  3. Starling 2 max Not detecting Wifi hardware
6 Posts 4 Posters 847 Views 2 Watching
  • V Offline
    V Offline
    vmbasvi
    I am setting up a new Starling 2 Max (SKU: MRB-D0012-4-V2-C28-T8-M11-X0) and am unable to configure Wi-Fi.
    The system reports:
    voxl-wifi getmode → Mode: undefined, Hardware: single-mode (None)
    voxl-my-ip only shows 192.168.168.100 (usb0)
    iw dev returns no wireless interfaces
    ip link shows no wlan0 or uap0
    ping 8.8.8.8 returns Network is unreachable
    I also verified that the Wi-Fi driver module exists and loads successfully:
    88XXau.ko is present under /lib/modules/4.19.125/
    modprobe 88XXau loads without errors
    lsmod shows 88XXau loaded
    However, no wireless interface appears after loading the driver. This Starling was taken directly out of the box and has not been modified.
    System information:
    System Image: 1.8.06-M0054-14.1a-perf
    VOXL Suite: 1.6.3
    Hardware Platform: M0054
    Kernel: 4.19.125
    Could you please advise whether additional configuration is required or if there may be an issue with the Wi-Fi hardware or image installation?
    • V vmbasvi
      The system reports:
      System information:
      VOXL Suite: 1.6.3
      Kernel: 4.19.125
      Are you able to unplug the wifi adapter from USB and plug it back in (while VOXL2 is on) and check what kernel reports in dmesg ?
      V 2 Replies Last reply
        V Offline
        V Offline
        vmbasvi
        @Alex-Kushleyev 04a8c33a-1e58-4acb-a897-8b8b4b708f9d.jpeg This is the drone in question so how exactly do you mean Wifi adapter
          V Offline
          V Offline
          vmbasvi
          @Alex-Kushleyev does it need additional usb wifi dongle?
          • N Offline
            N Offline
            nl_vdi
            @vmbasvi said in Starling 2 max Not detecting Wifi hardware:
            I don't have this config so I can't confirm, but It may not come with WiFi module out of the box.
            It looks like the modem carrier board may support USB2, Referencing documentation here:
            https://docs.modalai.com/microhard-add-on-datasheet/
            So you may be able to add:
            https://www.modalai.com/products/mcbl-00009
            To J4/J5 (or equiv) on your modem board
            And one of the USB WiFi modules listed here:
            https://docs.modalai.com/voxl-2-wifi-setup/
            Note: We've had great performance with the AWUS036ACS as long as it is connected to a 2.4ghz network.
            Perhaps @Alex-Kushleyev can confirm if this setup will work through the modem USB ports.
            • V vmbasvi
              @vmbasvi That appears to be a Microhard modem, not a WiFi dongle.
