Station Mode Issue with Voxl Suite 1.6.3
Hello Modal AI team,
I just flashed my Voxl2 with the newest SDK 1.6.3. The issue is I cannot seem to get station mode working with voxl-wifi. Is this a common bug or am I missing something here? Here is my system info from the abd shell "intro" for reference.
@Matt69 For further clarification, my understanding is that a 169.XXX.XXX.XXX IP address indicates off nominal wifi performance. Please advise.
Hi @Matt69 ,
Yes, the shown ip address is a self-assigned address which happens if there is no ip address assigned by a DHCP server.
What wifi module are you using?
Does output of
iwconfig wlan0show that you are connected to your Access Point?Alex
Hi @Matt69 ,
Does output of
I'm also facing this after updating. Worked on an older version but it is now defaulting to the link local. One thing I noticed is that it doesn't go through the connection process (finding the network, trying password, etc) when using voxl-wifi, just skips all of it:
Configuring station mode...
Detected WiFi interface: wlan0
NetworkManager not installed, using legacy wpa_supplicant/hostapd
stopping softap mode
Enabling station mode on wlan0 (legacy)...
creating wpa_supplicant configuration for station mode
Station mode enabled on wlan0
Station mode configured!This is using the MCBL-00022 kit on the voxl2.
Downgrading to 1.6.2 and the wifi works but seems a bit bugged because it cant find it at first even though it connects successfully :
Disabling all WiFi modes...
Scanning for network 'xxx'...
Scan succeeded, looking for network 'xxx'
Could not find network 'xxx' in scan results - proceeding anyway
Enabling station mode on wlan0...
Station mode configured! -
Station mode configured!@fhaltmayer , which wifi usb adapter are you using?
@Alex-Kushleyev The Alfa Network AWU2036
SDK 1.6.3 added support for usb-eth0 (ethernet over usb). That interface should be using subnet 192.168.7.x. If your wifi subnet is the same, that could cause issues. Can you please check to make sure your wifi subnet is different?
I have just tested this on voxl2 using SDK 1.6.3 and it seems to be working. The prints were updated, but what you see is normal (i saw the same messages). Did you check
dmesgfor any errors from wifi dongle? I used the following wifi adapter, which is unfortunately EOL (with our M0141 expansion board) :
──────────────────────────────────────────────────────────────────────────────── system-image: 1.8.06-M0054-14.1a-perf kernel: #1 SMP PREEMPT Wed Oct 22 04:13:18 UTC 2025 4.19.125 ──────────────────────────────────────────────────────────────────────────────── hw platform: M0054 mach.var: 1.0.1 SKU: MCCA-M0054-C8 ──────────────────────────────────────────────────────────────────────────────── voxl-suite: 1.6.3 ──────────────────────────────────────────────────────────────────────────────── no current network connection ──────────────────────────────────────────────────────────────────────────────── voxl2:/$ voxl-wifi station xxxxxx yyyyyy Detected WiFi interface: wlan0 NetworkManager not installed, using legacy wpa_supplicant/hostapd stopping softap mode Enabling station mode on wlan0 (legacy)... creating wpa_supplicant configuration for station mode Station mode enabled on wlan0 Station mode configured! voxl2:/$ ping 8.8.8.8 PING 8.8.8.8 (8.8.8.8): 56 data bytes 64 bytes from 8.8.8.8: icmp_seq=0 ttl=118 time=11.806 ms -
──────────────────────────────────────────────────────────────────────────────── system-image: 1.8.06-M0054-14.1a-perf kernel: #1 SMP PREEMPT Wed Oct 22 04:13:18 UTC 2025 4.19.125 ──────────────────────────────────────────────────────────────────────────────── hw platform: M0054 mach.var: 1.0.1 SKU: MCCA-M0054-C8 ──────────────────────────────────────────────────────────────────────────────── voxl-suite: 1.6.3 ──────────────────────────────────────────────────────────────────────────────── no current network connection ──────────────────────────────────────────────────────────────────────────────── voxl2:/$ voxl-wifi station xxxxxx yyyyyy Detected WiFi interface: wlan0 NetworkManager not installed, using legacy wpa_supplicant/hostapd stopping softap mode Enabling station mode on wlan0 (legacy)... creating wpa_supplicant configuration for station mode Station mode enabled on wlan0 Station mode configured! voxl2:/$ ping 8.8.8.8 PING 8.8.8.8 (8.8.8.8): 56 data bytes 64 bytes from 8.8.8.8: icmp_seq=0 ttl=118 time=11.806 ms@Alex-Kushleyev Hi!
I'm facing the same issue using station mode on sdk v1.6.3.
I've tried using the ALFA AWU2036 as well as the TP-LINK AC600.
Changing back to sdk 1.6.0, it works as expected.voxl2-mini (M0104):/$ voxl-my-ip 169.254.233.208 (wlan0) voxl2-mini (M0104):/$ ping 8.8.8.8 PING 8.8.8.8 (8.8.8.8): 56 data bytes 92 bytes from 169.254.233.208: Destination Host Unreachable 92 bytes from 169.254.233.208: Destination Host Unreachable 92 bytes from 169.254.233.208: Destination Host Unreachable 92 bytes from 169.254.233.208: Destination Host Unreachable 92 bytes from 169.254.233.208: Destination Host Unreachable ^C92 bytes from 169.254.233.208: Destination Host Unreachable --- 8.8.8.8 ping statistics --- 7 packets transmitted, 0 packets received, 100% packet loss voxl2-mini (M0104):/$ cat /data/misc/wifi/wpa_supplicant.conf # Only WPA-PSK is used. Any valid cipher combination is accepted. ctrl_interface=/var/run/wpa_supplicant update_config=1 network={ #Open # ssid="example open network" # key_mgmt=NONE #WPA-PSK ssid="xxxxxxx" #proto=WPA key_mgmt=WPA-PSK pairwise=TKIP CCMP group=TKIP CCMP psk="yyyyyyy" #WEP # ssid="example wep network" # key_mgmt=NONE # wep_key0="abcde" # wep_key1=0102030405 # wep_tx_keyidx=0 } wowlan_triggers=magic_pkt voxl2-mini (M0104):/$ cd data/misc/wifi/ voxl2-mini (M0104):/data/misc/wifi$ ls hostapd.conf station_band station_interface station_ssid wlan_mode wpa_supplicant.conf voxl2-mini (M0104):/data/misc/wifi$ cat station_band 2ghz -
@Alex-Kushleyev Hi!
Changing back to sdk 1.6.0, it works as expected.voxl2-mini (M0104):/$ voxl-my-ip 169.254.233.208 (wlan0) voxl2-mini (M0104):/$ ping 8.8.8.8 PING 8.8.8.8 (8.8.8.8): 56 data bytes 92 bytes from 169.254.233.208: Destination Host Unreachable 92 bytes from 169.254.233.208: Destination Host Unreachable 92 bytes from 169.254.233.208: Destination Host Unreachable 92 bytes from 169.254.233.208: Destination Host Unreachable 92 bytes from 169.254.233.208: Destination Host Unreachable ^C92 bytes from 169.254.233.208: Destination Host Unreachable --- 8.8.8.8 ping statistics --- 7 packets transmitted, 0 packets received, 100% packet loss voxl2-mini (M0104):/$ cat /data/misc/wifi/wpa_supplicant.conf # Only WPA-PSK is used. Any valid cipher combination is accepted. ctrl_interface=/var/run/wpa_supplicant update_config=1 network={ #Open # ssid="example open network" # key_mgmt=NONE #WPA-PSK ssid="xxxxxxx" #proto=WPA key_mgmt=WPA-PSK pairwise=TKIP CCMP group=TKIP CCMP psk="yyyyyyy" #WEP # ssid="example wep network" # key_mgmt=NONE # wep_key0="abcde" # wep_key1=0102030405 # wep_tx_keyidx=0 } wowlan_triggers=magic_pkt voxl2-mini (M0104):/$ cd data/misc/wifi/ voxl2-mini (M0104):/data/misc/wifi$ ls hostapd.conf station_band station_interface station_ssid wlan_mode wpa_supplicant.conf voxl2-mini (M0104):/data/misc/wifi$ cat station_band 2ghz@SKA , I don't have a file "station_band", also 2ghz seems incorrect (maybe it should be 2.4ghz? not sure). Try to rename / remove that file?
what does
iwconfig wlan0output? what about dmesg? anything useful?Alex
what does
@Alex-Kushleyev I didn't add the station_band file, and this is a freshly flashed voxl. Removing/changing it to 2.4ghz didn't help unfortunately.
voxl2-mini (M0104):/$ iwconfig wlan0 wlan0 unassociated ESSID:"" Nickname:"<WIFI@REALTEK>" Mode:Managed Frequency=2.412 GHz Access Point: Not-Associated Sensitivity:0/0 Retry:off RTS thr:off Fragment thr:off Encryption key:off Power Management:off Link Quality=0/100 Signal level=0 dBm Noise level=0 dBm Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0 Tx excessive retries:0 Invalid misc:0 Missed beacon:0 -
voxl2-mini (M0104):/$ iwconfig wlan0 wlan0 unassociated ESSID:"" Nickname:"<WIFI@REALTEK>" Mode:Managed Frequency=2.412 GHz Access Point: Not-Associated Sensitivity:0/0 Retry:off RTS thr:off Fragment thr:off Encryption key:off Power Management:off Link Quality=0/100 Signal level=0 dBm Noise level=0 dBm Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0 Tx excessive retries:0 Invalid misc:0 Missed beacon:0@SKA , can you please try to power down the wifi device and power it back up (using the commands below) and check the output of dmesg.
#turn off USB VBUS voxl-gpio write 157 0 #turn on USB VBUS voxl-gpio write 157 1my dmesg output:
[ 24.123592] usb 1-1: USB disconnect, device number 2 [ 24.152384] RTW: rtw_ndev_uninit(wlan0) if1 [ 24.172973] RTW: rtw_dev_unload: driver not in IPS [ 33.464284] usb 1-1: new high-speed USB device number 3 using xhci-hcd [ 33.602465] usb 1-1: New USB device found, idVendor=0bda, idProduct=c820, bcdDevice= 2.00 [ 33.602487] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 33.602502] usb 1-1: Product: 802.11ac NIC [ 33.602517] usb 1-1: Manufacturer: Realtek [ 33.602531] usb 1-1: SerialNumber: 123456 [ 33.614447] RTW: [HALMAC]55772M HALMAC_MAJOR_VER = 1 HALMAC_PROTOTYPE_VER = 6 HALMAC_MINOR_VER = 6 HALMAC_PATCH_VER = 22 [ 33.760178] vdd_tof: disabling [ 33.760182] vdd_hap_boost: disabling [ 33.835010] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x40d00 [ 33.835034] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x40d00 [ 33.835055] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x40d00 [ 33.835075] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x40d00 [ 33.835095] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x40d00 [ 33.835115] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x40d00 [ 33.951477] RTW: HW EFUSE [ 33.951489] RTW: 0x000: 29 81 00 BC 09 00 21 00 6E 04 A4 34 10 00 30 0B [ 33.951530] RTW: 0x010: 26 26 26 26 26 26 27 27 27 27 27 13 FF FF FF FF [ 33.951570] RTW: 0x020: FF FF 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D [ 33.951632] RTW: 0x030: 13 FF FF FF FF FF E0 FF FF FF 28 28 28 28 28 28 [ 33.951671] RTW: 0x040: 28 28 28 28 28 02 FF FF FF FF FF FF FF FF FF FF [ 33.951710] RTW: 0x050: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ 33.951749] RTW: 0x060: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ 33.951788] RTW: 0x070: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ 33.951827] RTW: 0x080: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ 33.951866] RTW: 0x090: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ 33.951904] RTW: 0x0A0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ 33.951943] RTW: 0x0B0: FF FF FF FF FF FF FF FF 7F 1A 1B 00 FF FF FF FF [ 33.951982] RTW: 0x0C0: FF 22 00 00 00 E6 00 00 00 FF 26 FF FF FF FF FF [ 33.952179] RTW: 0x0D0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ 33.952291] RTW: 0x0E0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ 33.952331] RTW: 0x0F0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ 33.952369] RTW: 0x100: DA 0B 20 C8 C3 46 02 00 C0 CA B3 A4 EC 09 03 52 [ 33.952408] RTW: 0x110: 65 61 6C 74 65 6B 0E 03 38 30 32 2E 31 31 61 63 [ 33.952447] RTW: 0x120: 20 4E 49 43 08 03 31 32 33 34 35 36 FF FF FF FF [ 33.952486] RTW: 0x130: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ 33.952533] RTW: 0x140: FF FF FF FF 00 00 31 0F FF FF FF FF FF FF FF FF [ 33.952602] RTW: 0x150: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ 33.952641] RTW: 0x160: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ 33.952691] RTW: 0x170: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ 33.952730] RTW: 0x180: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ 33.952769] RTW: 0x190: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ 33.952808] RTW: 0x1A0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ 33.952847] RTW: 0x1B0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ 33.952885] RTW: 0x1C0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ 33.952924] RTW: 0x1D0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ 33.952963] RTW: 0x1E0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ 33.953002] RTW: 0x1F0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ 33.953329] RTW: hal_com_config_channel_plan chplan:0x7F [ 34.184253] RTW: [RF_PATH] ver_id.RF_TYPE:RF_1T1R [ 34.184263] RTW: [RF_PATH] HALSPEC's rf_reg_trx_path_bmp:0x11, rf_reg_path_avail_num:1, max_tx_cnt:1 [ 34.184269] RTW: [RF_PATH] PG's trx_path_bmp:0x00, max_tx_cnt:0 [ 34.184276] RTW: [RF_PATH] Registry's trx_path_bmp:0x00, tx_path_lmt:0, rx_path_lmt:0 [ 34.184283] RTW: [RF_PATH] HALDATA's trx_path_bmp:0x11, max_tx_cnt:1 [ 34.184288] RTW: [RF_PATH] HALDATA's rf_type:RF_1T1R, NumTotalRFPath:1 [ 34.184296] RTW: [TRX_Nss] HALSPEC - tx_nss:1, rx_nss:1 [ 34.184301] RTW: [TRX_Nss] Registry - tx_nss:0, rx_nss:0 [ 34.184307] RTW: [TRX_Nss] HALDATA - tx_nss:1, rx_nss:1 [ 34.184315] RTW: txpath=0x1, rxpath=0x1 [ 34.184321] RTW: txpath_1ss:0x1, num:1 [ 34.185543] RTW: rtw_regsty_chk_target_tx_power_valid return _FALSE for band:0, path:0, rs:0, t:-1 [ 34.188733] RTW: rtw_ndev_init(wlan0) if1 mac_addr=00:c0:ca:b3:a4:ec [ 35.507557] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready -
[ 24.123592] usb 1-1: USB disconnect, device number 2 [ 24.152384] RTW: rtw_ndev_uninit(wlan0) if1 [ 24.172973] RTW: rtw_dev_unload: driver not in IPS [ 33.464284] usb 1-1: new high-speed USB device number 3 using xhci-hcd [ 33.602465] usb 1-1: New USB device found, idVendor=0bda, idProduct=c820, bcdDevice= 2.00 [ 33.602487] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 33.602502] usb 1-1: Product: 802.11ac NIC [ 33.602517] usb 1-1: Manufacturer: Realtek [ 33.602531] usb 1-1: SerialNumber: 123456 [ 33.614447] RTW: [HALMAC]55772M HALMAC_MAJOR_VER = 1 HALMAC_PROTOTYPE_VER = 6 HALMAC_MINOR_VER = 6 HALMAC_PATCH_VER = 22 [ 33.760178] vdd_tof: disabling [ 33.760182] vdd_hap_boost: disabling [ 33.835010] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x40d00 [ 33.835034] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x40d00 [ 33.835055] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x40d00 [ 33.835075] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x40d00 [ 33.835095] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x40d00 [ 33.835115] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x40d00 [ 33.951477] RTW: HW EFUSE [ 33.951489] RTW: 0x000: 29 81 00 BC 09 00 21 00 6E 04 A4 34 10 00 30 0B [ 33.951530] RTW: 0x010: 26 26 26 26 26 26 27 27 27 27 27 13 FF FF FF FF [ 33.951570] RTW: 0x020: FF FF 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D [ 33.951632] RTW: 0x030: 13 FF FF FF FF FF E0 FF FF FF 28 28 28 28 28 28 [ 33.951671] RTW: 0x040: 28 28 28 28 28 02 FF FF FF FF FF FF FF FF FF FF [ 33.951710] RTW: 0x050: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ 33.951749] RTW: 0x060: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ 33.951788] RTW: 0x070: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ 33.951827] RTW: 0x080: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ 33.951866] RTW: 0x090: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ 33.951904] RTW: 0x0A0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ 33.951943] RTW: 0x0B0: FF FF FF FF FF FF FF FF 7F 1A 1B 00 FF FF FF FF [ 33.951982] RTW: 0x0C0: FF 22 00 00 00 E6 00 00 00 FF 26 FF FF FF FF FF [ 33.952179] RTW: 0x0D0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ 33.952291] RTW: 0x0E0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ 33.952331] RTW: 0x0F0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ 33.952369] RTW: 0x100: DA 0B 20 C8 C3 46 02 00 C0 CA B3 A4 EC 09 03 52 [ 33.952408] RTW: 0x110: 65 61 6C 74 65 6B 0E 03 38 30 32 2E 31 31 61 63 [ 33.952447] RTW: 0x120: 20 4E 49 43 08 03 31 32 33 34 35 36 FF FF FF FF [ 33.952486] RTW: 0x130: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ 33.952533] RTW: 0x140: FF FF FF FF 00 00 31 0F FF FF FF FF FF FF FF FF [ 33.952602] RTW: 0x150: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ 33.952641] RTW: 0x160: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ 33.952691] RTW: 0x170: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ 33.952730] RTW: 0x180: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ 33.952769] RTW: 0x190: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ 33.952808] RTW: 0x1A0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ 33.952847] RTW: 0x1B0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ 33.952885] RTW: 0x1C0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ 33.952924] RTW: 0x1D0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ 33.952963] RTW: 0x1E0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ 33.953002] RTW: 0x1F0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ 33.953329] RTW: hal_com_config_channel_plan chplan:0x7F [ 34.184253] RTW: [RF_PATH] ver_id.RF_TYPE:RF_1T1R [ 34.184263] RTW: [RF_PATH] HALSPEC's rf_reg_trx_path_bmp:0x11, rf_reg_path_avail_num:1, max_tx_cnt:1 [ 34.184269] RTW: [RF_PATH] PG's trx_path_bmp:0x00, max_tx_cnt:0 [ 34.184276] RTW: [RF_PATH] Registry's trx_path_bmp:0x00, tx_path_lmt:0, rx_path_lmt:0 [ 34.184283] RTW: [RF_PATH] HALDATA's trx_path_bmp:0x11, max_tx_cnt:1 [ 34.184288] RTW: [RF_PATH] HALDATA's rf_type:RF_1T1R, NumTotalRFPath:1 [ 34.184296] RTW: [TRX_Nss] HALSPEC - tx_nss:1, rx_nss:1 [ 34.184301] RTW: [TRX_Nss] Registry - tx_nss:0, rx_nss:0 [ 34.184307] RTW: [TRX_Nss] HALDATA - tx_nss:1, rx_nss:1 [ 34.184315] RTW: txpath=0x1, rxpath=0x1 [ 34.184321] RTW: txpath_1ss:0x1, num:1 [ 34.185543] RTW: rtw_regsty_chk_target_tx_power_valid return _FALSE for band:0, path:0, rs:0, t:-1 [ 34.188733] RTW: rtw_ndev_init(wlan0) if1 mac_addr=00:c0:ca:b3:a4:ec [ 35.507557] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready@Alex-Kushleyev After turning it off and on, this was the dmesg output:
[ 1075.483890] usb 1-1: USB disconnect, device number 2 [ 1081.832158] usb 1-1: new high-speed USB device number 3 using xhci-hcd [ 1081.969792] usb 1-1: New USB device found, idVendor=2357, idProduct=011e, bcdDevice= 2.00 [ 1081.969808] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 1081.969819] usb 1-1: Product: 802.11ac WLAN Adapter [ 1081.969827] usb 1-1: Manufacturer: Realtek [ 1081.969836] usb 1-1: SerialNumber: 00e04c000001 [ 1082.194843] usb 1-1: 88XXau 10:5a:95:c7:9e:69 hw_info[107] [ 1082.911593] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready [ 1082.911656] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready -
[ 24.123592] usb 1-1: USB disconnect, device number 2 [ 24.152384] RTW: rtw_ndev_uninit(wlan0) if1 [ 24.172973] RTW: rtw_dev_unload: driver not in IPS [ 33.464284] usb 1-1: new high-speed USB device number 3 using xhci-hcd [ 33.602465] usb 1-1: New USB device found, idVendor=0bda, idProduct=c820, bcdDevice= 2.00 [ 33.602487] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 33.602502] usb 1-1: Product: 802.11ac NIC [ 33.602517] usb 1-1: Manufacturer: Realtek [ 33.602531] usb 1-1: SerialNumber: 123456 [ 33.614447] RTW: [HALMAC]55772M HALMAC_MAJOR_VER = 1 HALMAC_PROTOTYPE_VER = 6 HALMAC_MINOR_VER = 6 HALMAC_PATCH_VER = 22 [ 33.760178] vdd_tof: disabling [ 33.760182] vdd_hap_boost: disabling [ 33.835010] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x40d00 [ 33.835034] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x40d00 [ 33.835055] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x40d00 [ 33.835075] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x40d00 [ 33.835095] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x40d00 [ 33.835115] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x40d00 [ 33.951477] RTW: HW EFUSE [ 33.951489] RTW: 0x000: 29 81 00 BC 09 00 21 00 6E 04 A4 34 10 00 30 0B [ 33.951530] RTW: 0x010: 26 26 26 26 26 26 27 27 27 27 27 13 FF FF FF FF [ 33.951570] RTW: 0x020: FF FF 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D [ 33.951632] RTW: 0x030: 13 FF FF FF FF FF E0 FF FF FF 28 28 28 28 28 28 [ 33.951671] RTW: 0x040: 28 28 28 28 28 02 FF FF FF FF FF FF FF FF FF FF [ 33.951710] RTW: 0x050: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ 33.951749] RTW: 0x060: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ 33.951788] RTW: 0x070: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ 33.951827] RTW: 0x080: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ 33.951866] RTW: 0x090: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ 33.951904] RTW: 0x0A0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ 33.951943] RTW: 0x0B0: FF FF FF FF FF FF FF FF 7F 1A 1B 00 FF FF FF FF [ 33.951982] RTW: 0x0C0: FF 22 00 00 00 E6 00 00 00 FF 26 FF FF FF FF FF [ 33.952179] RTW: 0x0D0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ 33.952291] RTW: 0x0E0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ 33.952331] RTW: 0x0F0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ 33.952369] RTW: 0x100: DA 0B 20 C8 C3 46 02 00 C0 CA B3 A4 EC 09 03 52 [ 33.952408] RTW: 0x110: 65 61 6C 74 65 6B 0E 03 38 30 32 2E 31 31 61 63 [ 33.952447] RTW: 0x120: 20 4E 49 43 08 03 31 32 33 34 35 36 FF FF FF FF [ 33.952486] RTW: 0x130: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ 33.952533] RTW: 0x140: FF FF FF FF 00 00 31 0F FF FF FF FF FF FF FF FF [ 33.952602] RTW: 0x150: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ 33.952641] RTW: 0x160: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ 33.952691] RTW: 0x170: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ 33.952730] RTW: 0x180: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ 33.952769] RTW: 0x190: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ 33.952808] RTW: 0x1A0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ 33.952847] RTW: 0x1B0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ 33.952885] RTW: 0x1C0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ 33.952924] RTW: 0x1D0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ 33.952963] RTW: 0x1E0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ 33.953002] RTW: 0x1F0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF [ 33.953329] RTW: hal_com_config_channel_plan chplan:0x7F [ 34.184253] RTW: [RF_PATH] ver_id.RF_TYPE:RF_1T1R [ 34.184263] RTW: [RF_PATH] HALSPEC's rf_reg_trx_path_bmp:0x11, rf_reg_path_avail_num:1, max_tx_cnt:1 [ 34.184269] RTW: [RF_PATH] PG's trx_path_bmp:0x00, max_tx_cnt:0 [ 34.184276] RTW: [RF_PATH] Registry's trx_path_bmp:0x00, tx_path_lmt:0, rx_path_lmt:0 [ 34.184283] RTW: [RF_PATH] HALDATA's trx_path_bmp:0x11, max_tx_cnt:1 [ 34.184288] RTW: [RF_PATH] HALDATA's rf_type:RF_1T1R, NumTotalRFPath:1 [ 34.184296] RTW: [TRX_Nss] HALSPEC - tx_nss:1, rx_nss:1 [ 34.184301] RTW: [TRX_Nss] Registry - tx_nss:0, rx_nss:0 [ 34.184307] RTW: [TRX_Nss] HALDATA - tx_nss:1, rx_nss:1 [ 34.184315] RTW: txpath=0x1, rxpath=0x1 [ 34.184321] RTW: txpath_1ss:0x1, num:1 [ 34.185543] RTW: rtw_regsty_chk_target_tx_power_valid return _FALSE for band:0, path:0, rs:0, t:-1 [ 34.188733] RTW: rtw_ndev_init(wlan0) if1 mac_addr=00:c0:ca:b3:a4:ec [ 35.507557] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not readyAlso, here is output of
tail -n 100 /var/log/syslog:Apr 3 18:17:22 m0054 dhcpcd[2755]: wlan0: carrier lost Apr 3 18:17:22 m0054 wpa_supplicant[1996]: wlan0: CTRL-EVENT-DISCONNECTED bssid=5c:e9:31:0a:78:23 reason=3 locally_generated=1 Apr 3 18:17:22 m0054 kernel: [ 402.693093] RTW: rtw_ndev_uninit(wlan0) if1 Apr 3 18:17:22 m0054 systemd[1]: Starting Load/Save RF Kill Switch Status... Apr 3 18:17:22 m0054 systemd-rfkill[4368]: Failed to open device rfkill3: No such device Apr 3 18:17:22 m0054 systemd[1]: Started Load/Save RF Kill Switch Status. Apr 3 18:17:22 m0054 dhcpcd[2755]: wlan0: deleting address fe80::5c1e:5176:405d:82d8 Apr 3 18:17:22 m0054 dhcpcd[2755]: wlan0: deleting default route via 192.168.10.1 Apr 3 18:17:22 m0054 dhcpcd[2755]: wlan0: deleting route to 192.168.10.0/24 Apr 3 18:17:22 m0054 dhcpcd[2755]: wlan0: removing interface Apr 3 18:17:29 m0054 kernel: [ 409.880457] usb 1-1: new high-speed USB device number 5 using xhci-hcd Apr 3 18:17:30 m0054 kernel: [ 410.369086] RTW: HW EFUSE Apr 3 18:17:30 m0054 kernel: [ 410.369100] RTW: 0x000: 29 81 00 BC 09 00 21 00 6E 04 A4 34 10 00 30 0B Apr 3 18:17:30 m0054 kernel: [ 410.369142] RTW: 0x010: 26 26 26 26 26 26 27 27 27 27 27 13 FF FF FF FF Apr 3 18:17:30 m0054 kernel: [ 410.369221] RTW: 0x030: 13 FF FF FF FF FF E0 FF FF FF 28 28 28 28 28 28 Apr 3 18:17:30 m0054 kernel: [ 410.369299] RTW: 0x050: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Apr 3 18:17:30 m0054 kernel: [ 410.369377] RTW: 0x070: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Apr 3 18:17:30 m0054 kernel: [ 410.369454] RTW: 0x090: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Apr 3 18:17:30 m0054 kernel: [ 410.369532] RTW: 0x0B0: FF FF FF FF FF FF FF FF 7F 1A 1B 00 FF FF FF FF Apr 3 18:17:30 m0054 kernel: [ 410.369609] RTW: 0x0D0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Apr 3 18:17:30 m0054 kernel: [ 410.369687] RTW: 0x0F0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Apr 3 18:17:30 m0054 kernel: [ 410.369764] RTW: 0x110: 65 61 6C 74 65 6B 0E 03 38 30 32 2E 31 31 61 63 Apr 3 18:17:30 m0054 kernel: [ 410.369842] RTW: 0x130: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Apr 3 18:17:30 m0054 kernel: [ 410.369920] RTW: 0x150: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Apr 3 18:17:30 m0054 kernel: [ 410.369997] RTW: 0x170: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Apr 3 18:17:30 m0054 kernel: [ 410.370075] RTW: 0x190: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Apr 3 18:17:30 m0054 kernel: [ 410.370153] RTW: 0x1B0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Apr 3 18:17:30 m0054 kernel: [ 410.370230] RTW: 0x1D0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Apr 3 18:17:30 m0054 kernel: [ 410.370308] RTW: 0x1F0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Apr 3 18:17:30 m0054 kernel: [ 410.562635] RTW: [RF_PATH] ver_id.RF_TYPE:RF_1T1R Apr 3 18:17:30 m0054 kernel: [ 410.562646] RTW: [RF_PATH] HALSPEC's rf_reg_trx_path_bmp:0x11, rf_reg_path_avail_num:1, max_tx_cnt:1 Apr 3 18:17:30 m0054 kernel: [ 410.562653] RTW: [RF_PATH] PG's trx_path_bmp:0x00, max_tx_cnt:0 Apr 3 18:17:30 m0054 kernel: [ 410.562665] RTW: [RF_PATH] HALDATA's trx_path_bmp:0x11, max_tx_cnt:1 Apr 3 18:17:30 m0054 kernel: [ 410.562680] RTW: [TRX_Nss] HALSPEC - tx_nss:1, rx_nss:1 Apr 3 18:17:30 m0054 kernel: [ 410.562686] RTW: [TRX_Nss] Registry - tx_nss:0, rx_nss:0 Apr 3 18:17:30 m0054 kernel: [ 410.562691] RTW: [TRX_Nss] HALDATA - tx_nss:1, rx_nss:1 Apr 3 18:17:30 m0054 kernel: [ 410.562700] RTW: txpath=0x1, rxpath=0x1 Apr 3 18:17:30 m0054 kernel: [ 410.562707] RTW: txpath_1ss:0x1, num:1 Apr 3 18:17:30 m0054 kernel: [ 410.563928] RTW: rtw_regsty_chk_target_tx_power_valid return _FALSE for band:0, path:0, rs:0, t:-1 Apr 3 18:17:30 m0054 kernel: [ 410.567269] RTW: rtw_ndev_init(wlan0) if1 mac_addr=00:c0:ca:b3:a4:ec Apr 3 18:17:30 m0054 systemd[1]: Starting Load/Save RF Kill Switch Status... Apr 3 18:17:30 m0054 systemd-rfkill[4511]: Failed to parse state file /var/lib/systemd/rfkill/platform-xhci-hcd.0.auto-usb-0:1:1.2:wlan: Invalid argument Apr 3 18:17:30 m0054 systemd[1]: Started Load/Save RF Kill Switch Status. Apr 3 18:17:31 m0054 dhcpcd[2755]: wlan0: waiting for carrier Apr 3 18:17:31 m0054 systemd-udevd[4512]: link_config: autonegotiation is unset or enabled, the speed and duplex are not writable. Apr 3 18:17:36 m0054 kernel: [ 416.679144] RTW: wlan0- hw port(0) mac_addr =00:c0:ca:b3:a4:ec Apr 3 18:17:36 m0054 wpa_supplicant[1996]: wlan0: Trying to associate with 5c:e9:31:0a:78:24 (SSID='xxxxxx' freq=5200 MHz) Apr 3 18:17:36 m0054 wpa_supplicant[1996]: FT: Invalid key management type (2) Apr 3 18:17:36 m0054 kernel: [ 416.734679] RTW: rtw_set_802_11_connect(wlan0) fw_state=0x00000008 Apr 3 18:17:36 m0054 kernel: [ 416.868146] RTW: start auth Apr 3 18:17:36 m0054 kernel: [ 416.871600] RTW: auth success, start assoc Apr 3 18:17:36 m0054 kernel: [ 416.883349] RTW: assoc success Apr 3 18:17:36 m0054 wpa_supplicant[1996]: wlan0: Associated with 5c:e9:31:0a:78:24 Apr 3 18:17:36 m0054 wpa_supplicant[1996]: wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0 Apr 3 18:17:36 m0054 kernel: [ 416.888060] RTW: curr_tx_rate : CCK_1M (L) Apr 3 18:17:36 m0054 kernel: [ 416.888070] RTW: curr_retry_ratio : 0 Apr 3 18:17:36 m0054 kernel: [ 416.888075] RTW: ra_mask : 0x00000000003ffff0 Apr 3 18:17:36 m0054 kernel: [ 416.898522] RTW: recv eapol packet 1/4 Apr 3 18:17:36 m0054 wpa_supplicant[1996]: wlan0: WPA: Key negotiation completed with 5c:e9:31:0a:78:24 [PTK=CCMP GTK=CCMP] Apr 3 18:17:36 m0054 wpa_supplicant[1996]: wlan0: CTRL-EVENT-CONNECTED - Connection to 5c:e9:31:0a:78:24 completed [id=0 id_str=] Apr 3 18:17:36 m0054 kernel: [ 416.925772] RTW: set group key camid:1, addr:5c:e9:31:0a:78:24, kid:1, type:AES Apr 3 18:17:36 m0054 dhcpcd[2755]: wlan0: carrier acquired Apr 3 18:17:36 m0054 dhcpcd[2755]: wlan0: IAID ca:b3:a4:ec Apr 3 18:17:36 m0054 dhcpcd[2755]: wlan0: adding address fe80::5c1e:5176:405d:82d8 Apr 3 18:17:37 m0054 dhcpcd[2755]: wlan0: soliciting an IPv6 router Apr 3 18:17:37 m0054 dhcpcd[2755]: wlan0: rebinding lease of 192.168.10.179 Apr 3 18:17:37 m0054 dhcpcd[2755]: wlan0: truncated packet (179) from 127.0.0.1 Apr 3 18:17:37 m0054 dhcpcd[2755]: wlan0: truncated packet (207) from 127.0.0.1 Apr 3 18:17:37 m0054 dhcpcd[2755]: wlan0: probing address 192.168.10.179/24 Apr 3 18:17:42 m0054 dhcpcd[2755]: wlan0: leased 192.168.10.179 for 7200 seconds Apr 3 18:17:42 m0054 dhcpcd[2755]: wlan0: adding route to 192.168.10.0/24 Apr 3 18:17:42 m0054 dhcpcd[2755]: wlan0: adding default route via 192.168.10.1 Apr 3 18:17:50 m0054 dhcpcd[2755]: wlan0: no IPv6 Routers available -
tail -n 100 /var/log/syslog:Apr 3 18:17:22 m0054 dhcpcd[2755]: wlan0: carrier lost Apr 3 18:17:22 m0054 wpa_supplicant[1996]: wlan0: CTRL-EVENT-DISCONNECTED bssid=5c:e9:31:0a:78:23 reason=3 locally_generated=1 Apr 3 18:17:22 m0054 kernel: [ 402.693093] RTW: rtw_ndev_uninit(wlan0) if1 Apr 3 18:17:22 m0054 systemd[1]: Starting Load/Save RF Kill Switch Status... Apr 3 18:17:22 m0054 systemd-rfkill[4368]: Failed to open device rfkill3: No such device Apr 3 18:17:22 m0054 systemd[1]: Started Load/Save RF Kill Switch Status. Apr 3 18:17:22 m0054 dhcpcd[2755]: wlan0: deleting address fe80::5c1e:5176:405d:82d8 Apr 3 18:17:22 m0054 dhcpcd[2755]: wlan0: deleting default route via 192.168.10.1 Apr 3 18:17:22 m0054 dhcpcd[2755]: wlan0: deleting route to 192.168.10.0/24 Apr 3 18:17:22 m0054 dhcpcd[2755]: wlan0: removing interface Apr 3 18:17:29 m0054 kernel: [ 409.880457] usb 1-1: new high-speed USB device number 5 using xhci-hcd Apr 3 18:17:30 m0054 kernel: [ 410.369086] RTW: HW EFUSE Apr 3 18:17:30 m0054 kernel: [ 410.369100] RTW: 0x000: 29 81 00 BC 09 00 21 00 6E 04 A4 34 10 00 30 0B Apr 3 18:17:30 m0054 kernel: [ 410.369142] RTW: 0x010: 26 26 26 26 26 26 27 27 27 27 27 13 FF FF FF FF Apr 3 18:17:30 m0054 kernel: [ 410.369221] RTW: 0x030: 13 FF FF FF FF FF E0 FF FF FF 28 28 28 28 28 28 Apr 3 18:17:30 m0054 kernel: [ 410.369299] RTW: 0x050: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Apr 3 18:17:30 m0054 kernel: [ 410.369377] RTW: 0x070: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Apr 3 18:17:30 m0054 kernel: [ 410.369454] RTW: 0x090: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Apr 3 18:17:30 m0054 kernel: [ 410.369532] RTW: 0x0B0: FF FF FF FF FF FF FF FF 7F 1A 1B 00 FF FF FF FF Apr 3 18:17:30 m0054 kernel: [ 410.369609] RTW: 0x0D0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Apr 3 18:17:30 m0054 kernel: [ 410.369687] RTW: 0x0F0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Apr 3 18:17:30 m0054 kernel: [ 410.369764] RTW: 0x110: 65 61 6C 74 65 6B 0E 03 38 30 32 2E 31 31 61 63 Apr 3 18:17:30 m0054 kernel: [ 410.369842] RTW: 0x130: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Apr 3 18:17:30 m0054 kernel: [ 410.369920] RTW: 0x150: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Apr 3 18:17:30 m0054 kernel: [ 410.369997] RTW: 0x170: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Apr 3 18:17:30 m0054 kernel: [ 410.370075] RTW: 0x190: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Apr 3 18:17:30 m0054 kernel: [ 410.370153] RTW: 0x1B0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Apr 3 18:17:30 m0054 kernel: [ 410.370230] RTW: 0x1D0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Apr 3 18:17:30 m0054 kernel: [ 410.370308] RTW: 0x1F0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Apr 3 18:17:30 m0054 kernel: [ 410.562635] RTW: [RF_PATH] ver_id.RF_TYPE:RF_1T1R Apr 3 18:17:30 m0054 kernel: [ 410.562646] RTW: [RF_PATH] HALSPEC's rf_reg_trx_path_bmp:0x11, rf_reg_path_avail_num:1, max_tx_cnt:1 Apr 3 18:17:30 m0054 kernel: [ 410.562653] RTW: [RF_PATH] PG's trx_path_bmp:0x00, max_tx_cnt:0 Apr 3 18:17:30 m0054 kernel: [ 410.562665] RTW: [RF_PATH] HALDATA's trx_path_bmp:0x11, max_tx_cnt:1 Apr 3 18:17:30 m0054 kernel: [ 410.562680] RTW: [TRX_Nss] HALSPEC - tx_nss:1, rx_nss:1 Apr 3 18:17:30 m0054 kernel: [ 410.562686] RTW: [TRX_Nss] Registry - tx_nss:0, rx_nss:0 Apr 3 18:17:30 m0054 kernel: [ 410.562691] RTW: [TRX_Nss] HALDATA - tx_nss:1, rx_nss:1 Apr 3 18:17:30 m0054 kernel: [ 410.562700] RTW: txpath=0x1, rxpath=0x1 Apr 3 18:17:30 m0054 kernel: [ 410.562707] RTW: txpath_1ss:0x1, num:1 Apr 3 18:17:30 m0054 kernel: [ 410.563928] RTW: rtw_regsty_chk_target_tx_power_valid return _FALSE for band:0, path:0, rs:0, t:-1 Apr 3 18:17:30 m0054 kernel: [ 410.567269] RTW: rtw_ndev_init(wlan0) if1 mac_addr=00:c0:ca:b3:a4:ec Apr 3 18:17:30 m0054 systemd[1]: Starting Load/Save RF Kill Switch Status... Apr 3 18:17:30 m0054 systemd-rfkill[4511]: Failed to parse state file /var/lib/systemd/rfkill/platform-xhci-hcd.0.auto-usb-0:1:1.2:wlan: Invalid argument Apr 3 18:17:30 m0054 systemd[1]: Started Load/Save RF Kill Switch Status. Apr 3 18:17:31 m0054 dhcpcd[2755]: wlan0: waiting for carrier Apr 3 18:17:31 m0054 systemd-udevd[4512]: link_config: autonegotiation is unset or enabled, the speed and duplex are not writable. Apr 3 18:17:36 m0054 kernel: [ 416.679144] RTW: wlan0- hw port(0) mac_addr =00:c0:ca:b3:a4:ec Apr 3 18:17:36 m0054 wpa_supplicant[1996]: wlan0: Trying to associate with 5c:e9:31:0a:78:24 (SSID='xxxxxx' freq=5200 MHz) Apr 3 18:17:36 m0054 wpa_supplicant[1996]: FT: Invalid key management type (2) Apr 3 18:17:36 m0054 kernel: [ 416.734679] RTW: rtw_set_802_11_connect(wlan0) fw_state=0x00000008 Apr 3 18:17:36 m0054 kernel: [ 416.868146] RTW: start auth Apr 3 18:17:36 m0054 kernel: [ 416.871600] RTW: auth success, start assoc Apr 3 18:17:36 m0054 kernel: [ 416.883349] RTW: assoc success Apr 3 18:17:36 m0054 wpa_supplicant[1996]: wlan0: Associated with 5c:e9:31:0a:78:24 Apr 3 18:17:36 m0054 wpa_supplicant[1996]: wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0 Apr 3 18:17:36 m0054 kernel: [ 416.888060] RTW: curr_tx_rate : CCK_1M (L) Apr 3 18:17:36 m0054 kernel: [ 416.888070] RTW: curr_retry_ratio : 0 Apr 3 18:17:36 m0054 kernel: [ 416.888075] RTW: ra_mask : 0x00000000003ffff0 Apr 3 18:17:36 m0054 kernel: [ 416.898522] RTW: recv eapol packet 1/4 Apr 3 18:17:36 m0054 wpa_supplicant[1996]: wlan0: WPA: Key negotiation completed with 5c:e9:31:0a:78:24 [PTK=CCMP GTK=CCMP] Apr 3 18:17:36 m0054 wpa_supplicant[1996]: wlan0: CTRL-EVENT-CONNECTED - Connection to 5c:e9:31:0a:78:24 completed [id=0 id_str=] Apr 3 18:17:36 m0054 kernel: [ 416.925772] RTW: set group key camid:1, addr:5c:e9:31:0a:78:24, kid:1, type:AES Apr 3 18:17:36 m0054 dhcpcd[2755]: wlan0: carrier acquired Apr 3 18:17:36 m0054 dhcpcd[2755]: wlan0: IAID ca:b3:a4:ec Apr 3 18:17:36 m0054 dhcpcd[2755]: wlan0: adding address fe80::5c1e:5176:405d:82d8 Apr 3 18:17:37 m0054 dhcpcd[2755]: wlan0: soliciting an IPv6 router Apr 3 18:17:37 m0054 dhcpcd[2755]: wlan0: rebinding lease of 192.168.10.179 Apr 3 18:17:37 m0054 dhcpcd[2755]: wlan0: truncated packet (179) from 127.0.0.1 Apr 3 18:17:37 m0054 dhcpcd[2755]: wlan0: truncated packet (207) from 127.0.0.1 Apr 3 18:17:37 m0054 dhcpcd[2755]: wlan0: probing address 192.168.10.179/24 Apr 3 18:17:42 m0054 dhcpcd[2755]: wlan0: leased 192.168.10.179 for 7200 seconds Apr 3 18:17:42 m0054 dhcpcd[2755]: wlan0: adding route to 192.168.10.0/24 Apr 3 18:17:42 m0054 dhcpcd[2755]: wlan0: adding default route via 192.168.10.1 Apr 3 18:17:50 m0054 dhcpcd[2755]: wlan0: no IPv6 Routers available@SKA , please check the output of syslog, it may contain a hint as to why wlan0 has a static ip, maybe dhcpcd is not working properly.
tail -n 100 /var/log/syslog:Apr 3 18:17:22 m0054 dhcpcd[2755]: wlan0: carrier lost Apr 3 18:17:22 m0054 wpa_supplicant[1996]: wlan0: CTRL-EVENT-DISCONNECTED bssid=5c:e9:31:0a:78:23 reason=3 locally_generated=1 Apr 3 18:17:22 m0054 kernel: [ 402.693093] RTW: rtw_ndev_uninit(wlan0) if1 Apr 3 18:17:22 m0054 systemd[1]: Starting Load/Save RF Kill Switch Status... Apr 3 18:17:22 m0054 systemd-rfkill[4368]: Failed to open device rfkill3: No such device Apr 3 18:17:22 m0054 systemd[1]: Started Load/Save RF Kill Switch Status. Apr 3 18:17:22 m0054 dhcpcd[2755]: wlan0: deleting address fe80::5c1e:5176:405d:82d8 Apr 3 18:17:22 m0054 dhcpcd[2755]: wlan0: deleting default route via 192.168.10.1 Apr 3 18:17:22 m0054 dhcpcd[2755]: wlan0: deleting route to 192.168.10.0/24 Apr 3 18:17:22 m0054 dhcpcd[2755]: wlan0: removing interface Apr 3 18:17:29 m0054 kernel: [ 409.880457] usb 1-1: new high-speed USB device number 5 using xhci-hcd Apr 3 18:17:30 m0054 kernel: [ 410.369086] RTW: HW EFUSE Apr 3 18:17:30 m0054 kernel: [ 410.369100] RTW: 0x000: 29 81 00 BC 09 00 21 00 6E 04 A4 34 10 00 30 0B Apr 3 18:17:30 m0054 kernel: [ 410.369142] RTW: 0x010: 26 26 26 26 26 26 27 27 27 27 27 13 FF FF FF FF Apr 3 18:17:30 m0054 kernel: [ 410.369221] RTW: 0x030: 13 FF FF FF FF FF E0 FF FF FF 28 28 28 28 28 28 Apr 3 18:17:30 m0054 kernel: [ 410.369299] RTW: 0x050: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Apr 3 18:17:30 m0054 kernel: [ 410.369377] RTW: 0x070: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Apr 3 18:17:30 m0054 kernel: [ 410.369454] RTW: 0x090: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Apr 3 18:17:30 m0054 kernel: [ 410.369532] RTW: 0x0B0: FF FF FF FF FF FF FF FF 7F 1A 1B 00 FF FF FF FF Apr 3 18:17:30 m0054 kernel: [ 410.369609] RTW: 0x0D0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Apr 3 18:17:30 m0054 kernel: [ 410.369687] RTW: 0x0F0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Apr 3 18:17:30 m0054 kernel: [ 410.369764] RTW: 0x110: 65 61 6C 74 65 6B 0E 03 38 30 32 2E 31 31 61 63 Apr 3 18:17:30 m0054 kernel: [ 410.369842] RTW: 0x130: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Apr 3 18:17:30 m0054 kernel: [ 410.369920] RTW: 0x150: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Apr 3 18:17:30 m0054 kernel: [ 410.369997] RTW: 0x170: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Apr 3 18:17:30 m0054 kernel: [ 410.370075] RTW: 0x190: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Apr 3 18:17:30 m0054 kernel: [ 410.370153] RTW: 0x1B0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Apr 3 18:17:30 m0054 kernel: [ 410.370230] RTW: 0x1D0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Apr 3 18:17:30 m0054 kernel: [ 410.370308] RTW: 0x1F0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Apr 3 18:17:30 m0054 kernel: [ 410.562635] RTW: [RF_PATH] ver_id.RF_TYPE:RF_1T1R Apr 3 18:17:30 m0054 kernel: [ 410.562646] RTW: [RF_PATH] HALSPEC's rf_reg_trx_path_bmp:0x11, rf_reg_path_avail_num:1, max_tx_cnt:1 Apr 3 18:17:30 m0054 kernel: [ 410.562653] RTW: [RF_PATH] PG's trx_path_bmp:0x00, max_tx_cnt:0 Apr 3 18:17:30 m0054 kernel: [ 410.562665] RTW: [RF_PATH] HALDATA's trx_path_bmp:0x11, max_tx_cnt:1 Apr 3 18:17:30 m0054 kernel: [ 410.562680] RTW: [TRX_Nss] HALSPEC - tx_nss:1, rx_nss:1 Apr 3 18:17:30 m0054 kernel: [ 410.562686] RTW: [TRX_Nss] Registry - tx_nss:0, rx_nss:0 Apr 3 18:17:30 m0054 kernel: [ 410.562691] RTW: [TRX_Nss] HALDATA - tx_nss:1, rx_nss:1 Apr 3 18:17:30 m0054 kernel: [ 410.562700] RTW: txpath=0x1, rxpath=0x1 Apr 3 18:17:30 m0054 kernel: [ 410.562707] RTW: txpath_1ss:0x1, num:1 Apr 3 18:17:30 m0054 kernel: [ 410.563928] RTW: rtw_regsty_chk_target_tx_power_valid return _FALSE for band:0, path:0, rs:0, t:-1 Apr 3 18:17:30 m0054 kernel: [ 410.567269] RTW: rtw_ndev_init(wlan0) if1 mac_addr=00:c0:ca:b3:a4:ec Apr 3 18:17:30 m0054 systemd[1]: Starting Load/Save RF Kill Switch Status... Apr 3 18:17:30 m0054 systemd-rfkill[4511]: Failed to parse state file /var/lib/systemd/rfkill/platform-xhci-hcd.0.auto-usb-0:1:1.2:wlan: Invalid argument Apr 3 18:17:30 m0054 systemd[1]: Started Load/Save RF Kill Switch Status. Apr 3 18:17:31 m0054 dhcpcd[2755]: wlan0: waiting for carrier Apr 3 18:17:31 m0054 systemd-udevd[4512]: link_config: autonegotiation is unset or enabled, the speed and duplex are not writable. Apr 3 18:17:36 m0054 kernel: [ 416.679144] RTW: wlan0- hw port(0) mac_addr =00:c0:ca:b3:a4:ec Apr 3 18:17:36 m0054 wpa_supplicant[1996]: wlan0: Trying to associate with 5c:e9:31:0a:78:24 (SSID='xxxxxx' freq=5200 MHz) Apr 3 18:17:36 m0054 wpa_supplicant[1996]: FT: Invalid key management type (2) Apr 3 18:17:36 m0054 kernel: [ 416.734679] RTW: rtw_set_802_11_connect(wlan0) fw_state=0x00000008 Apr 3 18:17:36 m0054 kernel: [ 416.868146] RTW: start auth Apr 3 18:17:36 m0054 kernel: [ 416.871600] RTW: auth success, start assoc Apr 3 18:17:36 m0054 kernel: [ 416.883349] RTW: assoc success Apr 3 18:17:36 m0054 wpa_supplicant[1996]: wlan0: Associated with 5c:e9:31:0a:78:24 Apr 3 18:17:36 m0054 wpa_supplicant[1996]: wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0 Apr 3 18:17:36 m0054 kernel: [ 416.888060] RTW: curr_tx_rate : CCK_1M (L) Apr 3 18:17:36 m0054 kernel: [ 416.888070] RTW: curr_retry_ratio : 0 Apr 3 18:17:36 m0054 kernel: [ 416.888075] RTW: ra_mask : 0x00000000003ffff0 Apr 3 18:17:36 m0054 kernel: [ 416.898522] RTW: recv eapol packet 1/4 Apr 3 18:17:36 m0054 wpa_supplicant[1996]: wlan0: WPA: Key negotiation completed with 5c:e9:31:0a:78:24 [PTK=CCMP GTK=CCMP] Apr 3 18:17:36 m0054 wpa_supplicant[1996]: wlan0: CTRL-EVENT-CONNECTED - Connection to 5c:e9:31:0a:78:24 completed [id=0 id_str=] Apr 3 18:17:36 m0054 kernel: [ 416.925772] RTW: set group key camid:1, addr:5c:e9:31:0a:78:24, kid:1, type:AES Apr 3 18:17:36 m0054 dhcpcd[2755]: wlan0: carrier acquired Apr 3 18:17:36 m0054 dhcpcd[2755]: wlan0: IAID ca:b3:a4:ec Apr 3 18:17:36 m0054 dhcpcd[2755]: wlan0: adding address fe80::5c1e:5176:405d:82d8 Apr 3 18:17:37 m0054 dhcpcd[2755]: wlan0: soliciting an IPv6 router Apr 3 18:17:37 m0054 dhcpcd[2755]: wlan0: rebinding lease of 192.168.10.179 Apr 3 18:17:37 m0054 dhcpcd[2755]: wlan0: truncated packet (179) from 127.0.0.1 Apr 3 18:17:37 m0054 dhcpcd[2755]: wlan0: truncated packet (207) from 127.0.0.1 Apr 3 18:17:37 m0054 dhcpcd[2755]: wlan0: probing address 192.168.10.179/24 Apr 3 18:17:42 m0054 dhcpcd[2755]: wlan0: leased 192.168.10.179 for 7200 seconds Apr 3 18:17:42 m0054 dhcpcd[2755]: wlan0: adding route to 192.168.10.0/24 Apr 3 18:17:42 m0054 dhcpcd[2755]: wlan0: adding default route via 192.168.10.1 Apr 3 18:17:50 m0054 dhcpcd[2755]: wlan0: no IPv6 Routers available@Alex-Kushleyev When I run
tail -n 100 /var/log/syslog, I don't see any messages coming fromm0104 dhcpcdorm0104 wpa_supplicantedit: I turned the USB VBUS off and on, and saw this pop up on syslog:
Apr 3 16:07:44 m0104 dhcpcd[2276]: wlan0: probing for an IPv4LL address -
Apr 3 16:07:44 m0104 dhcpcd[2276]: wlan0: probing for an IPv4LL address@SKA , can you also please check
journalctl -u dhcpcdto see if there is anything interesting there?Apr 03 18:10:27 m0054 systemd[1]: Starting LSB: IPv4 DHCP client with IPv4LL support... Apr 03 18:10:27 m0054 dhcpcd[1982]: grep: /etc/network/interfaces: No such file or directory Apr 03 18:10:28 m0054 dhcpcd[2095]: DUID 00:01:00:01:2b:93:59:dc:ea:a6:9f:04:b1:61 Apr 03 18:10:28 m0054 dhcpcd[2095]: wlan0: IAID ca:b3:a4:ec Apr 03 18:10:28 m0054 dhcpcd[2095]: wlan0: adding address fe80::10c0:dcc6:145e:c4cd Apr 03 18:10:28 m0054 dhcpcd[2095]: bond0: waiting for carrier Apr 03 18:10:28 m0054 dhcpcd[2095]: dummy0: waiting for carrier Apr 03 18:10:28 m0054 dhcpcd[2095]: wlan0: carrier lost Apr 03 18:10:28 m0054 dhcpcd[2095]: wlan0: deleting address fe80::10c0:dcc6:145e:c4cd Apr 03 18:10:28 m0054 dhcpcd[2095]: wlan0: carrier acquired Apr 03 18:10:28 m0054 dhcpcd[2095]: wlan0: IAID ca:b3:a4:ec Apr 03 18:10:28 m0054 dhcpcd[2095]: wlan0: adding address fe80::10c0:dcc6:145e:c4cd Apr 03 18:10:28 m0054 dhcpcd[2095]: wlan0: carrier lost Apr 03 18:10:28 m0054 dhcpcd[2095]: wlan0: deleting address fe80::10c0:dcc6:145e:c4cd Apr 03 18:10:28 m0054 dhcpcd[2095]: dummy0: carrier acquired Apr 03 18:10:28 m0054 dhcpcd[2095]: dummy0: IAID 5b:b6:cf:20 Apr 03 18:10:28 m0054 dhcpcd[2095]: dummy0: adding address fe80::8837:2803:320d:3a20 Apr 03 18:10:29 m0054 dhcpcd[2095]: dummy0: soliciting a DHCP lease Apr 03 18:10:29 m0054 dhcpcd[2095]: dummy0: soliciting an IPv6 router Apr 03 18:10:34 m0054 dhcpcd[2095]: wlan0: carrier acquired Apr 03 18:10:34 m0054 dhcpcd[2095]: wlan0: IAID ca:b3:a4:ec Apr 03 18:10:35 m0054 dhcpcd[2095]: wlan0: soliciting an IPv6 router Apr 03 18:10:35 m0054 dhcpcd[2095]: wlan0: rebinding lease of 192.168.10.179 Apr 03 18:10:35 m0054 dhcpcd[2095]: wlan0: probing address 192.168.10.179/24 Apr 03 18:10:40 m0054 dhcpcd[2095]: wlan0: leased 192.168.10.179 for 7200 seconds Apr 03 18:10:40 m0054 dhcpcd[2095]: wlan0: adding route to 192.168.10.0/24 Apr 03 18:10:40 m0054 dhcpcd[2095]: wlan0: adding default route via 192.168.10.1 Apr 03 18:10:40 m0054 dhcpcd[2095]: forked to background, child pid 2755 Apr 03 18:10:40 m0054 systemd[1]: Started LSB: IPv4 DHCP client with IPv4LL support. Apr 03 18:10:41 m0054 dhcpcd[2755]: dummy0: no IPv6 Routers available -
journalctl -u dhcpcdto see if there is anything interesting there?Apr 03 18:10:27 m0054 systemd[1]: Starting LSB: IPv4 DHCP client with IPv4LL support... Apr 03 18:10:27 m0054 dhcpcd[1982]: grep: /etc/network/interfaces: No such file or directory Apr 03 18:10:28 m0054 dhcpcd[2095]: DUID 00:01:00:01:2b:93:59:dc:ea:a6:9f:04:b1:61 Apr 03 18:10:28 m0054 dhcpcd[2095]: wlan0: IAID ca:b3:a4:ec Apr 03 18:10:28 m0054 dhcpcd[2095]: wlan0: adding address fe80::10c0:dcc6:145e:c4cd Apr 03 18:10:28 m0054 dhcpcd[2095]: bond0: waiting for carrier Apr 03 18:10:28 m0054 dhcpcd[2095]: dummy0: waiting for carrier Apr 03 18:10:28 m0054 dhcpcd[2095]: wlan0: carrier lost Apr 03 18:10:28 m0054 dhcpcd[2095]: wlan0: deleting address fe80::10c0:dcc6:145e:c4cd Apr 03 18:10:28 m0054 dhcpcd[2095]: wlan0: carrier acquired Apr 03 18:10:28 m0054 dhcpcd[2095]: wlan0: IAID ca:b3:a4:ec Apr 03 18:10:28 m0054 dhcpcd[2095]: wlan0: adding address fe80::10c0:dcc6:145e:c4cd Apr 03 18:10:28 m0054 dhcpcd[2095]: wlan0: carrier lost Apr 03 18:10:28 m0054 dhcpcd[2095]: wlan0: deleting address fe80::10c0:dcc6:145e:c4cd Apr 03 18:10:28 m0054 dhcpcd[2095]: dummy0: carrier acquired Apr 03 18:10:28 m0054 dhcpcd[2095]: dummy0: IAID 5b:b6:cf:20 Apr 03 18:10:28 m0054 dhcpcd[2095]: dummy0: adding address fe80::8837:2803:320d:3a20 Apr 03 18:10:29 m0054 dhcpcd[2095]: dummy0: soliciting a DHCP lease Apr 03 18:10:29 m0054 dhcpcd[2095]: dummy0: soliciting an IPv6 router Apr 03 18:10:34 m0054 dhcpcd[2095]: wlan0: carrier acquired Apr 03 18:10:34 m0054 dhcpcd[2095]: wlan0: IAID ca:b3:a4:ec Apr 03 18:10:35 m0054 dhcpcd[2095]: wlan0: soliciting an IPv6 router Apr 03 18:10:35 m0054 dhcpcd[2095]: wlan0: rebinding lease of 192.168.10.179 Apr 03 18:10:35 m0054 dhcpcd[2095]: wlan0: probing address 192.168.10.179/24 Apr 03 18:10:40 m0054 dhcpcd[2095]: wlan0: leased 192.168.10.179 for 7200 seconds Apr 03 18:10:40 m0054 dhcpcd[2095]: wlan0: adding route to 192.168.10.0/24 Apr 03 18:10:40 m0054 dhcpcd[2095]: wlan0: adding default route via 192.168.10.1 Apr 03 18:10:40 m0054 dhcpcd[2095]: forked to background, child pid 2755 Apr 03 18:10:40 m0054 systemd[1]: Started LSB: IPv4 DHCP client with IPv4LL support. Apr 03 18:10:41 m0054 dhcpcd[2755]: dummy0: no IPv6 Routers available@Alex-Kushleyev Here's what I see! I wonder if this is the problem:
/etc/network/interfaces: No such file or directoryvoxl2-mini (M0104):/$ journalctl -u dhcpcd -- Logs begin at Thu 2023-03-02 12:58:02 UTC, end at Fri 2026-04-03 16:11:48 UTC. -- Mar 02 12:58:04 m0104 systemd[1]: Starting LSB: IPv4 DHCP client with IPv4LL support... Mar 02 12:58:04 m0104 dhcpcd[1250]: grep: /etc/network/interfaces: No such file or directory Mar 02 12:58:05 m0104 dhcpcd[1309]: no interfaces have a carrier Mar 02 12:58:05 m0104 dhcpcd[1309]: forked to background, child pid 1503 Mar 02 12:58:05 m0104 systemd[1]: Started LSB: IPv4 DHCP client with IPv4LL support. Mar 02 12:58:06 m0104 dhcpcd[1503]: bond0: waiting for carrier Mar 02 12:58:06 m0104 dhcpcd[1503]: dummy0: waiting for carrier Mar 02 12:58:06 m0104 dhcpcd[1503]: wlan0: waiting for carrier Mar 02 12:58:06 m0104 dhcpcd[1503]: dummy0: carrier acquired Mar 02 12:58:06 m0104 dhcpcd[1503]: DUID 00:01:00:01:2b:93:59:de:b6:a9:9d:64:6d:02 Mar 02 12:58:06 m0104 dhcpcd[1503]: dummy0: IAID 9d:64:6d:02 Mar 02 12:58:06 m0104 dhcpcd[1503]: dummy0: adding address fe80::54fe:595c:4ff6:b95c Mar 02 12:58:06 m0104 dhcpcd[1503]: dummy0: soliciting a DHCP lease Mar 02 12:58:07 m0104 dhcpcd[1503]: dummy0: soliciting an IPv6 router Mar 02 12:58:10 m0104 dhcpcd[1503]: wlan0: carrier acquired Mar 02 12:58:10 m0104 dhcpcd[1503]: wlan0: IAID ca:b3:a6:89 Mar 02 12:58:10 m0104 dhcpcd[1503]: wlan0: adding address fe80::bc34:9301:bd06:6b68 Mar 02 12:58:11 m0104 dhcpcd[1503]: wlan0: soliciting a DHCP lease Mar 02 12:58:11 m0104 dhcpcd[1503]: wlan0: soliciting an IPv6 router Mar 02 12:58:12 m0104 dhcpcd[1503]: wlan0: offered 10.10.10.116 from 10.10.10.1 Mar 02 12:58:12 m0104 dhcpcd[1503]: wlan0: probing address 10.10.10.116/24 Mar 02 12:58:17 m0104 dhcpcd[1503]: wlan0: leased 10.10.10.116 for 86400 seconds Mar 02 12:58:17 m0104 dhcpcd[1503]: wlan0: adding route to 10.10.10.0/24 Mar 02 12:58:17 m0104 dhcpcd[1503]: wlan0: adding default route via 10.10.10.1 Mar 02 12:58:19 m0104 dhcpcd[1503]: dummy0: no IPv6 Routers available Mar 02 12:58:24 m0104 dhcpcd[1503]: wlan0: no IPv6 Routers available -- Reboot -- Apr 03 15:39:02 m0104 systemd[1]: Starting LSB: IPv4 DHCP client with IPv4LL support... Apr 03 15:39:02 m0104 dhcpcd[1899]: grep: /etc/network/interfaces: No such file or directory Apr 03 15:39:03 m0104 dhcpcd[2026]: no interfaces have a carrier Apr 03 15:39:03 m0104 dhcpcd[2262]: bond0: waiting for carrier Apr 03 15:39:03 m0104 dhcpcd[2262]: dummy0: waiting for carrier Apr 03 15:39:03 m0104 dhcpcd[2262]: wlan0: waiting for carrier Apr 03 15:39:03 m0104 dhcpcd[2262]: dummy0: carrier acquired Apr 03 15:39:03 m0104 dhcpcd[2026]: forked to background, child pid 2262 Apr 03 15:39:03 m0104 systemd[1]: Started LSB: IPv4 DHCP client with IPv4LL support. Apr 03 15:39:03 m0104 dhcpcd[2262]: DUID 00:01:00:01:2b:93:59:de:b6:a9:9d:64:6d:02 Apr 03 15:39:03 m0104 dhcpcd[2262]: dummy0: IAID 7e:3c:18:e8 Apr 03 15:39:03 m0104 dhcpcd[2262]: dummy0: adding address fe80::e48d:a57d:cf5f:95ce Apr 03 15:39:03 m0104 dhcpcd[2262]: dummy0: soliciting an IPv6 router Apr 03 15:39:04 m0104 dhcpcd[2262]: dummy0: soliciting a DHCP lease Apr 03 15:39:12 m0104 dhcpcd[2262]: wlan0: carrier acquired Apr 03 15:39:12 m0104 dhcpcd[2262]: wlan0: IAID ca:b3:a6:89 Apr 03 15:39:12 m0104 dhcpcd[2262]: wlan0: adding address fe80::bc34:9301:bd06:6b68 Apr 03 15:39:12 m0104 dhcpcd[2262]: wlan0: soliciting a DHCP lease Apr 03 15:39:12 m0104 dhcpcd[2262]: wlan0: offered 10.10.10.116 from 10.10.10.1 Apr 03 15:39:12 m0104 dhcpcd[2262]: wlan0: probing address 10.10.10.116/24 Apr 03 15:39:13 m0104 dhcpcd[2262]: wlan0: soliciting an IPv6 router Apr 03 15:39:15 m0104 dhcpcd[2262]: dummy0: no IPv6 Routers available Apr 03 15:39:17 m0104 dhcpcd[2262]: wlan0: leased 10.10.10.116 for 86400 seconds Apr 03 15:39:17 m0104 dhcpcd[2262]: wlan0: adding route to 10.10.10.0/24 Apr 03 15:39:17 m0104 dhcpcd[2262]: wlan0: adding default route via 10.10.10.1 Apr 03 15:39:26 m0104 dhcpcd[2262]: wlan0: no IPv6 Routers available -- Reboot -- Apr 03 15:39:54 m0104 systemd[1]: Starting LSB: IPv4 DHCP client with IPv4LL support... -- Reboot -- Apr 03 15:39:54 m0104 systemd[1]: Starting LSB: IPv4 DHCP client with IPv4LL support... -- Reboot -- Apr 03 15:39:54 m0104 systemd[1]: Starting LSB: IPv4 DHCP client with IPv4LL support... -- Reboot -- Apr 03 15:39:54 m0104 systemd[1]: Starting LSB: IPv4 DHCP client with IPv4LL support... -- Reboot -- Apr 03 15:39:54 m0104 systemd[1]: Starting LSB: IPv4 DHCP client with IPv4LL support... -- Reboot -- Apr 03 15:39:54 m0104 systemd[1]: Starting LSB: IPv4 DHCP client with IPv4LL support... -- Reboot -- Apr 03 15:39:54 m0104 systemd[1]: Starting LSB: IPv4 DHCP client with IPv4LL support... -- Reboot -- --More-- -
/etc/network/interfaces: No such file or directoryvoxl2-mini (M0104):/$ journalctl -u dhcpcd -- Logs begin at Thu 2023-03-02 12:58:02 UTC, end at Fri 2026-04-03 16:11:48 UTC. -- Mar 02 12:58:04 m0104 systemd[1]: Starting LSB: IPv4 DHCP client with IPv4LL support... Mar 02 12:58:04 m0104 dhcpcd[1250]: grep: /etc/network/interfaces: No such file or directory Mar 02 12:58:05 m0104 dhcpcd[1309]: no interfaces have a carrier Mar 02 12:58:05 m0104 dhcpcd[1309]: forked to background, child pid 1503 Mar 02 12:58:05 m0104 systemd[1]: Started LSB: IPv4 DHCP client with IPv4LL support. Mar 02 12:58:06 m0104 dhcpcd[1503]: bond0: waiting for carrier Mar 02 12:58:06 m0104 dhcpcd[1503]: dummy0: waiting for carrier Mar 02 12:58:06 m0104 dhcpcd[1503]: wlan0: waiting for carrier Mar 02 12:58:06 m0104 dhcpcd[1503]: dummy0: carrier acquired Mar 02 12:58:06 m0104 dhcpcd[1503]: DUID 00:01:00:01:2b:93:59:de:b6:a9:9d:64:6d:02 Mar 02 12:58:06 m0104 dhcpcd[1503]: dummy0: IAID 9d:64:6d:02 Mar 02 12:58:06 m0104 dhcpcd[1503]: dummy0: adding address fe80::54fe:595c:4ff6:b95c Mar 02 12:58:06 m0104 dhcpcd[1503]: dummy0: soliciting a DHCP lease Mar 02 12:58:07 m0104 dhcpcd[1503]: dummy0: soliciting an IPv6 router Mar 02 12:58:10 m0104 dhcpcd[1503]: wlan0: carrier acquired Mar 02 12:58:10 m0104 dhcpcd[1503]: wlan0: IAID ca:b3:a6:89 Mar 02 12:58:10 m0104 dhcpcd[1503]: wlan0: adding address fe80::bc34:9301:bd06:6b68 Mar 02 12:58:11 m0104 dhcpcd[1503]: wlan0: soliciting a DHCP lease Mar 02 12:58:11 m0104 dhcpcd[1503]: wlan0: soliciting an IPv6 router Mar 02 12:58:12 m0104 dhcpcd[1503]: wlan0: offered 10.10.10.116 from 10.10.10.1 Mar 02 12:58:12 m0104 dhcpcd[1503]: wlan0: probing address 10.10.10.116/24 Mar 02 12:58:17 m0104 dhcpcd[1503]: wlan0: leased 10.10.10.116 for 86400 seconds Mar 02 12:58:17 m0104 dhcpcd[1503]: wlan0: adding route to 10.10.10.0/24 Mar 02 12:58:17 m0104 dhcpcd[1503]: wlan0: adding default route via 10.10.10.1 Mar 02 12:58:19 m0104 dhcpcd[1503]: dummy0: no IPv6 Routers available Mar 02 12:58:24 m0104 dhcpcd[1503]: wlan0: no IPv6 Routers available -- Reboot -- Apr 03 15:39:02 m0104 systemd[1]: Starting LSB: IPv4 DHCP client with IPv4LL support... Apr 03 15:39:02 m0104 dhcpcd[1899]: grep: /etc/network/interfaces: No such file or directory Apr 03 15:39:03 m0104 dhcpcd[2026]: no interfaces have a carrier Apr 03 15:39:03 m0104 dhcpcd[2262]: bond0: waiting for carrier Apr 03 15:39:03 m0104 dhcpcd[2262]: dummy0: waiting for carrier Apr 03 15:39:03 m0104 dhcpcd[2262]: wlan0: waiting for carrier Apr 03 15:39:03 m0104 dhcpcd[2262]: dummy0: carrier acquired Apr 03 15:39:03 m0104 dhcpcd[2026]: forked to background, child pid 2262 Apr 03 15:39:03 m0104 systemd[1]: Started LSB: IPv4 DHCP client with IPv4LL support. Apr 03 15:39:03 m0104 dhcpcd[2262]: DUID 00:01:00:01:2b:93:59:de:b6:a9:9d:64:6d:02 Apr 03 15:39:03 m0104 dhcpcd[2262]: dummy0: IAID 7e:3c:18:e8 Apr 03 15:39:03 m0104 dhcpcd[2262]: dummy0: adding address fe80::e48d:a57d:cf5f:95ce Apr 03 15:39:03 m0104 dhcpcd[2262]: dummy0: soliciting an IPv6 router Apr 03 15:39:04 m0104 dhcpcd[2262]: dummy0: soliciting a DHCP lease Apr 03 15:39:12 m0104 dhcpcd[2262]: wlan0: carrier acquired Apr 03 15:39:12 m0104 dhcpcd[2262]: wlan0: IAID ca:b3:a6:89 Apr 03 15:39:12 m0104 dhcpcd[2262]: wlan0: adding address fe80::bc34:9301:bd06:6b68 Apr 03 15:39:12 m0104 dhcpcd[2262]: wlan0: soliciting a DHCP lease Apr 03 15:39:12 m0104 dhcpcd[2262]: wlan0: offered 10.10.10.116 from 10.10.10.1 Apr 03 15:39:12 m0104 dhcpcd[2262]: wlan0: probing address 10.10.10.116/24 Apr 03 15:39:13 m0104 dhcpcd[2262]: wlan0: soliciting an IPv6 router Apr 03 15:39:15 m0104 dhcpcd[2262]: dummy0: no IPv6 Routers available Apr 03 15:39:17 m0104 dhcpcd[2262]: wlan0: leased 10.10.10.116 for 86400 seconds Apr 03 15:39:17 m0104 dhcpcd[2262]: wlan0: adding route to 10.10.10.0/24 Apr 03 15:39:17 m0104 dhcpcd[2262]: wlan0: adding default route via 10.10.10.1 Apr 03 15:39:26 m0104 dhcpcd[2262]: wlan0: no IPv6 Routers available -- Reboot -- Apr 03 15:39:54 m0104 systemd[1]: Starting LSB: IPv4 DHCP client with IPv4LL support... -- Reboot -- Apr 03 15:39:54 m0104 systemd[1]: Starting LSB: IPv4 DHCP client with IPv4LL support... -- Reboot -- Apr 03 15:39:54 m0104 systemd[1]: Starting LSB: IPv4 DHCP client with IPv4LL support... -- Reboot -- Apr 03 15:39:54 m0104 systemd[1]: Starting LSB: IPv4 DHCP client with IPv4LL support... -- Reboot -- Apr 03 15:39:54 m0104 systemd[1]: Starting LSB: IPv4 DHCP client with IPv4LL support... -- Reboot -- Apr 03 15:39:54 m0104 systemd[1]: Starting LSB: IPv4 DHCP client with IPv4LL support... -- Reboot -- Apr 03 15:39:54 m0104 systemd[1]: Starting LSB: IPv4 DHCP client with IPv4LL support... -- Reboot -- --More--@SKA ,
I have the same same error, but wifi is working (
/etc/network/interfaces: No such file or directory).I also see that your dhcp client is able to get an ip address 10.10.10.116 for wlan0, which is strange that you don't see that ip address in
ifconfig.. -
@SKA ,
ifconfig..can you please check output of
ifconfig? i wonder if wlan0 is not the primary interface for some reason
