  3. Starling 2 not following navigation path
21 Posts 3 Posters 2.2k Views
  • G Offline
    G Offline
    greg_s
    Hello ModalAI Team,
    I am still trying to get the navigation working with my team's Starling 2.
    kernel: #1 SMP PREEMPT Wed Oct 22 04:13:18 UTC 2025 4.19.125
    hw platform: M0054
    mach.var: 1.0.1
    SKU: MRB-D0014-4-V1-C27-T8-M22-X0
    voxl-suite: 1.6.2
    I have updated the drone to the latest voxl version 1.6.2. I am able to fly the drone in position mode and figure 8 mode.
    I few the drone around for a couple of minutes in our testing room gathering map data. I then switched the drone into offboard_mode: trajectory. I planned a point and saw the projected path drawing a simple straight line. There are not obstacles in the way to navigate around/avoid. The drone just flew directly at the grown instead of following the path. Is there anything I should try software/settings-wise to try and get navigation working? Is there anything about the layout/appearance of a room that could cause this? Please see the attached image.
    • G Offline
      G Offline
      greg_s
      Hello ModalAI Team,
      Please let me know if there is any further information needed. So far, I haven't had the drone successfully navigate in trajectory in any version of the VOXL SDK I've tried (1.4/1.5/1.6).
      A 1 Reply Last reply
      • G greg_s
        Hello ModalAI Team,
        ApoorvThapliyal
        Hey @greg_s,
        Can you post your voxl-logs and flight logs?
        G 1 Reply Last reply
        • A ApoorvThapliyal
          Hey @greg_s,
          G Offline
          G Offline
          greg_s
          wrote on last edited by greg_s
          Hello @ApoorvThapliyal,
          I put the log file here: log100.ulg on Filebin.net
          I also put the the output from voxl-vision-hub --debug_offboard suggested by @Cliff-Wong in another post in another upload here voxl-vision-hub-log.txt on Filebin.net.
          When I attempted the flight, the drone appeared to fly to the correct X and Z coordinates, but it was close to the floor and well below the correct Y coordinate.
          Here are a couple of picture of the map and projected route:
          And a couple of the map after the drone tried to navigate and ended up below the point:
          • G Offline
            G Offline
            greg_s
            For convenience I took out the section that has the trajectory from the voxl-vision-hub logs:
            commanding: XYZ -0.4 -0.2 -1.8 yaw: 0.3
            commanding: XYZ -0.4 -0.2 -1.7 yaw: 0.3
            Received trajectory has duration 1.953539 seconds
            Received load and start command.
            commanding: XYZ -0.4 -0.2 -1.0 yaw: 0.7 V: 0.0 0.0 -0.0 A: 0.1 0.0 -0.0
            commanding: XYZ -0.4 -0.2 -1.0 yaw: 0.7 V: 0.0 0.0 -0.0 A: 0.2 0.2 -0.0
            commanding: XYZ -0.4 -0.2 -1.0 yaw: 0.7 V: 0.0 0.0 -0.0 A: 0.3 0.3 -0.0
            commanding: XYZ -0.4 -0.2 -1.0 yaw: 0.7 V: 0.0 0.0 -0.0 A: 0.5 0.5 -0.0
            commanding: XYZ -0.4 -0.2 -1.0 yaw: 0.7 V: 0.0 0.0 -0.0 A: 0.7 0.6 0.0
            commanding: XYZ -0.4 -0.2 -1.0 yaw: 0.7 V: 0.1 0.1 -0.0 A: 0.9 0.7 0.0
            commanding: XYZ -0.3 -0.2 -1.0 yaw: 0.7 V: 0.1 0.1 0.0 A: 1.0 0.9 0.0
            commanding: XYZ -0.3 -0.2 -1.0 yaw: 0.7 V: 0.1 0.1 0.0 A: 1.1 0.9 0.0
            commanding: XYZ -0.3 -0.2 -1.0 yaw: 0.7 V: 0.2 0.2 0.0 A: 1.1 1.0 0.0
            commanding: XYZ -0.3 -0.2 -1.0 yaw: 0.7 V: 0.2 0.2 0.0 A: 1.2 1.0 0.0
            commanding: XYZ -0.3 -0.2 -1.0 yaw: 0.7 V: 0.3 0.2 0.0 A: 1.2 1.0 0.0
            commanding: XYZ -0.3 -0.2 -1.0 yaw: 0.7 V: 0.3 0.3 0.0 A: 1.2 1.0 0.0
            commanding: XYZ -0.3 -0.1 -1.0 yaw: 0.7 V: 0.3 0.3 0.0 A: 1.2 1.0 0.0
            commanding: XYZ -0.3 -0.1 -1.0 yaw: 0.7 V: 0.4 0.3 0.0 A: 1.1 1.0 0.0
            commanding: XYZ -0.3 -0.1 -1.0 yaw: 0.7 V: 0.4 0.4 0.0 A: 1.1 1.0 0.0
            Received trajectory has duration 1.452853 seconds
            Received insert command.
            commanding: XYZ -0.3 -0.1 -1.0 yaw: 0.7 V: 0.5 0.4 0.0 A: 1.1 0.9 0.0
            commanding: XYZ -0.2 -0.1 -1.0 yaw: 0.7 V: 0.5 0.4 0.0 A: 1.0 0.9 0.0
            commanding: XYZ -0.2 -0.1 -1.0 yaw: 0.7 V: 0.5 0.5 0.0 A: 1.0 0.9 0.0
            commanding: XYZ -0.2 -0.1 -1.0 yaw: 0.7 V: 0.6 0.5 0.0 A: 0.9 0.8 0.0
            commanding: XYZ -0.2 -0.0 -1.0 yaw: 0.7 V: 0.6 0.5 0.0 A: 0.8 0.7 0.1
            commanding: XYZ -0.2 -0.0 -1.0 yaw: 0.7 V: 0.6 0.6 0.0 A: 0.8 0.6 0.1
            commanding: XYZ -0.1 0.0 -1.0 yaw: 0.7 V: 0.7 0.6 0.0 A: 0.7 0.5 0.1
            commanding: XYZ -0.1 0.0 -1.0 yaw: 0.7 V: 0.7 0.6 0.0 A: 0.6 0.5 0.1
            commanding: XYZ -0.1 0.0 -1.0 yaw: 0.7 V: 0.7 0.6 0.0 A: 0.5 0.4 0.1
            commanding: XYZ -0.1 0.1 -1.0 yaw: 0.7 V: 0.7 0.6 0.0 A: 0.4 0.3 0.0
            commanding: XYZ -0.0 0.1 -1.0 yaw: 0.7 V: 0.7 0.6 0.0 A: 0.3 0.2 0.0
            commanding: XYZ -0.0 0.1 -1.0 yaw: 0.7 V: 0.7 0.6 0.0 A: 0.2 0.1 0.0
            commanding: XYZ 0.0 0.1 -1.0 yaw: 0.7 V: 0.7 0.6 0.0 A: 0.0 0.0 0.0
            Received trajectory has duration 0.510237 seconds
            commanding: XYZ 0.0 0.1 -1.0 yaw: 0.7 V: 0.7 0.6 0.0 A: -0.1 -0.1 0.0
            commanding: XYZ 0.1 0.2 -1.0 yaw: 0.7 V: 0.7 0.6 0.0 A: -0.2 -0.2 0.0
            commanding: XYZ 0.1 0.2 -1.0 yaw: 0.7 V: 0.6 0.5 0.0 A: -0.2 -0.2 0.0
            commanding: XYZ 0.1 0.2 -1.0 yaw: 0.7 V: 0.6 0.5 0.0 A: -0.3 -0.2 0.0
            commanding: XYZ 0.1 0.2 -1.0 yaw: 0.7 V: 0.6 0.5 0.0 A: -0.4 -0.3 -0.0
            commanding: XYZ 0.1 0.2 -1.0 yaw: 0.7 V: 0.6 0.5 0.0 A: -0.5 -0.4 -0.0
            commanding: XYZ 0.2 0.3 -1.0 yaw: 0.7 V: 0.6 0.5 0.0 A: -0.6 -0.5 -0.0
            commanding: XYZ 0.2 0.3 -1.0 yaw: 0.7 V: 0.6 0.5 0.0 A: -0.7 -0.6 -0.0
            commanding: XYZ 0.2 0.3 -1.0 yaw: 0.7 V: 0.5 0.5 0.0 A: -0.7 -0.6 -0.0
            commanding: XYZ 0.2 0.3 -1.0 yaw: 0.7 V: 0.5 0.4 0.0 A: -0.7 -0.6 -0.0
            commanding: XYZ 0.2 0.3 -1.0 yaw: 0.7 V: 0.5 0.4 0.0 A: -0.8 -0.7 -0.0
            commanding: XYZ 0.3 0.3 -1.0 yaw: 0.7 V: 0.4 0.4 0.0 A: -0.8 -0.7 -0.0
            commanding: XYZ 0.3 0.4 -1.0 yaw: 0.7 V: 0.4 0.3 0.0 A: -0.8 -0.7 -0.0
            commanding: XYZ 0.3 0.4 -1.0 yaw: 0.7 V: 0.4 0.3 0.0 A: -0.7 -0.6 -0.0
            commanding: XYZ 0.3 0.4 -1.0 yaw: 0.7 V: 0.3 0.3 0.0 A: -0.5 -0.5 -0.0
            commanding: XYZ 0.3 0.4 -1.0 yaw: 0.7 V: 0.3 0.3 0.0 A: -0.4 -0.3 0.0
            commanding: XYZ 0.3 0.4 -1.0 yaw: 0.7 V: 0.3 0.3 0.0 A: -0.3 -0.3 0.0
            commanding: XYZ 0.3 0.4 -1.0 yaw: 0.7 V: 0.3 0.2 0.0 A: -0.4 -0.4 0.0
            commanding: XYZ 0.3 0.4 -1.0 yaw: 0.7 V: 0.3 0.2 0.0 A: -0.6 -0.5 -0.0
            commanding: XYZ 0.4 0.4 -1.0 yaw: 0.7 V: 0.2 0.2 0.0 A: -0.8 -0.7 -0.0
            commanding: XYZ 0.4 0.4 -1.0 yaw: 0.7 V: 0.2 0.2 0.0 A: -1.1 -0.9 -0.1
            commanding: XYZ 0.4 0.4 -1.0 yaw: 0.7 V: 0.2 0.1 0.0 A: -1.3 -1.1 -0.1
            commanding: XYZ 0.4 0.4 -1.0 yaw: 0.7 V: 0.1 0.1 0.0 A: -1.4 -1.1 -0.1
            commanding: XYZ 0.4 0.4 -1.0 yaw: 0.7 V: 0.1 0.1 0.0 A: -1.3 -1.1 -0.1
            commanding: XYZ 0.4 0.4 -1.0 yaw: 0.7 V: 0.0 0.0 0.0 A: -1.0 -0.9 -0.1
            commanding: XYZ 0.4 0.4 -1.0 yaw: 0.7 V: 0.0 0.0 0.0 A: -0.7 -0.6 -0.1
            commanding: XYZ 0.4 0.4 -1.0 yaw: 0.7 V: 0.0 0.0 0.0 A: -0.3 -0.2 -0.0
            commanding: XYZ 0.4 0.4 -1.0 yaw: 0.7 V: 0.0 0.0 0.0 A: -0.0 -0.0 -0.0
            commanding: XYZ 0.4 0.4 -1.0 yaw: 0.7 V: -0.0 -0.0 0.0 A: -0.0 -0.0 0.0
            FINISHED TRAJECTORY
            commanding: XYZ 0.4 0.5 -1.0 yaw: 0.7
            • G Offline
              G Offline
              greg_s
              @ApoorvThapliyal, if you/your team needs anymore information or data, do let me know. Thank you.
              • G greg_s
                ApoorvThapliyal
                Hey @greg_s
                I just wanted to confirm, are you dragging the planned point to the height desired? By default, simply clicking on the map will generate a point at height 0.
                Let me know, thanks
                G 2 Replies Last reply
                • A ApoorvThapliyal
                  Hey @greg_s
                  Let me know, thanks
                  G Offline
                  G Offline
                  greg_s
                  Yes, I am dragging the point up and panning the camera around to ensure it is roughly the same height as the drone. The line drawn for the path is pretty straight and at the correctly level. The drone just ends up flying down below the point after I have move it.
                  • A ApoorvThapliyal
                    Hey @greg_s
                    Let me know, thanks
                    G Offline
                    G Offline
                    greg_s
                    Is there anything more your teams need to investigate/troubleshoot the issue? Thanks.
                    • G greg_s
                      ApoorvThapliyal
                      Hey @greg_s
                      I was able to reproduce the issue where the drone does not fly correctly toward the setpoint. I think reviewing the extrinsics.conf file is a good next step, as there may be an incorrect transform defined there.
                      • A ApoorvThapliyal
                        Hey @greg_s
                        G Offline
                        G Offline
                        greg_s
                        #11
                        Hey @ApoorvThapliyal,
                        Here is the output of the extrinsics:
                        voxl2:~$ voxl-inspect-extrinsics --all
                        #0:
                        parent: imu_apps
                        child: tracking_front
                        T_child_wrt_parent: 0.037 0.000 0.001
                        RPY_parent_to_child: 0.0 90.0 90.0
                        R_child_to_parent: 0.000 -0.000 1.000
                        1.000 0.000 -0.000
                        -0.000 1.000 0.000
                        #1:
                        parent: imu_apps
                        child: tracking_down
                        T_child_wrt_parent: -0.088 -0.004 0.027
                        RPY_parent_to_child: 0.0 0.0 180.0
                        R_child_to_parent: -1.000 -0.000 0.000
                        0.000 -1.000 -0.000
                        0.000 0.000 1.000
                        #2:
                        parent: imu_apps
                        child: tracking_rear
                        T_child_wrt_parent: -0.092 0.016 0.004
                        RPY_parent_to_child: 0.0 -90.0 -90.0
                        R_child_to_parent: 0.000 0.000 -1.000
                        -1.000 0.000 -0.000
                        0.000 1.000 0.000
                        #3:
                        parent: imu_apps
                        child: hires
                        T_child_wrt_parent: 0.039 0.000 0.019
                        1.000 0.000 -0.000
                        -0.000 1.000 0.000
                        #4:
                        parent: body
                        child: imu_apps
                        T_child_wrt_parent: 0.029 -0.006 -0.016
                        RPY_parent_to_child: 0.0 0.0 0.0
                        R_child_to_parent: 1.000 -0.000 0.000
                        0.000 1.000 -0.000
                        0.000 0.000 1.000
                        #5:
                        parent: body
                        child: imu_px4
                        T_child_wrt_parent: 0.004 0.007 -0.016
                        0.000 1.000 -0.000
                        0.000 0.000 1.000
                        #6:
                        parent: imu_apps
                        child: lepton0_raw
                        T_child_wrt_parent: -0.085 0.013 0.024
                        RPY_parent_to_child: 0.0 0.0 90.0
                        R_child_to_parent: 0.000 -1.000 0.000
                        1.000 0.000 -0.000
                        0.000 0.000 1.000
                        #7:
                        parent: body
                        child: tof
                        T_child_wrt_parent: 0.066 0.009 -0.012
                        RPY_parent_to_child: 0.0 90.0 180.0
                        R_child_to_parent: -0.000 -0.000 1.000
                        0.000 -1.000 -0.000
                        1.000 0.000 0.000
                        #8:
                        parent: body
                        child: ground
                        T_child_wrt_parent: 0.000 0.000 0.033
                        0.000 1.000 -0.000
                        0.000 0.000 1.000
                        • A ApoorvThapliyal
                          Hey @greg_s
                          G Offline
                          G Offline
                          greg_s
                          Is there anything that looks wrong or off about the configuration? Should I look at any other file in particular?
                          • G greg_s
                            Cliff WongC Offline
                            Cliff WongC Offline
                            Cliff Wong
                            wrote on last edited by Cliff Wong
                            #13
                            @greg_s
                            Hi there, your extrinsics are good: same as a factory Starling. Now, if you altered the voxl-camera-server.conf (e.g. enabled a flip of a camera stream when it wasn't) or physically changed a camera mount point then the extrinsics would need to be adjusted. Let assume that's not the case.
                            From your vvhub trajectory output, it appears your setpoints command the vehicle to move forward (X) and to the right (Y) > 1m while dropping altitude (Z) 0.8m --recall mapper runs in FRD (aka body) space where Z up is negative. Also you do pass through the take off origin (0,0,0). If that's not what you wanted, then we have a "requested trajectory" drawing problem in the portal tool or mapper's found invalid regions/obstacle and could not draw the "requested trajectory".
                            In the former case @ApoorvThapliyal mentions the un-intuitiveness of the portal tool that you already understand.
                            In the latter case, upon "request trajectory" submission, voxl-mapper will analyze the map to see if there are obstacles and alter the trajectory to fly around potential obstacles. You can alter in voxl-mapper.conf:
                            • rrt_min_distance (try 0.125)
                            • esdf_inner_sphere_radius (try 0.15)
                              if you seeing mapper create trajectories going around 'ghost' objects. This should allow RRT generated trajectories to get closer to objects.
                            In checking precision, you'll need to take the trajectory output (e.g. the setpoints in the *commanding: XYZ* messages) and compared it against VIO position to determine tracking error. You have 2 ways to get that data:
                            • option 1 is record you vvhub traj output as above and record the output of voxl-inspect-vins -n then plot compare the tracking error.
                            • option 2 is running voxl-vision-hub --debug_offboard --debug_odometry which you'll need to seperate the traj messages from the vio (T_body_wrt_local) messages, then you ca plot the tracking error.
                            The goal is we want the vio position to follow the commanded trajectory: (it's doing what is told to do). That will narrow down where your concerns are w.r.t what module has a problem.
                            Hopefully that gets you on the right track, just post any outputs you gather that continue to show tracking error.
                            • Cliff WongC Cliff Wong
                              @greg_s
                              G Offline
                              G Offline
                              greg_s
                              #14
                              Hello @Cliff-Wong,
                              I collected the output from voxl-vision-hub --debug_offboard and voxl-inspect-vins -n. I place a plan_to point that was about half a meter from the drone and slightly higher in altitude from the drone. I used the arrows to position the plan_to point and rotated camera to ensure the plan_to point it was placed correctly. I reduced the rrt_min_distance and esdf_inner_sphere_radius as suggested. The drone had more than a meter clearance on all sides. The room is empty with no obstacles.
                              The output from voxl-vision-hub --debug_offboard:
                              commanding: XYZ -1.0 -0.1 -2.4 yaw: 2.6
                              Setpoint position: XYZ -1.0 -0.1 -0.8 yaw: 0.4
                              Received trajectory has duration 3.309723 seconds
                              commanding: XYZ -1.0 -0.1 0.1 yaw: 0.4 V: 0.0 0.0 -0.0 A: 0.0 0.0 -0.0
                              commanding: XYZ -1.0 -0.1 0.1 yaw: 0.5 V: 0.0 0.0 -0.0 A: 0.0 0.0 -0.0
                              commanding: XYZ -1.0 -0.1 0.1 yaw: 0.4 V: 0.0 0.0 -0.0 A: 0.0 0.0 -0.1
                              commanding: XYZ -1.0 -0.1 0.1 yaw: 0.4 V: 0.0 0.0 -0.0 A: 0.1 0.0 -0.2
                              commanding: XYZ -1.0 -0.1 0.1 yaw: 0.4 V: 0.0 0.0 -0.0 A: 0.1 0.0 -0.3
                              commanding: XYZ -1.0 -0.1 0.1 yaw: 0.4 V: 0.0 0.0 -0.0 A: 0.1 0.1 -0.3
                              commanding: XYZ -1.0 -0.1 0.1 yaw: 0.4 V: 0.0 0.0 -0.0 A: 0.2 0.1 -0.4
                              commanding: XYZ -1.0 -0.1 0.1 yaw: 0.4 V: 0.0 0.0 -0.1 A: 0.2 0.1 -0.4
                              commanding: XYZ -1.0 -0.1 0.1 yaw: 0.4 V: 0.0 0.0 -0.1 A: 0.2 0.1 -0.5
                              commanding: XYZ -1.0 -0.1 0.1 yaw: 0.4 V: 0.0 0.0 -0.1 A: 0.3 0.1 -0.5
                              commanding: XYZ -1.0 -0.1 0.1 yaw: 0.4 V: 0.0 0.0 -0.1 A: 0.3 0.1 -0.6
                              commanding: XYZ -1.0 -0.1 0.1 yaw: 0.4 V: 0.1 0.0 -0.1 A: 0.4 0.1 -0.6
                              commanding: XYZ -1.0 -0.1 0.1 yaw: 0.4 V: 0.1 0.0 -0.2 A: 0.4 0.2 -0.6
                              commanding: XYZ -1.0 -0.1 0.1 yaw: 0.4 V: 0.1 0.0 -0.2 A: 0.5 0.2 -0.6
                              Received trajectory has duration 2.234033 seconds
                              commanding: XYZ -1.0 -0.1 0.1 yaw: 0.4 V: 0.1 0.1 -0.2 A: 0.5 0.2 -0.6
                              commanding: XYZ -1.0 -0.1 0.0 yaw: 0.4 V: 0.2 0.1 -0.3 A: 0.5 0.2 -0.6
                              commanding: XYZ -1.0 -0.1 0.0 yaw: 0.4 V: 0.2 0.1 -0.3 A: 0.6 0.2 -0.6
                              commanding: XYZ -1.0 -0.1 0.0 yaw: 0.4 V: 0.2 0.1 -0.3 A: 0.6 0.2 -0.5
                              commanding: XYZ -0.9 -0.1 -0.0 yaw: 0.4 V: 0.2 0.1 -0.3 A: 0.6 0.2 -0.5
                              commanding: XYZ -0.9 -0.1 -0.0 yaw: 0.4 V: 0.3 0.1 -0.4 A: 0.6 0.2 -0.5
                              commanding: XYZ -0.9 -0.1 -0.0 yaw: 0.4 V: 0.3 0.1 -0.4 A: 0.6 0.2 -0.4
                              commanding: XYZ -0.9 -0.1 -0.1 yaw: 0.4 V: 0.3 0.1 -0.4 A: 0.6 0.2 -0.4
                              commanding: XYZ -0.9 -0.1 -0.1 yaw: 0.4 V: 0.3 0.1 -0.4 A: 0.6 0.3 -0.4
                              commanding: XYZ -0.9 -0.1 -0.1 yaw: 0.4 V: 0.4 0.1 -0.4 A: 0.6 0.3 -0.4
                              commanding: XYZ -0.9 -0.1 -0.1 yaw: 0.4 V: 0.4 0.2 -0.4 A: 0.6 0.3 -0.4
                              commanding: XYZ -0.9 -0.1 -0.1 yaw: 0.4 V: 0.4 0.2 -0.4 A: 0.6 0.2 -0.4
                              commanding: XYZ -0.8 -0.1 -0.1 yaw: 0.4 V: 0.4 0.2 -0.5 A: 0.6 0.2 -0.4
                              commanding: XYZ -0.8 -0.1 -0.1 yaw: 0.4 V: 0.4 0.2 -0.5 A: 0.6 0.3 -0.4
                              commanding: XYZ -0.8 -0.1 -0.2 yaw: 0.4 V: 0.4 0.2 -0.5 A: 0.6 0.3 -0.4
                              commanding: XYZ -0.8 -0.1 -0.2 yaw: 0.4 V: 0.5 0.2 -0.5 A: 0.6 0.3 -0.4
                              commanding: XYZ -0.8 -0.0 -0.2 yaw: 0.4 V: 0.5 0.2 -0.5 A: 0.6 0.3 -0.3
                              commanding: XYZ -0.8 -0.0 -0.2 yaw: 0.4 V: 0.5 0.2 -0.5 A: 0.6 0.2 -0.3
                              commanding: XYZ -0.7 -0.0 -0.2 yaw: 0.4 V: 0.6 0.2 -0.5 A: 0.6 0.2 -0.3
                              commanding: XYZ -0.7 -0.0 -0.3 yaw: 0.4 V: 0.6 0.2 -0.5 A: 0.6 0.2 -0.3
                              commanding: XYZ -0.7 -0.0 -0.3 yaw: 0.4 V: 0.6 0.2 -0.6 A: 0.6 0.2 -0.2
                              commanding: XYZ -0.7 0.0 -0.3 yaw: 0.4 V: 0.6 0.3 -0.6 A: 0.5 0.2 -0.2
                              Received trajectory has duration 1.689594 seconds
                              commanding: XYZ -0.6 0.0 -0.3 yaw: 0.4 V: 0.7 0.3 -0.6 A: 0.5 0.2 -0.2
                              commanding: XYZ -0.6 0.0 -0.4 yaw: 0.4 V: 0.7 0.3 -0.6 A: 0.5 0.2 -0.1
                              commanding: XYZ -0.6 0.0 -0.4 yaw: 0.4 V: 0.7 0.3 -0.6 A: 0.4 0.2 -0.1
                              commanding: XYZ -0.6 0.0 -0.4 yaw: 0.4 V: 0.7 0.3 -0.6 A: 0.4 0.1 -0.1
                              commanding: XYZ -0.5 0.1 -0.4 yaw: 0.4 V: 0.7 0.3 -0.6 A: 0.4 0.1 -0.1
                              commanding: XYZ -0.5 0.1 -0.4 yaw: 0.4 V: 0.7 0.3 -0.6 A: 0.3 0.1 -0.0
                              commanding: XYZ -0.5 0.1 -0.5 yaw: 0.4 V: 0.7 0.3 -0.6 A: 0.3 0.1 -0.0
                              commanding: XYZ -0.5 0.1 -0.5 yaw: 0.4 V: 0.7 0.3 -0.6 A: 0.3 0.1 0.0
                              Received trajectory has duration 1.165000 seconds
                              commanding: XYZ -0.4 0.1 -0.5 yaw: 0.4 V: 0.7 0.3 -0.6 A: 0.2 0.1 0.1
                              Received trajectory has duration 1.342931 seconds
                              commanding: XYZ -0.4 0.1 -0.5 yaw: 0.4 V: 0.7 0.3 -0.6 A: 0.1 0.0 0.1
                              commanding: XYZ -0.4 0.1 -0.5 yaw: 0.4 V: 0.7 0.3 -0.6 A: 0.0 -0.0 0.2
                              commanding: XYZ -0.3 0.1 -0.6 yaw: 0.4 V: 0.7 0.3 -0.6 A: -0.0 -0.0 0.2
                              commanding: XYZ -0.3 0.1 -0.6 yaw: 0.4 V: 0.7 0.3 -0.6 A: -0.1 -0.0 0.2
                              commanding: XYZ -0.3 0.1 -0.6 yaw: 0.4 V: 0.7 0.3 -0.5 A: -0.1 -0.1 0.3
                              commanding: XYZ -0.3 0.2 -0.6 yaw: 0.4 V: 0.7 0.3 -0.5 A: -0.2 -0.1 0.3
                              commanding: XYZ -0.2 0.2 -0.6 yaw: 0.4 V: 0.7 0.3 -0.5 A: -0.2 -0.1 0.3
                              commanding: XYZ -0.2 0.2 -0.7 yaw: 0.4 V: 0.7 0.3 -0.5 A: -0.3 -0.1 0.3
                              commanding: XYZ -0.2 0.2 -0.7 yaw: 0.4 V: 0.7 0.3 -0.5 A: -0.3 -0.1 0.4
                              commanding: XYZ -0.2 0.2 -0.7 yaw: 0.4 V: 0.7 0.3 -0.5 A: -0.4 -0.2 0.4
                              Received trajectory has duration 1.508897 seconds
                              commanding: XYZ -0.1 0.2 -0.7 yaw: 0.4 V: 0.7 0.3 -0.5 A: -0.5 -0.2 0.4
                              commanding: XYZ -0.1 0.2 -0.8 yaw: 0.4 V: 0.6 0.2 -0.4 A: -0.5 -0.2 0.4
                              commanding: XYZ -0.0 0.2 -0.8 yaw: 0.4 V: 0.6 0.2 -0.4 A: -0.5 -0.2 0.4
                              commanding: XYZ -0.0 0.3 -0.8 yaw: 0.4 V: 0.5 0.2 -0.4 A: -0.6 -0.2 0.4
                              commanding: XYZ -0.0 0.3 -0.8 yaw: 0.4 V: 0.5 0.2 -0.3 A: -0.6 -0.2 0.5
                              commanding: XYZ 0.0 0.3 -0.8 yaw: 0.4 V: 0.5 0.2 -0.3 A: -0.6 -0.2 0.5
                              commanding: XYZ 0.0 0.3 -0.8 yaw: 0.4 V: 0.5 0.2 -0.3 A: -0.7 -0.3 0.5
                              commanding: XYZ 0.1 0.3 -0.8 yaw: 0.4 V: 0.4 0.2 -0.3 A: -0.7 -0.3 0.5
                              commanding: XYZ 0.1 0.3 -0.9 yaw: 0.4 V: 0.4 0.2 -0.3 A: -0.7 -0.3 0.5
                              commanding: XYZ 0.1 0.3 -0.9 yaw: 0.4 V: 0.4 0.1 -0.2 A: -0.7 -0.3 0.5
                              commanding: XYZ 0.1 0.3 -0.9 yaw: 0.4 V: 0.3 0.1 -0.2 A: -0.5 -0.2 0.4
                              commanding: XYZ 0.1 0.3 -0.9 yaw: 0.4 V: 0.2 0.1 -0.2 A: -0.5 -0.2 0.3
                              commanding: XYZ 0.1 0.3 -0.9 yaw: 0.4 V: 0.2 0.1 -0.1 A: -0.5 -0.2 0.3
                              commanding: XYZ 0.2 0.3 -0.9 yaw: 0.4 V: 0.2 0.1 -0.1 A: -0.5 -0.2 0.3
                              commanding: XYZ 0.2 0.3 -0.9 yaw: 0.4 V: 0.2 0.1 -0.1 A: -0.4 -0.2 0.3
                              commanding: XYZ 0.2 0.3 -0.9 yaw: 0.4 V: 0.1 0.1 -0.1 A: -0.4 -0.2 0.3
                              commanding: XYZ 0.2 0.3 -0.9 yaw: 0.4 V: 0.1 0.0 -0.1 A: -0.4 -0.1 0.3
                              commanding: XYZ 0.2 0.3 -0.9 yaw: 0.4 V: 0.1 0.0 -0.1 A: -0.4 -0.1 0.2
                              commanding: XYZ 0.2 0.3 -0.9 yaw: 0.4 V: 0.1 0.0 -0.1 A: -0.3 -0.1 0.2
                              commanding: XYZ 0.2 0.3 -0.9 yaw: 0.4 V: 0.1 0.0 -0.0 A: -0.3 -0.1 0.2
                              commanding: XYZ 0.2 0.3 -0.9 yaw: 0.4 V: 0.0 0.0 -0.0 A: -0.2 -0.1 0.1
                              commanding: XYZ 0.2 0.3 -0.9 yaw: 0.4 V: 0.0 0.0 -0.0 A: -0.1 -0.1 0.1
                              commanding: XYZ 0.2 0.3 -0.9 yaw: 0.4 V: 0.0 0.0 -0.0 A: -0.1 -0.0 0.1
                              commanding: XYZ 0.2 0.3 -0.9 yaw: 0.3 V: 0.0 0.0 -0.0 A: -0.1 -0.0 0.1
                              commanding: XYZ 0.2 0.3 -0.9 yaw: 0.3 V: 0.0 0.0 -0.0 A: -0.1 -0.0 0.0
                              commanding: XYZ 0.2 0.3 -0.9 yaw: 0.2 V: 0.0 0.0 -0.0 A: -0.1 -0.0 0.0
                              commanding: XYZ 0.2 0.3 -0.9 yaw: -2.8 V: -0.0 -0.0 0.0 A: -0.0 -0.0 0.0
                              Received stop command.
                              Stopped following trajectory.
                              commanding: XYZ -1.0 -0.1 -1.5 yaw: 0.5
                              The output from voxl-inspect-vins -n:
                              dt(ms) | T_imu_wrt_vio (m) |Roll Pitch Yaw (deg)|features|quality| state| error_codes
                              33.1 | -1.01 -0.14 -0.79| 1.6 -0.5 148.0| 22 | 78% | OKAY |
                              33.6 | -1.01 -0.14 -0.79| 1.6 -0.4 148.0| 22 | 78% | OKAY |
                              33.3 | -1.01 -0.14 -0.79| 1.6 -0.4 148.0| 22 | 78% | OKAY |
                              33.1 | -1.01 -0.14 -0.79| 1.6 -0.4 148.0| 22 | 78% | OKAY |
                              33.3 | -1.01 -0.14 -0.79| 1.6 -0.4 147.9| 22 | 78% | OKAY |
                              33.6 | -1.01 -0.14 -0.79| 1.5 -0.4 147.9| 22 | 78% | OKAY |
                              33.1 | -1.01 -0.14 -0.79| 1.4 -0.4 147.9| 22 | 78% | OKAY |
                              33.3 | -1.01 -0.14 -0.79| 1.4 -0.4 147.8| 22 | 78% | OKAY |
                              33.3 | -1.01 -0.14 -0.79| 1.5 -0.5 147.8| 22 | 78% | OKAY |
                              33.3 | -1.01 -0.14 -0.79| 1.5 -0.5 147.7| 22 | 78% | OKAY |
                              33.6 | -1.01 -0.14 -0.79| 1.4 -0.5 147.7| 22 | 78% | OKAY |
                              33.1 | -1.01 -0.14 -0.79| 1.4 -0.5 147.6| 22 | 78% | OKAY |
                              33.3 | -1.01 -0.15 -0.79| 1.4 -0.4 147.6| 22 | 78% | OKAY |
                              33.3 | -1.01 -0.15 -0.79| 1.4 -0.5 147.3| 22 | 74% | OKAY |
                              33.6 | -1.01 -0.15 -0.78| 1.1 -0.6 145.1| 21 | 70% | OKAY |
                              33.1 | -1.01 -0.14 -0.77| 1.0 -0.6 141.2| 20 | 70% | OKAY |
                              33.5 | -1.01 -0.14 -0.75| 0.8 -0.7 137.8| 19 | 65% | OKAY |
                              33.1 | -1.01 -0.14 -0.73| 0.6 -0.7 134.0| 25 | 75% | OKAY |
                              33.3 | -1.00 -0.14 -0.70| 0.5 -0.6 129.9| 26 | 83% | OKAY |
                              33.3 | -1.00 -0.14 -0.68| 0.6 -0.5 125.6| 24 | 82% | OKAY |
                              33.3 | -1.00 -0.14 -0.65| 0.7 -0.4 121.1| 26 | 100% | OKAY |
                              33.3 | -1.00 -0.13 -0.62| 0.8 -0.2 116.4| 27 | 100% | OKAY |
                              33.3 | -1.00 -0.13 -0.60| 1.0 -0.1 111.5| 27 | 99% | OKAY |
                              33.3 | -0.99 -0.13 -0.57| 1.2 0.0 106.5| 23 | 100% | OKAY |
                              33.3 | -0.99 -0.13 -0.54| 1.3 0.2 101.4| 18 | 73% | OKAY |
                              33.3 | -0.99 -0.13 -0.52| 1.3 0.3 96.3| 17 | 73% | OKAY |
                              33.3 | -0.99 -0.13 -0.49| 1.4 0.5 91.1| 17 | 65% | OKAY |
                              33.4 | -0.98 -0.13 -0.46| 1.4 0.8 85.8| 17 | 69% | OKAY |
                              33.3 | -0.98 -0.13 -0.43| 1.5 1.0 80.6| 18 | 77% | OKAY |
                              33.3 | -0.98 -0.13 -0.40| 1.5 1.3 75.2| 17 | 60% | OKAY |
                              33.3 | -0.98 -0.13 -0.37| 1.5 1.5 70.0| 16 | 52% | OKAY |
                              33.3 | -0.97 -0.13 -0.34| 1.6 1.6 65.0| 16 | 68% | OKAY |
                              33.3 | -0.97 -0.13 -0.32| 1.7 1.7 60.3| 13 | 51% | OKAY |
                              33.3 | -0.97 -0.13 -0.29| 1.8 1.7 56.0| 12 | 68% | OKAY |
                              33.3 | -0.97 -0.13 -0.26| 2.0 1.7 52.1| 14 | 56% | OKAY |
                              33.3 | -0.97 -0.13 -0.23| 2.2 1.7 48.5| 18 | 77% | OKAY |
                              33.5 | -0.97 -0.13 -0.20| 2.3 1.7 45.4| 25 | 99% | OKAY |
                              33.1 | -0.97 -0.13 -0.17| 2.4 1.9 42.6| 24 | 87% | OKAY |
                              33.6 | -0.97 -0.13 -0.14| 2.4 1.8 40.1| 27 | 100% | OKAY |
                              33.1 | -0.97 -0.13 -0.11| 2.4 1.7 37.9| 29 | 100% | OKAY |
                              33.3 | -0.98 -0.13 -0.08| 2.4 1.4 36.1| 28 | 96% | OKAY |
                              33.3 | -0.98 -0.13 -0.05| 2.2 1.1 34.4| 26 | 100% | OKAY |
                              33.3 | -0.98 -0.13 -0.02| 2.1 0.9 33.1| 24 | 91% | OKAY |
                              33.3 | -0.98 -0.13 0.01| 1.9 0.4 31.9| 28 | 100% | OKAY |
                              33.3 | -0.99 -0.13 0.04| 1.6 0.0 30.9| 22 | 99% | OKAY |
                              33.3 | -0.99 -0.12 0.07| 1.4 -0.0 30.1| 23 | 98% | OKAY |
                              33.3 | -0.99 -0.12 0.10| 1.1 0.1 29.4| 20 | 86% | OKAY |
                              33.3 | -1.00 -0.12 0.13| 0.6 -0.1 28.9| 16 | 80% | OKAY |
                              33.3 | -1.00 -0.12 0.13| 2.0 -1.4 28.8| 13 | 60% | OKAY |
                              33.3 | -1.00 -0.13 0.12| 6.1 -3.1 28.5| 11 | 59% | OKAY |
                              33.3 | -1.00 -0.13 0.13| 9.5 -2.7 28.3| 15 | 52% | OKAY |
                              33.3 | -1.00 -0.13 0.13| 8.4 1.1 28.4| 15 | 52% | OKAY |
                              33.3 | -1.00 -0.14 0.14| 1.3 -0.1 27.9| 16 | 52% | OKAY |
                              33.3 | -1.00 -0.14 0.14| 0.1 0.6 27.3| 17 | 57% | OKAY |
                              33.3 | -1.00 -0.14 0.14| 0.7 0.6 27.3| 17 | 57% | OKAY |
                              33.3 | -1.00 -0.14 0.14| 0.0 0.5 27.2| 16 | 52% | OKAY |
                              33.3 | -1.00 -0.14 0.14| 0.0 0.7 26.9| 16 | 52% | OKAY |
                              33.5 | -1.00 -0.13 0.13| 0.1 0.6 27.0| 16 | 52% | OKAY |
                              33.1 | -1.00 -0.13 0.13| 0.1 0.5 26.9| 16 | 52% | OKAY |
                              33.3 | -1.00 -0.13 0.13| 0.2 0.5 26.9| 20 | 65% | OKAY |
                              33.3 | -1.00 -0.13 0.13| 0.0 0.6 26.9| 20 | 65% | OKAY |
                              33.6 | -1.00 -0.13 0.13| 0.0 0.5 26.9| 20 | 65% | OKAY |
                              33.1 | -1.00 -0.13 0.13| 0.0 0.6 26.9| 20 | 65% | OKAY |
                              I am not sure if the Portal is creating/sending the correct point shown on the map. Is there a way to send a point via the command line? I couldn't find anything specific for this.
                              • G greg_s
                                Hello @Cliff-Wong,
                                G Offline
                                G Offline
                                greg_s
                                @Cliff-Wong. For completeness below is the output of the start of voxl-vision-hub --debug_offboard. I trimmed the entire output above until the drone started to move from the plan_to command.
                                voxl2:~$ voxl-vision-hub --debug_offboard
                                VOXL FLIGHT CONTROLLER (VFC)
                                always_on 0
                                vfc_rate 100.000000
                                vfc_rc_chan_min 980
                                vfc_rc_chan_max 2020
                                vfc_thrust_ch 3
                                vfc_roll_ch 1
                                vfc_pitch_ch 2
                                vfc_yaw_ch 4
                                vfc_submode_ch 6
                                vfc_backtrack_seconds : 60
                                vfc_backtrack_rc_chan : 10
                                vfc_backtrack_rc_thresh : 1500
                                vfc_alt_mode_rc_min 0
                                vfc_alt_mode_rc_max 0
                                vfc_flow_mode_rc_min 1700
                                vfc_flow_mode_rc_max 2100
                                vfc_hybrid_flow_mode_rc_min 0
                                vfc_hybrid_flow_mode_rc_max 0
                                vfc_position_mode_rc_min 1300
                                vfc_position_mode_rc_max 1700
                                vfc_traj_mode_rc_min 0
                                vfc_traj_mode_rc_max 0
                                vfc_yaw_deadband 30
                                vfc_vxy_deadband 50
                                vfc_vz_deadband 150
                                vfc_min_thrust 0.000000
                                vfc_max_thrust 0.800000
                                vfc_tilt_max 0.436000
                                vfc_yaw_rate_max 3.000000
                                vfc_thrust_hover 0.250000
                                vfc_vz_max 1.000000
                                vfc_kp_z 5.000000
                                vfc_ki_z 0.500000
                                vfc_ki_z_max 0.300000
                                vfc_kd_z 4.000000
                                vfc_vxy_max 3.000000
                                vfc_kp_xy 0.640000
                                vfc_kd_xy 2.560000
                                vfc_kp_z_vio 5.000000
                                vfc_ki_z_vio 0.700000
                                vfc_kd_z_vio 5.000000
                                vfc_kp_xy_vio 6.000000
                                vfc_kd_xy_vio 4.000000
                                vfc_w_filt_xy_vio 10.000000
                                vfc_w_filt_xy_flow 3.000000
                                vfc_vel_ff_factor_vio 0.500000
                                vfc_xy_acc_limit_vio 3.000000
                                vfc_max_z_delta 3.000000
                                vfc_att_transition_time 0.500000
                                vfc_stick_move_threshold 30.000000
                                vfc_flow_transition_time 1.000000
                                vfc_q_min 15
                                vfc_points_min 0
                                vfc_en_submode_announcement 1
                                vfc_en_backtrack_heading_hold 0
                                vfc_disable_fallback 0
                                loading our own config file
                                config_file_version: 1
                                MAVROS / MAVSDK
                                en_localhost_mavlink_udp 0
                                localhost_udp_port_number: 14551
                                VIO
                                en_vio: 1
                                vio_pipe: qvio
                                secondary_vio_pipe: ov
                                vio_warmup_s: 3.000000
                                send_odom_while_failed: 1
                                MISC FEATURES
                                horizon_cal_tolerance: 0.500000
                                en_hitl: 0
                                OFFBOARD MODE
                                follow_tag_id: 0
                                figure_eight_move_home: 1
                                tracking_trigger_ch: 12
                                tracking_trigger_ch_thresh_temp: 1200
                                tracking_trigger_ch_thresh_new: 1800
                                wps_move_home: 1
                                wps_timeout: 0.000000
                                wps_damp: 1.000000
                                wps_vfc_mission: true
                                wps_vfc_mission_loop: false
                                wps_vfc_mission_to_ramp: 25.000000
                                wps_vfc_mission_cruise_speed: 1.000000
                                wps_vfc_mission_to_kp: 0.100000
                                robot_radius: 0.300000
                                collision_sampling_dt: 0.100000
                                max_lookahead_distance: 1.000000
                                FIXED FRAME RELOCALIZATION
                                en_tag_fixed_frame: 0
                                fixed_frame_filter_len: 5
                                COLLISION PREVENTION (VOA)
                                en_voa: 1
                                voa_upper_bound_m: -0.150000
                                voa_lower_bound_m: 0.150000
                                voa_memory_s: 1.000000
                                voa_max_pc_per_fusion: 100
                                voa_pie_min_dist_m: 0.250000
                                voa_pie_max_dist_m: 20.000000
                                voa_pie_under_trim_m: 1.000000
                                voa_pie_threshold: 3
                                voa_pie_slices: 36
                                voa_pie_bin_depth_m: 0.150000
                                voa_send_rate_hz: 20.000000
                                voa_input #0
                                enabled: 1
                                type: point_cloud
                                input_pipe: dfs_point_cloud
                                frame: stereo_l
                                max_depth: 8.000000
                                min_depth: 0.300000
                                cell_size: 0.080000
                                threshold: 4
                                x_fov_deg: 68.000000
                                y_fov_deg: 56.000000
                                conf_cutoff: 0
                                voa_input #1
                                enabled: 1
                                type: point_cloud
                                input_pipe: stereo_front_pc
                                frame: stereo_front_l
                                max_depth: 8.000000
                                min_depth: 0.300000
                                cell_size: 0.080000
                                threshold: 4
                                conf_cutoff: 0
                                voa_input #2
                                enabled: 1
                                type: point_cloud
                                input_pipe: stereo_rear_pc
                                frame: stereo_rear_l
                                max_depth: 8.000000
                                min_depth: 0.300000
                                cell_size: 0.080000
                                threshold: 4
                                conf_cutoff: 0
                                voa_input #3
                                enabled: 1
                                type: tof
                                input_pipe: tof
                                frame: tof
                                max_depth: 6.000000
                                min_depth: 0.150000
                                cell_size: 0.080000
                                threshold: 3
                                x_fov_deg: 106.500000
                                y_fov_deg: 85.099998
                                conf_cutoff: 125
                                voa_input #4
                                enabled: 1
                                type: rangefinder
                                input_pipe: rangefinders
                                frame: body
                                max_depth: 8.000000
                                min_depth: 0.300000
                                cell_size: 0.080000
                                threshold: 4
                                conf_cutoff: 0
                                loading horizon cal file
                                existing instance of voxl-vision-hub found, attempting to stop it
                                starting geometry module
                                starting autopilot monitor
                                starting mavlink IO
                                Waiting to connect to voxl-mavlink-server
                                starting fixed pose input
                                starting vio manager
                                Connected to VIO pipe: ov
                                Geometry module updating to use imu: imu_apps_body for VIO
                                ERROR in vcc_fetch_extrinsic, failed to find desired extrinsic relation in file
                                Likely you need to run voxl-configure-extrinsics to make a new file
                                ERROR: /etc/modalai/extrinsics.conf missing body to imu_apps_body, sticking with identity for now
                                Detected Autopilot Mavlink SYSID 1
                                requesting autopilot_version
                                Detected autopilot version: 1.14.0
                                starting tag manager
                                starting voa manager
                                ERROR in pipe_client_open, channel 11 already running
                                Connected to VOA input pipe: tof
                                starting horizon cal module
                                starting imu manager
                                starting state manager
                                starting offboard trajectory
                                Connected to voxl-mapper
                                voxl-mapper pipe size is: 65536 bytes
                                Init complete
                                Trajectory Monitor connected to voa pointcloud
                                commanding: XYZ -1.0 -0.1 -2.3 yaw: 0.1
                                WARNING in VOA manager, no attitude data from px4
                                • G greg_s
                                  always_on 0
                                  vfc_rate 100.000000
                                  vfc_rc_chan_min 980
                                  vfc_thrust_ch 3
                                  vfc_roll_ch 1
                                  vfc_pitch_ch 2
                                  vfc_yaw_ch 4
                                  vfc_submode_ch 6
                                  vfc_yaw_deadband 30
                                  vfc_vxy_deadband 50
                                  vfc_vz_deadband 150
                                  vfc_vz_max 1.000000
                                  vfc_kp_z 5.000000
                                  vfc_ki_z 0.500000
                                  vfc_kd_z 4.000000
                                  vfc_kp_xy 0.640000
                                  vfc_kd_xy 2.560000
                                  vfc_q_min 15
                                  vfc_points_min 0
                                  MAVROS / MAVSDK
                                  VIO
                                  en_vio: 1
                                  vio_pipe: qvio
                                  MISC FEATURES
                                  en_hitl: 0
                                  OFFBOARD MODE
                                  follow_tag_id: 0
                                  wps_move_home: 1
                                  wps_damp: 1.000000
                                  en_voa: 1
                                  voa_pie_slices: 36
                                  voa_input #0
                                  enabled: 1
                                  type: point_cloud
                                  frame: stereo_l
                                  max_depth: 8.000000
                                  min_depth: 0.300000
                                  cell_size: 0.080000
                                  threshold: 4
                                  conf_cutoff: 0
                                  voa_input #1
                                  enabled: 1
                                  type: point_cloud
                                  max_depth: 8.000000
                                  min_depth: 0.300000
                                  cell_size: 0.080000
                                  threshold: 4
                                  conf_cutoff: 0
                                  voa_input #2
                                  enabled: 1
                                  type: point_cloud
                                  max_depth: 8.000000
                                  min_depth: 0.300000
                                  cell_size: 0.080000
                                  threshold: 4
                                  conf_cutoff: 0
                                  voa_input #3
                                  enabled: 1
                                  type: tof
                                  input_pipe: tof
                                  frame: tof
                                  max_depth: 6.000000
                                  min_depth: 0.150000
                                  cell_size: 0.080000
                                  threshold: 3
                                  conf_cutoff: 125
                                  voa_input #4
                                  enabled: 1
                                  type: rangefinder
                                  frame: body
                                  max_depth: 8.000000
                                  min_depth: 0.300000
                                  cell_size: 0.080000
                                  threshold: 4
                                  conf_cutoff: 0
                                  starting mavlink IO
                                  Init complete
                                  Cliff WongC Offline
                                  Cliff WongC Offline
                                  Cliff Wong
                                  @greg_s said in Starling 2 not following navigation path:
                                  One thing that looks suspect is the voxl-mapper pipe size 64k bytes is much smaller than expect (usually in MB, e.g. 32MB-64MB). Is this a preloaded 3D map?
                                  Otherwise your VIO data looks good. It appears the drone does go to the 1st setpoint (1st leg of the trajectory) where that setpoint also looks as if it is landing. It's possible the landing detector was triggered and why everything stops.
                                  I suggest the following:
                                  • power up, ssh into 2 terminals
                                  • terminal 1 -- run the voxl-mapper
                                    terminal 2 -- run voxl-vision-hub --debug_offboard
                                  • take off in position mode, bring up the portal into mapper 3D view as normal, perform a 360 yaw to get a good map
                                  • Select "Plan a Point": draw your point and position it correctly
                                  • switch to offboard mode (which you have set correctly to 'trajectory')
                                  • Select GO!
                                  • Select "Follow Path"
                                    (If no follow path is offered then the A* path creation failed)
                                  Hopefully with that sequence, you'll see the drone move along the path. If it does not, then the voxl-mapper output in terminal 1 will tell us if a latency is the culprit.
                                  As an example, here's how I expect the above to play out.. If you cannot repeat this then it maybe worth upgrading to SDK 1.6.3 (as the example was generated in).
                                    • Select GO!
                                    G Offline
                                    G Offline
                                    greg_s
                                    Hello @Cliff-Wong,
                                    I tried reproducing your suggestion. The first time I tried, it seems to work fine. After landing and trying again (I stopped and restarted the voxl-mapper and voxl-vision-hub), I few around to update the map again as it reloaded. I planned a route that was straight ahead for the drone. Instead of following the path shown in the 3D mapper, it flew diagonally upward and hit the ceiling. I captured a video similar to yours to show the result. Also note, I ran the update to get the latest patch version of the voxl sdk. After running the update twice, it updated some packages but the patch number remained 2. So this was run with 1.6.2 sdk version, unless something else messed up with the update. I did capture a log of the update I ran if that would be helpful.
                                    Link to video
                                      • Select GO!
                                      G Offline
                                      G Offline
                                      greg_s
                                      Hello @Cliff-Wong,
                                      If there is any additional information or method I should try, just let me know.
                                      • G greg_s
                                        Hello @Cliff-Wong,
                                        Cliff WongC Offline
                                        Cliff WongC Offline
                                        Cliff Wong
                                        #19
                                        @greg_s HI there,
                                        The video exhibits classic VIO lost behavior from extrinsics: hovers fine, then on translation just flys away. Can you switch from trajectory mode back to figure_eight mode and confirm the drone can fly in figure 8s for more than 30secs?
                                        Figure 8 also tests the trajectory engine that mapper uses so it will confirm a number of things on the sensor side.
                                          @greg_s HI there,
                                          G Offline
                                          G Offline
                                          greg_s
                                          Hello @Cliff-Wong,
                                          The figure 8 no longer works. It is now crashing into the netting in the room after starting the figure 8 mode. Though, it did in the past.
                                          Here is the screen recording as it was happening Link
                                          I also notice that it seems a sensor on the bottom has come loose due to the crashes sustained while trying to test the navigation. As well as the battery retention clips has broken off. Link
