  3. Station Mode Issue with Voxl Suite 1.6.3
23 Posts 4 Posters 3.5k Views 1 Watching
  • M Matt69
    @Matt69 For further clarification, my understanding is that a 169.XXX.XXX.XXX IP address indicates off nominal wifi performance. Please advise.
    Hi @Matt69 ,
    Yes, the shown ip address is a self-assigned address which happens if there is no ip address assigned by a DHCP server.
    What wifi module are you using?
    Does output of iwconfig wlan0 show that you are connected to your Access Point?
    F 1 Reply Last reply
      Hi @Matt69 ,
      F Offline
      F Offline
      fhaltmayer
      wrote on last edited by fhaltmayer
      I'm also facing this after updating. Worked on an older version but it is now defaulting to the link local. One thing I noticed is that it doesn't go through the connection process (finding the network, trying password, etc) when using voxl-wifi, just skips all of it:
      Configuring station mode...
      Detected WiFi interface: wlan0
      NetworkManager not installed, using legacy wpa_supplicant/hostapd
      stopping softap mode
      Enabling station mode on wlan0 (legacy)...
      creating wpa_supplicant configuration for station mode
      Station mode enabled on wlan0
      Station mode configured!
      This is using the MCBL-00022 kit on the voxl2.
      Downgrading to 1.6.2 and the wifi works but seems a bit bugged because it cant find it at first even though it connects successfully :
      Disabling all WiFi modes...
      Scanning for network 'xxx'...
      Scan succeeded, looking for network 'xxx'
      Could not find network 'xxx' in scan results - proceeding anyway
      Enabling station mode on wlan0...
      • F fhaltmayer
        @fhaltmayer , which wifi usb adapter are you using?
          F Offline
          F Offline
          fhaltmayer
          @Alex-Kushleyev The Alfa Network AWU2036
          • F fhaltmayer
            @fhaltmayer ,
            SDK 1.6.3 added support for usb-eth0 (ethernet over usb). That interface should be using subnet 192.168.7.x. If your wifi subnet is the same, that could cause issues. Can you please check to make sure your wifi subnet is different?
              @fhaltmayer ,
              I have just tested this on voxl2 using SDK 1.6.3 and it seems to be working. The prints were updated, but what you see is normal (i saw the same messages). Did you check dmesg for any errors from wifi dongle? I used the following wifi adapter, which is unfortunately EOL (with our M0141 expansion board) :
              kernel:       #1 SMP PREEMPT Wed Oct 22 04:13:18 UTC 2025 4.19.125
              hw platform:  M0054
              mach.var:     1.0.1
              SKU:          MCCA-M0054-C8
              voxl-suite:   1.6.3
              no current network connection
              voxl2:/$ voxl-wifi station xxxxxx yyyyyy
              voxl2:/$ ping 8.8.8.8
              PING 8.8.8.8 (8.8.8.8): 56 data bytes
              64 bytes from 8.8.8.8: icmp_seq=0 ttl=118 time=11.806 ms
              S 1 Reply Last reply
                hw platform:  M0054
                mach.var:     1.0.1
                SKU:          MCCA-M0054-C8
                voxl-suite:   1.6.3
                S Offline
                S Offline
                SKA
                wrote on last edited by SKA
                #9
                @Alex-Kushleyev Hi!
                I'm facing the same issue using station mode on sdk v1.6.3.
                I've tried using the ALFA AWU2036 as well as the TP-LINK AC600.
                Changing back to sdk 1.6.0, it works as expected.
                voxl2-mini (M0104):/$ voxl-my-ip
                169.254.233.208 (wlan0)
                voxl2-mini (M0104):/$ ping 8.8.8.8
                92 bytes from 169.254.233.208: Destination Host Unreachable
                ^C92 bytes from 169.254.233.208: Destination Host Unreachable
                --- 8.8.8.8 ping statistics ---
                7 packets transmitted, 0 packets received, 100% packet loss
                voxl2-mini (M0104):/$ cat /data/misc/wifi/wpa_supplicant.conf
                # Only WPA-PSK is used. Any valid cipher combination is accepted.
                ctrl_interface=/var/run/wpa_supplicant
                update_config=1
                network={
                #Open
                #        ssid="example open network"
                #        key_mgmt=NONE
                #WPA-PSK
                        ssid="xxxxxxx"
                        #proto=WPA
                        key_mgmt=WPA-PSK
                        pairwise=TKIP CCMP
                        group=TKIP CCMP
                        psk="yyyyyyy"
                #WEP
                #       ssid="example wep network"
                #       key_mgmt=NONE
                #       wep_key0="abcde"
                #       wep_key1=0102030405
                #       wep_tx_keyidx=0
                wowlan_triggers=magic_pkt
                voxl2-mini (M0104):/$ cd data/misc/wifi/
                voxl2-mini (M0104):/data/misc/wifi$ ls
                hostapd.conf  station_band  station_interface  station_ssid  wlan_mode  wpa_supplicant.conf
                voxl2-mini (M0104):/data/misc/wifi$ cat station_band
                2ghz
                • S SKA
                  @Alex-Kushleyev Hi!
                  update_config=1
                  network={
                  #Open
                  #        key_mgmt=NONE
                  #WPA-PSK
                          ssid="xxxxxxx"
                          #proto=WPA
                          key_mgmt=WPA-PSK
                          pairwise=TKIP CCMP
                          group=TKIP CCMP
                          psk="yyyyyyy"
                  #WEP
                  #       key_mgmt=NONE
                  #       wep_key0="abcde"
                  #       wep_tx_keyidx=0
                  2ghz
                  #10
                  @SKA , I don't have a file "station_band", also 2ghz seems incorrect (maybe it should be 2.4ghz? not sure). Try to rename / remove that file?
                  what does iwconfig wlan0 output? what about dmesg? anything useful?
                    S Offline
                    S Offline
                    SKA
                    #11
                    @Alex-Kushleyev I didn't add the station_band file, and this is a freshly flashed voxl. Removing/changing it to 2.4ghz didn't help unfortunately.
                    voxl2-mini (M0104):/$ iwconfig wlan0
                    wlan0     unassociated  ESSID:""  Nickname:"<WIFI@REALTEK>"
                              Mode:Managed  Frequency=2.412 GHz  Access Point: Not-Associated
                              Sensitivity:0/0
                              Retry:off   RTS thr:off   Fragment thr:off
                              Encryption key:off
                              Power Management:off
                              Link Quality=0/100  Signal level=0 dBm  Noise level=0 dBm
                              Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
                              Tx excessive retries:0  Invalid misc:0   Missed beacon:0
                    • S SKA
                                Sensitivity:0/0
                                Encryption key:off
                      @SKA , can you please try to power down the wifi device and power it back up (using the commands below) and check the output of dmesg.
                      #turn off USB VBUS
                      voxl-gpio write 157 0
                      #turn on USB VBUS
                      voxl-gpio write 157 1
                      my dmesg output:
                      [   24.123592] usb 1-1: USB disconnect, device number 2
                      [   24.152384] RTW: rtw_ndev_uninit(wlan0) if1
                      [   24.172973] RTW: rtw_dev_unload: driver not in IPS
                      [   33.464284] usb 1-1: new high-speed USB device number 3 using xhci-hcd
                      [   33.602465] usb 1-1: New USB device found, idVendor=0bda, idProduct=c820, bcdDevice= 2.00
                      [   33.602487] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
                      [   33.602502] usb 1-1: Product: 802.11ac NIC
                      [   33.602517] usb 1-1: Manufacturer: Realtek
                      [   33.602531] usb 1-1: SerialNumber: 123456
                      [   33.614447] RTW: [HALMAC]55772M
                                     HALMAC_MAJOR_VER = 1
                                     HALMAC_PROTOTYPE_VER = 6
                                     HALMAC_MINOR_VER = 6
                                     HALMAC_PATCH_VER = 22
                      [   33.760178] vdd_tof: disabling
                      [   33.760182] vdd_hap_boost: disabling
                      [   33.835010] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x40d00
                      [   33.835034] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x40d00
                      [   33.835055] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x40d00
                      [   33.835075] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x40d00
                      [   33.835095] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x40d00
                      [   33.835115] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x40d00
                      [   33.951477] RTW: HW EFUSE
                      [   33.951489] RTW: 0x000: 29 81 00 BC  09 00 21 00  6E 04 A4 34  10 00 30 0B
                      [   33.951530] RTW: 0x010: 26 26 26 26  26 26 27 27  27 27 27 13  FF FF FF FF
                      [   33.951570] RTW: 0x020: FF FF 2D 2D  2D 2D 2D 2D  2D 2D 2D 2D  2D 2D 2D 2D
                      [   33.951632] RTW: 0x030: 13 FF FF FF  FF FF E0 FF  FF FF 28 28  28 28 28 28
                      [   33.951671] RTW: 0x040: 28 28 28 28  28 02 FF FF  FF FF FF FF  FF FF FF FF
                      [   33.951710] RTW: 0x050: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
                      [   33.951749] RTW: 0x060: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
                      [   33.951788] RTW: 0x070: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
                      [   33.951827] RTW: 0x080: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
                      [   33.951866] RTW: 0x090: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
                      [   33.951904] RTW: 0x0A0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
                      [   33.951943] RTW: 0x0B0: FF FF FF FF  FF FF FF FF  7F 1A 1B 00  FF FF FF FF
                      [   33.951982] RTW: 0x0C0: FF 22 00 00  00 E6 00 00  00 FF 26 FF  FF FF FF FF
                      [   33.952179] RTW: 0x0D0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
                      [   33.952291] RTW: 0x0E0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
                      [   33.952331] RTW: 0x0F0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
                      [   33.952369] RTW: 0x100: DA 0B 20 C8  C3 46 02 00  C0 CA B3 A4  EC 09 03 52
                      [   33.952408] RTW: 0x110: 65 61 6C 74  65 6B 0E 03  38 30 32 2E  31 31 61 63
                      [   33.952447] RTW: 0x120: 20 4E 49 43  08 03 31 32  33 34 35 36  FF FF FF FF
                      [   33.952486] RTW: 0x130: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
                      [   33.952533] RTW: 0x140: FF FF FF FF  00 00 31 0F  FF FF FF FF  FF FF FF FF
                      [   33.952602] RTW: 0x150: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
                      [   33.952641] RTW: 0x160: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
                      [   33.952691] RTW: 0x170: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
                      [   33.952730] RTW: 0x180: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
                      [   33.952769] RTW: 0x190: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
                      [   33.952808] RTW: 0x1A0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
                      [   33.952847] RTW: 0x1B0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
                      [   33.952885] RTW: 0x1C0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
                      [   33.952924] RTW: 0x1D0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
                      [   33.952963] RTW: 0x1E0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
                      [   33.953002] RTW: 0x1F0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
                      [   33.953329] RTW: hal_com_config_channel_plan chplan:0x7F
                      [   34.184253] RTW: [RF_PATH] ver_id.RF_TYPE:RF_1T1R
                      [   34.184263] RTW: [RF_PATH] HALSPEC's rf_reg_trx_path_bmp:0x11, rf_reg_path_avail_num:1, max_tx_cnt:1
                      [   34.184269] RTW: [RF_PATH] PG's trx_path_bmp:0x00, max_tx_cnt:0
                      [   34.184276] RTW: [RF_PATH] Registry's trx_path_bmp:0x00, tx_path_lmt:0, rx_path_lmt:0
                      [   34.184283] RTW: [RF_PATH] HALDATA's trx_path_bmp:0x11, max_tx_cnt:1
                      [   34.184288] RTW: [RF_PATH] HALDATA's rf_type:RF_1T1R, NumTotalRFPath:1
                      [   34.184296] RTW: [TRX_Nss] HALSPEC - tx_nss:1, rx_nss:1
                      [   34.184301] RTW: [TRX_Nss] Registry - tx_nss:0, rx_nss:0
                      [   34.184307] RTW: [TRX_Nss] HALDATA - tx_nss:1, rx_nss:1
                      [   34.184315] RTW: txpath=0x1, rxpath=0x1
                      [   34.184321] RTW: txpath_1ss:0x1, num:1
                      [   34.185543] RTW: rtw_regsty_chk_target_tx_power_valid return _FALSE for band:0, path:0, rs:0, t:-1
                      [   34.188733] RTW: rtw_ndev_init(wlan0) if1 mac_addr=00:c0:ca:b3:a4:ec
                      [   35.507557] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
                      S Alex KushleyevA 2 Replies Last reply
                        #turn off USB VBUS
                        #turn on USB VBUS
                        my dmesg output:
                        S Offline
                        S Offline
                        SKA
                        @Alex-Kushleyev After turning it off and on, this was the dmesg output:
                        [ 1075.483890] usb 1-1: USB disconnect, device number 2
                        [ 1081.832158] usb 1-1: new high-speed USB device number 3 using xhci-hcd
                        [ 1081.969792] usb 1-1: New USB device found, idVendor=2357, idProduct=011e, bcdDevice= 2.00
                        [ 1081.969808] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
                        [ 1081.969819] usb 1-1: Product: 802.11ac WLAN Adapter
                        [ 1081.969827] usb 1-1: Manufacturer: Realtek
                        [ 1081.969836] usb 1-1: SerialNumber: 00e04c000001
                        [ 1082.194843] usb 1-1: 88XXau 10:5a:95:c7:9e:69 hw_info[107]
                        [ 1082.911593] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
                        [ 1082.911656] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
                          #turn off USB VBUS
                          #turn on USB VBUS
                          my dmesg output:
                          Also, here is output of tail -n 100 /var/log/syslog:
                          Apr  3 18:17:22 m0054 dhcpcd[2755]: wlan0: carrier lost
                          Apr  3 18:17:22 m0054 wpa_supplicant[1996]: wlan0: CTRL-EVENT-DISCONNECTED bssid=5c:e9:31:0a:78:23 reason=3 locally_generated=1
                          Apr  3 18:17:22 m0054 kernel: [  402.693093] RTW: rtw_ndev_uninit(wlan0) if1
                          Apr  3 18:17:22 m0054 systemd[1]: Starting Load/Save RF Kill Switch Status...
                          Apr  3 18:17:22 m0054 systemd-rfkill[4368]: Failed to open device rfkill3: No such device
                          Apr  3 18:17:22 m0054 systemd[1]: Started Load/Save RF Kill Switch Status.
                          Apr  3 18:17:22 m0054 dhcpcd[2755]: wlan0: deleting address fe80::5c1e:5176:405d:82d8
                          Apr  3 18:17:22 m0054 dhcpcd[2755]: wlan0: deleting default route via 192.168.10.1
                          Apr  3 18:17:22 m0054 dhcpcd[2755]: wlan0: deleting route to 192.168.10.0/24
                          Apr  3 18:17:22 m0054 dhcpcd[2755]: wlan0: removing interface
                          Apr  3 18:17:29 m0054 kernel: [  409.880457] usb 1-1: new high-speed USB device number 5 using xhci-hcd
                          Apr  3 18:17:30 m0054 kernel: [  410.369086] RTW: HW EFUSE
                          Apr  3 18:17:30 m0054 kernel: [  410.369100] RTW: 0x000: 29 81 00 BC  09 00 21 00  6E 04 A4 34  10 00 30 0B
                          Apr  3 18:17:30 m0054 kernel: [  410.369142] RTW: 0x010: 26 26 26 26  26 26 27 27  27 27 27 13  FF FF FF FF
                          Apr  3 18:17:30 m0054 kernel: [  410.369221] RTW: 0x030: 13 FF FF FF  FF FF E0 FF  FF FF 28 28  28 28 28 28
                          Apr  3 18:17:30 m0054 kernel: [  410.369299] RTW: 0x050: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
                          Apr  3 18:17:30 m0054 kernel: [  410.369377] RTW: 0x070: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
                          Apr  3 18:17:30 m0054 kernel: [  410.369454] RTW: 0x090: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
                          Apr  3 18:17:30 m0054 kernel: [  410.369532] RTW: 0x0B0: FF FF FF FF  FF FF FF FF  7F 1A 1B 00  FF FF FF FF
                          Apr  3 18:17:30 m0054 kernel: [  410.369609] RTW: 0x0D0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
                          Apr  3 18:17:30 m0054 kernel: [  410.369687] RTW: 0x0F0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
                          Apr  3 18:17:30 m0054 kernel: [  410.369764] RTW: 0x110: 65 61 6C 74  65 6B 0E 03  38 30 32 2E  31 31 61 63
                          Apr  3 18:17:30 m0054 kernel: [  410.369842] RTW: 0x130: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
                          Apr  3 18:17:30 m0054 kernel: [  410.369920] RTW: 0x150: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
                          Apr  3 18:17:30 m0054 kernel: [  410.369997] RTW: 0x170: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
                          Apr  3 18:17:30 m0054 kernel: [  410.370075] RTW: 0x190: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
                          Apr  3 18:17:30 m0054 kernel: [  410.370153] RTW: 0x1B0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
                          Apr  3 18:17:30 m0054 kernel: [  410.370230] RTW: 0x1D0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
                          Apr  3 18:17:30 m0054 kernel: [  410.370308] RTW: 0x1F0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
                          Apr  3 18:17:30 m0054 kernel: [  410.562635] RTW: [RF_PATH] ver_id.RF_TYPE:RF_1T1R
                          Apr  3 18:17:30 m0054 kernel: [  410.562646] RTW: [RF_PATH] HALSPEC's rf_reg_trx_path_bmp:0x11, rf_reg_path_avail_num:1, max_tx_cnt:1
                          Apr  3 18:17:30 m0054 kernel: [  410.562653] RTW: [RF_PATH] PG's trx_path_bmp:0x00, max_tx_cnt:0
                          Apr  3 18:17:30 m0054 kernel: [  410.562665] RTW: [RF_PATH] HALDATA's trx_path_bmp:0x11, max_tx_cnt:1
                          Apr  3 18:17:30 m0054 kernel: [  410.562680] RTW: [TRX_Nss] HALSPEC - tx_nss:1, rx_nss:1
                          Apr  3 18:17:30 m0054 kernel: [  410.562686] RTW: [TRX_Nss] Registry - tx_nss:0, rx_nss:0
                          Apr  3 18:17:30 m0054 kernel: [  410.562691] RTW: [TRX_Nss] HALDATA - tx_nss:1, rx_nss:1
                          Apr  3 18:17:30 m0054 kernel: [  410.562700] RTW: txpath=0x1, rxpath=0x1
                          Apr  3 18:17:30 m0054 kernel: [  410.562707] RTW: txpath_1ss:0x1, num:1
                          Apr  3 18:17:30 m0054 kernel: [  410.563928] RTW: rtw_regsty_chk_target_tx_power_valid return _FALSE for band:0, path:0, rs:0, t:-1
                          Apr  3 18:17:30 m0054 kernel: [  410.567269] RTW: rtw_ndev_init(wlan0) if1 mac_addr=00:c0:ca:b3:a4:ec
                          Apr  3 18:17:30 m0054 systemd[1]: Starting Load/Save RF Kill Switch Status...
                          Apr  3 18:17:30 m0054 systemd-rfkill[4511]: Failed to parse state file /var/lib/systemd/rfkill/platform-xhci-hcd.0.auto-usb-0:1:1.2:wlan: Invalid argument
                          Apr  3 18:17:30 m0054 systemd[1]: Started Load/Save RF Kill Switch Status.
                          Apr  3 18:17:31 m0054 dhcpcd[2755]: wlan0: waiting for carrier
                          Apr  3 18:17:31 m0054 systemd-udevd[4512]: link_config: autonegotiation is unset or enabled, the speed and duplex are not writable.
                          Apr  3 18:17:36 m0054 kernel: [  416.679144] RTW: wlan0- hw port(0) mac_addr =00:c0:ca:b3:a4:ec
                          Apr  3 18:17:36 m0054 wpa_supplicant[1996]: wlan0: Trying to associate with 5c:e9:31:0a:78:24 (SSID='xxxxxx' freq=5200 MHz)
                          Apr  3 18:17:36 m0054 wpa_supplicant[1996]: FT: Invalid key management type (2)
                          Apr  3 18:17:36 m0054 kernel: [  416.734679] RTW: rtw_set_802_11_connect(wlan0)  fw_state=0x00000008
                          Apr  3 18:17:36 m0054 kernel: [  416.868146] RTW: start auth
                          Apr  3 18:17:36 m0054 kernel: [  416.871600] RTW: auth success, start assoc
                          Apr  3 18:17:36 m0054 kernel: [  416.883349] RTW: assoc success
                          Apr  3 18:17:36 m0054 wpa_supplicant[1996]: wlan0: Associated with 5c:e9:31:0a:78:24
                          Apr  3 18:17:36 m0054 wpa_supplicant[1996]: wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
                          Apr  3 18:17:36 m0054 kernel: [  416.888060] RTW: curr_tx_rate : CCK_1M (L)
                          Apr  3 18:17:36 m0054 kernel: [  416.888070] RTW: curr_retry_ratio : 0
                          Apr  3 18:17:36 m0054 kernel: [  416.888075] RTW: ra_mask : 0x00000000003ffff0
                          Apr  3 18:17:36 m0054 kernel: [  416.898522] RTW: recv eapol packet 1/4
                          Apr  3 18:17:36 m0054 wpa_supplicant[1996]: wlan0: WPA: Key negotiation completed with 5c:e9:31:0a:78:24 [PTK=CCMP GTK=CCMP]
                          Apr  3 18:17:36 m0054 wpa_supplicant[1996]: wlan0: CTRL-EVENT-CONNECTED - Connection to 5c:e9:31:0a:78:24 completed [id=0 id_str=]
                          Apr  3 18:17:36 m0054 kernel: [  416.925772] RTW: set group key camid:1, addr:5c:e9:31:0a:78:24, kid:1, type:AES
                          Apr  3 18:17:36 m0054 dhcpcd[2755]: wlan0: carrier acquired
                          Apr  3 18:17:36 m0054 dhcpcd[2755]: wlan0: IAID ca:b3:a4:ec
                          Apr  3 18:17:36 m0054 dhcpcd[2755]: wlan0: adding address fe80::5c1e:5176:405d:82d8
                          Apr  3 18:17:37 m0054 dhcpcd[2755]: wlan0: soliciting an IPv6 router
                          Apr  3 18:17:37 m0054 dhcpcd[2755]: wlan0: rebinding lease of 192.168.10.179
                          Apr  3 18:17:37 m0054 dhcpcd[2755]: wlan0: truncated packet (179) from 127.0.0.1
                          Apr  3 18:17:37 m0054 dhcpcd[2755]: wlan0: truncated packet (207) from 127.0.0.1
                          Apr  3 18:17:37 m0054 dhcpcd[2755]: wlan0: probing address 192.168.10.179/24
                          Apr  3 18:17:42 m0054 dhcpcd[2755]: wlan0: leased 192.168.10.179 for 7200 seconds
                          Apr  3 18:17:42 m0054 dhcpcd[2755]: wlan0: adding route to 192.168.10.0/24
                          Apr  3 18:17:42 m0054 dhcpcd[2755]: wlan0: adding default route via 192.168.10.1
                          Apr  3 18:17:50 m0054 dhcpcd[2755]: wlan0: no IPv6 Routers available
                          Alex KushleyevA S 2 Replies Last reply
                            @SKA , please check the output of syslog, it may contain a hint as to why wlan0 has a static ip, maybe dhcpcd is not working properly.
                              S Offline
                              S Offline
                              SKA
                              #16
                              @Alex-Kushleyev When I run tail -n 100 /var/log/syslog, I don't see any messages coming from m0104 dhcpcd or m0104 wpa_supplicant
                              edit: I turned the USB VBUS off and on, and saw this pop up on syslog:
                              Apr  3 16:07:44 m0104 dhcpcd[2276]: wlan0: probing for an IPv4LL address
                              • S SKA
                                #17
                                @SKA , can you also please check journalctl -u dhcpcd to see if there is anything interesting there?
                                Apr 03 18:10:27 m0054 systemd[1]: Starting LSB: IPv4 DHCP client with IPv4LL support...
                                Apr 03 18:10:27 m0054 dhcpcd[1982]: grep: /etc/network/interfaces: No such file or directory
                                Apr 03 18:10:28 m0054 dhcpcd[2095]: DUID 00:01:00:01:2b:93:59:dc:ea:a6:9f:04:b1:61
                                Apr 03 18:10:28 m0054 dhcpcd[2095]: wlan0: IAID ca:b3:a4:ec
                                Apr 03 18:10:28 m0054 dhcpcd[2095]: wlan0: adding address fe80::10c0:dcc6:145e:c4cd
                                Apr 03 18:10:28 m0054 dhcpcd[2095]: bond0: waiting for carrier
                                Apr 03 18:10:28 m0054 dhcpcd[2095]: dummy0: waiting for carrier
                                Apr 03 18:10:28 m0054 dhcpcd[2095]: wlan0: carrier lost
                                Apr 03 18:10:28 m0054 dhcpcd[2095]: wlan0: deleting address fe80::10c0:dcc6:145e:c4cd
                                Apr 03 18:10:28 m0054 dhcpcd[2095]: wlan0: carrier acquired
                                Apr 03 18:10:28 m0054 dhcpcd[2095]: dummy0: carrier acquired
                                Apr 03 18:10:28 m0054 dhcpcd[2095]: dummy0: IAID 5b:b6:cf:20
                                Apr 03 18:10:28 m0054 dhcpcd[2095]: dummy0: adding address fe80::8837:2803:320d:3a20
                                Apr 03 18:10:29 m0054 dhcpcd[2095]: dummy0: soliciting a DHCP lease
                                Apr 03 18:10:29 m0054 dhcpcd[2095]: dummy0: soliciting an IPv6 router
                                Apr 03 18:10:34 m0054 dhcpcd[2095]: wlan0: carrier acquired
                                Apr 03 18:10:34 m0054 dhcpcd[2095]: wlan0: IAID ca:b3:a4:ec
                                Apr 03 18:10:35 m0054 dhcpcd[2095]: wlan0: soliciting an IPv6 router
                                Apr 03 18:10:35 m0054 dhcpcd[2095]: wlan0: rebinding lease of 192.168.10.179
                                Apr 03 18:10:35 m0054 dhcpcd[2095]: wlan0: probing address 192.168.10.179/24
                                Apr 03 18:10:40 m0054 dhcpcd[2095]: wlan0: leased 192.168.10.179 for 7200 seconds
                                Apr 03 18:10:40 m0054 dhcpcd[2095]: wlan0: adding route to 192.168.10.0/24
                                Apr 03 18:10:40 m0054 dhcpcd[2095]: wlan0: adding default route via 192.168.10.1
                                Apr 03 18:10:40 m0054 dhcpcd[2095]: forked to background, child pid 2755
                                Apr 03 18:10:40 m0054 systemd[1]: Started LSB: IPv4 DHCP client with IPv4LL support.
                                Apr 03 18:10:41 m0054 dhcpcd[2755]: dummy0: no IPv6 Routers available
                                  S Offline
                                  S Offline
                                  SKA
                                  #18
                                  @Alex-Kushleyev Here's what I see! I wonder if this is the problem:
                                  voxl2-mini (M0104):/$ journalctl -u dhcpcd
                                  -- Logs begin at Thu 2023-03-02 12:58:02 UTC, end at Fri 2026-04-03 16:11:48 UTC. --
                                  Mar 02 12:58:04 m0104 systemd[1]: Starting LSB: IPv4 DHCP client with IPv4LL support...
                                  Mar 02 12:58:04 m0104 dhcpcd[1250]: grep: /etc/network/interfaces: No such file or directory
                                  Mar 02 12:58:05 m0104 dhcpcd[1309]: no interfaces have a carrier
                                  Mar 02 12:58:05 m0104 dhcpcd[1309]: forked to background, child pid 1503
                                  Mar 02 12:58:05 m0104 systemd[1]: Started LSB: IPv4 DHCP client with IPv4LL support.
                                  Mar 02 12:58:06 m0104 dhcpcd[1503]: bond0: waiting for carrier
                                  Mar 02 12:58:06 m0104 dhcpcd[1503]: dummy0: waiting for carrier
                                  Mar 02 12:58:06 m0104 dhcpcd[1503]: wlan0: waiting for carrier
                                  Mar 02 12:58:06 m0104 dhcpcd[1503]: dummy0: carrier acquired
                                  Mar 02 12:58:06 m0104 dhcpcd[1503]: DUID 00:01:00:01:2b:93:59:de:b6:a9:9d:64:6d:02
                                  Mar 02 12:58:06 m0104 dhcpcd[1503]: dummy0: IAID 9d:64:6d:02
                                  Mar 02 12:58:06 m0104 dhcpcd[1503]: dummy0: adding address fe80::54fe:595c:4ff6:b95c
                                  Mar 02 12:58:06 m0104 dhcpcd[1503]: dummy0: soliciting a DHCP lease
                                  Mar 02 12:58:07 m0104 dhcpcd[1503]: dummy0: soliciting an IPv6 router
                                  Mar 02 12:58:10 m0104 dhcpcd[1503]: wlan0: carrier acquired
                                  Mar 02 12:58:10 m0104 dhcpcd[1503]: wlan0: IAID ca:b3:a6:89
                                  Mar 02 12:58:10 m0104 dhcpcd[1503]: wlan0: adding address fe80::bc34:9301:bd06:6b68
                                  Mar 02 12:58:11 m0104 dhcpcd[1503]: wlan0: soliciting a DHCP lease
                                  Mar 02 12:58:11 m0104 dhcpcd[1503]: wlan0: soliciting an IPv6 router
                                  Mar 02 12:58:12 m0104 dhcpcd[1503]: wlan0: offered 10.10.10.116 from 10.10.10.1
                                  Mar 02 12:58:12 m0104 dhcpcd[1503]: wlan0: probing address 10.10.10.116/24
                                  Mar 02 12:58:17 m0104 dhcpcd[1503]: wlan0: leased 10.10.10.116 for 86400 seconds
                                  Mar 02 12:58:17 m0104 dhcpcd[1503]: wlan0: adding route to 10.10.10.0/24
                                  Mar 02 12:58:17 m0104 dhcpcd[1503]: wlan0: adding default route via 10.10.10.1
                                  Mar 02 12:58:19 m0104 dhcpcd[1503]: dummy0: no IPv6 Routers available
                                  Mar 02 12:58:24 m0104 dhcpcd[1503]: wlan0: no IPv6 Routers available
                                  -- Reboot --
                                  Apr 03 15:39:02 m0104 systemd[1]: Starting LSB: IPv4 DHCP client with IPv4LL support...
                                  Apr 03 15:39:02 m0104 dhcpcd[1899]: grep: /etc/network/interfaces: No such file or directory
                                  Apr 03 15:39:03 m0104 dhcpcd[2026]: no interfaces have a carrier
                                  Apr 03 15:39:03 m0104 dhcpcd[2262]: bond0: waiting for carrier
                                  Apr 03 15:39:03 m0104 dhcpcd[2262]: dummy0: waiting for carrier
                                  Apr 03 15:39:03 m0104 dhcpcd[2262]: wlan0: waiting for carrier
                                  Apr 03 15:39:03 m0104 dhcpcd[2262]: dummy0: carrier acquired
                                  Apr 03 15:39:03 m0104 dhcpcd[2026]: forked to background, child pid 2262
                                  Apr 03 15:39:03 m0104 systemd[1]: Started LSB: IPv4 DHCP client with IPv4LL support.
                                  Apr 03 15:39:03 m0104 dhcpcd[2262]: DUID 00:01:00:01:2b:93:59:de:b6:a9:9d:64:6d:02
                                  Apr 03 15:39:03 m0104 dhcpcd[2262]: dummy0: IAID 7e:3c:18:e8
                                  Apr 03 15:39:03 m0104 dhcpcd[2262]: dummy0: adding address fe80::e48d:a57d:cf5f:95ce
                                  Apr 03 15:39:03 m0104 dhcpcd[2262]: dummy0: soliciting an IPv6 router
                                  Apr 03 15:39:04 m0104 dhcpcd[2262]: dummy0: soliciting a DHCP lease
                                  Apr 03 15:39:12 m0104 dhcpcd[2262]: wlan0: carrier acquired
                                  Apr 03 15:39:12 m0104 dhcpcd[2262]: wlan0: IAID ca:b3:a6:89
                                  Apr 03 15:39:12 m0104 dhcpcd[2262]: wlan0: adding address fe80::bc34:9301:bd06:6b68
                                  Apr 03 15:39:12 m0104 dhcpcd[2262]: wlan0: soliciting a DHCP lease
                                  Apr 03 15:39:12 m0104 dhcpcd[2262]: wlan0: offered 10.10.10.116 from 10.10.10.1
                                  Apr 03 15:39:12 m0104 dhcpcd[2262]: wlan0: probing address 10.10.10.116/24
                                  Apr 03 15:39:13 m0104 dhcpcd[2262]: wlan0: soliciting an IPv6 router
                                  Apr 03 15:39:15 m0104 dhcpcd[2262]: dummy0: no IPv6 Routers available
                                  Apr 03 15:39:17 m0104 dhcpcd[2262]: wlan0: leased 10.10.10.116 for 86400 seconds
                                  Apr 03 15:39:17 m0104 dhcpcd[2262]: wlan0: adding route to 10.10.10.0/24
                                  Apr 03 15:39:17 m0104 dhcpcd[2262]: wlan0: adding default route via 10.10.10.1
                                  Apr 03 15:39:26 m0104 dhcpcd[2262]: wlan0: no IPv6 Routers available
                                  -- Reboot --
                                  Apr 03 15:39:54 m0104 systemd[1]: Starting LSB: IPv4 DHCP client with IPv4LL support...
                                  -- Reboot --
                                  -- Reboot --
                                  -- Reboot --
                                  -- Reboot --
                                  -- Reboot --
                                  -- Reboot --
                                  -- Reboot --
                                  --More--
                                  • S SKA
                                    -- Reboot --
                                    -- Reboot --
                                    -- Reboot --
                                    -- Reboot --
                                    -- Reboot --
                                    -- Reboot --
                                    -- Reboot --
                                    -- Reboot --
                                    -- Reboot --
                                    --More--
                                    @SKA ,
                                    I have the same same error, but wifi is working (/etc/network/interfaces: No such file or directory).
                                    I also see that your dhcp client is able to get an ip address 10.10.10.116 for wlan0, which is strange that you don't see that ip address in ifconfig..
                                      @SKA ,
                                      can you please check output of ifconfig ? i wonder if wlan0 is not the primary interface for some reason
                                        S Offline
                                        S Offline
                                        SKA
                                        wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 2312
                                                inet 169.254.233.208  netmask 255.255.0.0  broadcast 169.254.255.255
                                                inet6 fe80::ddc:47bd:f5ec:71dd  prefixlen 64  scopeid 0x20<link>
                                                ether 10:5a:95:c7:9e:69  txqueuelen 1000  (Ethernet)
                                                RX packets 0  bytes 0 (0.0 B)
                                                TX packets 0  bytes 0 (0.0 B)
                                                TX errors 0  dropped 30 overruns 0  carrier 0  collisions 0
                                        • S SKA
                                          @SKA , thank you for providing all the information. We are doing more testing and will get back to you. So far cannot reproduce.
                                          M 1 Reply Last reply
