    Set static IP on ModalAI M500
    • vmassagueV
      vmassague
      Hi!
      I'm trying to set a static IP for a WiFi interface on my ModalAI M500. To do that I've been checking the forum because I didn't know how to start.
      I have experience doing this in other OS like Ubuntu 20.04, in which I just have to create a new interface using nmtui, setting the static and the gateway. However, to do that in yocto I'm facing some issues.
      I tried to do it like in this post:
      1. I have voxl-wifi set on station mode. Should change the mode or is it ok? It is not clear to me on the post I have been looking.
      2. I have created the folder network and script interfaces in /etc because I didn't have it on my drone by default.
      3. I have set up my interface like this:
      iface wlan0 inet static
      	address 10.42.0.25
      	netmask 255.255.255.0
      	gateway 10.42.0.1
      1. I rebooted the drone to see the changes but wlan0 interface is not set with the static IP.
      I also tried doing a ifconfig wlan0 down and then ifconfig wlan0 up.
      Maybe this is not the way to go, so I would really appreciate some advise on this. Thank you in advance!
        Eric Katzfey ModalAI Team @vmassague
        @vmassague You can try this: https://www.howtogeek.com/118337/stupid-geek-tricks-change-your-ip-address-from-the-command-line-in-linux/
        vmassagueV Tal RisinT 2 Replies Last reply Reply Quote 0
          tom admin
          @vmassague Another thing to look at is /etc/systemd/system/wlan_daemon.service which is default linux service that controls WiFi. You can look there to see if anything is hardcoded WiFi-wise.
          • vmassagueV
            vmassague @Eric Katzfey
            It works following the steps of the tutorial. Thank you!
            • Tal RisinT
              Tal Risin @Eric Katzfey
              @Eric-Katzfey said in Set static IP on ModalAI M500:
              Is there a way to set the static IP permanently?
              I saw that in the WiFi guide you recommend reserving the IP in the WiFi router, unfortunately that's not an option for me.
