  3. Set static IP on ModalAI M500
5 Posts 4 Posters 1.1k Views 4 Watching
  • vmassagueV Offline
    vmassagueV Offline
    vmassague
    Hi!
    I'm trying to set a static IP for a WiFi interface on my ModalAI M500. To do that I've been checking the forum because I didn't know how to start.
    I have experience doing this in other OS like Ubuntu 20.04, in which I just have to create a new interface using nmtui, setting the static and the gateway. However, to do that in yocto I'm facing some issues.
    I tried to do it like in this post:
    1. I have voxl-wifi set on station mode. Should change the mode or is it ok? It is not clear to me on the post I have been looking.
    2. I have created the folder network and script interfaces in /etc because I didn't have it on my drone by default.
    3. I have set up my interface like this:
    iface wlan0 inet static
    	address 10.42.0.25
    	netmask 255.255.255.0
    	gateway 10.42.0.1
    1. I rebooted the drone to see the changes but wlan0 interface is not set with the static IP.
    I also tried doing a ifconfig wlan0 down and then ifconfig wlan0 up.
    Maybe this is not the way to go, so I would really appreciate some advise on this. Thank you in advance!
    • vmassagueV vmassague
      Hi!
      	address 10.42.0.25
      	gateway 10.42.0.1
      @vmassague You can try this: https://www.howtogeek.com/118337/stupid-geek-tricks-change-your-ip-address-from-the-command-line-in-linux/
      vmassagueV Tal RisinT 2 Replies Last reply
        @vmassague Another thing to look at is /etc/systemd/system/wlan_daemon.service which is default linux service that controls WiFi. You can look there to see if anything is hardcoded WiFi-wise.
          vmassagueV Offline
          vmassagueV Offline
          vmassague
          It works following the steps of the tutorial. Thank you!
            Tal RisinT Offline
            Tal RisinT Offline
            Tal Risin
            @Eric-Katzfey said in Set static IP on ModalAI M500:
            Is there a way to set the static IP permanently?
            I saw that in the WiFi guide you recommend reserving the IP in the WiFi router, unfortunately that's not an option for me.
