    Help with drone familiarization
    FPV Drones
    • T
      taiwohazeez
      Hi support,
      I am a PhD student, and I am very new to robotics. We have 4 starling 2 drones in the lab, and right now, I have two of those drones being prepared for RMA. The drones keeps getting damaged because I don't have the right knowledge about drones. I looked up the technical documentations online, but there are still so many things I don't know. For instance, one of my drone crashed when i toggled the switch to hold mode (and it hasn't done that ever since I got it),it shot straight up very fast. I keep getting height estimate not stable (I don't even know what to do to fix that error). Also, the last working drone also drifts around when you toggle the controller to hold (the middle position). At this point, I cant even fly the drones because I might crash them again. And eventually I will get in trouble with these. Can you help with documentations that will make a beginner get all the necessary knowledge. Right now, I am just working on the drone blindly. I will be grateful if you can help with the situation.
      Taiwo
      • ModeratorM
        Moderator ModalAI Team @taiwohazeez
        @taiwohazeez You should start here: https://docs.modalai.com/voxl-developer-bootcamp/
        T 1 Reply Last reply Reply Quote 0
        • T
          taiwohazeez @Moderator
          @Moderator Thank you for your response. I have gone through the documentation several times. Even with that, I can't tell why I get those preflight check fails. Sometimes it clears, most times, I keep getting several warnings. I will go over the documentation again, maybe I am missing something.
          For instance, why do I have a cpu usage when the voxl-modem isnt running? or is that normal
          Regards,
          Taiwo
            tom admin @taiwohazeez
            @taiwohazeez What SDK version are you running? Can you post the output of voxl-version?
            It seems as though some missing CPU stats are causing the values to by shifted by one, the 98.2% is likely from voxl-open-vins-server
            • T
              taiwohazeez @tom
              @tom This is the output
              voxl2:/$ voxl-version
              kernel: #1 SMP PREEMPT Wed Oct 22 04:13:18 UTC 2025 4.19.125
              hw platform: M0054
              mach.var: 1.0.1
              SKU: MRB-D0014-4-V1-C27-T9-M0-X0
              voxl-suite: 1.6.2
              Packages:
              Repo: http://voxl-packages.modalai.com/ ./dists/qrb5165/sdk-1.6/binary-arm64/
              Last Updated: 2025-12-25 03:58:02
              List:
              libfc-sensor 1.0.8
              libmodal-cv 0.6.0
              libmodal-exposure 0.1.4
              libmodal-flow 1.0.3
              libmodal-journal 0.2.7
              libmodal-json 0.4.8
              libmodal-pipe 2.14.8
              libqrb5165-io 0.5.0
              libvoxl-cci-direct 0.3.3
              libvoxl-codec 0.0.1
              libvoxl-cutils 0.1.6
              modalai-slpi 1.2.2
              mv-voxl 0.1-r0
              qrb5165-bind 0.1-r0
              qrb5165-dfs-server 0.2.0
              qrb5165-imu-server 1.2.3
              qrb5165-mini-tof-server 0.2.2
              qrb5165-rangefinder-server 0.1.6
              qrb5165-slpi-test-sig 01-r0
              qrb5165-system-tweaks 0.3.11
              qrb5165-tflite 2.17.2
              voxl-bind-spektrum 0.1.1
              voxl-camera-calibration 0.6.1
              voxl-camera-server 2.2.17
              voxl-ceres-solver 2:2.0.0-2
              voxl-configurator 1.0.10
              voxl-cpu-monitor 0.7.4
              voxl-docker-support 1.3.1
              voxl-elrs 0.4.14
              voxl-esc 1.5.7
              voxl-feature-tracker 0.5.2
              voxl-flow-server 0.3.6
              voxl-gphoto2-server 0.0.10
              voxl-io-server 0.0.6
              voxl-jpeg-turbo 2.1.3-7
              voxl-lepton-server 1.3.3
              voxl-lepton-tracker 0.0.4
              voxl-libgeographic 1.0.0
              voxl-libgphoto2 0.0.4
              voxl-libuvc 1.0.7
              voxl-logger 0.6.0
              voxl-mavcam-manager 0.6.0
              voxl-mavlink 0.1.6
              voxl-mavlink-server 1.4.12
              voxl-microdds-agent 3.0.0-0
              voxl-modem 1.2.2
              voxl-mongoose 7.19.0
              voxl-mpa-to-ros 0.3.9
              voxl-mpa-to-ros2 0.0.7
              voxl-mpa-tools 1.5.5
              voxl-open-vins-server 0.5.7
              voxl-opencv 4.5.5-3
              voxl-osd 0.2.1
              voxl-portal 0.8.4
              voxl-px4 1.14.0-2.0.124
              voxl-px4-params 0.8.11
              voxl-qvio-server 1.2.2
              voxl-remote-id 0.0.9
              voxl-reset-slpi 0.0.1
              voxl-ros2-foxy 0.0.1
              voxl-state-estimator 0.0.5
              voxl-streamer 0.8.0
              voxl-suite 1.6.2
              voxl-tag-detector 0.0.5
              voxl-tflite-server 0.5.0
              voxl-utils 1.4.9
              voxl-uvc-server 0.1.7
              voxl-vision-hub 1.9.19
              voxl-vtx 1.7.6
              voxl-wavemux 0.0.3
              voxl2-io 0.0.3
              voxl2-security-hardening-utls 1.0-r0
              voxl2-system-image 1.8.06-r0
              voxl2-wlan 1.0-r0
              voxl2:/$
