  2. Software Development
  3. Instruction to set a Static IP for wlan0 voxl2
3 Posts 2 Posters 2.5k Views 1 Watching
  • J Offline
    Judoor 0
    Guide to Configure a Static IP Address with systemd-networkd
    I didn't find any guide on how to do it with the voxl2, even the static-ip service seem reserved for eth0 configuration, tell me, if i'm wrong i'll delete this.
    If you want to assign a static IP address to your wireless network interface (using systemd-networkd), follow this simple guide. In this example, we configure the wlan0 interface to use the static IP address 192.168.XX.XX.
    1. Check the Status of systemd-networkd
    Before starting, ensure that systemd-networkd is enabled and running:
    sudo systemctl status systemd-networkd
    If the service is not active, enable it:
    sudo systemctl enable systemd-networkd
    sudo systemctl start systemd-networkd
    2. Create the Configuration File for wlan0
    1. Navigate to the configuration directory:
      cd /etc/systemd/network/
    2. Create a configuration file for your wireless interface (e.g., 10-wlan0.network)
      sudo nano 10-wlan0.network
    3. Add the following lines to the file:
      [Match]
      Name=wlan0
      [Network]
      Address="192.168.XX.XX"/24
      Gateway="192.168.XX.1"
      DNS=8.8.8.8 1.1.1.1
      Explanation:
      • Name=wlan0: Specifies the target interface.
      • Address=192.168.XX.XX/24: Defines the IP address and subnet mask.
      • Gateway=192.168.XX.1: Sets the default gateway.
      • DNS=8.8.8.8 1.1.1.1: Configures the DNS servers.
    4. Save and close the file.
    3. Restart systemd-networkd
    Apply the new configuration by restarting the service:
    sudo systemctl restart systemd-networkd
    4. Verify the Configuration
    To verify that the IP address has been assigned to wlan0:
    ip addr show wlan0
    You should see the IP address 192.168.XX.XX assigned to the interface.
    5. Enable the Service at Boot
    Ensure that systemd-networkd is enabled to run at every boot:
    6. Reboot the System
    To confirm everything works correctly on startup:
    sudo reboot
    You have now successfully configured a static IP address for the wlan0 interface using systemd-networkd on your voxl2!
    • J Offline
      Judoor 0
      wrote on last edited by Judoor 0
      Another way to do it, maybe more in line with the way modal ai intended it is this :
      Update dhcpcd.conf for Static IP
      Open the dhcpcd.conf file for editing:
      nano /etc/dhcpcd.conf
      Add the following lines at the end of the file to configure a static IP for wlan0:
      interface wlan0
      static ip_address=192.168.XX.XX/24
      static routers=192.168.XX.1
      static domain_name_servers=8.8.8.8 1.1.1.1
      Explanation:
      interface wlan0: Specifies the network interface to configure.
      static ip_address=192.168.XX.XX/24: Assigns the static IP and subnet mask.
      static routers=192.168.XX.1: Sets the gateway address.
      static domain_name_servers=8.8.8.8 1.1.1.1: Configures DNS servers (Google and Cloudflare in this case).
      Save and exit the file.
      Restart dhcpcd Service
      Apply the changes by restarting the dhcpcd service:
      systemctl enable dhcpcd
      systemctl restart dhcpcd
      • J Judoor 0
        interface wlan0
        Explanation:
        @Judoor-0 Thanks for the contribution, this is very helpful!
        • J jmltt referenced this topic on
