  3. Station Mode Issue with Voxl Suite 1.6.3
23 Posts 4 Posters 1.8k Views 1 Watching
  • M Offline
    M Offline
    Matt69
    Hello Modal AI team,
    I just flashed my Voxl2 with the newest SDK 1.6.3. The issue is I cannot seem to get station mode working with voxl-wifi. Is this a common bug or am I missing something here? Here is my system info from the abd shell "intro" for reference.
    M 1 Reply Last reply
    • M Matt69
      M Offline
      M Offline
      Matt69
      @Matt69 For further clarification, my understanding is that a 169.XXX.XXX.XXX IP address indicates off nominal wifi performance. Please advise.
      • M Matt69
        Hi @Matt69 ,
        Yes, the shown ip address is a self-assigned address which happens if there is no ip address assigned by a DHCP server.
        What wifi module are you using?
        Does output of iwconfig wlan0 show that you are connected to your Access Point?
        F 1 Reply Last reply
          Hi @Matt69 ,
          F Offline
          F Offline
          fhaltmayer
          wrote on last edited by fhaltmayer
          I'm also facing this after updating. Worked on an older version but it is now defaulting to the link local. One thing I noticed is that it doesn't go through the connection process (finding the network, trying password, etc) when using voxl-wifi, just skips all of it:
          Configuring station mode...
          Detected WiFi interface: wlan0
          NetworkManager not installed, using legacy wpa_supplicant/hostapd
          stopping softap mode
          Enabling station mode on wlan0 (legacy)...
          creating wpa_supplicant configuration for station mode
          Station mode enabled on wlan0
          Station mode configured!
          This is using the MCBL-00022 kit on the voxl2.
          Downgrading to 1.6.2 and the wifi works but seems a bit bugged because it cant find it at first even though it connects successfully :
          Disabling all WiFi modes...
          Scanning for network 'xxx'...
          Scan succeeded, looking for network 'xxx'
          Could not find network 'xxx' in scan results - proceeding anyway
          Enabling station mode on wlan0...
          • F fhaltmayer
            @fhaltmayer , which wifi usb adapter are you using?
              F Offline
              F Offline
              fhaltmayer
              @Alex-Kushleyev The Alfa Network AWU2036
              • F fhaltmayer
                @fhaltmayer ,
                SDK 1.6.3 added support for usb-eth0 (ethernet over usb). That interface should be using subnet 192.168.7.x. If your wifi subnet is the same, that could cause issues. Can you please check to make sure your wifi subnet is different?
                  @fhaltmayer ,
                  I have just tested this on voxl2 using SDK 1.6.3 and it seems to be working. The prints were updated, but what you see is normal (i saw the same messages). Did you check dmesg for any errors from wifi dongle? I used the following wifi adapter, which is unfortunately EOL (with our M0141 expansion board) :
                  kernel:       #1 SMP PREEMPT Wed Oct 22 04:13:18 UTC 2025 4.19.125
                  hw platform:  M0054
                  mach.var:     1.0.1
                  SKU:          MCCA-M0054-C8
                  voxl-suite:   1.6.3
                  no current network connection
                  voxl2:/$ voxl-wifi station xxxxxx yyyyyy
                  voxl2:/$ ping 8.8.8.8
                  PING 8.8.8.8 (8.8.8.8): 56 data bytes
                  64 bytes from 8.8.8.8: icmp_seq=0 ttl=118 time=11.806 ms
                  S 1 Reply Last reply
                    hw platform:  M0054
                    mach.var:     1.0.1
                    SKU:          MCCA-M0054-C8
                    voxl-suite:   1.6.3
                    S Offline
                    S Offline
                    SKA
                    wrote on last edited by SKA
                    #9
                    @Alex-Kushleyev Hi!
                    I'm facing the same issue using station mode on sdk v1.6.3.
                    I've tried using the ALFA AWU2036 as well as the TP-LINK AC600.
                    Changing back to sdk 1.6.0, it works as expected.
                    voxl2-mini (M0104):/$ voxl-my-ip
                    169.254.233.208 (wlan0)
                    voxl2-mini (M0104):/$ ping 8.8.8.8
                    92 bytes from 169.254.233.208: Destination Host Unreachable
                    ^C92 bytes from 169.254.233.208: Destination Host Unreachable
                    --- 8.8.8.8 ping statistics ---
                    7 packets transmitted, 0 packets received, 100% packet loss
                    voxl2-mini (M0104):/$ cat /data/misc/wifi/wpa_supplicant.conf
                    # Only WPA-PSK is used. Any valid cipher combination is accepted.
                    ctrl_interface=/var/run/wpa_supplicant
                    update_config=1
                    network={
                    #Open
                    #        ssid="example open network"
                    #        key_mgmt=NONE
                    #WPA-PSK
                            ssid="xxxxxxx"
                            #proto=WPA
                            key_mgmt=WPA-PSK
                            pairwise=TKIP CCMP
                            group=TKIP CCMP
                            psk="yyyyyyy"
                    #WEP
                    #       ssid="example wep network"
                    #       key_mgmt=NONE
                    #       wep_key0="abcde"
                    #       wep_key1=0102030405
                    #       wep_tx_keyidx=0
                    wowlan_triggers=magic_pkt
                    voxl2-mini (M0104):/$ cd data/misc/wifi/
                    voxl2-mini (M0104):/data/misc/wifi$ ls
                    hostapd.conf  station_band  station_interface  station_ssid  wlan_mode  wpa_supplicant.conf
                    voxl2-mini (M0104):/data/misc/wifi$ cat station_band
                    2ghz
                    • S SKA
                      @Alex-Kushleyev Hi!
                      update_config=1
                      network={
                      #Open
                      #        key_mgmt=NONE
                      #WPA-PSK
                              ssid="xxxxxxx"
                              #proto=WPA
                              key_mgmt=WPA-PSK
                              pairwise=TKIP CCMP
                              group=TKIP CCMP
                              psk="yyyyyyy"
                      #WEP
                      #       key_mgmt=NONE
                      #       wep_key0="abcde"
                      #       wep_tx_keyidx=0
                      2ghz
                      #10
                      @SKA , I don't have a file "station_band", also 2ghz seems incorrect (maybe it should be 2.4ghz? not sure). Try to rename / remove that file?
                      what does iwconfig wlan0 output? what about dmesg? anything useful?
                        S Offline
                        S Offline
                        SKA
                        #11
                        @Alex-Kushleyev I didn't add the station_band file, and this is a freshly flashed voxl. Removing/changing it to 2.4ghz didn't help unfortunately.
                        voxl2-mini (M0104):/$ iwconfig wlan0
                        wlan0     unassociated  ESSID:""  Nickname:"<WIFI@REALTEK>"
                                  Mode:Managed  Frequency=2.412 GHz  Access Point: Not-Associated
                                  Sensitivity:0/0
                                  Retry:off   RTS thr:off   Fragment thr:off
                                  Encryption key:off
                                  Power Management:off
                                  Link Quality=0/100  Signal level=0 dBm  Noise level=0 dBm
                                  Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
                                  Tx excessive retries:0  Invalid misc:0   Missed beacon:0
                        • S SKA
                                    Sensitivity:0/0
                                    Encryption key:off
                          @SKA , can you please try to power down the wifi device and power it back up (using the commands below) and check the output of dmesg.
                          #turn off USB VBUS
                          voxl-gpio write 157 0
                          #turn on USB VBUS
                          voxl-gpio write 157 1
                          my dmesg output:
                          [   24.123592] usb 1-1: USB disconnect, device number 2
                          [   24.152384] RTW: rtw_ndev_uninit(wlan0) if1
                          [   24.172973] RTW: rtw_dev_unload: driver not in IPS
                          [   33.464284] usb 1-1: new high-speed USB device number 3 using xhci-hcd
                          [   33.602465] usb 1-1: New USB device found, idVendor=0bda, idProduct=c820, bcdDevice= 2.00
                          [   33.602487] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
                          [   33.602502] usb 1-1: Product: 802.11ac NIC
                          [   33.602517] usb 1-1: Manufacturer: Realtek
                          [   33.602531] usb 1-1: SerialNumber: 123456
                          [   33.614447] RTW: [HALMAC]55772M
                                         HALMAC_MAJOR_VER = 1
                                         HALMAC_PROTOTYPE_VER = 6
                                         HALMAC_MINOR_VER = 6
                                         HALMAC_PATCH_VER = 22
                          [   33.760178] vdd_tof: disabling
                          [   33.760182] vdd_hap_boost: disabling
                          [   33.835010] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x40d00
                          [   33.835034] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x40d00
                          [   33.835055] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x40d00
                          [   33.835075] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x40d00
                          [   33.835095] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x40d00
                          [   33.835115] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x40d00
                          [   33.951477] RTW: HW EFUSE
                          [   33.951489] RTW: 0x000: 29 81 00 BC  09 00 21 00  6E 04 A4 34  10 00 30 0B
                          [   33.951530] RTW: 0x010: 26 26 26 26  26 26 27 27  27 27 27 13  FF FF FF FF
                          [   33.951570] RTW: 0x020: FF FF 2D 2D  2D 2D 2D 2D  2D 2D 2D 2D  2D 2D 2D 2D
                          [   33.951632] RTW: 0x030: 13 FF FF FF  FF FF E0 FF  FF FF 28 28  28 28 28 28
                          [   33.951671] RTW: 0x040: 28 28 28 28  28 02 FF FF  FF FF FF FF  FF FF FF FF
                          [   33.951710] RTW: 0x050: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
                          [   33.951749] RTW: 0x060: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
                          [   33.951788] RTW: 0x070: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
                          [   33.951827] RTW: 0x080: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
                          [   33.951866] RTW: 0x090: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
                          [   33.951904] RTW: 0x0A0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
                          [   33.951943] RTW: 0x0B0: FF FF FF FF  FF FF FF FF  7F 1A 1B 00  FF FF FF FF
                          [   33.951982] RTW: 0x0C0: FF 22 00 00  00 E6 00 00  00 FF 26 FF  FF FF FF FF
                          [   33.952179] RTW: 0x0D0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
                          [   33.952291] RTW: 0x0E0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
                          [   33.952331] RTW: 0x0F0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
                          [   33.952369] RTW: 0x100: DA 0B 20 C8  C3 46 02 00  C0 CA B3 A4  EC 09 03 52
                          [   33.952408] RTW: 0x110: 65 61 6C 74  65 6B 0E 03  38 30 32 2E  31 31 61 63
                          [   33.952447] RTW: 0x120: 20 4E 49 43  08 03 31 32  33 34 35 36  FF FF FF FF
                          [   33.952486] RTW: 0x130: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
                          [   33.952533] RTW: 0x140: FF FF FF FF  00 00 31 0F  FF FF FF FF  FF FF FF FF
                          [   33.952602] RTW: 0x150: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
                          [   33.952641] RTW: 0x160: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
                          [   33.952691] RTW: 0x170: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
                          [   33.952730] RTW: 0x180: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
                          [   33.952769] RTW: 0x190: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
                          [   33.952808] RTW: 0x1A0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
                          [   33.952847] RTW: 0x1B0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
                          [   33.952885] RTW: 0x1C0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
                          [   33.952924] RTW: 0x1D0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
                          [   33.952963] RTW: 0x1E0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
                          [   33.953002] RTW: 0x1F0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
                          [   33.953329] RTW: hal_com_config_channel_plan chplan:0x7F
                          [   34.184253] RTW: [RF_PATH] ver_id.RF_TYPE:RF_1T1R
                          [   34.184263] RTW: [RF_PATH] HALSPEC's rf_reg_trx_path_bmp:0x11, rf_reg_path_avail_num:1, max_tx_cnt:1
                          [   34.184269] RTW: [RF_PATH] PG's trx_path_bmp:0x00, max_tx_cnt:0
                          [   34.184276] RTW: [RF_PATH] Registry's trx_path_bmp:0x00, tx_path_lmt:0, rx_path_lmt:0
                          [   34.184283] RTW: [RF_PATH] HALDATA's trx_path_bmp:0x11, max_tx_cnt:1
                          [   34.184288] RTW: [RF_PATH] HALDATA's rf_type:RF_1T1R, NumTotalRFPath:1
                          [   34.184296] RTW: [TRX_Nss] HALSPEC - tx_nss:1, rx_nss:1
                          [   34.184301] RTW: [TRX_Nss] Registry - tx_nss:0, rx_nss:0
                          [   34.184307] RTW: [TRX_Nss] HALDATA - tx_nss:1, rx_nss:1
                          [   34.184315] RTW: txpath=0x1, rxpath=0x1
                          [   34.184321] RTW: txpath_1ss:0x1, num:1
                          [   34.185543] RTW: rtw_regsty_chk_target_tx_power_valid return _FALSE for band:0, path:0, rs:0, t:-1
                          [   34.188733] RTW: rtw_ndev_init(wlan0) if1 mac_addr=00:c0:ca:b3:a4:ec
                          [   35.507557] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
                          S Alex KushleyevA 2 Replies Last reply
                            #turn off USB VBUS
                            #turn on USB VBUS
                            my dmesg output:
                            S Offline
                            S Offline
                            SKA
                            @Alex-Kushleyev After turning it off and on, this was the dmesg output:
                            [ 1075.483890] usb 1-1: USB disconnect, device number 2
                            [ 1081.832158] usb 1-1: new high-speed USB device number 3 using xhci-hcd
                            [ 1081.969792] usb 1-1: New USB device found, idVendor=2357, idProduct=011e, bcdDevice= 2.00
                            [ 1081.969808] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
                            [ 1081.969819] usb 1-1: Product: 802.11ac WLAN Adapter
                            [ 1081.969827] usb 1-1: Manufacturer: Realtek
                            [ 1081.969836] usb 1-1: SerialNumber: 00e04c000001
                            [ 1082.194843] usb 1-1: 88XXau 10:5a:95:c7:9e:69 hw_info[107]
                            [ 1082.911593] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
                            [ 1082.911656] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
                              #turn off USB VBUS
                              #turn on USB VBUS
                              my dmesg output:
                              Also, here is output of tail -n 100 /var/log/syslog:
                              Apr  3 18:17:22 m0054 dhcpcd[2755]: wlan0: carrier lost
                              Apr  3 18:17:22 m0054 wpa_supplicant[1996]: wlan0: CTRL-EVENT-DISCONNECTED bssid=5c:e9:31:0a:78:23 reason=3 locally_generated=1
                              Apr  3 18:17:22 m0054 kernel: [  402.693093] RTW: rtw_ndev_uninit(wlan0) if1
                              Apr  3 18:17:22 m0054 systemd[1]: Starting Load/Save RF Kill Switch Status...
                              Apr  3 18:17:22 m0054 systemd-rfkill[4368]: Failed to open device rfkill3: No such device
                              Apr  3 18:17:22 m0054 systemd[1]: Started Load/Save RF Kill Switch Status.
                              Apr  3 18:17:22 m0054 dhcpcd[2755]: wlan0: deleting address fe80::5c1e:5176:405d:82d8
                              Apr  3 18:17:22 m0054 dhcpcd[2755]: wlan0: deleting default route via 192.168.10.1
                              Apr  3 18:17:22 m0054 dhcpcd[2755]: wlan0: deleting route to 192.168.10.0/24
                              Apr  3 18:17:22 m0054 dhcpcd[2755]: wlan0: removing interface
                              Apr  3 18:17:29 m0054 kernel: [  409.880457] usb 1-1: new high-speed USB device number 5 using xhci-hcd
                              Apr  3 18:17:30 m0054 kernel: [  410.369086] RTW: HW EFUSE
                              Apr  3 18:17:30 m0054 kernel: [  410.369100] RTW: 0x000: 29 81 00 BC  09 00 21 00  6E 04 A4 34  10 00 30 0B
                              Apr  3 18:17:30 m0054 kernel: [  410.369142] RTW: 0x010: 26 26 26 26  26 26 27 27  27 27 27 13  FF FF FF FF
                              Apr  3 18:17:30 m0054 kernel: [  410.369221] RTW: 0x030: 13 FF FF FF  FF FF E0 FF  FF FF 28 28  28 28 28 28
                              Apr  3 18:17:30 m0054 kernel: [  410.369299] RTW: 0x050: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
                              Apr  3 18:17:30 m0054 kernel: [  410.369377] RTW: 0x070: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
                              Apr  3 18:17:30 m0054 kernel: [  410.369454] RTW: 0x090: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
                              Apr  3 18:17:30 m0054 kernel: [  410.369532] RTW: 0x0B0: FF FF FF FF  FF FF FF FF  7F 1A 1B 00  FF FF FF FF
                              Apr  3 18:17:30 m0054 kernel: [  410.369609] RTW: 0x0D0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
                              Apr  3 18:17:30 m0054 kernel: [  410.369687] RTW: 0x0F0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
                              Apr  3 18:17:30 m0054 kernel: [  410.369764] RTW: 0x110: 65 61 6C 74  65 6B 0E 03  38 30 32 2E  31 31 61 63
                              Apr  3 18:17:30 m0054 kernel: [  410.369842] RTW: 0x130: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
                              Apr  3 18:17:30 m0054 kernel: [  410.369920] RTW: 0x150: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
                              Apr  3 18:17:30 m0054 kernel: [  410.369997] RTW: 0x170: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
                              Apr  3 18:17:30 m0054 kernel: [  410.370075] RTW: 0x190: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
                              Apr  3 18:17:30 m0054 kernel: [  410.370153] RTW: 0x1B0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
                              Apr  3 18:17:30 m0054 kernel: [  410.370230] RTW: 0x1D0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
                              Apr  3 18:17:30 m0054 kernel: [  410.370308] RTW: 0x1F0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
                              Apr  3 18:17:30 m0054 kernel: [  410.562635] RTW: [RF_PATH] ver_id.RF_TYPE:RF_1T1R
                              Apr  3 18:17:30 m0054 kernel: [  410.562646] RTW: [RF_PATH] HALSPEC's rf_reg_trx_path_bmp:0x11, rf_reg_path_avail_num:1, max_tx_cnt:1
                              Apr  3 18:17:30 m0054 kernel: [  410.562653] RTW: [RF_PATH] PG's trx_path_bmp:0x00, max_tx_cnt:0
                              Apr  3 18:17:30 m0054 kernel: [  410.562665] RTW: [RF_PATH] HALDATA's trx_path_bmp:0x11, max_tx_cnt:1
                              Apr  3 18:17:30 m0054 kernel: [  410.562680] RTW: [TRX_Nss] HALSPEC - tx_nss:1, rx_nss:1
                              Apr  3 18:17:30 m0054 kernel: [  410.562686] RTW: [TRX_Nss] Registry - tx_nss:0, rx_nss:0
                              Apr  3 18:17:30 m0054 kernel: [  410.562691] RTW: [TRX_Nss] HALDATA - tx_nss:1, rx_nss:1
                              Apr  3 18:17:30 m0054 kernel: [  410.562700] RTW: txpath=0x1, rxpath=0x1
                              Apr  3 18:17:30 m0054 kernel: [  410.562707] RTW: txpath_1ss:0x1, num:1
                              Apr  3 18:17:30 m0054 kernel: [  410.563928] RTW: rtw_regsty_chk_target_tx_power_valid return _FALSE for band:0, path:0, rs:0, t:-1
                              Apr  3 18:17:30 m0054 kernel: [  410.567269] RTW: rtw_ndev_init(wlan0) if1 mac_addr=00:c0:ca:b3:a4:ec
                              Apr  3 18:17:30 m0054 systemd[1]: Starting Load/Save RF Kill Switch Status...
                              Apr  3 18:17:30 m0054 systemd-rfkill[4511]: Failed to parse state file /var/lib/systemd/rfkill/platform-xhci-hcd.0.auto-usb-0:1:1.2:wlan: Invalid argument
                              Apr  3 18:17:30 m0054 systemd[1]: Started Load/Save RF Kill Switch Status.
                              Apr  3 18:17:31 m0054 dhcpcd[2755]: wlan0: waiting for carrier
                              Apr  3 18:17:31 m0054 systemd-udevd[4512]: link_config: autonegotiation is unset or enabled, the speed and duplex are not writable.
                              Apr  3 18:17:36 m0054 kernel: [  416.679144] RTW: wlan0- hw port(0) mac_addr =00:c0:ca:b3:a4:ec
                              Apr  3 18:17:36 m0054 wpa_supplicant[1996]: wlan0: Trying to associate with 5c:e9:31:0a:78:24 (SSID='xxxxxx' freq=5200 MHz)
                              Apr  3 18:17:36 m0054 wpa_supplicant[1996]: FT: Invalid key management type (2)
                              Apr  3 18:17:36 m0054 kernel: [  416.734679] RTW: rtw_set_802_11_connect(wlan0)  fw_state=0x00000008
                              Apr  3 18:17:36 m0054 kernel: [  416.868146] RTW: start auth
                              Apr  3 18:17:36 m0054 kernel: [  416.871600] RTW: auth success, start assoc
                              Apr  3 18:17:36 m0054 kernel: [  416.883349] RTW: assoc success
                              Apr  3 18:17:36 m0054 wpa_supplicant[1996]: wlan0: Associated with 5c:e9:31:0a:78:24
                              Apr  3 18:17:36 m0054 wpa_supplicant[1996]: wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
                              Apr  3 18:17:36 m0054 kernel: [  416.888060] RTW: curr_tx_rate : CCK_1M (L)
                              Apr  3 18:17:36 m0054 kernel: [  416.888070] RTW: curr_retry_ratio : 0
                              Apr  3 18:17:36 m0054 kernel: [  416.888075] RTW: ra_mask : 0x00000000003ffff0
                              Apr  3 18:17:36 m0054 kernel: [  416.898522] RTW: recv eapol packet 1/4
                              Apr  3 18:17:36 m0054 wpa_supplicant[1996]: wlan0: WPA: Key negotiation completed with 5c:e9:31:0a:78:24 [PTK=CCMP GTK=CCMP]
                              Apr  3 18:17:36 m0054 wpa_supplicant[1996]: wlan0: CTRL-EVENT-CONNECTED - Connection to 5c:e9:31:0a:78:24 completed [id=0 id_str=]
                              Apr  3 18:17:36 m0054 kernel: [  416.925772] RTW: set group key camid:1, addr:5c:e9:31:0a:78:24, kid:1, type:AES
                              Apr  3 18:17:36 m0054 dhcpcd[2755]: wlan0: carrier acquired
                              Apr  3 18:17:36 m0054 dhcpcd[2755]: wlan0: IAID ca:b3:a4:ec
                              Apr  3 18:17:36 m0054 dhcpcd[2755]: wlan0: adding address fe80::5c1e:5176:405d:82d8
                              Apr  3 18:17:37 m0054 dhcpcd[2755]: wlan0: soliciting an IPv6 router
                              Apr  3 18:17:37 m0054 dhcpcd[2755]: wlan0: rebinding lease of 192.168.10.179
                              Apr  3 18:17:37 m0054 dhcpcd[2755]: wlan0: truncated packet (179) from 127.0.0.1
                              Apr  3 18:17:37 m0054 dhcpcd[2755]: wlan0: truncated packet (207) from 127.0.0.1
                              Apr  3 18:17:37 m0054 dhcpcd[2755]: wlan0: probing address 192.168.10.179/24
                              Apr  3 18:17:42 m0054 dhcpcd[2755]: wlan0: leased 192.168.10.179 for 7200 seconds
                              Apr  3 18:17:42 m0054 dhcpcd[2755]: wlan0: adding route to 192.168.10.0/24
                              Apr  3 18:17:42 m0054 dhcpcd[2755]: wlan0: adding default route via 192.168.10.1
                              Apr  3 18:17:50 m0054 dhcpcd[2755]: wlan0: no IPv6 Routers available
                              Alex KushleyevA S 2 Replies Last reply
                                @SKA , please check the output of syslog, it may contain a hint as to why wlan0 has a static ip, maybe dhcpcd is not working properly.
                                  S Offline
                                  S Offline
                                  SKA
                                  #16
                                  @Alex-Kushleyev When I run tail -n 100 /var/log/syslog, I don't see any messages coming from m0104 dhcpcd or m0104 wpa_supplicant
                                  edit: I turned the USB VBUS off and on, and saw this pop up on syslog:
                                  Apr  3 16:07:44 m0104 dhcpcd[2276]: wlan0: probing for an IPv4LL address
                                  • S SKA
                                    #17
                                    @SKA , can you also please check journalctl -u dhcpcd to see if there is anything interesting there?
                                    Apr 03 18:10:27 m0054 systemd[1]: Starting LSB: IPv4 DHCP client with IPv4LL support...
                                    Apr 03 18:10:27 m0054 dhcpcd[1982]: grep: /etc/network/interfaces: No such file or directory
                                    Apr 03 18:10:28 m0054 dhcpcd[2095]: DUID 00:01:00:01:2b:93:59:dc:ea:a6:9f:04:b1:61
                                    Apr 03 18:10:28 m0054 dhcpcd[2095]: wlan0: IAID ca:b3:a4:ec
                                    Apr 03 18:10:28 m0054 dhcpcd[2095]: wlan0: adding address fe80::10c0:dcc6:145e:c4cd
                                    Apr 03 18:10:28 m0054 dhcpcd[2095]: bond0: waiting for carrier
                                    Apr 03 18:10:28 m0054 dhcpcd[2095]: dummy0: waiting for carrier
                                    Apr 03 18:10:28 m0054 dhcpcd[2095]: wlan0: carrier lost
                                    Apr 03 18:10:28 m0054 dhcpcd[2095]: wlan0: deleting address fe80::10c0:dcc6:145e:c4cd
                                    Apr 03 18:10:28 m0054 dhcpcd[2095]: wlan0: carrier acquired
                                    Apr 03 18:10:28 m0054 dhcpcd[2095]: dummy0: carrier acquired
                                    Apr 03 18:10:28 m0054 dhcpcd[2095]: dummy0: IAID 5b:b6:cf:20
                                    Apr 03 18:10:28 m0054 dhcpcd[2095]: dummy0: adding address fe80::8837:2803:320d:3a20
                                    Apr 03 18:10:29 m0054 dhcpcd[2095]: dummy0: soliciting a DHCP lease
                                    Apr 03 18:10:29 m0054 dhcpcd[2095]: dummy0: soliciting an IPv6 router
                                    Apr 03 18:10:34 m0054 dhcpcd[2095]: wlan0: carrier acquired
                                    Apr 03 18:10:34 m0054 dhcpcd[2095]: wlan0: IAID ca:b3:a4:ec
                                    Apr 03 18:10:35 m0054 dhcpcd[2095]: wlan0: soliciting an IPv6 router
                                    Apr 03 18:10:35 m0054 dhcpcd[2095]: wlan0: rebinding lease of 192.168.10.179
                                    Apr 03 18:10:35 m0054 dhcpcd[2095]: wlan0: probing address 192.168.10.179/24
                                    Apr 03 18:10:40 m0054 dhcpcd[2095]: wlan0: leased 192.168.10.179 for 7200 seconds
                                    Apr 03 18:10:40 m0054 dhcpcd[2095]: wlan0: adding route to 192.168.10.0/24
                                    Apr 03 18:10:40 m0054 dhcpcd[2095]: wlan0: adding default route via 192.168.10.1
                                    Apr 03 18:10:40 m0054 dhcpcd[2095]: forked to background, child pid 2755
                                    Apr 03 18:10:40 m0054 systemd[1]: Started LSB: IPv4 DHCP client with IPv4LL support.
                                    Apr 03 18:10:41 m0054 dhcpcd[2755]: dummy0: no IPv6 Routers available
                                      S Offline
                                      S Offline
                                      SKA
                                      #18
                                      @Alex-Kushleyev Here's what I see! I wonder if this is the problem:
                                      voxl2-mini (M0104):/$ journalctl -u dhcpcd
                                      -- Logs begin at Thu 2023-03-02 12:58:02 UTC, end at Fri 2026-04-03 16:11:48 UTC. --
                                      Mar 02 12:58:04 m0104 systemd[1]: Starting LSB: IPv4 DHCP client with IPv4LL support...
                                      Mar 02 12:58:04 m0104 dhcpcd[1250]: grep: /etc/network/interfaces: No such file or directory
                                      Mar 02 12:58:05 m0104 dhcpcd[1309]: no interfaces have a carrier
                                      Mar 02 12:58:05 m0104 dhcpcd[1309]: forked to background, child pid 1503
                                      Mar 02 12:58:05 m0104 systemd[1]: Started LSB: IPv4 DHCP client with IPv4LL support.
                                      Mar 02 12:58:06 m0104 dhcpcd[1503]: bond0: waiting for carrier
                                      Mar 02 12:58:06 m0104 dhcpcd[1503]: dummy0: waiting for carrier
                                      Mar 02 12:58:06 m0104 dhcpcd[1503]: wlan0: waiting for carrier
                                      Mar 02 12:58:06 m0104 dhcpcd[1503]: dummy0: carrier acquired
                                      Mar 02 12:58:06 m0104 dhcpcd[1503]: DUID 00:01:00:01:2b:93:59:de:b6:a9:9d:64:6d:02
                                      Mar 02 12:58:06 m0104 dhcpcd[1503]: dummy0: IAID 9d:64:6d:02
                                      Mar 02 12:58:06 m0104 dhcpcd[1503]: dummy0: adding address fe80::54fe:595c:4ff6:b95c
                                      Mar 02 12:58:06 m0104 dhcpcd[1503]: dummy0: soliciting a DHCP lease
                                      Mar 02 12:58:07 m0104 dhcpcd[1503]: dummy0: soliciting an IPv6 router
                                      Mar 02 12:58:10 m0104 dhcpcd[1503]: wlan0: carrier acquired
                                      Mar 02 12:58:10 m0104 dhcpcd[1503]: wlan0: IAID ca:b3:a6:89
                                      Mar 02 12:58:10 m0104 dhcpcd[1503]: wlan0: adding address fe80::bc34:9301:bd06:6b68
                                      Mar 02 12:58:11 m0104 dhcpcd[1503]: wlan0: soliciting a DHCP lease
                                      Mar 02 12:58:11 m0104 dhcpcd[1503]: wlan0: soliciting an IPv6 router
                                      Mar 02 12:58:12 m0104 dhcpcd[1503]: wlan0: offered 10.10.10.116 from 10.10.10.1
                                      Mar 02 12:58:12 m0104 dhcpcd[1503]: wlan0: probing address 10.10.10.116/24
                                      Mar 02 12:58:17 m0104 dhcpcd[1503]: wlan0: leased 10.10.10.116 for 86400 seconds
                                      Mar 02 12:58:17 m0104 dhcpcd[1503]: wlan0: adding route to 10.10.10.0/24
                                      Mar 02 12:58:17 m0104 dhcpcd[1503]: wlan0: adding default route via 10.10.10.1
                                      Mar 02 12:58:19 m0104 dhcpcd[1503]: dummy0: no IPv6 Routers available
                                      Mar 02 12:58:24 m0104 dhcpcd[1503]: wlan0: no IPv6 Routers available
                                      -- Reboot --
                                      Apr 03 15:39:02 m0104 systemd[1]: Starting LSB: IPv4 DHCP client with IPv4LL support...
                                      Apr 03 15:39:02 m0104 dhcpcd[1899]: grep: /etc/network/interfaces: No such file or directory
                                      Apr 03 15:39:03 m0104 dhcpcd[2026]: no interfaces have a carrier
                                      Apr 03 15:39:03 m0104 dhcpcd[2262]: bond0: waiting for carrier
                                      Apr 03 15:39:03 m0104 dhcpcd[2262]: dummy0: waiting for carrier
                                      Apr 03 15:39:03 m0104 dhcpcd[2262]: wlan0: waiting for carrier
                                      Apr 03 15:39:03 m0104 dhcpcd[2262]: dummy0: carrier acquired
                                      Apr 03 15:39:03 m0104 dhcpcd[2026]: forked to background, child pid 2262
                                      Apr 03 15:39:03 m0104 systemd[1]: Started LSB: IPv4 DHCP client with IPv4LL support.
                                      Apr 03 15:39:03 m0104 dhcpcd[2262]: DUID 00:01:00:01:2b:93:59:de:b6:a9:9d:64:6d:02
                                      Apr 03 15:39:03 m0104 dhcpcd[2262]: dummy0: IAID 7e:3c:18:e8
                                      Apr 03 15:39:03 m0104 dhcpcd[2262]: dummy0: adding address fe80::e48d:a57d:cf5f:95ce
                                      Apr 03 15:39:03 m0104 dhcpcd[2262]: dummy0: soliciting an IPv6 router
                                      Apr 03 15:39:04 m0104 dhcpcd[2262]: dummy0: soliciting a DHCP lease
                                      Apr 03 15:39:12 m0104 dhcpcd[2262]: wlan0: carrier acquired
                                      Apr 03 15:39:12 m0104 dhcpcd[2262]: wlan0: IAID ca:b3:a6:89
                                      Apr 03 15:39:12 m0104 dhcpcd[2262]: wlan0: adding address fe80::bc34:9301:bd06:6b68
                                      Apr 03 15:39:12 m0104 dhcpcd[2262]: wlan0: soliciting a DHCP lease
                                      Apr 03 15:39:12 m0104 dhcpcd[2262]: wlan0: offered 10.10.10.116 from 10.10.10.1
                                      Apr 03 15:39:12 m0104 dhcpcd[2262]: wlan0: probing address 10.10.10.116/24
                                      Apr 03 15:39:13 m0104 dhcpcd[2262]: wlan0: soliciting an IPv6 router
                                      Apr 03 15:39:15 m0104 dhcpcd[2262]: dummy0: no IPv6 Routers available
                                      Apr 03 15:39:17 m0104 dhcpcd[2262]: wlan0: leased 10.10.10.116 for 86400 seconds
                                      Apr 03 15:39:17 m0104 dhcpcd[2262]: wlan0: adding route to 10.10.10.0/24
                                      Apr 03 15:39:17 m0104 dhcpcd[2262]: wlan0: adding default route via 10.10.10.1
                                      Apr 03 15:39:26 m0104 dhcpcd[2262]: wlan0: no IPv6 Routers available
                                      -- Reboot --
                                      Apr 03 15:39:54 m0104 systemd[1]: Starting LSB: IPv4 DHCP client with IPv4LL support...
                                      -- Reboot --
                                      -- Reboot --
                                      -- Reboot --
                                      -- Reboot --
                                      -- Reboot --
                                      -- Reboot --
                                      -- Reboot --
                                      --More--
                                      • S SKA
                                        -- Reboot --
                                        -- Reboot --
                                        -- Reboot --
                                        -- Reboot --
                                        -- Reboot --
                                        -- Reboot --
                                        -- Reboot --
                                        -- Reboot --
                                        -- Reboot --
                                        --More--
                                        @SKA ,
                                        I have the same same error, but wifi is working (/etc/network/interfaces: No such file or directory).
                                        I also see that your dhcp client is able to get an ip address 10.10.10.116 for wlan0, which is strange that you don't see that ip address in ifconfig..
                                          @SKA ,
                                          can you please check output of ifconfig ? i wonder if wlan0 is not the primary interface for some reason
