VOXLFlight LTE modem
I have several questions:- What's reason that by voxl-inspect-services I see, that :
voxl-modem
voxl-qvio-server
voxl-vision-px4
are in "Not running" state, while the services were configured and I received "approving for it enabling and starting" -
"enabling voxl-qvio-server systemd service
starting voxl-qvio-server systemd service
Done configuring voxl-qvio-server"
2)How could i know if voxl flight is LTE server or client?
3)Is it possible to configure LTE v2 modem except of "voxl-configure-modem"?(AT commands)
If the voxl services were marked as enabled but not running that means that they were stopped for one of two reasons: A) you ran them manually in a terminal window which killed the background process since only one instance can run at a time or B) they encountered some sort of error. If the ran into an error you can check the output logs from the services using
journalctl -u voxl-qvio-serverorjournalctl -u voxl-vision-px4. If they crashed due to an error, the info as to why will be there and posting those logs will allow us to help further.I can't speak to the modem configuration stuff but i'll ping someone who can.
@relevinsky For
voxl-modemdepending on what configuration is set up, the background service may exit. This could be due to a failure, or it may be a successful exit if it finished running everything it needed to.Once the modem is brought up, you can send AT commands to
/dev/ttyUSB2using something similar to:echo -ne "AT+QENG=\"servingcell\"\r" | busybox microcom -t 1000 /dev/ttyUSB2This exact AT command isn't supported on Sierra modems but using this same format of piping a command to microcom will work.
Here is a link to a Sierra doc about which AT commands are supported on 76** modems: https://source.sierrawireless.com/resources/airprime/software/airprime_wpx5xx_wp76xx_wp77xx_at_command_reference/
@Alex-Gardner said in VOXLFlight LTE modem:
Thank you for your answer.
I found a problem:
"loading qvio config file
Error in json_read_file while parsing file /etc/modalai/voxl-qvio-server.conf"
I made only voxl-configure-qvio ,the broken file is created after that (i think)
Could you help me to solve a problem?
Thanks -
Thank you.
How could i know wherever voxl flight is LTE server or client?
Thanks, -
@relevinsky What do you mean by LTE server / client? LTE is a cellular technology that will provide your Voxl flight with Internet access.
