  3. Starling 2 not following navigation path
21 Posts 3 Posters 4.0k Views
  • G Offline
    G Offline
    greg_s
    For convenience I took out the section that has the trajectory from the voxl-vision-hub logs:
    commanding: XYZ -0.4 -0.2 -1.8 yaw: 0.3
    commanding: XYZ -0.4 -0.2 -1.7 yaw: 0.3
    Received trajectory has duration 1.953539 seconds
    Received load and start command.
    commanding: XYZ -0.4 -0.2 -1.0 yaw: 0.7 V: 0.0 0.0 -0.0 A: 0.1 0.0 -0.0
    commanding: XYZ -0.4 -0.2 -1.0 yaw: 0.7 V: 0.0 0.0 -0.0 A: 0.2 0.2 -0.0
    commanding: XYZ -0.4 -0.2 -1.0 yaw: 0.7 V: 0.0 0.0 -0.0 A: 0.3 0.3 -0.0
    commanding: XYZ -0.4 -0.2 -1.0 yaw: 0.7 V: 0.0 0.0 -0.0 A: 0.5 0.5 -0.0
    commanding: XYZ -0.4 -0.2 -1.0 yaw: 0.7 V: 0.0 0.0 -0.0 A: 0.7 0.6 0.0
    commanding: XYZ -0.4 -0.2 -1.0 yaw: 0.7 V: 0.1 0.1 -0.0 A: 0.9 0.7 0.0
    commanding: XYZ -0.3 -0.2 -1.0 yaw: 0.7 V: 0.1 0.1 0.0 A: 1.0 0.9 0.0
    commanding: XYZ -0.3 -0.2 -1.0 yaw: 0.7 V: 0.1 0.1 0.0 A: 1.1 0.9 0.0
    commanding: XYZ -0.3 -0.2 -1.0 yaw: 0.7 V: 0.2 0.2 0.0 A: 1.1 1.0 0.0
    commanding: XYZ -0.3 -0.2 -1.0 yaw: 0.7 V: 0.2 0.2 0.0 A: 1.2 1.0 0.0
    commanding: XYZ -0.3 -0.2 -1.0 yaw: 0.7 V: 0.3 0.2 0.0 A: 1.2 1.0 0.0
    commanding: XYZ -0.3 -0.2 -1.0 yaw: 0.7 V: 0.3 0.3 0.0 A: 1.2 1.0 0.0
    commanding: XYZ -0.3 -0.1 -1.0 yaw: 0.7 V: 0.3 0.3 0.0 A: 1.2 1.0 0.0
    commanding: XYZ -0.3 -0.1 -1.0 yaw: 0.7 V: 0.4 0.3 0.0 A: 1.1 1.0 0.0
    commanding: XYZ -0.3 -0.1 -1.0 yaw: 0.7 V: 0.4 0.4 0.0 A: 1.1 1.0 0.0
    Received trajectory has duration 1.452853 seconds
    Received insert command.
    commanding: XYZ -0.3 -0.1 -1.0 yaw: 0.7 V: 0.5 0.4 0.0 A: 1.1 0.9 0.0
    commanding: XYZ -0.2 -0.1 -1.0 yaw: 0.7 V: 0.5 0.4 0.0 A: 1.0 0.9 0.0
    commanding: XYZ -0.2 -0.1 -1.0 yaw: 0.7 V: 0.5 0.5 0.0 A: 1.0 0.9 0.0
    commanding: XYZ -0.2 -0.1 -1.0 yaw: 0.7 V: 0.6 0.5 0.0 A: 0.9 0.8 0.0
    commanding: XYZ -0.2 -0.0 -1.0 yaw: 0.7 V: 0.6 0.5 0.0 A: 0.8 0.7 0.1
    commanding: XYZ -0.2 -0.0 -1.0 yaw: 0.7 V: 0.6 0.6 0.0 A: 0.8 0.6 0.1
    commanding: XYZ -0.1 0.0 -1.0 yaw: 0.7 V: 0.7 0.6 0.0 A: 0.7 0.5 0.1
    commanding: XYZ -0.1 0.0 -1.0 yaw: 0.7 V: 0.7 0.6 0.0 A: 0.6 0.5 0.1
    commanding: XYZ -0.1 0.0 -1.0 yaw: 0.7 V: 0.7 0.6 0.0 A: 0.5 0.4 0.1
    commanding: XYZ -0.1 0.1 -1.0 yaw: 0.7 V: 0.7 0.6 0.0 A: 0.4 0.3 0.0
    commanding: XYZ -0.0 0.1 -1.0 yaw: 0.7 V: 0.7 0.6 0.0 A: 0.3 0.2 0.0
    commanding: XYZ -0.0 0.1 -1.0 yaw: 0.7 V: 0.7 0.6 0.0 A: 0.2 0.1 0.0
    commanding: XYZ 0.0 0.1 -1.0 yaw: 0.7 V: 0.7 0.6 0.0 A: 0.0 0.0 0.0
    Received trajectory has duration 0.510237 seconds
    commanding: XYZ 0.0 0.1 -1.0 yaw: 0.7 V: 0.7 0.6 0.0 A: -0.1 -0.1 0.0
    commanding: XYZ 0.1 0.2 -1.0 yaw: 0.7 V: 0.7 0.6 0.0 A: -0.2 -0.2 0.0
    commanding: XYZ 0.1 0.2 -1.0 yaw: 0.7 V: 0.6 0.5 0.0 A: -0.2 -0.2 0.0
    commanding: XYZ 0.1 0.2 -1.0 yaw: 0.7 V: 0.6 0.5 0.0 A: -0.3 -0.2 0.0
    commanding: XYZ 0.1 0.2 -1.0 yaw: 0.7 V: 0.6 0.5 0.0 A: -0.4 -0.3 -0.0
    commanding: XYZ 0.1 0.2 -1.0 yaw: 0.7 V: 0.6 0.5 0.0 A: -0.5 -0.4 -0.0
    commanding: XYZ 0.2 0.3 -1.0 yaw: 0.7 V: 0.6 0.5 0.0 A: -0.6 -0.5 -0.0
    commanding: XYZ 0.2 0.3 -1.0 yaw: 0.7 V: 0.6 0.5 0.0 A: -0.7 -0.6 -0.0
    commanding: XYZ 0.2 0.3 -1.0 yaw: 0.7 V: 0.5 0.5 0.0 A: -0.7 -0.6 -0.0
    commanding: XYZ 0.2 0.3 -1.0 yaw: 0.7 V: 0.5 0.4 0.0 A: -0.7 -0.6 -0.0
    commanding: XYZ 0.2 0.3 -1.0 yaw: 0.7 V: 0.5 0.4 0.0 A: -0.8 -0.7 -0.0
    commanding: XYZ 0.3 0.3 -1.0 yaw: 0.7 V: 0.4 0.4 0.0 A: -0.8 -0.7 -0.0
    commanding: XYZ 0.3 0.4 -1.0 yaw: 0.7 V: 0.4 0.3 0.0 A: -0.8 -0.7 -0.0
    commanding: XYZ 0.3 0.4 -1.0 yaw: 0.7 V: 0.4 0.3 0.0 A: -0.7 -0.6 -0.0
    commanding: XYZ 0.3 0.4 -1.0 yaw: 0.7 V: 0.3 0.3 0.0 A: -0.5 -0.5 -0.0
    commanding: XYZ 0.3 0.4 -1.0 yaw: 0.7 V: 0.3 0.3 0.0 A: -0.4 -0.3 0.0
    commanding: XYZ 0.3 0.4 -1.0 yaw: 0.7 V: 0.3 0.3 0.0 A: -0.3 -0.3 0.0
    commanding: XYZ 0.3 0.4 -1.0 yaw: 0.7 V: 0.3 0.2 0.0 A: -0.4 -0.4 0.0
    commanding: XYZ 0.3 0.4 -1.0 yaw: 0.7 V: 0.3 0.2 0.0 A: -0.6 -0.5 -0.0
    commanding: XYZ 0.4 0.4 -1.0 yaw: 0.7 V: 0.2 0.2 0.0 A: -0.8 -0.7 -0.0
    commanding: XYZ 0.4 0.4 -1.0 yaw: 0.7 V: 0.2 0.2 0.0 A: -1.1 -0.9 -0.1
    commanding: XYZ 0.4 0.4 -1.0 yaw: 0.7 V: 0.2 0.1 0.0 A: -1.3 -1.1 -0.1
    commanding: XYZ 0.4 0.4 -1.0 yaw: 0.7 V: 0.1 0.1 0.0 A: -1.4 -1.1 -0.1
    commanding: XYZ 0.4 0.4 -1.0 yaw: 0.7 V: 0.1 0.1 0.0 A: -1.3 -1.1 -0.1
    commanding: XYZ 0.4 0.4 -1.0 yaw: 0.7 V: 0.0 0.0 0.0 A: -1.0 -0.9 -0.1
    commanding: XYZ 0.4 0.4 -1.0 yaw: 0.7 V: 0.0 0.0 0.0 A: -0.7 -0.6 -0.1
    commanding: XYZ 0.4 0.4 -1.0 yaw: 0.7 V: 0.0 0.0 0.0 A: -0.3 -0.2 -0.0
    commanding: XYZ 0.4 0.4 -1.0 yaw: 0.7 V: 0.0 0.0 0.0 A: -0.0 -0.0 -0.0
    commanding: XYZ 0.4 0.4 -1.0 yaw: 0.7 V: -0.0 -0.0 0.0 A: -0.0 -0.0 0.0
    FINISHED TRAJECTORY
    commanding: XYZ 0.4 0.5 -1.0 yaw: 0.7
    • G Offline
      G Offline
      greg_s
      @ApoorvThapliyal, if you/your team needs anymore information or data, do let me know. Thank you.
      A 1 Reply Last reply
      • G greg_s
        ApoorvThapliyal
        Hey @greg_s
        I just wanted to confirm, are you dragging the planned point to the height desired? By default, simply clicking on the map will generate a point at height 0.
        Let me know, thanks
        G 2 Replies Last reply
        • A ApoorvThapliyal
          Hey @greg_s
          Let me know, thanks
          G Offline
          G Offline
          greg_s
          Hello @ApoorvThapliyal,
          Yes, I am dragging the point up and panning the camera around to ensure it is roughly the same height as the drone. The line drawn for the path is pretty straight and at the correctly level. The drone just ends up flying down below the point after I have move it.
          • A ApoorvThapliyal
            Hey @greg_s
            Let me know, thanks
            G Offline
            G Offline
            greg_s
            Is there anything more your teams need to investigate/troubleshoot the issue? Thanks.
            • G greg_s
              ApoorvThapliyal
              Hey @greg_s
              I was able to reproduce the issue where the drone does not fly correctly toward the setpoint. I think reviewing the extrinsics.conf file is a good next step, as there may be an incorrect transform defined there.
              • A ApoorvThapliyal
                Hey @greg_s
                G Offline
                G Offline
                greg_s
                wrote on last edited by greg_s
                #11
                Hey @ApoorvThapliyal,
                Here is the output of the extrinsics:
                voxl2:~$ voxl-inspect-extrinsics --all
                #0:
                parent: imu_apps
                child: tracking_front
                T_child_wrt_parent: 0.037 0.000 0.001
                RPY_parent_to_child: 0.0 90.0 90.0
                R_child_to_parent: 0.000 -0.000 1.000
                1.000 0.000 -0.000
                -0.000 1.000 0.000
                #1:
                parent: imu_apps
                child: tracking_down
                T_child_wrt_parent: -0.088 -0.004 0.027
                RPY_parent_to_child: 0.0 0.0 180.0
                R_child_to_parent: -1.000 -0.000 0.000
                0.000 -1.000 -0.000
                0.000 0.000 1.000
                #2:
                parent: imu_apps
                child: tracking_rear
                T_child_wrt_parent: -0.092 0.016 0.004
                RPY_parent_to_child: 0.0 -90.0 -90.0
                R_child_to_parent: 0.000 0.000 -1.000
                -1.000 0.000 -0.000
                0.000 1.000 0.000
                #3:
                parent: imu_apps
                child: hires
                T_child_wrt_parent: 0.039 0.000 0.019
                1.000 0.000 -0.000
                -0.000 1.000 0.000
                #4:
                parent: body
                child: imu_apps
                T_child_wrt_parent: 0.029 -0.006 -0.016
                RPY_parent_to_child: 0.0 0.0 0.0
                R_child_to_parent: 1.000 -0.000 0.000
                0.000 1.000 -0.000
                0.000 0.000 1.000
                #5:
                parent: body
                child: imu_px4
                T_child_wrt_parent: 0.004 0.007 -0.016
                0.000 1.000 -0.000
                0.000 0.000 1.000
                #6:
                parent: imu_apps
                child: lepton0_raw
                T_child_wrt_parent: -0.085 0.013 0.024
                RPY_parent_to_child: 0.0 0.0 90.0
                R_child_to_parent: 0.000 -1.000 0.000
                1.000 0.000 -0.000
                0.000 0.000 1.000
                #7:
                parent: body
                child: tof
                T_child_wrt_parent: 0.066 0.009 -0.012
                RPY_parent_to_child: 0.0 90.0 180.0
                R_child_to_parent: -0.000 -0.000 1.000
                0.000 -1.000 -0.000
                1.000 0.000 0.000
                #8:
                parent: body
                child: ground
                T_child_wrt_parent: 0.000 0.000 0.033
                0.000 1.000 -0.000
                0.000 0.000 1.000
                • A ApoorvThapliyal
                  Hey @greg_s
                  G Offline
                  G Offline
                  greg_s
                  Is there anything that looks wrong or off about the configuration? Should I look at any other file in particular?
                  • G greg_s
                    Cliff WongC Offline
                    Cliff WongC Offline
                    Cliff Wong
                    wrote on last edited by Cliff Wong
                    #13
                    @greg_s
                    Hi there, your extrinsics are good: same as a factory Starling. Now, if you altered the voxl-camera-server.conf (e.g. enabled a flip of a camera stream when it wasn't) or physically changed a camera mount point then the extrinsics would need to be adjusted. Let assume that's not the case.
                    From your vvhub trajectory output, it appears your setpoints command the vehicle to move forward (X) and to the right (Y) > 1m while dropping altitude (Z) 0.8m --recall mapper runs in FRD (aka body) space where Z up is negative. Also you do pass through the take off origin (0,0,0). If that's not what you wanted, then we have a "requested trajectory" drawing problem in the portal tool or mapper's found invalid regions/obstacle and could not draw the "requested trajectory".
                    In the former case @ApoorvThapliyal mentions the un-intuitiveness of the portal tool that you already understand.
                    In the latter case, upon "request trajectory" submission, voxl-mapper will analyze the map to see if there are obstacles and alter the trajectory to fly around potential obstacles. You can alter in voxl-mapper.conf:
                    • rrt_min_distance (try 0.125)
                    • esdf_inner_sphere_radius (try 0.15)
                      if you seeing mapper create trajectories going around 'ghost' objects. This should allow RRT generated trajectories to get closer to objects.
                    In checking precision, you'll need to take the trajectory output (e.g. the setpoints in the *commanding: XYZ* messages) and compared it against VIO position to determine tracking error. You have 2 ways to get that data:
                    • option 1 is record you vvhub traj output as above and record the output of voxl-inspect-vins -n then plot compare the tracking error.
                    • option 2 is running voxl-vision-hub --debug_offboard --debug_odometry which you'll need to seperate the traj messages from the vio (T_body_wrt_local) messages, then you ca plot the tracking error.
                    The goal is we want the vio position to follow the commanded trajectory: (it's doing what is told to do). That will narrow down where your concerns are w.r.t what module has a problem.
                    Hopefully that gets you on the right track, just post any outputs you gather that continue to show tracking error.
                    G 1 Reply Last reply
                    • Cliff WongC Cliff Wong
                      @greg_s
                      G Offline
                      G Offline
                      greg_s
                      #14
                      Hello @Cliff-Wong,
                      I collected the output from voxl-vision-hub --debug_offboard and voxl-inspect-vins -n. I place a plan_to point that was about half a meter from the drone and slightly higher in altitude from the drone. I used the arrows to position the plan_to point and rotated camera to ensure the plan_to point it was placed correctly. I reduced the rrt_min_distance and esdf_inner_sphere_radius as suggested. The drone had more than a meter clearance on all sides. The room is empty with no obstacles.
                      The output from voxl-vision-hub --debug_offboard:
                      commanding: XYZ -1.0 -0.1 -2.4 yaw: 2.6
                      Setpoint position: XYZ -1.0 -0.1 -0.8 yaw: 0.4
                      Received trajectory has duration 3.309723 seconds
                      commanding: XYZ -1.0 -0.1 0.1 yaw: 0.4 V: 0.0 0.0 -0.0 A: 0.0 0.0 -0.0
                      commanding: XYZ -1.0 -0.1 0.1 yaw: 0.5 V: 0.0 0.0 -0.0 A: 0.0 0.0 -0.0
                      commanding: XYZ -1.0 -0.1 0.1 yaw: 0.4 V: 0.0 0.0 -0.0 A: 0.0 0.0 -0.1
                      commanding: XYZ -1.0 -0.1 0.1 yaw: 0.4 V: 0.0 0.0 -0.0 A: 0.1 0.0 -0.2
                      commanding: XYZ -1.0 -0.1 0.1 yaw: 0.4 V: 0.0 0.0 -0.0 A: 0.1 0.0 -0.3
                      commanding: XYZ -1.0 -0.1 0.1 yaw: 0.4 V: 0.0 0.0 -0.0 A: 0.1 0.1 -0.3
                      commanding: XYZ -1.0 -0.1 0.1 yaw: 0.4 V: 0.0 0.0 -0.0 A: 0.2 0.1 -0.4
                      commanding: XYZ -1.0 -0.1 0.1 yaw: 0.4 V: 0.0 0.0 -0.1 A: 0.2 0.1 -0.4
                      commanding: XYZ -1.0 -0.1 0.1 yaw: 0.4 V: 0.0 0.0 -0.1 A: 0.2 0.1 -0.5
                      commanding: XYZ -1.0 -0.1 0.1 yaw: 0.4 V: 0.0 0.0 -0.1 A: 0.3 0.1 -0.5
                      commanding: XYZ -1.0 -0.1 0.1 yaw: 0.4 V: 0.0 0.0 -0.1 A: 0.3 0.1 -0.6
                      commanding: XYZ -1.0 -0.1 0.1 yaw: 0.4 V: 0.1 0.0 -0.1 A: 0.4 0.1 -0.6
                      commanding: XYZ -1.0 -0.1 0.1 yaw: 0.4 V: 0.1 0.0 -0.2 A: 0.4 0.2 -0.6
                      commanding: XYZ -1.0 -0.1 0.1 yaw: 0.4 V: 0.1 0.0 -0.2 A: 0.5 0.2 -0.6
                      Received trajectory has duration 2.234033 seconds
                      commanding: XYZ -1.0 -0.1 0.1 yaw: 0.4 V: 0.1 0.1 -0.2 A: 0.5 0.2 -0.6
                      commanding: XYZ -1.0 -0.1 0.0 yaw: 0.4 V: 0.2 0.1 -0.3 A: 0.5 0.2 -0.6
                      commanding: XYZ -1.0 -0.1 0.0 yaw: 0.4 V: 0.2 0.1 -0.3 A: 0.6 0.2 -0.6
                      commanding: XYZ -1.0 -0.1 0.0 yaw: 0.4 V: 0.2 0.1 -0.3 A: 0.6 0.2 -0.5
                      commanding: XYZ -0.9 -0.1 -0.0 yaw: 0.4 V: 0.2 0.1 -0.3 A: 0.6 0.2 -0.5
                      commanding: XYZ -0.9 -0.1 -0.0 yaw: 0.4 V: 0.3 0.1 -0.4 A: 0.6 0.2 -0.5
                      commanding: XYZ -0.9 -0.1 -0.0 yaw: 0.4 V: 0.3 0.1 -0.4 A: 0.6 0.2 -0.4
                      commanding: XYZ -0.9 -0.1 -0.1 yaw: 0.4 V: 0.3 0.1 -0.4 A: 0.6 0.2 -0.4
                      commanding: XYZ -0.9 -0.1 -0.1 yaw: 0.4 V: 0.3 0.1 -0.4 A: 0.6 0.3 -0.4
                      commanding: XYZ -0.9 -0.1 -0.1 yaw: 0.4 V: 0.4 0.1 -0.4 A: 0.6 0.3 -0.4
                      commanding: XYZ -0.9 -0.1 -0.1 yaw: 0.4 V: 0.4 0.2 -0.4 A: 0.6 0.3 -0.4
                      commanding: XYZ -0.9 -0.1 -0.1 yaw: 0.4 V: 0.4 0.2 -0.4 A: 0.6 0.2 -0.4
                      commanding: XYZ -0.8 -0.1 -0.1 yaw: 0.4 V: 0.4 0.2 -0.5 A: 0.6 0.2 -0.4
                      commanding: XYZ -0.8 -0.1 -0.1 yaw: 0.4 V: 0.4 0.2 -0.5 A: 0.6 0.3 -0.4
                      commanding: XYZ -0.8 -0.1 -0.2 yaw: 0.4 V: 0.4 0.2 -0.5 A: 0.6 0.3 -0.4
                      commanding: XYZ -0.8 -0.1 -0.2 yaw: 0.4 V: 0.5 0.2 -0.5 A: 0.6 0.3 -0.4
                      commanding: XYZ -0.8 -0.0 -0.2 yaw: 0.4 V: 0.5 0.2 -0.5 A: 0.6 0.3 -0.3
                      commanding: XYZ -0.8 -0.0 -0.2 yaw: 0.4 V: 0.5 0.2 -0.5 A: 0.6 0.2 -0.3
                      commanding: XYZ -0.7 -0.0 -0.2 yaw: 0.4 V: 0.6 0.2 -0.5 A: 0.6 0.2 -0.3
                      commanding: XYZ -0.7 -0.0 -0.3 yaw: 0.4 V: 0.6 0.2 -0.5 A: 0.6 0.2 -0.3
                      commanding: XYZ -0.7 -0.0 -0.3 yaw: 0.4 V: 0.6 0.2 -0.6 A: 0.6 0.2 -0.2
                      commanding: XYZ -0.7 0.0 -0.3 yaw: 0.4 V: 0.6 0.3 -0.6 A: 0.5 0.2 -0.2
                      Received trajectory has duration 1.689594 seconds
                      commanding: XYZ -0.6 0.0 -0.3 yaw: 0.4 V: 0.7 0.3 -0.6 A: 0.5 0.2 -0.2
                      commanding: XYZ -0.6 0.0 -0.4 yaw: 0.4 V: 0.7 0.3 -0.6 A: 0.5 0.2 -0.1
                      commanding: XYZ -0.6 0.0 -0.4 yaw: 0.4 V: 0.7 0.3 -0.6 A: 0.4 0.2 -0.1
                      commanding: XYZ -0.6 0.0 -0.4 yaw: 0.4 V: 0.7 0.3 -0.6 A: 0.4 0.1 -0.1
                      commanding: XYZ -0.5 0.1 -0.4 yaw: 0.4 V: 0.7 0.3 -0.6 A: 0.4 0.1 -0.1
                      commanding: XYZ -0.5 0.1 -0.4 yaw: 0.4 V: 0.7 0.3 -0.6 A: 0.3 0.1 -0.0
                      commanding: XYZ -0.5 0.1 -0.5 yaw: 0.4 V: 0.7 0.3 -0.6 A: 0.3 0.1 -0.0
                      commanding: XYZ -0.5 0.1 -0.5 yaw: 0.4 V: 0.7 0.3 -0.6 A: 0.3 0.1 0.0
                      Received trajectory has duration 1.165000 seconds
                      commanding: XYZ -0.4 0.1 -0.5 yaw: 0.4 V: 0.7 0.3 -0.6 A: 0.2 0.1 0.1
                      Received trajectory has duration 1.342931 seconds
                      commanding: XYZ -0.4 0.1 -0.5 yaw: 0.4 V: 0.7 0.3 -0.6 A: 0.1 0.0 0.1
                      commanding: XYZ -0.4 0.1 -0.5 yaw: 0.4 V: 0.7 0.3 -0.6 A: 0.0 -0.0 0.2
                      commanding: XYZ -0.3 0.1 -0.6 yaw: 0.4 V: 0.7 0.3 -0.6 A: -0.0 -0.0 0.2
                      commanding: XYZ -0.3 0.1 -0.6 yaw: 0.4 V: 0.7 0.3 -0.6 A: -0.1 -0.0 0.2
                      commanding: XYZ -0.3 0.1 -0.6 yaw: 0.4 V: 0.7 0.3 -0.5 A: -0.1 -0.1 0.3
                      commanding: XYZ -0.3 0.2 -0.6 yaw: 0.4 V: 0.7 0.3 -0.5 A: -0.2 -0.1 0.3
                      commanding: XYZ -0.2 0.2 -0.6 yaw: 0.4 V: 0.7 0.3 -0.5 A: -0.2 -0.1 0.3
                      commanding: XYZ -0.2 0.2 -0.7 yaw: 0.4 V: 0.7 0.3 -0.5 A: -0.3 -0.1 0.3
                      commanding: XYZ -0.2 0.2 -0.7 yaw: 0.4 V: 0.7 0.3 -0.5 A: -0.3 -0.1 0.4
                      commanding: XYZ -0.2 0.2 -0.7 yaw: 0.4 V: 0.7 0.3 -0.5 A: -0.4 -0.2 0.4
                      Received trajectory has duration 1.508897 seconds
                      commanding: XYZ -0.1 0.2 -0.7 yaw: 0.4 V: 0.7 0.3 -0.5 A: -0.5 -0.2 0.4
                      commanding: XYZ -0.1 0.2 -0.8 yaw: 0.4 V: 0.6 0.2 -0.4 A: -0.5 -0.2 0.4
                      commanding: XYZ -0.0 0.2 -0.8 yaw: 0.4 V: 0.6 0.2 -0.4 A: -0.5 -0.2 0.4
                      commanding: XYZ -0.0 0.3 -0.8 yaw: 0.4 V: 0.5 0.2 -0.4 A: -0.6 -0.2 0.4
                      commanding: XYZ -0.0 0.3 -0.8 yaw: 0.4 V: 0.5 0.2 -0.3 A: -0.6 -0.2 0.5
                      commanding: XYZ 0.0 0.3 -0.8 yaw: 0.4 V: 0.5 0.2 -0.3 A: -0.6 -0.2 0.5
                      commanding: XYZ 0.0 0.3 -0.8 yaw: 0.4 V: 0.5 0.2 -0.3 A: -0.7 -0.3 0.5
                      commanding: XYZ 0.1 0.3 -0.8 yaw: 0.4 V: 0.4 0.2 -0.3 A: -0.7 -0.3 0.5
                      commanding: XYZ 0.1 0.3 -0.9 yaw: 0.4 V: 0.4 0.2 -0.3 A: -0.7 -0.3 0.5
                      commanding: XYZ 0.1 0.3 -0.9 yaw: 0.4 V: 0.4 0.1 -0.2 A: -0.7 -0.3 0.5
                      commanding: XYZ 0.1 0.3 -0.9 yaw: 0.4 V: 0.3 0.1 -0.2 A: -0.5 -0.2 0.4
                      commanding: XYZ 0.1 0.3 -0.9 yaw: 0.4 V: 0.2 0.1 -0.2 A: -0.5 -0.2 0.3
                      commanding: XYZ 0.1 0.3 -0.9 yaw: 0.4 V: 0.2 0.1 -0.1 A: -0.5 -0.2 0.3
                      commanding: XYZ 0.2 0.3 -0.9 yaw: 0.4 V: 0.2 0.1 -0.1 A: -0.5 -0.2 0.3
                      commanding: XYZ 0.2 0.3 -0.9 yaw: 0.4 V: 0.2 0.1 -0.1 A: -0.4 -0.2 0.3
                      commanding: XYZ 0.2 0.3 -0.9 yaw: 0.4 V: 0.1 0.1 -0.1 A: -0.4 -0.2 0.3
                      commanding: XYZ 0.2 0.3 -0.9 yaw: 0.4 V: 0.1 0.0 -0.1 A: -0.4 -0.1 0.3
                      commanding: XYZ 0.2 0.3 -0.9 yaw: 0.4 V: 0.1 0.0 -0.1 A: -0.4 -0.1 0.2
                      commanding: XYZ 0.2 0.3 -0.9 yaw: 0.4 V: 0.1 0.0 -0.1 A: -0.3 -0.1 0.2
                      commanding: XYZ 0.2 0.3 -0.9 yaw: 0.4 V: 0.1 0.0 -0.0 A: -0.3 -0.1 0.2
                      commanding: XYZ 0.2 0.3 -0.9 yaw: 0.4 V: 0.0 0.0 -0.0 A: -0.2 -0.1 0.1
                      commanding: XYZ 0.2 0.3 -0.9 yaw: 0.4 V: 0.0 0.0 -0.0 A: -0.1 -0.1 0.1
                      commanding: XYZ 0.2 0.3 -0.9 yaw: 0.4 V: 0.0 0.0 -0.0 A: -0.1 -0.0 0.1
                      commanding: XYZ 0.2 0.3 -0.9 yaw: 0.3 V: 0.0 0.0 -0.0 A: -0.1 -0.0 0.1
                      commanding: XYZ 0.2 0.3 -0.9 yaw: 0.3 V: 0.0 0.0 -0.0 A: -0.1 -0.0 0.0
                      commanding: XYZ 0.2 0.3 -0.9 yaw: 0.2 V: 0.0 0.0 -0.0 A: -0.1 -0.0 0.0
                      commanding: XYZ 0.2 0.3 -0.9 yaw: -2.8 V: -0.0 -0.0 0.0 A: -0.0 -0.0 0.0
                      Received stop command.
                      Stopped following trajectory.
                      commanding: XYZ -1.0 -0.1 -1.5 yaw: 0.5
                      The output from voxl-inspect-vins -n:
                      dt(ms) | T_imu_wrt_vio (m) |Roll Pitch Yaw (deg)|features|quality| state| error_codes
                      33.1 | -1.01 -0.14 -0.79| 1.6 -0.5 148.0| 22 | 78% | OKAY |
                      33.6 | -1.01 -0.14 -0.79| 1.6 -0.4 148.0| 22 | 78% | OKAY |
                      33.3 | -1.01 -0.14 -0.79| 1.6 -0.4 148.0| 22 | 78% | OKAY |
                      33.1 | -1.01 -0.14 -0.79| 1.6 -0.4 148.0| 22 | 78% | OKAY |
                      33.3 | -1.01 -0.14 -0.79| 1.6 -0.4 147.9| 22 | 78% | OKAY |
                      33.6 | -1.01 -0.14 -0.79| 1.5 -0.4 147.9| 22 | 78% | OKAY |
                      33.1 | -1.01 -0.14 -0.79| 1.4 -0.4 147.9| 22 | 78% | OKAY |
                      33.3 | -1.01 -0.14 -0.79| 1.4 -0.4 147.8| 22 | 78% | OKAY |
                      33.3 | -1.01 -0.14 -0.79| 1.5 -0.5 147.8| 22 | 78% | OKAY |
                      33.3 | -1.01 -0.14 -0.79| 1.5 -0.5 147.7| 22 | 78% | OKAY |
                      33.6 | -1.01 -0.14 -0.79| 1.4 -0.5 147.7| 22 | 78% | OKAY |
                      33.1 | -1.01 -0.14 -0.79| 1.4 -0.5 147.6| 22 | 78% | OKAY |
                      33.3 | -1.01 -0.15 -0.79| 1.4 -0.4 147.6| 22 | 78% | OKAY |
                      33.3 | -1.01 -0.15 -0.79| 1.4 -0.5 147.3| 22 | 74% | OKAY |
                      33.6 | -1.01 -0.15 -0.78| 1.1 -0.6 145.1| 21 | 70% | OKAY |
                      33.1 | -1.01 -0.14 -0.77| 1.0 -0.6 141.2| 20 | 70% | OKAY |
                      33.5 | -1.01 -0.14 -0.75| 0.8 -0.7 137.8| 19 | 65% | OKAY |
                      33.1 | -1.01 -0.14 -0.73| 0.6 -0.7 134.0| 25 | 75% | OKAY |
                      33.3 | -1.00 -0.14 -0.70| 0.5 -0.6 129.9| 26 | 83% | OKAY |
                      33.3 | -1.00 -0.14 -0.68| 0.6 -0.5 125.6| 24 | 82% | OKAY |
                      33.3 | -1.00 -0.14 -0.65| 0.7 -0.4 121.1| 26 | 100% | OKAY |
                      33.3 | -1.00 -0.13 -0.62| 0.8 -0.2 116.4| 27 | 100% | OKAY |
                      33.3 | -1.00 -0.13 -0.60| 1.0 -0.1 111.5| 27 | 99% | OKAY |
                      33.3 | -0.99 -0.13 -0.57| 1.2 0.0 106.5| 23 | 100% | OKAY |
                      33.3 | -0.99 -0.13 -0.54| 1.3 0.2 101.4| 18 | 73% | OKAY |
                      33.3 | -0.99 -0.13 -0.52| 1.3 0.3 96.3| 17 | 73% | OKAY |
                      33.3 | -0.99 -0.13 -0.49| 1.4 0.5 91.1| 17 | 65% | OKAY |
                      33.4 | -0.98 -0.13 -0.46| 1.4 0.8 85.8| 17 | 69% | OKAY |
                      33.3 | -0.98 -0.13 -0.43| 1.5 1.0 80.6| 18 | 77% | OKAY |
                      33.3 | -0.98 -0.13 -0.40| 1.5 1.3 75.2| 17 | 60% | OKAY |
                      33.3 | -0.98 -0.13 -0.37| 1.5 1.5 70.0| 16 | 52% | OKAY |
                      33.3 | -0.97 -0.13 -0.34| 1.6 1.6 65.0| 16 | 68% | OKAY |
                      33.3 | -0.97 -0.13 -0.32| 1.7 1.7 60.3| 13 | 51% | OKAY |
                      33.3 | -0.97 -0.13 -0.29| 1.8 1.7 56.0| 12 | 68% | OKAY |
                      33.3 | -0.97 -0.13 -0.26| 2.0 1.7 52.1| 14 | 56% | OKAY |
                      33.3 | -0.97 -0.13 -0.23| 2.2 1.7 48.5| 18 | 77% | OKAY |
                      33.5 | -0.97 -0.13 -0.20| 2.3 1.7 45.4| 25 | 99% | OKAY |
                      33.1 | -0.97 -0.13 -0.17| 2.4 1.9 42.6| 24 | 87% | OKAY |
                      33.6 | -0.97 -0.13 -0.14| 2.4 1.8 40.1| 27 | 100% | OKAY |
                      33.1 | -0.97 -0.13 -0.11| 2.4 1.7 37.9| 29 | 100% | OKAY |
                      33.3 | -0.98 -0.13 -0.08| 2.4 1.4 36.1| 28 | 96% | OKAY |
                      33.3 | -0.98 -0.13 -0.05| 2.2 1.1 34.4| 26 | 100% | OKAY |
                      33.3 | -0.98 -0.13 -0.02| 2.1 0.9 33.1| 24 | 91% | OKAY |
                      33.3 | -0.98 -0.13 0.01| 1.9 0.4 31.9| 28 | 100% | OKAY |
                      33.3 | -0.99 -0.13 0.04| 1.6 0.0 30.9| 22 | 99% | OKAY |
                      33.3 | -0.99 -0.12 0.07| 1.4 -0.0 30.1| 23 | 98% | OKAY |
                      33.3 | -0.99 -0.12 0.10| 1.1 0.1 29.4| 20 | 86% | OKAY |
                      33.3 | -1.00 -0.12 0.13| 0.6 -0.1 28.9| 16 | 80% | OKAY |
                      33.3 | -1.00 -0.12 0.13| 2.0 -1.4 28.8| 13 | 60% | OKAY |
                      33.3 | -1.00 -0.13 0.12| 6.1 -3.1 28.5| 11 | 59% | OKAY |
                      33.3 | -1.00 -0.13 0.13| 9.5 -2.7 28.3| 15 | 52% | OKAY |
                      33.3 | -1.00 -0.13 0.13| 8.4 1.1 28.4| 15 | 52% | OKAY |
                      33.3 | -1.00 -0.14 0.14| 1.3 -0.1 27.9| 16 | 52% | OKAY |
                      33.3 | -1.00 -0.14 0.14| 0.1 0.6 27.3| 17 | 57% | OKAY |
                      33.3 | -1.00 -0.14 0.14| 0.7 0.6 27.3| 17 | 57% | OKAY |
                      33.3 | -1.00 -0.14 0.14| 0.0 0.5 27.2| 16 | 52% | OKAY |
                      33.3 | -1.00 -0.14 0.14| 0.0 0.7 26.9| 16 | 52% | OKAY |
                      33.5 | -1.00 -0.13 0.13| 0.1 0.6 27.0| 16 | 52% | OKAY |
                      33.1 | -1.00 -0.13 0.13| 0.1 0.5 26.9| 16 | 52% | OKAY |
                      33.3 | -1.00 -0.13 0.13| 0.2 0.5 26.9| 20 | 65% | OKAY |
                      33.3 | -1.00 -0.13 0.13| 0.0 0.6 26.9| 20 | 65% | OKAY |
                      33.6 | -1.00 -0.13 0.13| 0.0 0.5 26.9| 20 | 65% | OKAY |
                      33.1 | -1.00 -0.13 0.13| 0.0 0.6 26.9| 20 | 65% | OKAY |
                      I am not sure if the Portal is creating/sending the correct point shown on the map. Is there a way to send a point via the command line? I couldn't find anything specific for this.
                      • G greg_s
                        Hello @Cliff-Wong,
                        G Offline
                        G Offline
                        greg_s
                        @Cliff-Wong. For completeness below is the output of the start of voxl-vision-hub --debug_offboard. I trimmed the entire output above until the drone started to move from the plan_to command.
                        voxl2:~$ voxl-vision-hub --debug_offboard
                        VOXL FLIGHT CONTROLLER (VFC)
                        always_on 0
                        vfc_rate 100.000000
                        vfc_rc_chan_min 980
                        vfc_rc_chan_max 2020
                        vfc_thrust_ch 3
                        vfc_roll_ch 1
                        vfc_pitch_ch 2
                        vfc_yaw_ch 4
                        vfc_submode_ch 6
                        vfc_backtrack_seconds : 60
                        vfc_backtrack_rc_chan : 10
                        vfc_backtrack_rc_thresh : 1500
                        vfc_alt_mode_rc_min 0
                        vfc_alt_mode_rc_max 0
                        vfc_flow_mode_rc_min 1700
                        vfc_flow_mode_rc_max 2100
                        vfc_hybrid_flow_mode_rc_min 0
                        vfc_hybrid_flow_mode_rc_max 0
                        vfc_position_mode_rc_min 1300
                        vfc_position_mode_rc_max 1700
                        vfc_traj_mode_rc_min 0
                        vfc_traj_mode_rc_max 0
                        vfc_yaw_deadband 30
                        vfc_vxy_deadband 50
                        vfc_vz_deadband 150
                        vfc_min_thrust 0.000000
                        vfc_max_thrust 0.800000
                        vfc_tilt_max 0.436000
                        vfc_yaw_rate_max 3.000000
                        vfc_thrust_hover 0.250000
                        vfc_vz_max 1.000000
                        vfc_kp_z 5.000000
                        vfc_ki_z 0.500000
                        vfc_ki_z_max 0.300000
                        vfc_kd_z 4.000000
                        vfc_vxy_max 3.000000
                        vfc_kp_xy 0.640000
                        vfc_kd_xy 2.560000
                        vfc_kp_z_vio 5.000000
                        vfc_ki_z_vio 0.700000
                        vfc_kd_z_vio 5.000000
                        vfc_kp_xy_vio 6.000000
                        vfc_kd_xy_vio 4.000000
                        vfc_w_filt_xy_vio 10.000000
                        vfc_w_filt_xy_flow 3.000000
                        vfc_vel_ff_factor_vio 0.500000
                        vfc_xy_acc_limit_vio 3.000000
                        vfc_max_z_delta 3.000000
                        vfc_att_transition_time 0.500000
                        vfc_stick_move_threshold 30.000000
                        vfc_flow_transition_time 1.000000
                        vfc_q_min 15
                        vfc_points_min 0
                        vfc_en_submode_announcement 1
                        vfc_en_backtrack_heading_hold 0
                        vfc_disable_fallback 0
                        loading our own config file
                        config_file_version: 1
                        MAVROS / MAVSDK
                        en_localhost_mavlink_udp 0
                        localhost_udp_port_number: 14551
                        VIO
                        en_vio: 1
                        vio_pipe: qvio
                        secondary_vio_pipe: ov
                        vio_warmup_s: 3.000000
                        send_odom_while_failed: 1
                        MISC FEATURES
                        horizon_cal_tolerance: 0.500000
                        en_hitl: 0
                        OFFBOARD MODE
                        offboard_mode: trajectory
                        follow_tag_id: 0
                        figure_eight_move_home: 1
                        tracking_trigger_ch: 12
                        tracking_trigger_ch_thresh_temp: 1200
                        tracking_trigger_ch_thresh_new: 1800
                        wps_move_home: 1
                        wps_timeout: 0.000000
                        wps_damp: 1.000000
                        wps_vfc_mission: true
                        wps_vfc_mission_loop: false
                        wps_vfc_mission_to_ramp: 25.000000
                        wps_vfc_mission_cruise_speed: 1.000000
                        wps_vfc_mission_to_kp: 0.100000
                        robot_radius: 0.300000
                        collision_sampling_dt: 0.100000
                        max_lookahead_distance: 1.000000
                        FIXED FRAME RELOCALIZATION
                        en_tag_fixed_frame: 0
                        fixed_frame_filter_len: 5
                        COLLISION PREVENTION (VOA)
                        en_voa: 1
                        voa_upper_bound_m: -0.150000
                        voa_lower_bound_m: 0.150000
                        voa_memory_s: 1.000000
                        voa_max_pc_per_fusion: 100
                        voa_pie_min_dist_m: 0.250000
                        voa_pie_max_dist_m: 20.000000
                        voa_pie_under_trim_m: 1.000000
                        voa_pie_threshold: 3
                        voa_pie_slices: 36
                        voa_pie_bin_depth_m: 0.150000
                        voa_send_rate_hz: 20.000000
                        voa_input #0
                        enabled: 1
                        type: point_cloud
                        input_pipe: dfs_point_cloud
                        frame: stereo_l
                        max_depth: 8.000000
                        min_depth: 0.300000
                        cell_size: 0.080000
                        threshold: 4
                        x_fov_deg: 68.000000
                        y_fov_deg: 56.000000
                        conf_cutoff: 0
                        voa_input #1
                        enabled: 1
                        type: point_cloud
                        input_pipe: stereo_front_pc
                        frame: stereo_front_l
                        max_depth: 8.000000
                        min_depth: 0.300000
                        cell_size: 0.080000
                        threshold: 4
                        conf_cutoff: 0
                        voa_input #2
                        enabled: 1
                        type: point_cloud
                        input_pipe: stereo_rear_pc
                        frame: stereo_rear_l
                        max_depth: 8.000000
                        min_depth: 0.300000
                        cell_size: 0.080000
                        threshold: 4
                        conf_cutoff: 0
                        voa_input #3
                        enabled: 1
                        type: tof
                        input_pipe: tof
                        frame: tof
                        max_depth: 6.000000
                        min_depth: 0.150000
                        cell_size: 0.080000
                        threshold: 3
                        x_fov_deg: 106.500000
                        y_fov_deg: 85.099998
                        conf_cutoff: 125
                        voa_input #4
                        enabled: 1
                        type: rangefinder
                        input_pipe: rangefinders
                        frame: body
                        max_depth: 8.000000
                        min_depth: 0.300000
                        cell_size: 0.080000
                        threshold: 4
                        conf_cutoff: 0
                        loading horizon cal file
                        existing instance of voxl-vision-hub found, attempting to stop it
                        starting geometry module
                        starting autopilot monitor
                        starting mavlink IO
                        Waiting to connect to voxl-mavlink-server
                        starting fixed pose input
                        starting vio manager
                        Connected to VIO pipe: ov
                        Geometry module updating to use imu: imu_apps_body for VIO
                        ERROR in vcc_fetch_extrinsic, failed to find desired extrinsic relation in file
                        Likely you need to run voxl-configure-extrinsics to make a new file
                        ERROR: /etc/modalai/extrinsics.conf missing body to imu_apps_body, sticking with identity for now
                        Detected Autopilot Mavlink SYSID 1
                        requesting autopilot_version
                        Detected autopilot version: 1.14.0
                        starting tag manager
                        starting voa manager
                        ERROR in pipe_client_open, channel 11 already running
                        Connected to VOA input pipe: tof
                        starting horizon cal module
                        starting imu manager
                        starting state manager
                        starting offboard trajectory
                        Connected to voxl-mapper
                        voxl-mapper pipe size is: 65536 bytes
                        Init complete
                        Trajectory Monitor connected to voa pointcloud
                        commanding: XYZ -1.0 -0.1 -2.3 yaw: 0.1
                        WARNING in VOA manager, no attitude data from px4
                        • G greg_s
                          always_on 0
                          vfc_rate 100.000000
                          vfc_rc_chan_min 980
                          vfc_thrust_ch 3
                          vfc_roll_ch 1
                          vfc_pitch_ch 2
                          vfc_yaw_ch 4
                          vfc_submode_ch 6
                          vfc_yaw_deadband 30
                          vfc_vxy_deadband 50
                          vfc_vz_deadband 150
                          vfc_vz_max 1.000000
                          vfc_kp_z 5.000000
                          vfc_ki_z 0.500000
                          vfc_kd_z 4.000000
                          vfc_kp_xy 0.640000
                          vfc_kd_xy 2.560000
                          vfc_q_min 15
                          vfc_points_min 0
                          MAVROS / MAVSDK
                          VIO
                          en_vio: 1
                          vio_pipe: qvio
                          MISC FEATURES
                          en_hitl: 0
                          OFFBOARD MODE
                          follow_tag_id: 0
                          wps_move_home: 1
                          wps_damp: 1.000000
                          en_voa: 1
                          voa_pie_slices: 36
                          voa_input #0
                          enabled: 1
                          type: point_cloud
                          frame: stereo_l
                          max_depth: 8.000000
                          min_depth: 0.300000
                          cell_size: 0.080000
                          threshold: 4
                          conf_cutoff: 0
                          voa_input #1
                          enabled: 1
                          type: point_cloud
                          max_depth: 8.000000
                          min_depth: 0.300000
                          cell_size: 0.080000
                          threshold: 4
                          conf_cutoff: 0
                          voa_input #2
                          enabled: 1
                          type: point_cloud
                          max_depth: 8.000000
                          min_depth: 0.300000
                          cell_size: 0.080000
                          threshold: 4
                          conf_cutoff: 0
                          voa_input #3
                          enabled: 1
                          type: tof
                          input_pipe: tof
                          frame: tof
                          max_depth: 6.000000
                          min_depth: 0.150000
                          cell_size: 0.080000
                          threshold: 3
                          conf_cutoff: 125
                          voa_input #4
                          enabled: 1
                          type: rangefinder
                          frame: body
                          max_depth: 8.000000
                          min_depth: 0.300000
                          cell_size: 0.080000
                          threshold: 4
                          conf_cutoff: 0
                          starting mavlink IO
                          Init complete
                          Cliff WongC Offline
                          Cliff WongC Offline
                          Cliff Wong
                          @greg_s said in Starling 2 not following navigation path:
                          One thing that looks suspect is the voxl-mapper pipe size 64k bytes is much smaller than expect (usually in MB, e.g. 32MB-64MB). Is this a preloaded 3D map?
                          Otherwise your VIO data looks good. It appears the drone does go to the 1st setpoint (1st leg of the trajectory) where that setpoint also looks as if it is landing. It's possible the landing detector was triggered and why everything stops.
                          I suggest the following:
                          • power up, ssh into 2 terminals
                          • terminal 1 -- run the voxl-mapper
                            terminal 2 -- run voxl-vision-hub --debug_offboard
                          • take off in position mode, bring up the portal into mapper 3D view as normal, perform a 360 yaw to get a good map
                          • Select "Plan a Point": draw your point and position it correctly
                          • switch to offboard mode (which you have set correctly to 'trajectory')
                          • Select GO!
                          • Select "Follow Path"
                            (If no follow path is offered then the A* path creation failed)
                          Hopefully with that sequence, you'll see the drone move along the path. If it does not, then the voxl-mapper output in terminal 1 will tell us if a latency is the culprit.
                          As an example, here's how I expect the above to play out.. If you cannot repeat this then it maybe worth upgrading to SDK 1.6.3 (as the example was generated in).
                            • Select GO!
                            G Offline
                            G Offline
                            greg_s
                            Hello @Cliff-Wong,
                            I tried reproducing your suggestion. The first time I tried, it seems to work fine. After landing and trying again (I stopped and restarted the voxl-mapper and voxl-vision-hub), I few around to update the map again as it reloaded. I planned a route that was straight ahead for the drone. Instead of following the path shown in the 3D mapper, it flew diagonally upward and hit the ceiling. I captured a video similar to yours to show the result. Also note, I ran the update to get the latest patch version of the voxl sdk. After running the update twice, it updated some packages but the patch number remained 2. So this was run with 1.6.2 sdk version, unless something else messed up with the update. I did capture a log of the update I ran if that would be helpful.
                            Link to video
                              • Select GO!
                              G Offline
                              G Offline
                              greg_s
                              Hello @Cliff-Wong,
                              If there is any additional information or method I should try, just let me know.
                              • G greg_s
                                Hello @Cliff-Wong,
                                Cliff WongC Offline
                                Cliff WongC Offline
                                Cliff Wong
                                #19
                                @greg_s HI there,
                                The video exhibits classic VIO lost behavior from extrinsics: hovers fine, then on translation just flys away. Can you switch from trajectory mode back to figure_eight mode and confirm the drone can fly in figure 8s for more than 30secs?
                                Figure 8 also tests the trajectory engine that mapper uses so it will confirm a number of things on the sensor side.
                                  @greg_s HI there,
                                  G Offline
                                  G Offline
                                  greg_s
                                  Hello @Cliff-Wong,
                                  The figure 8 no longer works. It is now crashing into the netting in the room after starting the figure 8 mode. Though, it did in the past.
                                  Here is the screen recording as it was happening Link
                                  I also notice that it seems a sensor on the bottom has come loose due to the crashes sustained while trying to test the navigation. As well as the battery retention clips has broken off. Link
                                  • G greg_s
                                    Hello @Cliff-Wong,
                                    Cliff WongC Offline
                                    Cliff WongC Offline
                                    Cliff Wong
                                    #21
                                    @greg_s That would explain a lot what's happening.
                                    If you start fresh and connect to the drone with voxl-portal and goto the VIO tab/menu option, you should be able to pick up the drone and perform a bench test.
                                    Considering Figure 8 is not working, you will need to inspect the front and downward camera, tighten/remount any loose parts and possibly check camera focus & calibration.
                                    Worse case if the forward camera is good and not changed from factory, you can edit /etc/modalai/vio_cam.conf on the drone and disabled the faulty camera (disabled the down camera).
                                    You'll have degraded precision (mainly bad vio in fast yaw motions), but should be able to perform a figure 8 and should get you running until you repair that bottom sensor.
