    m500 Failed take-off: CPU load too high 100%
    • yu zhangY
      yu zhang
      Hi team,
      I am trying to test the drone take-off the first time, but I got the CPU load too high 100% error after flying 5-8s, then it automatically landed. It's about 20-30 cm high above the take-off spot, so it doesn't hurt the drone.
      I am wondering why it happened? It's the first take-off with propellers, and the battery remains at 35-38% before flying, but it drops to about 15-18% after 5-8s.
      I am not sure if the battery spec causes this issue (I could only find these with a similar capacity to the recommended one in Australia).
      So, any suggestions about it? And any parameters I should check if it would happen again? Thanks.
      • yu zhangY
        yu zhang
        The firmware is v1.11.3. I am not sure if I should need to update to the latest one.
        • Chad SweetC
          Chad Sweet ModalAI Team
          You should not change the firmware from what was shipped. It was all tested and working
          It looks most likely you need to charge your batteries.
          I have not seen that error, but trying to fly with low battery is not safe
          yu zhangY 1 Reply Last reply Reply Quote 1
          • Chad SweetC
            Please:
            1. charge the battery
            2. collect PX4 logs and retrieve from the SD card
            3. post logs here: https://logs.px4.io/ and we can take a look
              Battery setup information is here: https://docs.modalai.com/fc-configure-misc/#11-battery-configuration
              Ensure this is properly set and batteries are charged 🙂
              You can also pull logs directly from QGC to make it easier.
              I haven't seen this CPU error before. Update the parameters, try again, and share the log if it comes up.
              yu zhangY 1 Reply Last reply Reply Quote 0
              • yu zhangY
                yu zhang @Chad Sweet
                • yu zhangY
                  yu zhang @Guest
                  @RichieRich ,
                  I may find an issue with one of the batteries (the blue one in the above pic). I was trying to charge it with 4S 14.8v, 3.3A settings, but the charger tells that the blue one is recognized as only 3S and breaks the charging every time. It's quite weird why the charger tests the battery as a 3S setting. The green one works well, and no CPU error happened after fully charging.
                  So, I think I may have to contact the battery provider to double-check the quality of the blue one. Since the blue one cannot charge at the time, I may not be able to test this error with logs. I will get back if the battery provider could advise me how to charge it.
