  3. Cannot Connect to 5G network
rb5
15 Posts 3 Posters 3.4k Views 3 Watching
    @chris_macdonald Okay, Verizon is not supported by Quectel. They won't allow a Quectel modem to connect to their network.
    Internally we test with GoogleFi (uses TMobile)
    C 1 Reply Last reply
      C Offline
      C Offline
      chris_macdonald
      @tom Gotcha. We had the same issue on our private network that does support Quectel.
        @chris_macdonald Okay another thought, we had another customer who needed to unlock their SIM using a PIN in order to enable it: https://forum.modalai.com/topic/783/sim-card-pin-issue-for-lte-v2-module?_=1647023788468
          C Offline
          C Offline
          chris_macdonald
          @tom Just checked it on a phone and SIM card doesn't seem to have a PIN
          • C chris_macdonald
            @chris_macdonald What band is your private network using?
              C Offline
              C Offline
              chris_macdonald
              @Eric-Katzfey N41 (2.5Ghz)
              • C chris_macdonald
                C Offline
                C Offline
                chris_macdonald
                Are there any forcing options? Can we force the drone to be on 5G only?
                  wrote on last edited by tom
                  #13
                  There are, however most carriers require an initial connection to 4G and then a handoff to 5G, therefore the modem may not be able to make a connection when setting to 5G only.
                  By default it is set to both LTE and 5G and will always prefer 5G if it's available.
                  We set this setting in /usr/bin/set-mode-pref
                  which sends an AT command to the modem.
                    C Offline
                    C Offline
                    chris_macdonald
                    @tom The link is coming back bad on my end. We will try a different carrier as well.
                      @chris_macdonald Oops, my bad. It is on board at /usr/bin/set-mode-pref
