$ voxl-inspect-services
     Service Name             |  Enabled  |   Running   |  CPU Usage
     docker-autorun           | Disabled  | Not Running |
     docker-daemon            | Disabled  | Not Running |
     modallink-relink         | Disabled  | Not Running |
     voxl-camera-server       |  Enabled  |   Running   |    18.0
     voxl-cpu-monitor         |  Enabled  |   Running   |     0.0
     voxl-dfs-server          |  Enabled  | Not Running |
     voxl-imu-server          |  Enabled  |   Running   |     2.0
     voxl-mavlink-server      |  Enabled  |   Running   |     2.0
     voxl-modem               | Disabled  | Not Running |
     voxl-portal              |  Enabled  |   Running   |     0.0
     voxl-qvio-server         |  Enabled  |   Running   |     8.0
     voxl-rangefinder-server  | Disabled  | Not Running |
     voxl-streamer            | Disabled  | Not Running |
     voxl-tag-detector        |  Enabled  | Not Running |
     voxl-tflite-server       | Disabled  | Not Running |
     voxl-time-sync           | Disabled  | Not Running |
     voxl-vision-px4          |  Enabled  |   Running   |     2.0
     voxl-wait-for-fs         |  Enabled  |  Completed  |
    voxl:~$ cd /home/root/ipk
    voxl:~/ipk$ opkg update
    Downloading http://voxl-packages.modalai.com/dists/apq8096/stable/binary-arm64//Packages.gz.
    Updated source 'modalai'.
    voxl:~/ipk$ opkg install voxl-uvc-server
    Package voxl-uvc-server (0.1.1) installed in root is up to date.
    voxl:~/ipk$ cd
    ^Cvoxl:~$
    voxl:~$ voxl-uvc-server -m
    Enabling MPA debug messages
    ^Chelper thread received sigusr 10
    channel 0 request thread closing
    voxl:~$
    voxl:~$ voxl-uvc-server -d
    Enabling debug messages
    voxl-uvc-server starting
    Image resolution 640x480, 30 fps chosen
    UVC initialized
    Device found
    Device opened
    uvc_get_stream_ctrl_format_size succeeded for format 0
    Streaming starting
    Got frame callback! frame_format = 3, width = 640, height = 480, length = 614400, ptr = (nil)
     * got image 30
     * got image 60
     * got image 90
     * got image 120
     * got image 150
     * got image 180
     * got image 210
     * got image 240
     * got image 270
    ^CGot SIGINT, exiting
    Done streaming
    UVC exited
    voxl-uvc-server ending
    voxl:~$
    • KrisK Kris
      When I enter;
      nothing happens.
      system-image: 3.8.0
      hw version:   VOXL
      voxl-suite:   0.8.1
      0.7.0
      voxl:~/ipk$ cd
      ^Cvoxl:~$
      voxl:~$
      UVC initialized
      Device found
      Device opened
      Streaming starting
       * got image 30
       * got image 60
       * got image 90
       * got image 120
       * got image 150
       * got image 180
       * got image 210
       * got image 240
       * got image 270
      Done streaming
      UVC exited
      voxl:~$
      @Kris What do you get if you try voxl-uvc-server -s?
      KrisK 1 Reply Last reply
        KrisK Offline
        KrisK Offline
        Kris
        wrote on last edited by Kris
        Hi, @Eric-Katzfey.
        This is what I get.
        voxl:~$ voxl-uvc-server -s
        *** START DEVICE LIST ***
        Found device 1
        Got device descriptor for 0bda:3035 200901010001
        Found device 0bda:3035
        DEVICE CONFIGURATION (0bda:3035/200901010001) ---
        Status: idle
        VideoControl:
        	bcdUVC: 0x0100
        VideoStreaming(1):
        	bEndpointAddress: 129
        	Formats:
        	MJPEGFormat(1)
        		  bits per pixel: 0
        		  GUID: 4d4a5047000000000000000000000000 (MJPG)
        		  default frame: 1
        		  aspect ratio: 0x0
        		  interlace flags: 00
        		  copy protect: 00
        			FrameDescriptor(1)
        			  capabilities: 00
        			  bit rate: 995328000-995328000
        			  max frame size: 4147200
        			  default interval: 1/30
        			  interval[0]: 1/30
        			FrameDescriptor(2)
        			  capabilities: 00
        			  bit rate: 147456000-147456000
        			  max frame size: 614400
        			  interval[0]: 1/30
        			FrameDescriptor(3)
        			  capabilities: 00
        			  bit rate: 230400000-230400000
        			  max frame size: 960000
        			  interval[0]: 1/30
        			FrameDescriptor(4)
        			  capabilities: 00
        			  bit rate: 377487360-377487360
        			  max frame size: 1572864
        			  interval[0]: 1/30
        			FrameDescriptor(5)
        			  capabilities: 00
        			  bit rate: 442368000-442368000
        			  max frame size: 1843200
        			  interval[0]: 1/30
        			FrameDescriptor(6)
        			  capabilities: 00
        			  bit rate: 589824000-589824000
        			  max frame size: 2457600
        			  interval[0]: 1/30
        			FrameDescriptor(7)
        			  capabilities: 00
        			  bit rate: 986112000-986112000
        			  max frame size: 4108800
        			  interval[0]: 1/30
        			FrameDescriptor(8)
        			  capabilities: 00
        			  bit rate: 1509949440-1509949440
        			  max frame size: 6291456
        			  interval[0]: 1/30
        			FrameDescriptor(9)
        			  capabilities: 00
        			  bit rate: -1876320256--1876320256
        			  max frame size: 10077696
        			  interval[0]: 1/30
        			FrameDescriptor(10)
        			  capabilities: 00
        			  interval[0]: 1/30
        			StillFrameDescriptor
        			  bEndPointAddress: 00
        			  wWidth(1) = 1920
        			  wHeight(1) = 1080
        			  wWidth(2) = 640
        			  wHeight(2) = 480
        			  wWidth(3) = 640
        			  wHeight(3) = 480
        			  wWidth(4) = 640
        			  wHeight(4) = 480
        			  wWidth(5) = 640
        			  wHeight(5) = 480
        			  wWidth(6) = 640
        			  wHeight(6) = 480
        			  wWidth(7) = 640
        			  wHeight(7) = 480
        			  wWidth(8) = 640
        			  wHeight(8) = 480
        			  wWidth(9) = 640
        			  wHeight(9) = 480
        	UncompressedFormat(2)
        		  bits per pixel: 16
        		  GUID: 5955593200001000800000aa00389b71 (YUY2)
        		  default frame: 1
        		  aspect ratio: 0x0
        		  interlace flags: 00
        		  copy protect: 00
        			FrameDescriptor(1)
        			  capabilities: 00
        			  bit rate: 99532800-99532800
        			  interval[0]: 1/3
        			FrameDescriptor(2)
        			  capabilities: 00
        			  interval[0]: 1/30
        			FrameDescriptor(3)
        			  capabilities: 00
        			  bit rate: 117964800-117964800
        			  default interval: 1/8
        			  interval[0]: 1/8
        			FrameDescriptor(4)
        			  capabilities: 00
        			  bit rate: 153600000-153600000
        			  default interval: 1/20
        			  interval[0]: 1/20
        			FrameDescriptor(5)
        			  capabilities: 00
        			  bit rate: 157286400-157286400
        			  interval[0]: 1/8
        			FrameDescriptor(6)
        			  capabilities: 00
        			  bit rate: 150994944-150994944
        			  interval[0]: 1/3
        			FrameDescriptor(7)
        			  capabilities: 00
        			  bit rate: 161243136-161243136
        voxl:~$ lsusb
        Bus 001 Device 003: ID 0bda:3035 Realtek Semiconductor Corp.
        Bus 001 Device 002: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
        Found device 1
        Status: idle
        VideoControl:
        	bcdUVC: 0x0100
        VideoStreaming(1):
        	Formats:
        	MJPEGFormat(1)
        		  bits per pixel: 0
        		  default frame: 1
        		  aspect ratio: 0x0
        		  interlace flags: 00
        		  copy protect: 00
        			FrameDescriptor(1)
        			  capabilities: 00
        			  interval[0]: 1/30
        			FrameDescriptor(2)
        			  capabilities: 00
        			  interval[0]: 1/30
        			FrameDescriptor(3)
        			  capabilities: 00
        			  interval[0]: 1/30
        			FrameDescriptor(4)
        			  capabilities: 00
        			  interval[0]: 1/30
        			FrameDescriptor(5)
        			  capabilities: 00
        			  interval[0]: 1/30
        			FrameDescriptor(6)
        			  capabilities: 00
        			  interval[0]: 1/30
        			FrameDescriptor(7)
        			  capabilities: 00
        			  interval[0]: 1/30
        			FrameDescriptor(8)
        			  capabilities: 00
        			  interval[0]: 1/30
        			FrameDescriptor(9)
        			  capabilities: 00
        			  interval[0]: 1/30
        			FrameDescriptor(10)
        			  capabilities: 00
        			  interval[0]: 1/30
        			  wWidth(1) = 1920
        			  wHeight(1) = 1080
        			  wWidth(2) = 640
        			  wHeight(2) = 480
        			  wWidth(3) = 640
        			  wHeight(3) = 480
        			  wWidth(4) = 640
        			  wHeight(4) = 480
        			  wWidth(5) = 640
        			  wHeight(5) = 480
        			  wWidth(6) = 640
        			  wHeight(6) = 480
        			  wWidth(7) = 640
        			  wHeight(7) = 480
        			  wWidth(8) = 640
        			  wHeight(8) = 480
        			  wWidth(9) = 640
        			  wHeight(9) = 480
        		  bits per pixel: 16
        		  default frame: 1
        		  aspect ratio: 0x0
        		  interlace flags: 00
        		  copy protect: 00
        			FrameDescriptor(1)
        			  capabilities: 00
        			  interval[0]: 1/3
        			FrameDescriptor(2)
        			  capabilities: 00
        			  interval[0]: 1/30
        			FrameDescriptor(3)
        			  capabilities: 00
        			  interval[0]: 1/8
        			FrameDescriptor(4)
        			  capabilities: 00
        			  interval[0]: 1/20
        			FrameDescriptor(5)
        			  capabilities: 00
        			  interval[0]: 1/8
        			FrameDescriptor(6)
        			  capabilities: 00
        			  interval[0]: 1/3
        			FrameDescriptor(7)
        			  capabilities: 00
        			  interval[0]: 1/2
        			FrameDescriptor(8)
        			  capabilities: 00
        			  interval[0]: 1/3
        			  wWidth(1) = 640
        			  wHeight(1) = 480
        			  wWidth(2) = 1920
        			  wHeight(2) = 1080
        			  wWidth(3) = 1280
        			  wHeight(3) = 720
        			  wWidth(4) = 2592
        			  wHeight(4) = 1944
        END DEVICE CONFIGURATION
        *** END DEVICE LIST ***
        voxl:~$
        voxl:~$ lsusb
        • KrisK Kris
          Hi, @Eric-Katzfey.
          This is what I get.
          Found device 1
          Status: idle
          VideoControl:
          	bcdUVC: 0x0100
          VideoStreaming(1):
          	Formats:
          	MJPEGFormat(1)
          		  bits per pixel: 0
          		  default frame: 1
          		  aspect ratio: 0x0
          		  interlace flags: 00
          		  copy protect: 00
          			FrameDescriptor(1)
          			  capabilities: 00
          			  interval[0]: 1/30
          			FrameDescriptor(2)
          			  capabilities: 00
          			  interval[0]: 1/30
          			FrameDescriptor(3)
          			  capabilities: 00
          			  interval[0]: 1/30
          			FrameDescriptor(4)
          			  capabilities: 00
          			  interval[0]: 1/30
          			FrameDescriptor(5)
          			  capabilities: 00
          			  interval[0]: 1/30
          			FrameDescriptor(6)
          			  capabilities: 00
          			  interval[0]: 1/30
          			FrameDescriptor(7)
          			  capabilities: 00
          			  interval[0]: 1/30
          			FrameDescriptor(8)
          			  capabilities: 00
          			  interval[0]: 1/30
          			FrameDescriptor(9)
          			  capabilities: 00
          			  interval[0]: 1/30
          			FrameDescriptor(10)
          			  capabilities: 00
          			  interval[0]: 1/30
          			  wWidth(1) = 1920
          			  wHeight(1) = 1080
          			  wWidth(2) = 640
          			  wHeight(2) = 480
          			  wWidth(3) = 640
          			  wHeight(3) = 480
          			  wWidth(4) = 640
          			  wHeight(4) = 480
          			  wWidth(5) = 640
          			  wHeight(5) = 480
          			  wWidth(6) = 640
          			  wHeight(6) = 480
          			  wWidth(7) = 640
          			  wHeight(7) = 480
          			  wWidth(8) = 640
          			  wHeight(8) = 480
          			  wWidth(9) = 640
          			  wHeight(9) = 480
          		  bits per pixel: 16
          		  default frame: 1
          		  aspect ratio: 0x0
          		  interlace flags: 00
          		  copy protect: 00
          			FrameDescriptor(1)
          			  capabilities: 00
          			  interval[0]: 1/3
          			FrameDescriptor(2)
          			  capabilities: 00
          			  interval[0]: 1/30
          			FrameDescriptor(3)
          			  capabilities: 00
          			  interval[0]: 1/8
          			FrameDescriptor(4)
          			  capabilities: 00
          			  interval[0]: 1/20
          			FrameDescriptor(5)
          			  capabilities: 00
          			  interval[0]: 1/8
          			FrameDescriptor(6)
          			  capabilities: 00
          			  interval[0]: 1/3
          			FrameDescriptor(7)
          			  capabilities: 00
          voxl:~$ lsusb
          Found device 1
          Status: idle
          VideoControl:
          	bcdUVC: 0x0100
          VideoStreaming(1):
          	Formats:
          	MJPEGFormat(1)
          		  bits per pixel: 0
          		  default frame: 1
          		  aspect ratio: 0x0
          		  interlace flags: 00
          		  copy protect: 00
          			FrameDescriptor(1)
          			  capabilities: 00
          			  interval[0]: 1/30
          			FrameDescriptor(2)
          			  capabilities: 00
          			  interval[0]: 1/30
          			FrameDescriptor(3)
          			  capabilities: 00
          			  interval[0]: 1/30
          			FrameDescriptor(4)
          			  capabilities: 00
          			  interval[0]: 1/30
          			FrameDescriptor(5)
          			  capabilities: 00
          			  interval[0]: 1/30
          			FrameDescriptor(6)
          			  capabilities: 00
          			  interval[0]: 1/30
          			FrameDescriptor(7)
          			  capabilities: 00
          			  interval[0]: 1/30
          			FrameDescriptor(8)
          			  capabilities: 00
          			  interval[0]: 1/30
          			FrameDescriptor(9)
          			  capabilities: 00
          			  interval[0]: 1/30
          			FrameDescriptor(10)
          			  capabilities: 00
          			  interval[0]: 1/30
          			  wWidth(1) = 1920
          			  wHeight(1) = 1080
          			  wWidth(2) = 640
          			  wHeight(2) = 480
          			  wWidth(3) = 640
          			  wHeight(3) = 480
          			  wWidth(4) = 640
          			  wHeight(4) = 480
          			  wWidth(5) = 640
          			  wHeight(5) = 480
          			  wWidth(6) = 640
          			  wHeight(6) = 480
          			  wWidth(7) = 640
          			  wHeight(7) = 480
          			  wWidth(8) = 640
          			  wHeight(8) = 480
          			  wWidth(9) = 640
          			  wHeight(9) = 480
          		  bits per pixel: 16
          		  default frame: 1
          		  aspect ratio: 0x0
          		  interlace flags: 00
          		  copy protect: 00
          			FrameDescriptor(1)
          			  capabilities: 00
          			  interval[0]: 1/3
          			FrameDescriptor(2)
          			  capabilities: 00
          			  interval[0]: 1/30
          			FrameDescriptor(3)
          			  capabilities: 00
          			  interval[0]: 1/8
          			FrameDescriptor(4)
          			  capabilities: 00
          			  interval[0]: 1/20
          			FrameDescriptor(5)
          			  capabilities: 00
          			  interval[0]: 1/8
          			FrameDescriptor(6)
          			  capabilities: 00
          			  interval[0]: 1/3
          			FrameDescriptor(7)
          			  capabilities: 00
          			  interval[0]: 1/2
          			FrameDescriptor(8)
          			  capabilities: 00
          			  interval[0]: 1/3
          			  wWidth(1) = 640
          			  wHeight(1) = 480
          			  wWidth(2) = 1920
          			  wHeight(2) = 1080
          			  wWidth(3) = 1280
          			  wHeight(3) = 720
          			  wWidth(4) = 2592
          			  wHeight(4) = 1944
          voxl:~$
          voxl:~$ lsusb
          @Kris Okay, that all looks good. What about voxl-uvc-server -d -m?
            KrisK Offline
            KrisK Offline
            Kris
            voxl:~$ voxl-uvc-server -d -m
            UVC initialized
            Device found
            Device opened
            Streaming starting
             * got image 30
             * got image 60
             * got image 90
             * got image 120
             * got image 150
             * got image 180
             * got image 210
             * got image 240
             * got image 270
             * got image 300
             * got image 330
             * got image 360
             * got image 390
             * got image 420
             * got image 450
             * got image 480
             * got image 510
             * got image 540
             * got image 570
             * got image 600
             * got image 630
             * got image 660
             * got image 690
             * got image 720
             * got image 750
             * got image 780
             * got image 810
             * got image 840
             * got image 870
             * got image 900
             * got image 930
             * got image 960
             * got image 990
            Done streaming
            UVC exited
            voxl:~$
            • KrisK Kris
              UVC initialized
              Device found
              Device opened
              Streaming starting
               * got image 30
               * got image 60
               * got image 90
               * got image 120
               * got image 150
               * got image 180
               * got image 210
               * got image 240
               * got image 270
               * got image 300
               * got image 330
               * got image 360
               * got image 390
               * got image 420
               * got image 450
               * got image 480
               * got image 510
               * got image 540
               * got image 570
               * got image 600
               * got image 630
               * got image 660
               * got image 690
               * got image 720
               * got image 750
               * got image 780
               * got image 810
               * got image 840
               * got image 870
               * got image 900
               * got image 930
               * got image 960
               * got image 990
              Done streaming
              UVC exited
              voxl:~$
              @Kris Okay, so that shows that voxl-uvc-server is running.
                KrisK Offline
                KrisK Offline
                Kris
                What do I need to do to view the images/video from my UVC camera?
                voxl:~$ show-video-device-info.sh
                /dev/video2: USB Camera 0bda:3035
                • KrisK Kris
                  @Kris You run voxl-uvc-server to get the frames from the camera. See docs.modalai.com/voxl-uvc-server for more information. Then you run voxl-streamer -c uvc-generic to create an RTSP stream that can be viewed remotely using VLC or QGC. Se docs.modalai.com/voxl-streamer for more information.
                  KrisK 2 Replies Last reply
                    KrisK Offline
                    KrisK Offline
                    Kris
                    #9
                    This is where I am a little confused. Do I need to SSH into VOXL and run the
                    in one terminal. Then open a new terminal, SSH into VOXL again and run
                    voxl:~$ voxl-streamer -c uvc-generic
                      KrisK Offline
                      KrisK Offline
                      Kris
                      @Eric-Katzfey Ok, Thank you!!! I finally got it working 👍
                      • KrisK Kris
                        @Kris I usually use adb shell to setup two separate sessions. I run voxl-uvc-server in one and voxl-streamer in the other.
                          KrisK Offline
                          KrisK Offline
                          Kris
                          @Eric-Katzfey How can I change the frame rates, etc.
                          Or edit the config files?
                            KrisK Offline
                            KrisK Offline
                            Kris
                            @Eric-Katzfey I am trying to get better quality because I need to record via some type of Screen Recorder. I would prefer to save the recorded videos to an SD card, but I don't think that is possible.
                            • KrisK Kris
                              @Kris Yes, you can edit the config files to change resolution, frame rate, etc.
                              • KrisK Kris
                                @Kris We don't currently have a way to save to SD card from the UVC camera. However, you can create your own code to do this. This is a feature that we will be adding in the future.
                                  KrisK Offline
                                  KrisK Offline
                                  Kris
                                  @Eric-Katzfey Would I edit the config files from the "uvc-geneirc" at the top or the "uvc-video" at the bottom of the config files?
                                  • KrisK Kris
                                    @Kris If you are using the uvc-generic configuration then that is the one that you would edit.
                                      KrisK Offline
                                      KrisK Offline
                                      Kris
                                      @Eric-Katzfey Got it 👍
                                      Thank you for your help and quick responses 😊
                                      • local adL Offline
                                        local adL Offline
                                        local ad
                                        WOW what a great thread, so on time for me Thanks Kris
