    Starling 2 not following navigation path
    1423
    • G
      greg_s
      Hello ModalAI Team,
      I am still trying to get the navigation working with my team's Starling 2.
      kernel: #1 SMP PREEMPT Wed Oct 22 04:13:18 UTC 2025 4.19.125
      hw platform: M0054
      mach.var: 1.0.1
      SKU: MRB-D0014-4-V1-C27-T8-M22-X0
      voxl-suite: 1.6.2
      I have updated the drone to the latest voxl version 1.6.2. I am able to fly the drone in position mode and figure 8 mode.
      I few the drone around for a couple of minutes in our testing room gathering map data. I then switched the drone into offboard_mode: trajectory. I planned a point and saw the projected path drawing a simple straight line. There are not obstacles in the way to navigate around/avoid. The drone just flew directly at the grown instead of following the path. Is there anything I should try software/settings-wise to try and get navigation working? Is there anything about the layout/appearance of a room that could cause this? Please see the attached image.
      • G
        greg_s
        Hello ModalAI Team,
        Please let me know if there is any further information needed. So far, I haven't had the drone successfully navigate in trajectory in any version of the VOXL SDK I've tried (1.4/1.5/1.6).
        • A
          ApoorvThapliyal @greg_s
          Hey @greg_s,
          Can you post your voxl-logs and flight logs?
          • G
            greg_s @ApoorvThapliyal
            Hello @ApoorvThapliyal,
            I put the log file here: log100.ulg on Filebin.net
            I also put the the output from voxl-vision-hub --debug_offboard suggested by @Cliff-Wong in another post in another upload here voxl-vision-hub-log.txt on Filebin.net.
            When I attempted the flight, the drone appeared to fly to the correct X and Z coordinates, but it was close to the floor and well below the correct Y coordinate.
            Here are a couple of picture of the map and projected route:
            And a couple of the map after the drone tried to navigate and ended up below the point:
            • G
              greg_s
              For convenience I took out the section that has the trajectory from the voxl-vision-hub logs:
              commanding: XYZ -0.4 -0.2 -1.8 yaw: 0.3
              commanding: XYZ -0.4 -0.2 -1.7 yaw: 0.3
              Received trajectory has duration 1.953539 seconds
              Received load and start command.
              commanding: XYZ -0.4 -0.2 -1.0 yaw: 0.7 V: 0.0 0.0 -0.0 A: 0.1 0.0 -0.0
              commanding: XYZ -0.4 -0.2 -1.0 yaw: 0.7 V: 0.0 0.0 -0.0 A: 0.2 0.2 -0.0
              commanding: XYZ -0.4 -0.2 -1.0 yaw: 0.7 V: 0.0 0.0 -0.0 A: 0.3 0.3 -0.0
              commanding: XYZ -0.4 -0.2 -1.0 yaw: 0.7 V: 0.0 0.0 -0.0 A: 0.5 0.5 -0.0
              commanding: XYZ -0.4 -0.2 -1.0 yaw: 0.7 V: 0.0 0.0 -0.0 A: 0.7 0.6 0.0
              commanding: XYZ -0.4 -0.2 -1.0 yaw: 0.7 V: 0.1 0.1 -0.0 A: 0.9 0.7 0.0
              commanding: XYZ -0.3 -0.2 -1.0 yaw: 0.7 V: 0.1 0.1 0.0 A: 1.0 0.9 0.0
              commanding: XYZ -0.3 -0.2 -1.0 yaw: 0.7 V: 0.1 0.1 0.0 A: 1.1 0.9 0.0
              commanding: XYZ -0.3 -0.2 -1.0 yaw: 0.7 V: 0.2 0.2 0.0 A: 1.1 1.0 0.0
              commanding: XYZ -0.3 -0.2 -1.0 yaw: 0.7 V: 0.2 0.2 0.0 A: 1.2 1.0 0.0
              commanding: XYZ -0.3 -0.2 -1.0 yaw: 0.7 V: 0.3 0.2 0.0 A: 1.2 1.0 0.0
              commanding: XYZ -0.3 -0.2 -1.0 yaw: 0.7 V: 0.3 0.3 0.0 A: 1.2 1.0 0.0
              commanding: XYZ -0.3 -0.1 -1.0 yaw: 0.7 V: 0.3 0.3 0.0 A: 1.2 1.0 0.0
              commanding: XYZ -0.3 -0.1 -1.0 yaw: 0.7 V: 0.4 0.3 0.0 A: 1.1 1.0 0.0
              commanding: XYZ -0.3 -0.1 -1.0 yaw: 0.7 V: 0.4 0.4 0.0 A: 1.1 1.0 0.0
              Received trajectory has duration 1.452853 seconds
              Received insert command.
              commanding: XYZ -0.3 -0.1 -1.0 yaw: 0.7 V: 0.5 0.4 0.0 A: 1.1 0.9 0.0
              commanding: XYZ -0.2 -0.1 -1.0 yaw: 0.7 V: 0.5 0.4 0.0 A: 1.0 0.9 0.0
              commanding: XYZ -0.2 -0.1 -1.0 yaw: 0.7 V: 0.5 0.5 0.0 A: 1.0 0.9 0.0
              commanding: XYZ -0.2 -0.1 -1.0 yaw: 0.7 V: 0.6 0.5 0.0 A: 0.9 0.8 0.0
              commanding: XYZ -0.2 -0.0 -1.0 yaw: 0.7 V: 0.6 0.5 0.0 A: 0.8 0.7 0.1
              commanding: XYZ -0.2 -0.0 -1.0 yaw: 0.7 V: 0.6 0.6 0.0 A: 0.8 0.6 0.1
              commanding: XYZ -0.1 0.0 -1.0 yaw: 0.7 V: 0.7 0.6 0.0 A: 0.7 0.5 0.1
              commanding: XYZ -0.1 0.0 -1.0 yaw: 0.7 V: 0.7 0.6 0.0 A: 0.6 0.5 0.1
              commanding: XYZ -0.1 0.0 -1.0 yaw: 0.7 V: 0.7 0.6 0.0 A: 0.5 0.4 0.1
              commanding: XYZ -0.1 0.1 -1.0 yaw: 0.7 V: 0.7 0.6 0.0 A: 0.4 0.3 0.0
              commanding: XYZ -0.0 0.1 -1.0 yaw: 0.7 V: 0.7 0.6 0.0 A: 0.3 0.2 0.0
              commanding: XYZ -0.0 0.1 -1.0 yaw: 0.7 V: 0.7 0.6 0.0 A: 0.2 0.1 0.0
              commanding: XYZ 0.0 0.1 -1.0 yaw: 0.7 V: 0.7 0.6 0.0 A: 0.0 0.0 0.0
              Received trajectory has duration 0.510237 seconds
              commanding: XYZ 0.0 0.1 -1.0 yaw: 0.7 V: 0.7 0.6 0.0 A: -0.1 -0.1 0.0
              commanding: XYZ 0.1 0.2 -1.0 yaw: 0.7 V: 0.7 0.6 0.0 A: -0.2 -0.2 0.0
              commanding: XYZ 0.1 0.2 -1.0 yaw: 0.7 V: 0.6 0.5 0.0 A: -0.2 -0.2 0.0
              commanding: XYZ 0.1 0.2 -1.0 yaw: 0.7 V: 0.6 0.5 0.0 A: -0.3 -0.2 0.0
              commanding: XYZ 0.1 0.2 -1.0 yaw: 0.7 V: 0.6 0.5 0.0 A: -0.4 -0.3 -0.0
              commanding: XYZ 0.1 0.2 -1.0 yaw: 0.7 V: 0.6 0.5 0.0 A: -0.5 -0.4 -0.0
              commanding: XYZ 0.2 0.3 -1.0 yaw: 0.7 V: 0.6 0.5 0.0 A: -0.6 -0.5 -0.0
              commanding: XYZ 0.2 0.3 -1.0 yaw: 0.7 V: 0.6 0.5 0.0 A: -0.7 -0.6 -0.0
              commanding: XYZ 0.2 0.3 -1.0 yaw: 0.7 V: 0.5 0.5 0.0 A: -0.7 -0.6 -0.0
              commanding: XYZ 0.2 0.3 -1.0 yaw: 0.7 V: 0.5 0.4 0.0 A: -0.7 -0.6 -0.0
              commanding: XYZ 0.2 0.3 -1.0 yaw: 0.7 V: 0.5 0.4 0.0 A: -0.8 -0.7 -0.0
              commanding: XYZ 0.3 0.3 -1.0 yaw: 0.7 V: 0.4 0.4 0.0 A: -0.8 -0.7 -0.0
              commanding: XYZ 0.3 0.4 -1.0 yaw: 0.7 V: 0.4 0.3 0.0 A: -0.8 -0.7 -0.0
              commanding: XYZ 0.3 0.4 -1.0 yaw: 0.7 V: 0.4 0.3 0.0 A: -0.7 -0.6 -0.0
              commanding: XYZ 0.3 0.4 -1.0 yaw: 0.7 V: 0.3 0.3 0.0 A: -0.5 -0.5 -0.0
              commanding: XYZ 0.3 0.4 -1.0 yaw: 0.7 V: 0.3 0.3 0.0 A: -0.4 -0.3 0.0
              commanding: XYZ 0.3 0.4 -1.0 yaw: 0.7 V: 0.3 0.3 0.0 A: -0.3 -0.3 0.0
              commanding: XYZ 0.3 0.4 -1.0 yaw: 0.7 V: 0.3 0.2 0.0 A: -0.4 -0.4 0.0
              commanding: XYZ 0.3 0.4 -1.0 yaw: 0.7 V: 0.3 0.2 0.0 A: -0.6 -0.5 -0.0
              commanding: XYZ 0.4 0.4 -1.0 yaw: 0.7 V: 0.2 0.2 0.0 A: -0.8 -0.7 -0.0
              commanding: XYZ 0.4 0.4 -1.0 yaw: 0.7 V: 0.2 0.2 0.0 A: -1.1 -0.9 -0.1
              commanding: XYZ 0.4 0.4 -1.0 yaw: 0.7 V: 0.2 0.1 0.0 A: -1.3 -1.1 -0.1
              commanding: XYZ 0.4 0.4 -1.0 yaw: 0.7 V: 0.1 0.1 0.0 A: -1.4 -1.1 -0.1
              commanding: XYZ 0.4 0.4 -1.0 yaw: 0.7 V: 0.1 0.1 0.0 A: -1.3 -1.1 -0.1
              commanding: XYZ 0.4 0.4 -1.0 yaw: 0.7 V: 0.0 0.0 0.0 A: -1.0 -0.9 -0.1
              commanding: XYZ 0.4 0.4 -1.0 yaw: 0.7 V: 0.0 0.0 0.0 A: -0.7 -0.6 -0.1
              commanding: XYZ 0.4 0.4 -1.0 yaw: 0.7 V: 0.0 0.0 0.0 A: -0.3 -0.2 -0.0
              commanding: XYZ 0.4 0.4 -1.0 yaw: 0.7 V: 0.0 0.0 0.0 A: -0.0 -0.0 -0.0
              commanding: XYZ 0.4 0.4 -1.0 yaw: 0.7 V: -0.0 -0.0 0.0 A: -0.0 -0.0 0.0
              FINISHED TRAJECTORY
              commanding: XYZ 0.4 0.5 -1.0 yaw: 0.7
              • G
                greg_s
                @ApoorvThapliyal, if you/your team needs anymore information or data, do let me know. Thank you.
                • A
                  Hey @greg_s
                  I just wanted to confirm, are you dragging the planned point to the height desired? By default, simply clicking on the map will generate a point at height 0.
                  Let me know, thanks
                  G 2 Replies Last reply Reply Quote 0
                  • G
                    Yes, I am dragging the point up and panning the camera around to ensure it is roughly the same height as the drone. The line drawn for the path is pretty straight and at the correctly level. The drone just ends up flying down below the point after I have move it.
                    • G
                      Is there anything more your teams need to investigate/troubleshoot the issue? Thanks.
                      • A
                        Hey @greg_s
                        I was able to reproduce the issue where the drone does not fly correctly toward the setpoint. I think reviewing the extrinsics.conf file is a good next step, as there may be an incorrect transform defined there.
                        • G
                          Hey @ApoorvThapliyal,
                          Here is the output of the extrinsics:
                          voxl2:~$ voxl-inspect-extrinsics --all
                          #0:
                          parent: imu_apps
                          child: tracking_front
                          T_child_wrt_parent: 0.037 0.000 0.001
                          RPY_parent_to_child: 0.0 90.0 90.0
                          R_child_to_parent: 0.000 -0.000 1.000
                          1.000 0.000 -0.000
                          -0.000 1.000 0.000
                          #1:
                          parent: imu_apps
                          child: tracking_down
                          T_child_wrt_parent: -0.088 -0.004 0.027
                          RPY_parent_to_child: 0.0 0.0 180.0
                          R_child_to_parent: -1.000 -0.000 0.000
                          0.000 -1.000 -0.000
                          0.000 0.000 1.000
                          #2:
                          parent: imu_apps
                          child: tracking_rear
                          T_child_wrt_parent: -0.092 0.016 0.004
                          RPY_parent_to_child: 0.0 -90.0 -90.0
                          R_child_to_parent: 0.000 0.000 -1.000
                          -1.000 0.000 -0.000
                          0.000 1.000 0.000
                          #3:
                          parent: imu_apps
                          child: hires
                          T_child_wrt_parent: 0.039 0.000 0.019
                          1.000 0.000 -0.000
                          -0.000 1.000 0.000
                          #4:
                          parent: body
                          child: imu_apps
                          T_child_wrt_parent: 0.029 -0.006 -0.016
                          RPY_parent_to_child: 0.0 0.0 0.0
                          R_child_to_parent: 1.000 -0.000 0.000
                          0.000 1.000 -0.000
                          0.000 0.000 1.000
                          #5:
                          parent: body
                          child: imu_px4
                          T_child_wrt_parent: 0.004 0.007 -0.016
                          0.000 1.000 -0.000
                          0.000 0.000 1.000
                          #6:
                          parent: imu_apps
                          child: lepton0_raw
                          T_child_wrt_parent: -0.085 0.013 0.024
                          RPY_parent_to_child: 0.0 0.0 90.0
                          R_child_to_parent: 0.000 -1.000 0.000
                          1.000 0.000 -0.000
                          0.000 0.000 1.000
                          #7:
                          parent: body
                          child: tof
                          T_child_wrt_parent: 0.066 0.009 -0.012
                          RPY_parent_to_child: 0.0 90.0 180.0
                          R_child_to_parent: -0.000 -0.000 1.000
                          0.000 -1.000 -0.000
                          1.000 0.000 0.000
                          #8:
                          parent: body
                          child: ground
                          T_child_wrt_parent: 0.000 0.000 0.033
                          0.000 1.000 -0.000
                          0.000 0.000 1.000
                          • G
                            Is there anything that looks wrong or off about the configuration? Should I look at any other file in particular?
                            Cliff WongC 1 Reply Last reply Reply Quote 0
                            • Cliff WongC
                              Cliff Wong ModalAI Team @greg_s
                              @greg_s
                              Hi there, your extrinsics are good: same as a factory Starling. Now, if you altered the voxl-camera-server.conf (e.g. enabled a flip of a camera stream when it wasn't) or physically changed a camera mount point then the extrinsics would need to be adjusted. Let assume that's not the case.
                              From your vvhub trajectory output, it appears your setpoints command the vehicle to move forward (X) and to the right (Y) > 1m while dropping altitude (Z) 0.8m --recall mapper runs in FRD (aka body) space where Z up is negative. Also you do pass through the take off origin (0,0,0). If that's not what you wanted, then we have a "requested trajectory" drawing problem in the portal tool or mapper's found invalid regions/obstacle and could not draw the "requested trajectory".
                              In the former case @ApoorvThapliyal mentions the un-intuitiveness of the portal tool that you already understand.
                              In the latter case, upon "request trajectory" submission, voxl-mapper will analyze the map to see if there are obstacles and alter the trajectory to fly around potential obstacles. You can alter in voxl-mapper.conf:
                              • rrt_min_distance (try 0.125)
                              • esdf_inner_sphere_radius (try 0.15)
                                if you seeing mapper create trajectories going around 'ghost' objects. This should allow RRT generated trajectories to get closer to objects.
                              In checking precision, you'll need to take the trajectory output (e.g. the setpoints in the *commanding: XYZ* messages) and compared it against VIO position to determine tracking error. You have 2 ways to get that data:
                              • option 1 is record you vvhub traj output as above and record the output of voxl-inspect-vins -n then plot compare the tracking error.
                              • option 2 is running voxl-vision-hub --debug_offboard --debug_odometry which you'll need to seperate the traj messages from the vio (T_body_wrt_local) messages, then you ca plot the tracking error.
                              The goal is we want the vio position to follow the commanded trajectory: (it's doing what is told to do). That will narrow down where your concerns are w.r.t what module has a problem.
                              Hopefully that gets you on the right track, just post any outputs you gather that continue to show tracking error.
                              • G
                                greg_s @Cliff Wong
                                Hello @Cliff-Wong,
                                I collected the output from voxl-vision-hub --debug_offboard and voxl-inspect-vins -n. I place a plan_to point that was about half a meter from the drone and slightly higher in altitude from the drone. I used the arrows to position the plan_to point and rotated camera to ensure the plan_to point it was placed correctly. I reduced the rrt_min_distance and esdf_inner_sphere_radius as suggested. The drone had more than a meter clearance on all sides. The room is empty with no obstacles.
                                The output from voxl-vision-hub --debug_offboard:
                                commanding: XYZ -1.0 -0.1 -2.4 yaw: 2.6
                                Setpoint position: XYZ -1.0 -0.1 -0.8 yaw: 0.4
                                Received trajectory has duration 3.309723 seconds
                                commanding: XYZ -1.0 -0.1 0.1 yaw: 0.4 V: 0.0 0.0 -0.0 A: 0.0 0.0 -0.0
                                commanding: XYZ -1.0 -0.1 0.1 yaw: 0.5 V: 0.0 0.0 -0.0 A: 0.0 0.0 -0.0
                                commanding: XYZ -1.0 -0.1 0.1 yaw: 0.4 V: 0.0 0.0 -0.0 A: 0.0 0.0 -0.1
                                commanding: XYZ -1.0 -0.1 0.1 yaw: 0.4 V: 0.0 0.0 -0.0 A: 0.1 0.0 -0.2
                                commanding: XYZ -1.0 -0.1 0.1 yaw: 0.4 V: 0.0 0.0 -0.0 A: 0.1 0.0 -0.3
                                commanding: XYZ -1.0 -0.1 0.1 yaw: 0.4 V: 0.0 0.0 -0.0 A: 0.1 0.1 -0.3
                                commanding: XYZ -1.0 -0.1 0.1 yaw: 0.4 V: 0.0 0.0 -0.0 A: 0.2 0.1 -0.4
                                commanding: XYZ -1.0 -0.1 0.1 yaw: 0.4 V: 0.0 0.0 -0.1 A: 0.2 0.1 -0.4
                                commanding: XYZ -1.0 -0.1 0.1 yaw: 0.4 V: 0.0 0.0 -0.1 A: 0.2 0.1 -0.5
                                commanding: XYZ -1.0 -0.1 0.1 yaw: 0.4 V: 0.0 0.0 -0.1 A: 0.3 0.1 -0.5
                                commanding: XYZ -1.0 -0.1 0.1 yaw: 0.4 V: 0.0 0.0 -0.1 A: 0.3 0.1 -0.6
                                commanding: XYZ -1.0 -0.1 0.1 yaw: 0.4 V: 0.1 0.0 -0.1 A: 0.4 0.1 -0.6
                                commanding: XYZ -1.0 -0.1 0.1 yaw: 0.4 V: 0.1 0.0 -0.2 A: 0.4 0.2 -0.6
                                commanding: XYZ -1.0 -0.1 0.1 yaw: 0.4 V: 0.1 0.0 -0.2 A: 0.5 0.2 -0.6
                                Received trajectory has duration 2.234033 seconds
                                commanding: XYZ -1.0 -0.1 0.1 yaw: 0.4 V: 0.1 0.1 -0.2 A: 0.5 0.2 -0.6
                                commanding: XYZ -1.0 -0.1 0.0 yaw: 0.4 V: 0.2 0.1 -0.3 A: 0.5 0.2 -0.6
                                commanding: XYZ -1.0 -0.1 0.0 yaw: 0.4 V: 0.2 0.1 -0.3 A: 0.6 0.2 -0.6
                                commanding: XYZ -1.0 -0.1 0.0 yaw: 0.4 V: 0.2 0.1 -0.3 A: 0.6 0.2 -0.5
                                commanding: XYZ -0.9 -0.1 -0.0 yaw: 0.4 V: 0.2 0.1 -0.3 A: 0.6 0.2 -0.5
                                commanding: XYZ -0.9 -0.1 -0.0 yaw: 0.4 V: 0.3 0.1 -0.4 A: 0.6 0.2 -0.5
                                commanding: XYZ -0.9 -0.1 -0.0 yaw: 0.4 V: 0.3 0.1 -0.4 A: 0.6 0.2 -0.4
                                commanding: XYZ -0.9 -0.1 -0.1 yaw: 0.4 V: 0.3 0.1 -0.4 A: 0.6 0.2 -0.4
                                commanding: XYZ -0.9 -0.1 -0.1 yaw: 0.4 V: 0.3 0.1 -0.4 A: 0.6 0.3 -0.4
                                commanding: XYZ -0.9 -0.1 -0.1 yaw: 0.4 V: 0.4 0.1 -0.4 A: 0.6 0.3 -0.4
                                commanding: XYZ -0.9 -0.1 -0.1 yaw: 0.4 V: 0.4 0.2 -0.4 A: 0.6 0.3 -0.4
                                commanding: XYZ -0.9 -0.1 -0.1 yaw: 0.4 V: 0.4 0.2 -0.4 A: 0.6 0.2 -0.4
                                commanding: XYZ -0.8 -0.1 -0.1 yaw: 0.4 V: 0.4 0.2 -0.5 A: 0.6 0.2 -0.4
                                commanding: XYZ -0.8 -0.1 -0.1 yaw: 0.4 V: 0.4 0.2 -0.5 A: 0.6 0.3 -0.4
                                commanding: XYZ -0.8 -0.1 -0.2 yaw: 0.4 V: 0.4 0.2 -0.5 A: 0.6 0.3 -0.4
                                commanding: XYZ -0.8 -0.1 -0.2 yaw: 0.4 V: 0.5 0.2 -0.5 A: 0.6 0.3 -0.4
                                commanding: XYZ -0.8 -0.0 -0.2 yaw: 0.4 V: 0.5 0.2 -0.5 A: 0.6 0.3 -0.3
                                commanding: XYZ -0.8 -0.0 -0.2 yaw: 0.4 V: 0.5 0.2 -0.5 A: 0.6 0.2 -0.3
                                commanding: XYZ -0.7 -0.0 -0.2 yaw: 0.4 V: 0.6 0.2 -0.5 A: 0.6 0.2 -0.3
                                commanding: XYZ -0.7 -0.0 -0.3 yaw: 0.4 V: 0.6 0.2 -0.5 A: 0.6 0.2 -0.3
                                commanding: XYZ -0.7 -0.0 -0.3 yaw: 0.4 V: 0.6 0.2 -0.6 A: 0.6 0.2 -0.2
                                commanding: XYZ -0.7 0.0 -0.3 yaw: 0.4 V: 0.6 0.3 -0.6 A: 0.5 0.2 -0.2
                                Received trajectory has duration 1.689594 seconds
                                commanding: XYZ -0.6 0.0 -0.3 yaw: 0.4 V: 0.7 0.3 -0.6 A: 0.5 0.2 -0.2
                                commanding: XYZ -0.6 0.0 -0.4 yaw: 0.4 V: 0.7 0.3 -0.6 A: 0.5 0.2 -0.1
                                commanding: XYZ -0.6 0.0 -0.4 yaw: 0.4 V: 0.7 0.3 -0.6 A: 0.4 0.2 -0.1
                                commanding: XYZ -0.6 0.0 -0.4 yaw: 0.4 V: 0.7 0.3 -0.6 A: 0.4 0.1 -0.1
                                commanding: XYZ -0.5 0.1 -0.4 yaw: 0.4 V: 0.7 0.3 -0.6 A: 0.4 0.1 -0.1
                                commanding: XYZ -0.5 0.1 -0.4 yaw: 0.4 V: 0.7 0.3 -0.6 A: 0.3 0.1 -0.0
                                commanding: XYZ -0.5 0.1 -0.5 yaw: 0.4 V: 0.7 0.3 -0.6 A: 0.3 0.1 -0.0
                                commanding: XYZ -0.5 0.1 -0.5 yaw: 0.4 V: 0.7 0.3 -0.6 A: 0.3 0.1 0.0
                                Received trajectory has duration 1.165000 seconds
                                commanding: XYZ -0.4 0.1 -0.5 yaw: 0.4 V: 0.7 0.3 -0.6 A: 0.2 0.1 0.1
                                Received trajectory has duration 1.342931 seconds
                                commanding: XYZ -0.4 0.1 -0.5 yaw: 0.4 V: 0.7 0.3 -0.6 A: 0.1 0.0 0.1
                                commanding: XYZ -0.4 0.1 -0.5 yaw: 0.4 V: 0.7 0.3 -0.6 A: 0.0 -0.0 0.2
                                commanding: XYZ -0.3 0.1 -0.6 yaw: 0.4 V: 0.7 0.3 -0.6 A: -0.0 -0.0 0.2
                                commanding: XYZ -0.3 0.1 -0.6 yaw: 0.4 V: 0.7 0.3 -0.6 A: -0.1 -0.0 0.2
                                commanding: XYZ -0.3 0.1 -0.6 yaw: 0.4 V: 0.7 0.3 -0.5 A: -0.1 -0.1 0.3
                                commanding: XYZ -0.3 0.2 -0.6 yaw: 0.4 V: 0.7 0.3 -0.5 A: -0.2 -0.1 0.3
                                commanding: XYZ -0.2 0.2 -0.6 yaw: 0.4 V: 0.7 0.3 -0.5 A: -0.2 -0.1 0.3
                                commanding: XYZ -0.2 0.2 -0.7 yaw: 0.4 V: 0.7 0.3 -0.5 A: -0.3 -0.1 0.3
                                commanding: XYZ -0.2 0.2 -0.7 yaw: 0.4 V: 0.7 0.3 -0.5 A: -0.3 -0.1 0.4
                                commanding: XYZ -0.2 0.2 -0.7 yaw: 0.4 V: 0.7 0.3 -0.5 A: -0.4 -0.2 0.4
                                Received trajectory has duration 1.508897 seconds
                                commanding: XYZ -0.1 0.2 -0.7 yaw: 0.4 V: 0.7 0.3 -0.5 A: -0.5 -0.2 0.4
                                commanding: XYZ -0.1 0.2 -0.8 yaw: 0.4 V: 0.6 0.2 -0.4 A: -0.5 -0.2 0.4
                                commanding: XYZ -0.0 0.2 -0.8 yaw: 0.4 V: 0.6 0.2 -0.4 A: -0.5 -0.2 0.4
                                commanding: XYZ -0.0 0.3 -0.8 yaw: 0.4 V: 0.5 0.2 -0.4 A: -0.6 -0.2 0.4
                                commanding: XYZ -0.0 0.3 -0.8 yaw: 0.4 V: 0.5 0.2 -0.3 A: -0.6 -0.2 0.5
                                commanding: XYZ 0.0 0.3 -0.8 yaw: 0.4 V: 0.5 0.2 -0.3 A: -0.6 -0.2 0.5
                                commanding: XYZ 0.0 0.3 -0.8 yaw: 0.4 V: 0.5 0.2 -0.3 A: -0.7 -0.3 0.5
                                commanding: XYZ 0.1 0.3 -0.8 yaw: 0.4 V: 0.4 0.2 -0.3 A: -0.7 -0.3 0.5
                                commanding: XYZ 0.1 0.3 -0.9 yaw: 0.4 V: 0.4 0.2 -0.3 A: -0.7 -0.3 0.5
                                commanding: XYZ 0.1 0.3 -0.9 yaw: 0.4 V: 0.4 0.1 -0.2 A: -0.7 -0.3 0.5
                                commanding: XYZ 0.1 0.3 -0.9 yaw: 0.4 V: 0.3 0.1 -0.2 A: -0.5 -0.2 0.4
                                commanding: XYZ 0.1 0.3 -0.9 yaw: 0.4 V: 0.2 0.1 -0.2 A: -0.5 -0.2 0.3
                                commanding: XYZ 0.1 0.3 -0.9 yaw: 0.4 V: 0.2 0.1 -0.1 A: -0.5 -0.2 0.3
                                commanding: XYZ 0.2 0.3 -0.9 yaw: 0.4 V: 0.2 0.1 -0.1 A: -0.5 -0.2 0.3
                                commanding: XYZ 0.2 0.3 -0.9 yaw: 0.4 V: 0.2 0.1 -0.1 A: -0.4 -0.2 0.3
                                commanding: XYZ 0.2 0.3 -0.9 yaw: 0.4 V: 0.1 0.1 -0.1 A: -0.4 -0.2 0.3
                                commanding: XYZ 0.2 0.3 -0.9 yaw: 0.4 V: 0.1 0.0 -0.1 A: -0.4 -0.1 0.3
                                commanding: XYZ 0.2 0.3 -0.9 yaw: 0.4 V: 0.1 0.0 -0.1 A: -0.4 -0.1 0.2
                                commanding: XYZ 0.2 0.3 -0.9 yaw: 0.4 V: 0.1 0.0 -0.1 A: -0.3 -0.1 0.2
                                commanding: XYZ 0.2 0.3 -0.9 yaw: 0.4 V: 0.1 0.0 -0.0 A: -0.3 -0.1 0.2
                                commanding: XYZ 0.2 0.3 -0.9 yaw: 0.4 V: 0.0 0.0 -0.0 A: -0.2 -0.1 0.1
                                commanding: XYZ 0.2 0.3 -0.9 yaw: 0.4 V: 0.0 0.0 -0.0 A: -0.1 -0.1 0.1
                                commanding: XYZ 0.2 0.3 -0.9 yaw: 0.4 V: 0.0 0.0 -0.0 A: -0.1 -0.0 0.1
                                commanding: XYZ 0.2 0.3 -0.9 yaw: 0.3 V: 0.0 0.0 -0.0 A: -0.1 -0.0 0.1
                                commanding: XYZ 0.2 0.3 -0.9 yaw: 0.3 V: 0.0 0.0 -0.0 A: -0.1 -0.0 0.0
                                commanding: XYZ 0.2 0.3 -0.9 yaw: 0.2 V: 0.0 0.0 -0.0 A: -0.1 -0.0 0.0
                                commanding: XYZ 0.2 0.3 -0.9 yaw: -2.8 V: -0.0 -0.0 0.0 A: -0.0 -0.0 0.0
                                Received stop command.
                                Stopped following trajectory.
                                commanding: XYZ -1.0 -0.1 -1.5 yaw: 0.5
                                The output from voxl-inspect-vins -n:
                                dt(ms) | T_imu_wrt_vio (m) |Roll Pitch Yaw (deg)|features|quality| state| error_codes
                                33.1 | -1.01 -0.14 -0.79| 1.6 -0.5 148.0| 22 | 78% | OKAY |
                                33.6 | -1.01 -0.14 -0.79| 1.6 -0.4 148.0| 22 | 78% | OKAY |
                                33.3 | -1.01 -0.14 -0.79| 1.6 -0.4 148.0| 22 | 78% | OKAY |
                                33.1 | -1.01 -0.14 -0.79| 1.6 -0.4 148.0| 22 | 78% | OKAY |
                                33.3 | -1.01 -0.14 -0.79| 1.6 -0.4 147.9| 22 | 78% | OKAY |
                                33.6 | -1.01 -0.14 -0.79| 1.5 -0.4 147.9| 22 | 78% | OKAY |
                                33.1 | -1.01 -0.14 -0.79| 1.4 -0.4 147.9| 22 | 78% | OKAY |
                                33.3 | -1.01 -0.14 -0.79| 1.4 -0.4 147.8| 22 | 78% | OKAY |
                                33.3 | -1.01 -0.14 -0.79| 1.5 -0.5 147.8| 22 | 78% | OKAY |
                                33.3 | -1.01 -0.14 -0.79| 1.5 -0.5 147.7| 22 | 78% | OKAY |
                                33.6 | -1.01 -0.14 -0.79| 1.4 -0.5 147.7| 22 | 78% | OKAY |
                                33.1 | -1.01 -0.14 -0.79| 1.4 -0.5 147.6| 22 | 78% | OKAY |
                                33.3 | -1.01 -0.15 -0.79| 1.4 -0.4 147.6| 22 | 78% | OKAY |
                                33.3 | -1.01 -0.15 -0.79| 1.4 -0.5 147.3| 22 | 74% | OKAY |
                                33.6 | -1.01 -0.15 -0.78| 1.1 -0.6 145.1| 21 | 70% | OKAY |
                                33.1 | -1.01 -0.14 -0.77| 1.0 -0.6 141.2| 20 | 70% | OKAY |
                                33.5 | -1.01 -0.14 -0.75| 0.8 -0.7 137.8| 19 | 65% | OKAY |
                                33.1 | -1.01 -0.14 -0.73| 0.6 -0.7 134.0| 25 | 75% | OKAY |
                                33.3 | -1.00 -0.14 -0.70| 0.5 -0.6 129.9| 26 | 83% | OKAY |
                                33.3 | -1.00 -0.14 -0.68| 0.6 -0.5 125.6| 24 | 82% | OKAY |
                                33.3 | -1.00 -0.14 -0.65| 0.7 -0.4 121.1| 26 | 100% | OKAY |
                                33.3 | -1.00 -0.13 -0.62| 0.8 -0.2 116.4| 27 | 100% | OKAY |
                                33.3 | -1.00 -0.13 -0.60| 1.0 -0.1 111.5| 27 | 99% | OKAY |
                                33.3 | -0.99 -0.13 -0.57| 1.2 0.0 106.5| 23 | 100% | OKAY |
                                33.3 | -0.99 -0.13 -0.54| 1.3 0.2 101.4| 18 | 73% | OKAY |
                                33.3 | -0.99 -0.13 -0.52| 1.3 0.3 96.3| 17 | 73% | OKAY |
                                33.3 | -0.99 -0.13 -0.49| 1.4 0.5 91.1| 17 | 65% | OKAY |
                                33.4 | -0.98 -0.13 -0.46| 1.4 0.8 85.8| 17 | 69% | OKAY |
                                33.3 | -0.98 -0.13 -0.43| 1.5 1.0 80.6| 18 | 77% | OKAY |
                                33.3 | -0.98 -0.13 -0.40| 1.5 1.3 75.2| 17 | 60% | OKAY |
                                33.3 | -0.98 -0.13 -0.37| 1.5 1.5 70.0| 16 | 52% | OKAY |
                                33.3 | -0.97 -0.13 -0.34| 1.6 1.6 65.0| 16 | 68% | OKAY |
                                33.3 | -0.97 -0.13 -0.32| 1.7 1.7 60.3| 13 | 51% | OKAY |
                                33.3 | -0.97 -0.13 -0.29| 1.8 1.7 56.0| 12 | 68% | OKAY |
                                33.3 | -0.97 -0.13 -0.26| 2.0 1.7 52.1| 14 | 56% | OKAY |
                                33.3 | -0.97 -0.13 -0.23| 2.2 1.7 48.5| 18 | 77% | OKAY |
                                33.5 | -0.97 -0.13 -0.20| 2.3 1.7 45.4| 25 | 99% | OKAY |
                                33.1 | -0.97 -0.13 -0.17| 2.4 1.9 42.6| 24 | 87% | OKAY |
                                33.6 | -0.97 -0.13 -0.14| 2.4 1.8 40.1| 27 | 100% | OKAY |
                                33.1 | -0.97 -0.13 -0.11| 2.4 1.7 37.9| 29 | 100% | OKAY |
                                33.3 | -0.98 -0.13 -0.08| 2.4 1.4 36.1| 28 | 96% | OKAY |
                                33.3 | -0.98 -0.13 -0.05| 2.2 1.1 34.4| 26 | 100% | OKAY |
                                33.3 | -0.98 -0.13 -0.02| 2.1 0.9 33.1| 24 | 91% | OKAY |
                                33.3 | -0.98 -0.13 0.01| 1.9 0.4 31.9| 28 | 100% | OKAY |
                                33.3 | -0.99 -0.13 0.04| 1.6 0.0 30.9| 22 | 99% | OKAY |
                                33.3 | -0.99 -0.12 0.07| 1.4 -0.0 30.1| 23 | 98% | OKAY |
                                33.3 | -0.99 -0.12 0.10| 1.1 0.1 29.4| 20 | 86% | OKAY |
                                33.3 | -1.00 -0.12 0.13| 0.6 -0.1 28.9| 16 | 80% | OKAY |
                                33.3 | -1.00 -0.12 0.13| 2.0 -1.4 28.8| 13 | 60% | OKAY |
                                33.3 | -1.00 -0.13 0.12| 6.1 -3.1 28.5| 11 | 59% | OKAY |
                                33.3 | -1.00 -0.13 0.13| 9.5 -2.7 28.3| 15 | 52% | OKAY |
                                33.3 | -1.00 -0.13 0.13| 8.4 1.1 28.4| 15 | 52% | OKAY |
                                33.3 | -1.00 -0.14 0.14| 1.3 -0.1 27.9| 16 | 52% | OKAY |
                                33.3 | -1.00 -0.14 0.14| 0.1 0.6 27.3| 17 | 57% | OKAY |
                                33.3 | -1.00 -0.14 0.14| 0.7 0.6 27.3| 17 | 57% | OKAY |
                                33.3 | -1.00 -0.14 0.14| 0.0 0.5 27.2| 16 | 52% | OKAY |
                                33.3 | -1.00 -0.14 0.14| 0.0 0.7 26.9| 16 | 52% | OKAY |
                                33.5 | -1.00 -0.13 0.13| 0.1 0.6 27.0| 16 | 52% | OKAY |
                                33.1 | -1.00 -0.13 0.13| 0.1 0.5 26.9| 16 | 52% | OKAY |
                                33.3 | -1.00 -0.13 0.13| 0.2 0.5 26.9| 20 | 65% | OKAY |
                                33.3 | -1.00 -0.13 0.13| 0.0 0.6 26.9| 20 | 65% | OKAY |
                                33.6 | -1.00 -0.13 0.13| 0.0 0.5 26.9| 20 | 65% | OKAY |
                                33.1 | -1.00 -0.13 0.13| 0.0 0.6 26.9| 20 | 65% | OKAY |
                                I am not sure if the Portal is creating/sending the correct point shown on the map. Is there a way to send a point via the command line? I couldn't find anything specific for this.
                                • G
                                  greg_s @greg_s
                                  @Cliff-Wong. For completeness below is the output of the start of voxl-vision-hub --debug_offboard. I trimmed the entire output above until the drone started to move from the plan_to command.
                                  voxl2:~$ voxl-vision-hub --debug_offboard
                                  VOXL FLIGHT CONTROLLER (VFC)
                                  always_on 0
                                  vfc_rate 100.000000
                                  vfc_rc_chan_min 980
                                  vfc_rc_chan_max 2020
                                  vfc_thrust_ch 3
                                  vfc_roll_ch 1
                                  vfc_pitch_ch 2
                                  vfc_yaw_ch 4
                                  vfc_submode_ch 6
                                  vfc_backtrack_seconds : 60
                                  vfc_backtrack_rc_chan : 10
                                  vfc_backtrack_rc_thresh : 1500
                                  vfc_alt_mode_rc_min 0
                                  vfc_alt_mode_rc_max 0
                                  vfc_flow_mode_rc_min 1700
                                  vfc_flow_mode_rc_max 2100
                                  vfc_hybrid_flow_mode_rc_min 0
                                  vfc_hybrid_flow_mode_rc_max 0
                                  vfc_position_mode_rc_min 1300
                                  vfc_position_mode_rc_max 1700
                                  vfc_traj_mode_rc_min 0
                                  vfc_traj_mode_rc_max 0
                                  vfc_yaw_deadband 30
                                  vfc_vxy_deadband 50
                                  vfc_vz_deadband 150
                                  vfc_min_thrust 0.000000
                                  vfc_max_thrust 0.800000
                                  vfc_tilt_max 0.436000
                                  vfc_yaw_rate_max 3.000000
                                  vfc_thrust_hover 0.250000
                                  vfc_vz_max 1.000000
                                  vfc_kp_z 5.000000
                                  vfc_ki_z 0.500000
                                  vfc_ki_z_max 0.300000
                                  vfc_kd_z 4.000000
                                  vfc_vxy_max 3.000000
                                  vfc_kp_xy 0.640000
                                  vfc_kd_xy 2.560000
                                  vfc_kp_z_vio 5.000000
                                  vfc_ki_z_vio 0.700000
                                  vfc_kd_z_vio 5.000000
                                  vfc_kp_xy_vio 6.000000
                                  vfc_kd_xy_vio 4.000000
                                  vfc_w_filt_xy_vio 10.000000
                                  vfc_w_filt_xy_flow 3.000000
                                  vfc_vel_ff_factor_vio 0.500000
                                  vfc_xy_acc_limit_vio 3.000000
                                  vfc_max_z_delta 3.000000
                                  vfc_att_transition_time 0.500000
                                  vfc_stick_move_threshold 30.000000
                                  vfc_flow_transition_time 1.000000
                                  vfc_q_min 15
                                  vfc_points_min 0
                                  vfc_en_submode_announcement 1
                                  vfc_en_backtrack_heading_hold 0
                                  vfc_disable_fallback 0
                                  loading our own config file
                                  config_file_version: 1
                                  MAVROS / MAVSDK
                                  en_localhost_mavlink_udp 0
                                  localhost_udp_port_number: 14551
                                  VIO
                                  en_vio: 1
                                  vio_pipe: qvio
                                  secondary_vio_pipe: ov
                                  vio_warmup_s: 3.000000
                                  send_odom_while_failed: 1
                                  MISC FEATURES
                                  horizon_cal_tolerance: 0.500000
                                  en_hitl: 0
                                  OFFBOARD MODE
                                  follow_tag_id: 0
                                  figure_eight_move_home: 1
                                  tracking_trigger_ch: 12
                                  tracking_trigger_ch_thresh_temp: 1200
                                  tracking_trigger_ch_thresh_new: 1800
                                  wps_move_home: 1
                                  wps_timeout: 0.000000
                                  wps_damp: 1.000000
                                  wps_vfc_mission: true
                                  wps_vfc_mission_loop: false
                                  wps_vfc_mission_to_ramp: 25.000000
                                  wps_vfc_mission_cruise_speed: 1.000000
                                  wps_vfc_mission_to_kp: 0.100000
                                  robot_radius: 0.300000
                                  collision_sampling_dt: 0.100000
                                  max_lookahead_distance: 1.000000
                                  FIXED FRAME RELOCALIZATION
                                  en_tag_fixed_frame: 0
                                  fixed_frame_filter_len: 5
                                  COLLISION PREVENTION (VOA)
                                  en_voa: 1
                                  voa_upper_bound_m: -0.150000
                                  voa_lower_bound_m: 0.150000
                                  voa_memory_s: 1.000000
                                  voa_max_pc_per_fusion: 100
                                  voa_pie_min_dist_m: 0.250000
                                  voa_pie_max_dist_m: 20.000000
                                  voa_pie_under_trim_m: 1.000000
                                  voa_pie_threshold: 3
                                  voa_pie_slices: 36
                                  voa_pie_bin_depth_m: 0.150000
                                  voa_send_rate_hz: 20.000000
                                  voa_input #0
                                  enabled: 1
                                  type: point_cloud
                                  input_pipe: dfs_point_cloud
                                  frame: stereo_l
                                  max_depth: 8.000000
                                  min_depth: 0.300000
                                  cell_size: 0.080000
                                  threshold: 4
                                  x_fov_deg: 68.000000
                                  y_fov_deg: 56.000000
                                  conf_cutoff: 0
                                  voa_input #1
                                  enabled: 1
                                  type: point_cloud
                                  input_pipe: stereo_front_pc
                                  frame: stereo_front_l
                                  max_depth: 8.000000
                                  min_depth: 0.300000
                                  cell_size: 0.080000
                                  threshold: 4
                                  conf_cutoff: 0
                                  voa_input #2
                                  enabled: 1
                                  type: point_cloud
                                  input_pipe: stereo_rear_pc
                                  frame: stereo_rear_l
                                  max_depth: 8.000000
                                  min_depth: 0.300000
                                  cell_size: 0.080000
                                  threshold: 4
                                  conf_cutoff: 0
                                  voa_input #3
                                  enabled: 1
                                  type: tof
                                  input_pipe: tof
                                  frame: tof
                                  max_depth: 6.000000
                                  min_depth: 0.150000
                                  cell_size: 0.080000
                                  threshold: 3
                                  x_fov_deg: 106.500000
                                  y_fov_deg: 85.099998
                                  conf_cutoff: 125
                                  voa_input #4
                                  enabled: 1
                                  type: rangefinder
                                  input_pipe: rangefinders
                                  frame: body
                                  max_depth: 8.000000
                                  min_depth: 0.300000
                                  cell_size: 0.080000
                                  threshold: 4
                                  conf_cutoff: 0
                                  loading horizon cal file
                                  existing instance of voxl-vision-hub found, attempting to stop it
                                  starting geometry module
                                  starting autopilot monitor
                                  starting mavlink IO
                                  Waiting to connect to voxl-mavlink-server
                                  starting fixed pose input
                                  starting vio manager
                                  Connected to VIO pipe: ov
                                  Geometry module updating to use imu: imu_apps_body for VIO
                                  ERROR in vcc_fetch_extrinsic, failed to find desired extrinsic relation in file
                                  Likely you need to run voxl-configure-extrinsics to make a new file
                                  ERROR: /etc/modalai/extrinsics.conf missing body to imu_apps_body, sticking with identity for now
                                  Detected Autopilot Mavlink SYSID 1
                                  requesting autopilot_version
                                  Detected autopilot version: 1.14.0
                                  starting tag manager
                                  starting voa manager
                                  ERROR in pipe_client_open, channel 11 already running
                                  Connected to VOA input pipe: tof
                                  starting horizon cal module
                                  starting imu manager
                                  starting state manager
                                  starting offboard trajectory
                                  Connected to voxl-mapper
                                  voxl-mapper pipe size is: 65536 bytes
                                  Init complete
                                  Trajectory Monitor connected to voa pointcloud
                                  commanding: XYZ -1.0 -0.1 -2.3 yaw: 0.1
                                  WARNING in VOA manager, no attitude data from px4
                                  • Cliff WongC
                                    @greg_s said in Starling 2 not following navigation path:
                                    One thing that looks suspect is the voxl-mapper pipe size 64k bytes is much smaller than expect (usually in MB, e.g. 32MB-64MB). Is this a preloaded 3D map?
                                    Otherwise your VIO data looks good. It appears the drone does go to the 1st setpoint (1st leg of the trajectory) where that setpoint also looks as if it is landing. It's possible the landing detector was triggered and why everything stops.
                                    I suggest the following:
                                    • power up, ssh into 2 terminals
                                    • terminal 1 -- run the voxl-mapper
                                      terminal 2 -- run voxl-vision-hub --debug_offboard
                                    • take off in position mode, bring up the portal into mapper 3D view as normal, perform a 360 yaw to get a good map
                                    • Select "Plan a Point": draw your point and position it correctly
                                    • switch to offboard mode (which you have set correctly to 'trajectory')
                                    • Select GO!
                                    • Select "Follow Path"
                                      (If no follow path is offered then the A* path creation failed)
                                    Hopefully with that sequence, you'll see the drone move along the path. If it does not, then the voxl-mapper output in terminal 1 will tell us if a latency is the culprit.
                                    As an example, here's how I expect the above to play out.. If you cannot repeat this then it maybe worth upgrading to SDK 1.6.3 (as the example was generated in).
                                    • G
                                      greg_s @Cliff Wong
                                      Hello @Cliff-Wong,
                                      I tried reproducing your suggestion. The first time I tried, it seems to work fine. After landing and trying again (I stopped and restarted the voxl-mapper and voxl-vision-hub), I few around to update the map again as it reloaded. I planned a route that was straight ahead for the drone. Instead of following the path shown in the 3D mapper, it flew diagonally upward and hit the ceiling. I captured a video similar to yours to show the result. Also note, I ran the update to get the latest patch version of the voxl sdk. After running the update twice, it updated some packages but the patch number remained 2. So this was run with 1.6.2 sdk version, unless something else messed up with the update. I did capture a log of the update I ran if that would be helpful.
                                      Link to video
                                      • G
                                        greg_s @Cliff Wong
                                        Hello @Cliff-Wong,
                                        If there is any additional information or method I should try, just let me know.
                                        • Cliff WongC
                                          @greg_s HI there,
                                          The video exhibits classic VIO lost behavior from extrinsics: hovers fine, then on translation just flys away. Can you switch from trajectory mode back to figure_eight mode and confirm the drone can fly in figure 8s for more than 30secs?
                                          Figure 8 also tests the trajectory engine that mapper uses so it will confirm a number of things on the sensor side.
                                          • G
                                            greg_s @Cliff Wong
                                            Hello @Cliff-Wong,
                                            The figure 8 no longer works. It is now crashing into the netting in the room after starting the figure 8 mode. Though, it did in the past.
                                            Here is the screen recording as it was happening Link
                                            I also notice that it seems a sensor on the bottom has come loose due to the crashes sustained while trying to test the navigation. As well as the battery retention clips has broken off. Link
