Wifi Adapter Disconnecting - wlan0 not detected
I have multiple Sentinels with microhard add-on boards and wifi adapters connected to the USB peripheral port on the microhard carrier board (not custom, this is how they were shipped). Wifi is working without issue on 3/4 of the vehicles, but for one of the vehicles the wifi adapter is either never recognized after booting up or it is detected and works for a few minutes but then disconnects and will not reestablish a connection.
I used the instructions here to configure dhcpcd to set a static ip adress for the wlan0 interface for all the vehicles:
https://forum.modalai.com/topic/4105/instruction-to-set-a-static-ip-for-wlan0-voxl2It works without issue for the other vehicles so I don't think it's part of the problem. I've attached the output of dmesg following a boot experiencing these issues and filtered the output for lines that contain "usb". You can see the wifi adapter is detected around 7 seconds after boot, the microhard interface is detected around 26 seconds after boot, but around 281 s after boot the wifi adapter starts diconnecting and can't be enabled.
Can me someone help me troubleshoot this? I'm assuming at this point since the configurations are the same on all the other vehicles that this is most likely a hardware issue. How can I confirm whether it is or not?
[ 0.000000] Kernel command line: rcupdate.rcu_expedited=1 rcu_nocbs=0-7 kpti=off noinitrd earlycon=msm_geni_serial,0xa90000 androidboot.hardware=qcom androidboot.console=ttyMSM0 androidboot.memcg=1 lpm_levels.sleep_disabled=1 video=vfb:640x400,bpp=32,memsize=3072000 msm_rtb.filter=0x237 service_locator.enable=1 androidboot.usbcontroller=a600000.dwc3 swiotlb=2048 loop.max_part=7 cgroup.memory=nokmem,nosocket reboot=panic_warm net.ifnames=0 usbcore.autosuspend=-1 apparmor=1 security=apparmor root=/dev/sda9 androidboot.bootdevice=1d84000.ufshc androidboot.serialno=75caf339 androidboot.baseband=apq msm_drm.dsi_display0=qcom,mdss_dsi_ext_bridge_1080p: systemd.setenv="SLOT_SUFFIX=_a" skip_initramfs rootwait rw init=/sbin/init [ 1.672769] usbcore: registered new interface driver usbfs [ 1.672790] usbcore: registered new interface driver hub [ 1.672883] usbcore: registered new device driver usb [ 1.673141] usb_phy_generic soc:usb_nop_phy: soc:usb_nop_phy supply vcc not found, using dummy regulator [ 1.673170] usb_phy_generic soc:usb_nop_phy: Linked as a consumer to regulator.0 [ 1.857352] usbcore: registered new interface driver r8152 [ 1.857366] usbcore: registered new interface driver lan78xx [ 1.857374] usbcore: registered new interface driver asix [ 1.857380] usbcore: registered new interface driver ax88179_178a [ 1.857385] usbcore: registered new interface driver cdc_ether [ 1.857391] usbcore: registered new interface driver cdc_eem [ 1.857399] usbcore: registered new interface driver smsc75xx [ 1.857406] usbcore: registered new interface driver smsc95xx [ 1.857412] usbcore: registered new interface driver net1080 [ 1.857418] usbcore: registered new interface driver rndis_host [ 1.857422] usbcore: registered new interface driver cdc_subset [ 1.857428] usbcore: registered new interface driver zaurus [ 1.857434] usbcore: registered new interface driver sierra_net [ 1.857440] usbcore: registered new interface driver cdc_ncm [ 1.857446] usbcore: registered new interface driver qmi_wwan [ 1.857451] usbcore: registered new interface driver cdc_mbim [ 1.857698] msm-usb-ssphy-qmp 88e8000.ssphy: Linked as a consumer to regulator.32 [ 1.857712] msm-usb-ssphy-qmp 88e8000.ssphy: Linked as a consumer to regulator.18 [ 1.857718] msm-usb-ssphy-qmp 88e8000.ssphy: failed to get phandle for msm_ssphy_qmp [ 1.857744] msm-usb-ssphy-qmp 88e8000.ssphy: Dropping the link to regulator.18 [ 1.857759] msm-usb-ssphy-qmp 88e8000.ssphy: Dropping the link to regulator.32 [ 1.857837] msm-usb-ssphy-qmp 88eb000.ssphy: Linked as a consumer to regulator.32 [ 1.857847] msm-usb-ssphy-qmp 88eb000.ssphy: Linked as a consumer to regulator.18 [ 1.857999] msm-usb-hsphy 88e3000.hsphy: Linked as a consumer to regulator.13 [ 1.858021] msm-usb-hsphy 88e3000.hsphy: Linked as a consumer to regulator.10 [ 1.858034] msm-usb-hsphy 88e3000.hsphy: Linked as a consumer to regulator.21 [ 1.858211] msm-usb-hsphy 88e4000.hsphy: Linked as a consumer to regulator.13 [ 1.858222] msm-usb-hsphy 88e4000.hsphy: Linked as a consumer to regulator.10 [ 1.858232] msm-usb-hsphy 88e4000.hsphy: Linked as a consumer to regulator.21 [ 1.858778] msm-dwc3 a600000.ssusb: Linked as a consumer to 15000000.apps-smmu [ 1.859004] iommu: Adding device a600000.ssusb to group 13 [ 1.859152] msm-dwc3 a600000.ssusb: Linked as a consumer to regulator.66 [ 1.860588] msm-dwc3 a600000.ssusb: unable to get ssphy device [ 1.861600] msm-dwc3 a600000.ssusb: Dropping the link to regulator.66 [ 1.861655] msm-dwc3 a800000.ssusb: Linked as a consumer to 15000000.apps-smmu [ 1.861848] iommu: Adding device a800000.ssusb to group 14 [ 1.862001] msm-dwc3 a800000.ssusb: Linked as a consumer to regulator.67 [ 1.863002] register_client_adhoc:Client handle 36 usb1 [ 1.863723] usbcore: registered new interface driver cdc_acm [ 1.863732] usbcore: registered new interface driver cdc_wdm [ 1.863741] usbcore: registered new interface driver usb-storage [ 1.863756] usbcore: registered new interface driver cp210x [ 1.863761] usbserial: USB Serial support registered for cp210x [ 1.863767] usbcore: registered new interface driver ftdi_sio [ 1.863771] usbserial: USB Serial support registered for FTDI USB Serial Device [ 1.863778] usbcore: registered new interface driver option [ 1.863782] usbserial: USB Serial support registered for GSM modem (1-port) [ 1.863787] usbcore: registered new interface driver qcserial [ 1.863791] usbserial: USB Serial support registered for Qualcomm USB modem [ 1.863797] usbcore: registered new interface driver sierra [ 1.863801] usbserial: USB Serial support registered for Sierra USB modem [ 1.863807] usbcore: registered new interface driver usb_ehset_test [ 1.863813] usbcore: registered new interface driver lvs [ 1.864094] qpnp-pdphy c440000.qcom,spmi:qcom,pm8150b@2:qcom,usb-pdphy@1700: Linked as a consumer to regulator.10 [ 1.864626] qpnp-pdphy c440000.qcom,spmi:qcom,pm8150b@2:qcom,usb-pdphy@1700: usbpd_create failed: -517 [ 1.864693] qpnp-pdphy c440000.qcom,spmi:qcom,pm8150b@2:qcom,usb-pdphy@1700: Dropping the link to regulator.10 [ 1.864840] usbcore: registered new interface driver xpad [ 1.864847] usbcore: registered new interface driver usb_acecad [ 1.864852] usbcore: registered new interface driver aiptek [ 1.864858] usbcore: registered new interface driver gtco [ 1.864864] usbcore: registered new interface driver hanwang [ 1.864868] usbcore: registered new interface driver kbtab [ 1.871415] ssusb redriver 3-001c: Could not get usb power_supply [ 1.871420] ssusb redriver 3-001c: failed to get phandle for redriver [ 1.877138] usbcore: registered new interface driver uvcvideo [ 1.893434] usbcore: registered new interface driver usbhid [ 1.893436] usbhid: USB HID core driver [ 1.907420] usbcore: registered new interface driver snd-usb-audio [ 1.907510] uaudio-qmi soc:usb_audio_qmi_dev: Linked as a consumer to 15000000.apps-smmu [ 1.907534] iommu: Adding device soc:usb_audio_qmi_dev to group 20 [ 1.920303] msm-dwc3 a800000.ssusb: DWC3 exited from low power mode [ 1.921251] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19 [ 1.921264] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.921274] usb usb1: Product: xHCI Host Controller [ 1.921281] usb usb1: Manufacturer: Linux 4.19.125 xhci-hcd [ 1.921288] usb usb1: SerialNumber: xhci-hcd.0.auto [ 1.922122] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19 [ 1.922134] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.922145] usb usb2: Product: xHCI Host Controller [ 1.922152] usb usb2: Manufacturer: Linux 4.19.125 xhci-hcd [ 1.922160] usb usb2: SerialNumber: xhci-hcd.0.auto [ 1.959048] msm-usb-ssphy-qmp 88e8000.ssphy: Linked as a consumer to regulator.32 [ 1.959075] msm-usb-ssphy-qmp 88e8000.ssphy: Linked as a consumer to regulator.18 [ 1.959080] msm-usb-ssphy-qmp 88e8000.ssphy: failed to get phandle for msm_ssphy_qmp [ 1.959099] msm-usb-ssphy-qmp 88e8000.ssphy: Dropping the link to regulator.18 [ 1.959109] msm-usb-ssphy-qmp 88e8000.ssphy: Dropping the link to regulator.32 [ 1.959186] msm-dwc3 a600000.ssusb: Linked as a consumer to regulator.66 [ 1.960319] usb_bam_init: setting SPS_BAM_SMMU_EN flag with (a704000.qcom,usbbam) [ 1.960427] msm-dwc3 a600000.ssusb: unable to get ssphy device [ 1.961090] msm-dwc3 a600000.ssusb: Dropping the link to regulator.66 [ 1.961154] qpnp-pdphy c440000.qcom,spmi:qcom,pm8150b@2:qcom,usb-pdphy@1700: Linked as a consumer to regulator.10 [ 1.961704] qpnp-pdphy c440000.qcom,spmi:qcom,pm8150b@2:qcom,usb-pdphy@1700: usbpd_create failed: -517 [ 1.961777] qpnp-pdphy c440000.qcom,spmi:qcom,pm8150b@2:qcom,usb-pdphy@1700: Dropping the link to regulator.10 [ 1.967371] ssusb redriver 3-001c: Could not get usb power_supply [ 1.967375] ssusb redriver 3-001c: failed to get phandle for redriver [ 1.977320] SMB5 status - usb:present=0 type=0 batt:present = 1 health = 1 charge = 1 [ 1.989400] msm-usb-ssphy-qmp 88e8000.ssphy: Linked as a consumer to regulator.32 [ 1.989413] msm-usb-ssphy-qmp 88e8000.ssphy: Linked as a consumer to regulator.18 [ 1.989418] msm-usb-ssphy-qmp 88e8000.ssphy: failed to get phandle for msm_ssphy_qmp [ 1.989433] msm-usb-ssphy-qmp 88e8000.ssphy: Dropping the link to regulator.18 [ 1.989441] msm-usb-ssphy-qmp 88e8000.ssphy: Dropping the link to regulator.32 [ 1.989517] msm-dwc3 a600000.ssusb: Linked as a consumer to regulator.66 [ 1.990404] usb_bam_init: setting SPS_BAM_SMMU_EN flag with (a704000.qcom,usbbam) [ 1.990508] msm-dwc3 a600000.ssusb: unable to get ssphy device [ 1.991138] msm-dwc3 a600000.ssusb: Dropping the link to regulator.66 [ 1.991202] qpnp-pdphy c440000.qcom,spmi:qcom,pm8150b@2:qcom,usb-pdphy@1700: Linked as a consumer to regulator.10 [ 1.997331] msm-usb-ssphy-qmp 88e8000.ssphy: Linked as a consumer to regulator.32 [ 1.997345] msm-usb-ssphy-qmp 88e8000.ssphy: Linked as a consumer to regulator.18 [ 1.997349] msm-usb-ssphy-qmp 88e8000.ssphy: No separate ID extcon device [ 1.997392] msm-dwc3 a600000.ssusb: Linked as a consumer to regulator.66 [ 1.998227] usb_bam_init: setting SPS_BAM_SMMU_EN flag with (a704000.qcom,usbbam) [ 1.998632] register_client_adhoc:Client handle 63 usb0 [ 1.998672] msm-dwc3 a600000.ssusb: Linked as a consumer to regulator.86 [ 2.056179] msm-dwc3 a600000.ssusb: DWC3 exited from low power mode [ 2.056930] msm-dwc3 a600000.ssusb: DWC3 in low power mode [ 2.287804] usbcore: registered new interface driver 8188eu [ 2.327455] usbcore: registered new interface driver rtl8821cu [ 2.346036] usbcore: registered new interface driver rtl88XXau [ 2.656045] usb 1-1: new high-speed USB device number 2 using xhci-hcd [ 2.792395] usb 1-1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3 [ 2.792401] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0 [ 3.184140] usb 1-1.4: new high-speed USB device number 3 using xhci-hcd [ 4.016323] usb 1-1-port4: Cannot enable. Maybe the USB cable is bad? [ 4.852415] usb 1-1-port4: Cannot enable. Maybe the USB cable is bad? [ 4.852644] usb 1-1-port4: attempt power cycle [ 5.018757] f_cdev_alloc: port_name:at_usb0 (ffffffe38c15a800) portno:(0) [ 5.021717] f_cdev_alloc: port_name:at_usb1 (ffffffe38c158400) portno:(1) [ 6.016434] usb 1-1-port4: Cannot enable. Maybe the USB cable is bad? [ 6.088053] usb 1-1.4: new high-speed USB device number 6 using xhci-hcd [ 6.088136] usb 1-1.4: Device not responding to setup address. [ 6.297149] usb 1-1.4: Device not responding to setup address. [ 6.500946] usb 1-1.4: device not accepting address 6, error -71 [ 6.501376] usb 1-1-port4: unable to enumerate USB device [ 6.921975] usb 1-1.4: new high-speed USB device number 7 using xhci-hcd [ 7.029686] usb 1-1.4: New USB device found, idVendor=0bda, idProduct=0811, bcdDevice= 2.00 [ 7.029695] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 7.029700] usb 1-1.4: Product: 802.11ac WLAN Adapter [ 7.029705] usb 1-1.4: Manufacturer: Realtek [ 7.029709] usb 1-1.4: SerialNumber: 00e04c000001 [ 7.274284] usb 1-1.4: 88XXau 00:c0:ca:b5:ab:9c hw_info[107] [ 26.444557] usb 1-1.2: new high-speed USB device number 8 using xhci-hcd [ 26.534908] usb 1-1.2: New USB device found, idVendor=1f94, idProduct=3002, bcdDevice= 4.14 [ 26.534925] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 26.534934] usb 1-1.2: Product: pMDDL2450AES256 [ 26.534942] usb 1-1.2: Manufacturer: Microhard [ 26.534951] usb 1-1.2: SerialNumber: 1592348 [ 26.634655] rndis_host 1-1.2:1.0 usb0: register 'rndis_host' at usb-xhci-hcd.0.auto-1.2, RNDIS device, 06:f2:15:a9:a5:b2 [ 281.219466] usb 1-1.4: USB disconnect, device number 7 [ 281.515539] usb 1-1.4: new high-speed USB device number 9 using xhci-hcd [ 281.605319] usb 1-1.4: New USB device found, idVendor=0bda, idProduct=0811, bcdDevice= 2.00 [ 281.605329] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 281.605333] usb 1-1.4: Product: 802.11ac WLAN Adapter [ 281.605337] usb 1-1.4: Manufacturer: Realtek [ 281.605341] usb 1-1.4: SerialNumber: 00e04c000001 [ 281.932340] usb 1-1.4: 88XXau 00:c0:ca:b5:ab:9c hw_info[107] [ 297.859348] usb 1-1.4: USB disconnect, device number 9 [ 298.159693] usb 1-1.4: new high-speed USB device number 10 using xhci-hcd [ 298.249415] usb 1-1.4: New USB device found, idVendor=0bda, idProduct=0811, bcdDevice= 2.00 [ 298.249426] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 298.249432] usb 1-1.4: Product: 802.11ac WLAN Adapter [ 298.249437] usb 1-1.4: Manufacturer: Realtek [ 298.249442] usb 1-1.4: SerialNumber: 00e04c000001 [ 298.574671] usb 1-1.4: 88XXau 00:c0:ca:b5:ab:9c hw_info[107] [ 300.419153] usb 1-1.4: USB disconnect, device number 10 [ 300.684351] usb 1-1.4: new high-speed USB device number 11 using xhci-hcd [ 301.534222] usb 1-1-port4: Cannot enable. Maybe the USB cable is bad? [ 301.607787] usb 1-1.4: new high-speed USB device number 12 using xhci-hcd [ 302.440236] usb 1-1-port4: Cannot enable. Maybe the USB cable is bad? [ 302.440408] usb 1-1-port4: attempt power cycle [ 303.580855] usb 1-1-port4: Cannot enable. Maybe the USB cable is bad? [ 304.428990] usb 1-1-port4: Cannot enable. Maybe the USB cable is bad? [ 304.430266] usb 1-1-port4: unable to enumerate USB device -
I just disconnected/reconnected the USB to 4-pin JST cable from the microhard carrier board and rebooted the vehicle. Now the wlan0 interface has been up the entire time the vehicle's on, but none of the other devices on the vLAN the wifi adapter is connected to can ping the vehicle over wifi.
Output from dmesg looks the same except the following output after the microhard interface is found:
[ 26.460342] usb 1-1.2: new high-speed USB device number 4 using xhci-hcd [ 26.550901] usb 1-1.2: New USB device found, idVendor=1f94, idProduct=3002, bcdDevice= 4.14 [ 26.550915] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 26.550922] usb 1-1.2: Product: pMDDL2450AES256 [ 26.550929] usb 1-1.2: Manufacturer: Microhard [ 26.550935] usb 1-1.2: SerialNumber: 1592348 [ 26.639101] rndis_host 1-1.2:1.0 usb0: register 'rndis_host' at usb-xhci-hcd.0.auto-1.2, RNDIS device, 16:4f:08:e4:e1:09 [ 26.643401] cdc_acm 1-1.2:1.2: ttyACM0: USB ACM device [ 33.765387] vdd_tof: disabling [ 33.765393] vdd_hap_boost: disabling [ 37.240138] hrtimer: interrupt took 112083 ns [ 101.412343] boot log copy done [ 114.937520] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x41b08 [ 233.747906] perf: interrupt took too long (2778 > 2500), lowering kernel.perf_event_max_sample_rate to 72000 [ 339.990578] perf: interrupt took too long (3473 > 3472), lowering kernel.perf_event_max_sample_rate to 57500 [ 386.060248] perf: interrupt took too long (4425 > 4341), lowering kernel.perf_event_max_sample_rate to 45000 -
[ 26.460342] usb 1-1.2: new high-speed USB device number 4 using xhci-hcd [ 26.550901] usb 1-1.2: New USB device found, idVendor=1f94, idProduct=3002, bcdDevice= 4.14 [ 26.550915] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 26.550922] usb 1-1.2: Product: pMDDL2450AES256 [ 26.550929] usb 1-1.2: Manufacturer: Microhard [ 26.550935] usb 1-1.2: SerialNumber: 1592348 [ 26.639101] rndis_host 1-1.2:1.0 usb0: register 'rndis_host' at usb-xhci-hcd.0.auto-1.2, RNDIS device, 16:4f:08:e4:e1:09 [ 26.643401] cdc_acm 1-1.2:1.2: ttyACM0: USB ACM device [ 33.765387] vdd_tof: disabling [ 33.765393] vdd_hap_boost: disabling [ 37.240138] hrtimer: interrupt took 112083 ns [ 101.412343] boot log copy done [ 114.937520] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x41b08 [ 233.747906] perf: interrupt took too long (2778 > 2500), lowering kernel.perf_event_max_sample_rate to 72000 [ 339.990578] perf: interrupt took too long (3473 > 3472), lowering kernel.perf_event_max_sample_rate to 57500 [ 386.060248] perf: interrupt took too long (4425 > 4341), lowering kernel.perf_event_max_sample_rate to 45000@jmltt This is still a problem. I reverted the changes for static IP set-up and am just using DHCP so the settings are the same as how the quad was shipped. Still getting cannot enable, usb cable bad? messages after the wifi adapter if recognized on start-up. I'm hoping the the wifi adapter or cabling is just bad and not the port on the carrier board.
[ 2.361738] usbcore: registered new interface driver 8188eu [ 2.447119] usbcore: registered new interface driver rtl8821cu [ 2.499469] usbcore: registered new interface driver rtl88XXau [ 2.912052] usb 1-1: new high-speed USB device number 2 using xhci-hcd [ 3.048404] usb 1-1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3 [ 3.048410] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0 [ 4.220352] usb 1-1-port4: Cannot enable. Maybe the USB cable is bad? [ 5.022237] f_cdev_alloc: port_name:at_usb0 (ffffffe44efe8000) portno:(0) [ 5.024793] f_cdev_alloc: port_name:at_usb1 (ffffffe44c25f400) portno:(1) [ 5.068782] usb 1-1-port4: Cannot enable. Maybe the USB cable is bad? [ 5.069166] usb 1-1-port4: attempt power cycle [ 6.208341] usb 1-1-port4: Cannot enable. Maybe the USB cable is bad? [ 6.280130] usb 1-1.4: new high-speed USB device number 6 using xhci-hcd [ 6.280207] usb 1-1.4: Device not responding to setup address. [ 6.484149] usb 1-1.4: Device not responding to setup address. [ 6.688146] usb 1-1.4: device not accepting address 6, error -71 [ 6.688417] usb 1-1-port4: unable to enumerate USB device [ 7.673010] usb 1-1-port4: Cannot enable. Maybe the USB cable is bad? [ 8.520477] usb 1-1-port4: Cannot enable. Maybe the USB cable is bad? [ 8.520664] usb 1-1-port4: attempt power cycle [ 9.660805] usb 1-1-port4: Cannot enable. Maybe the USB cable is bad? [ 10.500523] usb 1-1-port4: Cannot enable. Maybe the USB cable is bad? [ 10.500714] usb 1-1-port4: unable to enumerate USB deviceWhen I take the lid off the and reseat the JST connector it starts working again. Maybe the problem is the lid clamping down on the wires and slowly pulling the connector out or maybe it's just bad wires.
Is there any way to order a replacement assembly? Like the way it's shipped, 4-pin JST to to USB to wifi adapter with the shrink wrap and everything? I know Sentinels EOL but I'm assuming you might have the same wifi adapter set-up for another platform
If this is more of a customer support question can someone point me to an email address to direct this to? Thanks
@jmltt , are you looking for an adapter like this? https://www.modalai.com/products/mcbl-00009 . If not, please attache a picture of what you need.
Definitely worth trying another adapter cable.
@Alex-Kushleyev That is the type of cable I'd need but I've actually ordered that one (MCBL-00009-1) before for a separate application and just eyeballing it it's about half the length I'd need. Here's a picture of the set-up
Also, in addition to trying to troubleshoot this adapter/cable I need to retrofit four older Sentinel models (were only shipped with the microhard carrier board, no wifi adapter) with wifi adapters so if it's possible I'd like to just purchase five assemblies (usb to jst and wifi adapter shrink wrapped together). If you guys don't have any of that cabling already made or there's no mechanism for me to order them as a set that's totally fine. We can order the piece parts and make the cabling ourselves, it'd just be easier for us to order them if that's possible.
@jmltt , ok, thanks for the details. I will check if we have any of those assemblies in stock, or what the best course of action in your case.
Meanwhile, if you already have the shorter cable, are you able to use it for checking if the USB issues are resolved by switching the USB cable?
@Alex-Kushleyev I just wanted to check back and see if you guys still have any of the longer cables or the entire assemblies that I could purchase. I haven't had a chance to troubleshoot the potentially bad cable, but we're just looking to replace it since we need to retrofit the older models anyways.
Again, if not no worries we make our own cables and buy the adapters it'd just be easier to buy ready-made sets.
@Vinny That's it! I don't know how I missed it.
I couldn't find the wifi adapters that shipped with the sentinels in your store so I'm assuming you don't sell them individually.
Does it matter what kind of adapter I get, are there any specs that I need to looks for or can I pretty much use anything?
@jmltt
Yes, that looks correct.
https://docs.modalai.com/voxl-2-wifi-setup/#overviewThe dongle is expected to have the specific Realtek RTL8812/8818 part in there. You'll see the RTL part number in the serial console or ifconfig (I think, I'm not SW).
@jmltt
