  2. VOXL Dev Drones
  3. Qualcomm Flight RB5 5G Drone
  4. Cannot Connect to 5G network
Scheduled Pinned Locked Moved Qualcomm Flight RB5 5G Drone
15 Posts 3 Posters 3.1k Views 3 Watching
  • C Offline
    C Offline
    chris_macdonald
    We have the 5G Sim card in and the connectivity guide is not working for us. We can start the connection process, but the modem is not connecting to the 5G network.
    • tomT Online
      tomT Online
      @chris_macdonald Did you run through rb5-modem-configure ?
      C 1 Reply Last reply
        C Offline
        C Offline
        chris_macdonald
        @tom Yes we did. We tried both carrier and private network and neither worked for us.
        • tomT Online
          tomT Online
          @chris_macdonald One note, after running through rb5-modem-configure it'll setup a rb5-modem background service. I recommend disabling that service if you're experimenting with initializing a connection manually: systemctl stop rb5-modem && systemctl disable rb5-modem
          Otherwise you may have the same script running twice at the same time.
          What cellular provider are you attempting to use?
            C Offline
            C Offline
            chris_macdonald
            @tom Noted. Stopping and disabling the service before manually running the modem start script appears to have not changed the outcome. Letting the service start it by itself does not seem to work to establish a connection either.
            The carrier network we tried was Verizon. We have switched back to our private network.
            • tomT Online
              tomT Online
              @chris_macdonald Okay, Verizon is not supported by Quectel. They won't allow a Quectel modem to connect to their network.
              Internally we test with GoogleFi (uses TMobile)
                C Offline
                C Offline
                chris_macdonald
                @tom Gotcha. We had the same issue on our private network that does support Quectel.
                • tomT Online
                  tomT Online
                  @chris_macdonald Okay another thought, we had another customer who needed to unlock their SIM using a PIN in order to enable it: https://forum.modalai.com/topic/783/sim-card-pin-issue-for-lte-v2-module?_=1647023788468
                    C Offline
                    C Offline
                    chris_macdonald
                    @tom Just checked it on a phone and SIM card doesn't seem to have a PIN
                    • C chris_macdonald
                      Eric KatzfeyE Online
                      @chris_macdonald What band is your private network using?
                        C Offline
                        C Offline
                        chris_macdonald
                        @Eric-Katzfey N41 (2.5Ghz)
                        • C chris_macdonald
                          C Offline
                          C Offline
                          chris_macdonald
                          Are there any forcing options? Can we force the drone to be on 5G only?
                          • tomT Online
                            tomT Online
                            wrote on last edited by tom
                            #13
                            There are, however most carriers require an initial connection to 4G and then a handoff to 5G, therefore the modem may not be able to make a connection when setting to 5G only.
                            By default it is set to both LTE and 5G and will always prefer 5G if it's available.
                            We set this setting in /usr/bin/set-mode-pref
                            which sends an AT command to the modem.
                              C Offline
                              C Offline
                              chris_macdonald
                              @tom The link is coming back bad on my end. We will try a different carrier as well.
                              • tomT Online
                                tomT Online
                                @chris_macdonald Oops, my bad. It is on board at /usr/bin/set-mode-pref
