  3. VOXL m500 GPS not working and no light indicating
16 Posts 4 Posters 1.9k Views 3 Watching
  • Chad SweetC Chad Sweet
    You should not change the firmware that shipped with the drone. The drone was flown right before putting in the box and it is tested to be in working order.
    Are you outside testing GPS?
    The instructions before are in case you accidentally changed the firmware.
    Everything you are looking for can be found at https://docs.modalai.com
    yu zhangY Offline
    yu zhangY Offline
    yu zhang
    @Chad-Sweet I just tested outside, and it seems the GPS is still not showing. It shows No GPS lock to the drone, and the sensor list still shows GPS error. So, I am not sure if this is the issue with firmware or the GPS sensor.
      yu zhangY Offline
      yu zhangY Offline
      yu zhang
      @Chad-Sweet I took off the propellers for a safe test, so I am not sure if this is an issue. Will the firmware be able to check if the propellers are not ready?
      • yu zhangY yu zhang
        @yu-zhang The software doesn't know whether the drone has propellers on or off.
        • ? Offline
          Hi @yu-zhang ,
          I'm sorry you have this issue. GPS can be a pain sometimes.
          I'm curious what part of the world are you located? Somtimes if the GPS location is very far from the original GPS lock, it can take a long time to get a new GPS lock.
          For debugging, can you capture and share a log?
          Outside with no propellers, arm the drone. Disable after 1 minute. Upload the log here privately: https://review.px4.io/
          Share the link to the log after it's loaded into flight review. Maybe there will be some hints there, etc.
          Another question, does the LED flash when you transition from manual to altitude to position flight modes while disarmed on the ground? QGC should update telling you that your flight modes have changed.
          Also, what is the value of your EKF2_AID_MASK? Sometimes that value can be left in vision mode, something like 280 as opposed to 1 for GPS outdoor flight.
          Rich
          • yu zhangY Offline
            yu zhangY Offline
            yu zhang
            Hi @RichieRich ,
            Thanks for that.
            I am located in Melbourne, Australia. I am not quite sure if this issue is caused due to different regions, and I am wondering if the original GPS lock is located in USA?
            All right, I will collect a log for double-check. So, should I simply use "logcat" command to output the log during the arm for 1 min?
            The LED flash is disabled when I transition from manual to altitude to position flight modes, and it seems the firmware issue mentioned in the post: https://forum.modalai.com/topic/623/gps-led-not-lighting-up?_=1641961403054. QGC works well to tell me different modes when changed.
            And can you please advise where could I check the value of EKF2_AID_MASK? I am currently learning the SDK.
            • ? Offline
              The drone was built at our headquarters in San Diego, California.
              The PX4 flight log can be downloaded through QGC.
              The PX4 parameters can be viewed and updated through QGC as well.
              If the LED is disabled, it's possible it has newer hardware that will need the updated firmware. But, let's first see if the GPS unit is OK.
              yu zhangY 1 Reply Last reply
              • ? A Former User
                yu zhangY Offline
                yu zhangY Offline
                yu zhang
                Hi @RichieRich ,
                I just made a test and uploaded the log to this link: https://review.px4.io/plot_app?log=94b707d4-8deb-4f32-84fe-f102c8d243b1
                And the value of EKF2_AID_MASK is 280 during the test:
                For this time, it seems the drone gets a GPS lock (after flying 40-50s), but QGC couldn't show the map.
                However, it seems the sensor status is still showing that GPS has an error.
                So, please any advice about this?
                By the way, I am wondering how to use the RC controller to take off the drone? I saw in the quick start video that the pilot used a default mapping (turning the left stick down-right for take-off and down-left for disable) to control it. But, in my case that I used DX6e with 6 channels, I couldn't control the take-off, and turning left stick up is the disable as default. It seems that I couldn't config it in QGC.
                • ? Offline
                  wrote on last edited by A Former User
                  #13
                  Great, looks like the GPS is now working 🙂
                  This document is helpful for a few m500 things: https://docs.modalai.com/voxl-m500-getting-started/
                  If you would like to use GPS for position flight, you'll need to update the parameters, especially ekf2_aid_mask, which should be set to 1. You can use the helpers here to load the correct value for outdoor setup: https://gitlab.com/voxl-public/flight-core-px4/px4-parameters/-/tree/master/helpers/m500
                  If you're indoors, it's possible the GPS may get a fix, but still have a large error in vertical or horizontal speed.
                  To use a DX6e, ensure that is bound to the satellite receiver (the orange LED should be illuminated on the receiver). The document linked above shows you how to bind to a new R/C. You also need to calibrate a new R/C in the QGC radio menu as well.
                  Regarding the map in QGC, you need an internet connection to cache the map before connecting to an isolated WiFi network, such at the m500 hostspot. You can also download maps using the QGC application settings.
                  It takes a while to get up to speed, but I'm sure you'll figure out all these little things quickly 🙂
                  • ? A Former User
                    yu zhangY Offline
                    yu zhangY Offline
                    yu zhang
                    @RichieRich Thanks for your advice! I will figure that out very soon 😉
                    One quick question, what is the m500's maximum flight speed? It seems this spec doesn't show it in the m500's list, but I see the maximum speed of the latest Qualcomm Flight RB5 is about 5 m/s. So, I am not sure if m500 can reach the same speed.
                    If so, are there any restraints (e.g., code or parameter settings should be updated) for enabling flying at high speed? And is that possible that we could speed m500 over 5 m/s like up to 7-10 m/s?
                    • ? Offline
                      #15
                      https://docs.px4.io/master/en/advanced_config/parameter_reference.html#multicopter-attitude-control
                      The RB5 and m500 are very close physically (same motors and frame) with some changes to main fuelselage.
                      The m500 can easily fly 10 m/s +. You might have to update the parameter noted here, which is set at default at 12 m/s. In addition, when you run a mission you can set the speed directly when flying to each waypoint. You can experiment and see how it updates, etc.
                      • ? A Former User
                        yu zhangY Offline
                        yu zhangY Offline
                        yu zhang
                        @RichieRich , It's great to know about it. Thanks!
                        I will then try to update to see how it goes 😉
