    m500 accessing camera and image stream data
    269
    • yu zhangY
      yu zhang
      Hi team,
      I am wondering how to open video view in QGC or there is another app for image viewing? I tried to hit the recording button in QGC, but I got this error:
      1. I am not sure if this button could switch between the map view and video view in QGC, or I should run another app like Image View GUI? If I plug a sdcard, all of the image data will be stored atomically by the sdcard path? Or I could config a specific file path for storing?
      2. I would access image stream data for development purposes, should I use any APIs to achieve this? And I check that the voxl-camera-server lists all 3 types of cameras' default settings. Should I change the settings if I would change the stereo to 90fps for example? Also, could I access all 3 cameras' data simultaneously? Please advise any related development documents for further instructions. Thanks.
        Eric Katzfey ModalAI Team @yu zhang
        @yu-zhang Our recommended method for streaming video is via our voxl-streamer application. The documentation is here: https://docs.modalai.com/voxl-streamer/
        yu zhangY 1 Reply Last reply Reply Quote 0
        • yu zhangY
          yu zhang @Eric Katzfey
          Hi @Eric-Katzfey ,
          Thanks, and will the image view of the voxl-streamer look like the below Image Viewer GUI?
          I am also wondering how to show the resource monitoring via a command line like the left side of the screenshot?
            tom admin
            @yu-zhang The user is ssh'ed into the drone and using: voxl-inspect-cpu
              @yu-zhang I'm not sure I understand your first question. voxl-streamer streams the image to a viewer. It isn't a viewer. The viewer is something like QGroundControl or VLC.
              • yu zhangY
                yu zhang @tom
                @tom Thanks!
                • yu zhangY
                  @Eric-Katzfey I see, so what if I would have a viewer to show the stream data in real-time, how should I config it in QGC?
                  If I would access the stream data remotely on PC, I could get data via voxl-streamer, right?
                  What if I would access the data onboard? For example, if I would develop a native VO application, should I still use voxl-streamer or other APIs?
                    @yu-zhang Please read through the documentation at https://docs.modalai.com/voxl-streamer/. This gives an overview on how the whole process is supposed to work.
                    • yu zhangY
                      @Eric-Katzfey Thanks, all right I will have a look at it then.
