  3. VOXL UVC Server not connecting
19 Posts 3 Posters 3.0k Views 1 Watching
  • KrisK Kris
    voxl:~$ voxl-uvc-server -d -m
    Enabling debug messages
    Enabling MPA debug messages
    voxl-uvc-server starting
    Image resolution 640x480, 30 fps chosen
    UVC initialized
    Device found
    Device opened
    uvc_get_stream_ctrl_format_size succeeded for format 0
    Streaming starting
    Got frame callback! frame_format = 3, width = 640, height = 480, length = 614400, ptr = (nil)
     * got image 30
     * got image 60
     * got image 90
     * got image 120
     * got image 150
     * got image 180
     * got image 210
     * got image 240
     * got image 270
     * got image 300
     * got image 330
     * got image 360
     * got image 390
     * got image 420
     * got image 450
     * got image 480
     * got image 510
     * got image 540
     * got image 570
     * got image 600
     * got image 630
     * got image 660
     * got image 690
     * got image 720
     * got image 750
     * got image 780
     * got image 810
     * got image 840
     * got image 870
     * got image 900
     * got image 930
     * got image 960
     * got image 990
    ^CGot SIGINT, exiting
    helper thread received sigusr 10
    channel 0 request thread closing
    Done streaming
    UVC exited
    voxl-uvc-server ending
    voxl:~$
    @Kris Okay, so that shows that voxl-uvc-server is running.
    KrisK 1 Reply Last reply
      KrisK Offline
      KrisK Offline
      Kris
      What do I need to do to view the images/video from my UVC camera?
      voxl:~$ show-video-device-info.sh
      /dev/video2: USB Camera 0bda:3035
      • KrisK Kris
        @Kris You run voxl-uvc-server to get the frames from the camera. See docs.modalai.com/voxl-uvc-server for more information. Then you run voxl-streamer -c uvc-generic to create an RTSP stream that can be viewed remotely using VLC or QGC. Se docs.modalai.com/voxl-streamer for more information.
        KrisK 2 Replies Last reply
          KrisK Offline
          KrisK Offline
          Kris
          wrote on last edited by Kris
          #9
          This is where I am a little confused. Do I need to SSH into VOXL and run the
          in one terminal. Then open a new terminal, SSH into VOXL again and run
          voxl:~$ voxl-streamer -c uvc-generic
            KrisK Offline
            KrisK Offline
            Kris
            @Eric-Katzfey Ok, Thank you!!! I finally got it working 👍
            • KrisK Kris
              @Kris I usually use adb shell to setup two separate sessions. I run voxl-uvc-server in one and voxl-streamer in the other.
                KrisK Offline
                KrisK Offline
                Kris
                @Eric-Katzfey How can I change the frame rates, etc.
                Or edit the config files?
                  KrisK Offline
                  KrisK Offline
                  Kris
                  @Eric-Katzfey I am trying to get better quality because I need to record via some type of Screen Recorder. I would prefer to save the recorded videos to an SD card, but I don't think that is possible.
                  • KrisK Kris
                    @Kris Yes, you can edit the config files to change resolution, frame rate, etc.
                    • KrisK Kris
                      @Kris We don't currently have a way to save to SD card from the UVC camera. However, you can create your own code to do this. This is a feature that we will be adding in the future.
                        KrisK Offline
                        KrisK Offline
                        Kris
                        @Eric-Katzfey Would I edit the config files from the "uvc-geneirc" at the top or the "uvc-video" at the bottom of the config files?
                        • KrisK Kris
                          @Kris If you are using the uvc-generic configuration then that is the one that you would edit.
                            KrisK Offline
                            KrisK Offline
                            Kris
                            @Eric-Katzfey Got it 👍
                            Thank you for your help and quick responses 😊
                            • local adL Offline
                              local adL Offline
                              local ad
                              WOW what a great thread, so on time for me Thanks Kris
