    Seeker Factory Reset
    Seeker
    1.0k
    • V
      VOXL Flight
      Is there any instruction for the factory reset on Seeker?
      • A
        Adrian Hidalgo ModalAI Team
        Yes, depends on what you're trying to reset though. There are several options but before that can you explain your situation that you're having? Might be possible to resolve without a reset.
        • V
          VOXL Flight
          Thank you for your reply, @Adrian-Hidalgo .
          Please refer to https://forum.modalai.com/topic/547/voxl-camera-server/7?_=1656346172322
          This is the problem.
          • A
            Did camera-server work before? Trying to grasp why it's not working; what's the history/what were you trying to attempt?
            What config of Seeker do you have? Hi-Res, TOF, & Tracking?
            • A
              @VOXL-Flight What happens when you restart camera-server?
              systemctl restart voxl-camera-server
              Are all the camera cables in good condition? Intact wires?
              You may also want to re-configuring mpa:
              voxl-configure-mpa -p -f seeker -b blue -c 7 --fc yes
              If it comes down to it, you can flash the Voxl with a system image & Voxl-suite.
              Select wipe & you'll start with a clean slate. Instructions can be found here
              *After flashing you will need to calibrate the cameras, both stereo & tracking: here
              • V
                VOXL Flight
                @Adrian-Hidalgo Thanks for your suggestions that I have already tried.
                Cables and connections are fine.
                What I found just before is cameras were shown up when I did not choose 7: TOF + Stereo + Tracking with voxl-configure-cameras.
                Just before, I chose 3: Hires + Stereo + Tracking and 2) yes_rotate.
                Then voxl-inspect-qvio outputted correct x,y, and z data (in QGC).
                Do you think this is the issue only for my Seeker?
                • A
                  Ah, then you must have the Seeker with the c3 config, Hi-Res, Stereo & Tracking. The Voxl-Cam on the Seeker can have many camera layouts, but generally there's two prominent configs:
                  C 3: Hi-Res, Stereo & Tracking
                  C 7: TOF, Stereo & Tracking
                  Of course the Voxl-Cam can be any of the camera configs listed in the configure cameras.
                  So from what I gather C7 config didn't work, but in configure cameras selecting C3 displayed all cameras & QGC had all the correct data. What happened after selecting C3 in configure cameras?
                  V 1 Reply Last reply 28 Jun 2022, 20:13 Reply Quote 0
                  • V
                    VOXL Flight @Adrian Hidalgo
                    @Adrian-Hidalgo
                    As I mentioned, selecting C3 configuration in my Seeker make voxl-camera-server work correctly.
                    I confirmed voxl-inspect-qvio displayed correct pose data.
                    Thanks, though.
                    By the way, I am wondering if I can increase the storage size of /dev/root on the VOXL. Do you have any idea?
                    • A
                      I'd have to defer you to the software team can answer that specific question, but there is additional 16GB in /data partition
                      V 1 Reply Last reply 29 Jun 2022, 16:32 Reply Quote 0
                      • V
                        @Adrian-Hidalgo Thank you.
                        But the target directory is /dev/root for libraries... so I need to increase the size of this.
                        E 1 Reply Last reply 30 Jun 2022, 16:45 Reply Quote 0
                        • E
                          Eric Katzfey ModalAI Team @VOXL Flight
                          @VOXL-Flight Unfortunately, the partition sizes are determined by the system image build and that is not something that is public. What library do you need to load that is too large? Is there any way to "slim" it down, like remove debug information? Alternately, can you place it somewhere else in the file system and use an environment variable like LD_LIBRARY_PATH to be able to link with it?
                          V 1 Reply Last reply 5 Jul 2022, 15:35 Reply Quote 0
                          • V
                            VOXL Flight @Eric Katzfey
                            I am moving files to /data folder.
                            I have
                            voxl:/usr$ ls
                            aarch64-oe-linux             bin   etc    include  lib64    local  share  tests
                            arm-oemllib32-linux-gnueabi  data  games  lib      libexec  sbin   src
                            I would like to move lib64 and lib folders to /data/usr and do sudo ln -s /data/usr/lib /usr/lib and 'sudo ln -s /data/usr/lib64 /usr/lib64.
                            But I see the error -bash: /bin/resize: No such file or directory when I used some ubuntu commands.
                            Could you please advise me to move these folders into /data?
                            E 1 Reply Last reply 5 Jul 2022, 16:20 Reply Quote 0
                            • E
                              @VOXL-Flight I'm sorry, but this isn't something that we have ever attempted.
                              V 1 Reply Last reply 5 Jul 2022, 21:01 Reply Quote 0
                              • V
                                FYI, I just moved /lib and /usr/lib to /data.
                                This allowed to have enough space for my work.
                                Thank you.
                                1 out of 14
