    No able to update the time using time-sync
    4102
    • Aldo Castro FreireA
      Aldo Castro Freire
      Hey guys I have been using the time service to get the time to get access the internet. but it is not able to update the time and therefore no access to the internet. It has been running for quite some time now
      so it is able to get an IP
        tom admin
        @Aldo-Castro-Freire The voxl-time-sync service does not update the VOXL's time. All it does is loop until the VOXL's time is updated. The VOXL's time is usually updated shortly after it has connected to the internet.
        It looks like you're using an LTE modem? Are you able to ping an IP to determine whether you have an internet connection?
        Aldo Castro FreireA 1 Reply Last reply Reply Quote 0
          Aldo Castro Freire @tom
          @tom yes, but I am unable to ping 8.8.8.8 for example it just hangs there. also, voxl-time-sync never picks up the real-time. I am not sure how to debug this one because the modem shows it does pick up an IP
            tom admin
            @Aldo-Castro-Freire Okay so that is a different issue and voxl-time-sync is not affecting that at all.
            What kind of LTE modem are you using and what carrier?
              Aldo Castro Freire
              it is using the LTE modem https://www.modalai.com/collections/voxl-add-ons/products/voxl-lte?variant=32449203601459 WP7610.
              it is currently using the Telus carrier, apn is isp.telus.com
                tom admin
                @Aldo-Castro-Freire Where are you located? Depending on your location the modem / SIM may not be supported.
                  tom admin
                  @Aldo-Castro-Freire And has it worked in the past?
                    Aldo Castro Freire
                    the current location is Okotoks, Alberta, Canada. It was working fine a week ago but today it wasn't working. I have a 40Gbs plan. I got the sim in the same place and it was working fine
                      tom admin
                      @Aldo-Castro-Freire What does ifconfig wwan0 show ? And what if you just try pinging www.google.com
                        tom admin
                        Actually the full output of ifconfig may be more helpful
                          tom admin
                          Was your previous test in the same location as well?
                            Aldo Castro Freire
                            this is what I get
                              @tom same location.
                                tom admin
                                @Aldo-Castro-Freire And pinging google.com fails the same as 8.8.8.8?
                                  Aldo Castro Freire
                                  it just hangs there, it does not even try I believe!!
                                    tom admin
                                    @Aldo-Castro-Freire Interesting, form what I can see, everything looks like it's running correctly on the software side since you're able to get an IP just fine but the internet connection itself doesn't work...
                                    What does your antenna situation look like?
                                      Aldo Castro Freire
                                      it was power-off at the moment of the photo
                                        tom admin
                                        @Aldo-Castro-Freire Okay that looks normal. Can you try testing the SIM card in another device such as a cellphone to verify it can establish a valid network connection at your location?
                                          Aldo Castro Freire
                                          it is working fine on my phone
                                            Aldo Castro Freire
                                            I saw the wlan has a number for some odd reason
